Not connected, Your IP: 18.117.111.1
mith_y2k
Frequent disconnects on fire tv
I've been using android ICS openvpn client on a fire tv for a while now. It initially worked well, but I started getting disconnected frequently in the last couple of months. I have since upgraded to the latest build of openvpn (from http://plai.de/android), but saw no improvement. I have two configurations on the device, one to a specific server where I usually get good performance and one for an entire region.
Disconnects only happen with the fire tv, other devices on the same network work fine.
Any thoughts? My first guess is client (hence the upgrade ) or the OS. If it’s the OS many others should be having the same issue.
