Not connected, Your IP: 3.140.185.147
enigma
Disconnect issues
HI,
i´ve a problem.Random my connection go aut with a message "Authorization failed. Maybe you are connected from another machine?"
The log :
09.06.2012 - 13:11 OpenVPN current version: OpenVPN 2.2.2
09.06.2012 - 13:11 Login...
09.06.2012 - 13:11 Login success.
09.06.2012 - 13:14 Contacting service...
09.06.2012 - 13:14 Connecting...
09.06.2012 - 13:14 OpenVPN 2.2.2 Win32-MSVC++ [sSL] [LZO2] [PKCS11] built on Dec 15 2011
09.06.2012 - 13:14 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
09.06.2012 - 13:14 LZO compression initialized
09.06.2012 - 13:14 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
09.06.2012 - 13:14 Socket Buffers: R=[8192->8192] S=[8192->8192]
09.06.2012 - 13:14 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
09.06.2012 - 13:14 Local Options hash (VER=V4): '22188c5b'
09.06.2012 - 13:14 Expected Remote Options hash (VER=V4): 'a8f55717'
09.06.2012 - 13:14 UDPv4 link local: [undef]
09.06.2012 - 13:14 UDPv4 link remote: 146.185.25.170:443
09.06.2012 - 13:14 TLS: Initial packet from 146.185.25.170:443, sid=7e3e0a0a 84484c46
09.06.2012 - 13:14 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
09.06.2012 - 13:14 VERIFY OK: nsCertType=SERVER
09.06.2012 - 13:14 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
09.06.2012 - 13:14 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
09.06.2012 - 13:14 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
09.06.2012 - 13:14 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
09.06.2012 - 13:14 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
09.06.2012 - 13:14 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
09.06.2012 - 13:14 [server] Peer Connection Initiated with 146.185.25.170:443
09.06.2012 - 13:14 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
09.06.2012 - 13:14 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 120,ifconfig 10.4.6.6 10.4.6.5'
09.06.2012 - 13:14 OPTIONS IMPORT: timers and/or timeouts modified
09.06.2012 - 13:14 OPTIONS IMPORT: LZO parms modified
09.06.2012 - 13:14 OPTIONS IMPORT: --ifconfig/up options modified
09.06.2012 - 13:14 OPTIONS IMPORT: route options modified
09.06.2012 - 13:14 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
09.06.2012 - 13:14 ROUTE default_gateway=192.168.1.1
09.06.2012 - 13:14 TAP-WIN32 device [Connessione alla rete locale (LAN)] opened: \\.\Global\{4360408B-BEBC-43A7-97E3-29F3836A8E35}.tap
09.06.2012 - 13:14 TAP-Win32 Driver Version 9.9
09.06.2012 - 13:14 TAP-Win32 MTU=1500
09.06.2012 - 13:14 Notified TAP-Win32 driver to set a DHCP IP/netmask of 10.4.6.6/255.255.255.252 on interface {4360408B-BEBC-43A7-97E3-29F3836A8E35} [DHCP-serv: 10.4.6.5, lease-time: 31536000]
09.06.2012 - 13:14 Successful ARP Flush on interface [28] {4360408B-BEBC-43A7-97E3-29F3836A8E35}
09.06.2012 - 13:14 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
09.06.2012 - 13:14 C:\WINDOWS\system32\route.exe ADD 146.185.25.170 MASK 255.255.255.255 192.168.1.1
09.06.2012 - 13:14 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
09.06.2012 - 13:14 Route addition via IPAPI succeeded [adaptive]
09.06.2012 - 13:14 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.6.5
09.06.2012 - 13:14 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
09.06.2012 - 13:14 C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.6.5
09.06.2012 - 13:14 C:\WINDOWS\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.6.5
09.06.2012 - 13:14 Initialization Sequence Completed
09.06.2012 - 13:14 Starting Management Interface...
09.06.2012 - 13:14 Checking...
09.06.2012 - 13:15 Retrieve statistics...
09.06.2012 - 13:15 Connected.
