Not connected, Your IP: 18.223.196.59
strykenKN
ANSWERED Eddie and Manjaro - Request for help to install Eddie under Manjaro
 good Morning
I have the following question for you. I use Manjaro Linux in the latest version. And would like to use AirVPN, I've also downloaded the file down. However, I honestly do not know how to install AirVPN, because there is no manual. And of course also so that it starts with the computer restart.
Would someone help me please?
I would be very happy - thank you!
I don't have Manjaro so can't really help if it has some specific stuff, but if you downloaded portable version, can't you just extract it and launch eddie from file in extracted folder. Can't really help with auto start.
Hey. I'd hope you found a solution already; but if not I enabled the AUR support in the add/remove software's preferences, then searched airvpn and installed automatically.
