harold_l 0 Posted ... Hi Community, I've been working on a case for many hours, and I can't figure out what's wrong.I've issue to connect AirVPN with some protocols. The Eddie Client try to connect over and over on different server without establish the connection. - UDP and TCP on all port and all IP are OK (I tested one by one )- SSL all ports all IP NOK- SSH all port all IP NOK My Environnement :- Windows 10 1803- Firewall disabled- Antivirus disabled- Eddie 2.15.2 the last- Orange France ISP- Ethernet card wired 1 Gbps LAN- Ryzen 2600X CPU Eddie config :- TCP/UDP buffer size 512 KB- Layer IPv6 to BLOCK- IP Prot used for connection to IPv4 ONLY- Interface used for connection to Ethernet- Other config are the default ones Here some logs of an SSL 443 IP 2 connection : I 2018.07.19 16:59:05 - Session starting.I 2018.07.19 16:59:05 - Checking authorization .... 2018.07.19 16:59:06 - IPv6 disabled with packet filtering.! 2018.07.19 16:59:06 - Connecting to Gienah (Netherlands, Alblasserdam). 2018.07.19 16:59:06 - Routes, added a new route, 213.152.162.95 for gateway 192.168.1.1. 2018.07.19 16:59:06 - SSL > 2018.07.19 16:59:06 LOG5[ui]: stunnel 5.40 on x86-pc-mingw32-gnu platform. 2018.07.19 16:59:06 - SSL > 2018.07.19 16:59:06 LOG5[ui]: Compiled/running with OpenSSL 1.0.2k 26 Jan 2017. 2018.07.19 16:59:06 - SSL > 2018.07.19 16:59:06 LOG5[ui]: Threading:WIN32 Sockets:SELECT,IPv6 TLS:ENGINE,OCSP,PSK,SNI. 2018.07.19 16:59:06 - SSL > 2018.07.19 16:59:06 LOG5[ui]: Reading configuration from file C:\*\AppData\Local\AirVPN\9f9d6b2a288678dd7cd7d6c9435f5a6f698999a7eb024b0d200d43ff160300b6.tmp.ssl. 2018.07.19 16:59:06 - SSL > 2018.07.19 16:59:06 LOG5[ui]: UTF-8 byte order mark not detected. 2018.07.19 16:59:06 - SSL > 2018.07.19 16:59:06 LOG6[ui]: Initializing service [openvpn]. 2018.07.19 16:59:06 - SSL > 2018.07.19 16:59:06 LOG4[ui]: Service [openvpn] needs authentication to prevent MITM attacks. 2018.07.19 16:59:06 - SSL > 2018.07.19 16:59:06 LOG5[ui]: Configuration successful. 2018.07.19 16:59:06 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018. 2018.07.19 16:59:06 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2018.07.19 16:59:06 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10. 2018.07.19 16:59:06 - Connection to OpenVPN Management Interface. 2018.07.19 16:59:06 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2018.07.19 16:59:06 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.07.19 16:59:06 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.07.19 16:59:06 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:53481. 2018.07.19 16:59:06 - OpenVPN > Socket Buffers: R=[65536->524288] S=[65536->524288]. 2018.07.19 16:59:06 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:53481 [nonblock]. 2018.07.19 16:59:07 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2018.07.19 17:00:06 - SSL > 2018.07.19 17:00:06 LOG6[cron]: Executing cron jobs. 2018.07.19 17:00:06 - SSL > 2018.07.19 17:00:06 LOG6[cron]: Cron jobs completed in 0 seconds. 2018.07.19 17:01:06 - OpenVPN > TCP: connect to [AF_INET]127.0.0.1:53481 failed: Unknown error. 2018.07.19 17:01:06 - OpenVPN > SIGUSR1[connection failed(soft),init_instance] received, process restarting. 2018.07.19 17:01:06 - OpenVPN > Restart pause, 5 second(s)! 2018.07.19 17:01:06 - Disconnecting. 