Not connected, Your IP: 3.144.202.167
joseluis
Pi-hole + Air VPN on a Raspberry Pi 3
Hi guys,
Sorry I'm a bit of a noob. Is there any tutorial or has anyone set up Pi-hole (https://pi-hole.net/)+ Air on a RP3 so as to not have DNS be leaked via Pi-hole? Also the ability to VPN from my phone whilst on cellular data to my Pi would be great. How exactly would would the whole process look, presumably I wont use Eddie because the Pi will be handling the Air VPN requests? So how exactly do I connect using my computer and phone?
Thank you!
