Not connected, Your IP: 13.59.61.119
gl7
v2.14.5 routes - outside tunnel not working?
Hi, upgraded from 2.13.6, the routes outside tunnel i previously set are no longer works, the ip still will use the vpn instead outside vpn, can you verify if it working or another other setting needed? thank you.
