Not connected, Your IP: 216.73.216.33
randomdudex
Stuck in connection loop with school wifi
Log:
I 2018.05.29 11:35:11 - Eddie version: 2.13.6 / windows_x64, System: Windows, Name: Windows 10 Home, Version: Microsoft Windows NT 10.0.15063.0, Mono/.Net Framework: v4.0.30319
. 2018.05.29 11:35:11 - Reading options from C:\Program Files\AirVPN\AirVPN.xml
. 2018.05.29 11:35:11 - Profile options not found, using defaults.
. 2018.05.29 11:35:11 - Command line arguments (0):
I 2018.05.29 11:35:15 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2
I 2018.05.29 11:35:15 - OpenVPN - Version: 2.4.3 - OpenSSL 1.0.2l  25 May 2017, LZO 2.10 (C:\Program Files\AirVPN\openvpn.exe)
I 2018.05.29 11:35:15 - SSH - Version: plink 0.67 (C:\Program Files\AirVPN\plink.exe)
I 2018.05.29 11:35:15 - SSL - Version: stunnel 5.40 (C:\Program Files\AirVPN\stunnel.exe)
I 2018.05.29 11:35:15 - curl - Version: 7.54.1 (C:\Program Files\AirVPN\curl.exe)
I 2018.05.29 11:35:15 - Certification Authorities: C:\Program Files\AirVPN\cacert.pem
. 2018.05.29 11:35:16 - Updating systems & servers data ...
! 2018.05.29 11:35:16 - Ready
. 2018.05.29 11:35:20 - Systems & servers data update completed
I 2018.05.29 11:35:34 - Checking login ...
! 2018.05.29 11:35:36 - Logged in.
I 2018.05.29 11:35:40 - Session starting.
. 2018.05.29 11:35:40 - IPv6 disabled with packet filtering.
I 2018.05.29 11:35:49 - Checking authorization ...
! 2018.05.29 11:35:50 - Connecting to Agena (Canada, Toronto, Ontario)
. 2018.05.29 11:35:50 - OpenVPN > OpenVPN 2.4.3 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jun 23 2017
. 2018.05.29 11:35:50 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.05.29 11:35:50 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2018.05.29 11:35:50 - Connection to OpenVPN Management Interface
. 2018.05.29 11:35:50 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.05.29 11:35:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.05.29 11:35:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.05.29 11:35:50 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.223.210:443
. 2018.05.29 11:35:50 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.05.29 11:35:50 - OpenVPN > UDP link local: (not bound)
. 2018.05.29 11:35:50 - OpenVPN > UDP link remote: [AF_INET]184.75.223.210:443
. 2018.05.29 11:35:50 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.05.29 11:36:22 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2018.05.29 11:36:22 - OpenVPN > SIGTERM received, sending exit notification to peer
! 2018.05.29 11:36:28 - Disconnecting
. 2018.05.29 11:36:28 - Connection terminated.
I 2018.05.29 11:36:31 - Checking authorization ...
! 2018.05.29 11:36:32 - Connecting to Tegmen (Canada, Toronto, Ontario)
. 2018.05.29 11:36:32 - OpenVPN > OpenVPN 2.4.3 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jun 23 2017
. 2018.05.29 11:36:32 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit
. 2018.05.29 11:36:32 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2018.05.29 11:36:32 - Connection to OpenVPN Management Interface
. 2018.05.29 11:36:32 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.05.29 11:36:32 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.05.29 11:36:32 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.05.29 11:36:32 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]137.63.71.50:443
. 2018.05.29 11:36:32 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2018.05.29 11:36:32 - OpenVPN > UDP link local: (not bound)
. 2018.05.29 11:36:32 - OpenVPN > UDP link remote: [AF_INET]137.63.71.50:443
. 2018.05.29 11:36:32 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