2018.07.19 17:01:07 - Routes, removed a route previously added, 213.152.162.95 for gateway 192.168.1.1. 2018.07.19 17:01:07 - Sending management termination signal. 2018.07.19 17:01:07 - Management - Send 'signal SIGTERM'. 2018.07.19 17:01:07 - OpenVPN > MANAGEMENT: CMD 'c5d8b01266873afe568bf401b8d2f49d3291b4a5630f694846e20d44c8521f0c'. 2018.07.19 17:01:11 - OpenVPN > MANAGEMENT: Client disconnected. 2018.07.19 17:01:11 - OpenVPN > All connections have been connect-retry-max (1) times unsuccessful, exiting. 2018.07.19 17:01:11 - OpenVPN > Exiting due to fatal error. 2018.07.19 17:01:16 - Sending soft termination signal. 2018.07.19 17:01:16 - Connection terminated.. 2018.07.19 17:01:16 - IPv6 restored with packet filtering. Here some logs of an SSH port 22 IP 1 : I 2018.07.19 17:27:48 - Session starting.I 2018.07.19 17:27:48 - Checking authorization .... 2018.07.19 17:27:48 - IPv6 disabled with packet filtering.! 2018.07.19 17:27:48 - Connecting to Ancha (Netherlands, Alblasserdam). 2018.07.19 17:27:48 - Routes, added a new route, 213.152.162.164 for gateway 192.168.1.1. 2018.07.19 17:27:48 - SSH > Looking up host "213.152.162.164". 2018.07.19 17:27:48 - SSH > Connecting to 213.152.162.164 port 22. 2018.07.19 17:27:48 - SSH > We claim version: SSH-2.0-PuTTY_Release_0.67. 2018.07.19 17:27:48 - SSH > Server version: SSH-2.0-OpenSSH_7.4p1 Debian-10+deb9u1. 2018.07.19 17:27:48 - SSH > Using SSH protocol version 2. 2018.07.19 17:27:49 - SSH > Doing Diffie-Hellman group exchange. 2018.07.19 17:27:49 - SSH > Doing Diffie-Hellman key exchange with hash SHA-256. 2018.07.19 17:27:49 - SSH > Host key fingerprint is:. 2018.07.19 17:27:49 - SSH > ssh-rsa 2048 4d:79:1e:2c:fe:a2:ce:2d:9b:ff:5d:fb:eb:f0:6e:a9. 2018.07.19 17:27:49 - SSH > Initialised AES-256 SDCTR client->server encryption. 2018.07.19 17:27:49 - SSH > Initialised HMAC-SHA-256 client->server MAC algorithm. 2018.07.19 17:27:49 - SSH > Initialised AES-256 SDCTR server->client encryption. 2018.07.19 17:27:49 - SSH > Initialised HMAC-SHA-256 server->client MAC algorithm. 2018.07.19 17:27:49 - SSH > Reading private key file "C:\Users\*\Local\AirVPN\5636ac2f3f6fd940306bfa8eba4fb6b866cb06fa01a8590bacd500dfdb0c54cb.tmp.ppk". 2018.07.19 17:27:49 - SSH > Using username "sshtunnel".. 2018.07.19 17:27:49 - SSH > Offered public key. 2018.07.19 17:27:49 - SSH > Offer of public key accepted. 2018.07.19 17:27:49 - SSH > Authenticating with public key "". 2018.07.19 17:27:49 - SSH > Sent public key signature. 2018.07.19 17:27:49 - SSH > Access granted. 2018.07.19 17:27:49 - SSH > Local port 24747 forwarding to 127.0.0.1:2018. 2018.07.19 17:27:49 - SSH > Remote debug message: PTY allocation disabled.. 2018.07.19 17:27:49 - SSH > Remote debug message: X11 forwarding disabled.. 2018.07.19 17:27:49 - SSH > Remote debug message: Forced command.. 2018.07.19 17:27:49 - SSH > Remote debug message: PTY allocation disabled.. 2018.07.19 17:27:49 - SSH > Remote debug message: X11 forwarding disabled.. 2018.07.19 17:27:49 - SSH > Remote debug message: Forced command.. 2018.07.19 17:27:49 - OpenVPN > OpenVPN 2.4.6 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Apr 27 2018. 2018.07.19 17:27:49 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit. 2018.07.19 17:27:49 - OpenVPN > library versions: OpenSSL 1.1.0h 27 Mar 2018, LZO 2.10. 2018.07.19 17:27:49 - Connection to OpenVPN Management Interface. 