09.06.2012 - 13:15 Replay-window backtrack occurred [1]
09.06.2012 - 13:29 Replay-window backtrack occurred [2]
09.06.2012 - 13:50 Replay-window backtrack occurred [4]
09.06.2012 - 14:14 TLS: soft reset sec=0 bytes=524565527/0 pkts=634690/0
09.06.2012 - 14:14 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
09.06.2012 - 14:14 VERIFY OK: nsCertType=SERVER
09.06.2012 - 14:14 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
09.06.2012 - 14:14 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
09.06.2012 - 14:14 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
09.06.2012 - 14:14 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
09.06.2012 - 14:14 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
09.06.2012 - 14:14 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
09.06.2012 - 15:14 TLS: tls_process: killed expiring key
09.06.2012 - 15:14 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
09.06.2012 - 15:14 VERIFY OK: nsCertType=SERVER
09.06.2012 - 15:14 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
09.06.2012 - 15:14 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
09.06.2012 - 15:14 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
09.06.2012 - 15:14 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
09.06.2012 - 15:14 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
09.06.2012 - 15:14 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
09.06.2012 - 16:14 TLS: tls_process: killed expiring key
09.06.2012 - 16:14 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
09.06.2012 - 16:14 VERIFY OK: nsCertType=SERVER
09.06.2012 - 16:14 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
09.06.2012 - 16:14 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
09.06.2012 - 16:14 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
09.06.2012 - 16:14 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
09.06.2012 - 16:14 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
09.06.2012 - 16:14 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
09.06.2012 - 17:14 TLS: tls_process: killed expiring key
09.06.2012 - 17:14 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
09.06.2012 - 17:14 VERIFY OK: nsCertType=SERVER
09.06.2012 - 17:14 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
09.06.2012 - 17:14 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
09.06.2012 - 17:14 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
09.06.2012 - 17:14 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
09.06.2012 - 17:14 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
09.06.2012 - 17:14 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
09.06.2012 - 17:31 [server] Inactivity timeout (--ping-restart), restarting
09.06.2012 - 17:31 TCP/UDP: Closing socket
09.06.2012 - 17:31 Re-connecting...
09.06.2012 - 17:31 C:\WINDOWS\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.6.5
09.06.2012 - 17:31 Route deletion via IPAPI succeeded [adaptive]
09.06.2012 - 17:31 C:\WINDOWS\system32\route.exe DELETE 146.185.25.170 MASK 255.255.255.255 192.168.1.1
09.06.2012 - 17:31 C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.6.5
09.06.2012 - 17:31 C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.6.5
09.06.2012 - 17:31 Closing TUN/TAP interface
09.06.2012 - 17:31 SIGUSR1[soft,ping-restart] received, process restarting
09.06.2012 - 17:31 Restart pause, 2 second(s)
09.06.2012 - 17:31 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
09.06.2012 - 17:31 LZO compression initialized
09.06.2012 - 17:31 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
09.06.2012 - 17:31 Socket Buffers: R=[8192->8192] S=[8192->8192]
09.06.2012 - 17:31 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
09.06.2012 - 17:31 Local Options hash (VER=V4): '22188c5b'
09.06.2012 - 17:31 Expected Remote Options hash (VER=V4): 'a8f55717'
09.06.2012 - 17:31 UDPv4 link local: [undef]
09.06.2012 - 17:31 UDPv4 link remote: 146.185.25.170:443
09.06.2012 - 17:31 TLS: Initial packet from 146.185.25.170:443, sid=6dded94e 57dbc7d8
09.06.2012 - 17:31 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
09.06.2012 - 17:31 VERIFY OK: nsCertType=SERVER
09.06.2012 - 17:31 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
09.06.2012 - 17:31 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
09.06.2012 - 17:31 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
09.06.2012 - 17:31 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
09.06.2012 - 17:31 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
09.06.2012 - 17:31 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
09.06.2012 - 17:31 [server] Peer Connection Initiated with 146.185.25.170:443
09.06.2012 - 17:31 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
09.06.2012 - 17:31 AUTH: Received AUTH_FAILED control message
09.06.2012 - 17:31 Authorization failed. Maybe you are connected from another machine?
09.06.2012 - 20:01 Failed to start.
09.06.2012 - 20:01 Disconnecting...
09.06.2012 - 20:01 SIGTERM received, sending exit notification to peer
09.06.2012 - 20:01 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
09.06.2012 - 20:01 TCP/UDP: Closing socket
09.06.2012 - 20:01 SIGTERM[soft,exit-with-notification] received, process exiting
The obvious first question is, *ARE* you connecting from another machine? smartphone, maybe? Have you tried changing your password (is it easily hackable?)
Hi All,
I am facing exactly the same problem now. I've restarted my PC and 100% sure that I do not login to VPN anywhere else.
Any idea?
