Not connected, Your IP: 18.221.187.121
Hi there !!
I just tried a DNS leak test from many website et all of them give me a dns leak....I can see my country and internet provider....
I'm using airvpn on debian 9..
You have to disable ipv6 completely.  You'll need to install gedit, and open/create  /ect/sysctl.conf
Then add these lines:
net.ipv6.conf.all.disable_ipv6 = 1net.ipv6.conf.default.disable_ipv6 = 1net.ipv6.conf.lo.disable_ipv6 = 1
Then activate sysctl by running:
sudo sysctl -p
Hint,  you have to use sudo for gedit as well...
Didn't notice if you were using windows,  if you are,  go into your network and internet/network connections,  and in your adapter properties,  uncheck ipv6.  Leak gone!
Thanks for reply guys,
I put those lines in sysctl.conf
I ran sysctl -p
But dns leak again....
Have I to disable ipv6 somewhere else ?
So guys,
I follow the step of johnspack, folow this guide too, to add the airvpn dns server to my host file but I still have a DNS leak.....
Any help ?
you should check file
/etc/network/interfaces
and remove from here any DNS servers belonged to your ISP.
also check file
/etc/resolv.conf
and place here your trusted DNS (for example google dns 8.8.8.8)
I recommend to make this file readonly to prevent it from change
chattr +i /etc/resolv.conf
Hope this help. Also try to check dns leak with different tools https://bash.ws/dnsleak or https://leaktest.online/
Good luck.
i have an issue too. I routed all the traffic through my VPN. In the merlinwrt settings on my rt-ac86u in lan settings i only use the dns 10.4.0.1 but when i check on ipleak.net i see the airdns and a second dns...?
how is this possible my system leaks dns? the second dns is: 45.76.91.215 - this isnt my ISP dns but i feel something i s leaking. firefox is already configured in the about:config setting. i set the media.peerconnection.enabled to false.
Edit: I was wrong... I deleted the dns server in the lan tab and added an opennic dns in the wan tab as secondary dns. now evrything looks fine i think. i see on ipleak.net now the airdns and the second one from opennic: 94.247.43.254
am i fine with this setting or do i have to fear because this shows a dns leak?