2018.07.19 17:27:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2018.07.19 17:27:49 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.07.19 17:27:49 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2018.07.19 17:27:49 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]127.0.0.1:24747. 2018.07.19 17:27:49 - OpenVPN > Socket Buffers: R=[65536->524288] S=[65536->524288]. 2018.07.19 17:27:49 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:24747 [nonblock]. 2018.07.19 17:27:49 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2018.07.19 17:28:37 - Updating systems & servers data .... 2018.07.19 17:28:38 - Systems & servers data update completed. 2018.07.19 17:29:49 - OpenVPN > TCP: connect to [AF_INET]127.0.0.1:24747 failed: Unknown error. 2018.07.19 17:29:49 - OpenVPN > SIGUSR1[connection failed(soft),init_instance] received, process restarting. 2018.07.19 17:29:49 - OpenVPN > Restart pause, 5 second(s)! 2018.07.19 17:29:49 - Disconnecting. 2018.07.19 17:29:49 - Routes, removed a route previously added, 213.152.162.164 for gateway 192.168.1.1. 2018.07.19 17:29:49 - Sending management termination signal. 2018.07.19 17:29:49 - Management - Send 'signal SIGTERM'. 2018.07.19 17:29:49 - OpenVPN > MANAGEMENT: CMD '39cea6bd844dbb8b26bbf6fb5a9463d9775f43fcab5928b650850b0ec633839a'. 2018.07.19 17:29:54 - OpenVPN > MANAGEMENT: Client disconnected. 2018.07.19 17:29:54 - OpenVPN > All connections have been connect-retry-max (1) times unsuccessful, exiting. 2018.07.19 17:29:54 - OpenVPN > Exiting due to fatal error. 2018.07.19 17:29:59 - Sending soft termination signal. 2018.07.19 17:29:59 - Connection terminated.. 2018.07.19 17:29:59 - IPv6 restored with packet filtering. Same Error on both case :OpenVPN > TCP: connect to [AF_INET]127.0.0.1:24747 failed: Unknown error Any ideas ? Quote Share this post Link to post
nick75 25 Posted ... Hello, It seems like there's a problem on the loopback: either there are some firewall rules blocking the loopback (very unlikely) or the port is already busy.Can you type this in a prompt as administrator: netstat -a -b > C:\net_result.txt This will create a file named net_result.txt in your C drive, can you post its content?You may want to redact its content to remove your login name. Also check that you don't have any anti-malware installed (Malwarebytes, Bytefence etc...) Quote Share this post Link to post
Nasdaq 10 Posted ... Hi guys! I have the same problem. I solved it this way : - TCP/UDP buffer size (send-receive) : Automatic- Layer IPv4 : inside tunnel if supported, otherwise blocked- Layer IPv6 : inside tunnel if supported, otherwise blocked- IP Prot used for connection to : IPv4, IPv6- Interface used for connection to : Automatic - DNS switch mode : Automatic- Check AirVPN DNS- Ensure DNS Lock Network Lock :- Windows Firewall (not recommended)- Incoming : block- Outcoming : block- Allow lan/private- Allow ping And I setup rules of Windows Firewall to : On (private and public) Eddie - In - Allow localEddie - In - Allow VPNEddie - In - ICMP IPv4Eddie - In - ICMP IPv6 Eddie - Out - : are the default ones I tested it using "netstat -a" & "netsat -b" and nothing pass outside SSL tunnel Using Windows Filtering Platform or Automatic doesn't work. If someone has a better idea, I'm ready to test it. Best regards 1 knighthawk reacted to this Quote Share this post Link to post
