Not connected, Your IP: 18.117.183.150
overmorrow
ANSWERED Eddie stuck in infinite reconnect loop
It seems to connect, but then it just gives up the ghost after sending "PUSH REQUEST", and retries with a different server... forever.
I 2018.01.06 16:42:28 - Eddie version: 2.13.6 / linux_x64, System: Linux, Name: Devuan GNU/Linux ascii/ceres \n \l, Version: Linux xxxxx 4.9.0-4-amd64 #1 SMP Debian 4.9.51-1 (2017-09-28) x86_64 GNU/Linux, Mono/.Net Framework: v4.0.30319
. 2018.01.06 16:42:28 - Reading options from /home/redacted/.airvpn/AirVPN.xml
. 2018.01.06 16:42:29 - Command line arguments (2): path="/home/redacted/.airvpn" console.mode="none"
I 2018.01.06 16:42:30 - OpenVPN Driver - Found, /dev/net/tun
I 2018.01.06 16:42:30 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2l  25 May 2017, LZO 2.08 (/usr/sbin/openvpn)
I 2018.01.06 16:42:30 - SSH - Version: OpenSSH_7.4p1 Debian-10+deb9u2, OpenSSL 1.0.2l  25 May 2017 (/usr/bin/ssh)
I 2018.01.06 16:42:30 - SSL - Version: stunnel 5.39 (/usr/bin/stunnel4)
I 2018.01.06 16:42:30 - curl - Version: 7.52.1 (/usr/bin/curl)
I 2018.01.06 16:42:30 - Certification Authorities: /usr/share/AirVPN/cacert.pem
! 2018.01.06 16:42:30 - Activation of Network Lock - Linux iptables
. 2018.01.06 16:42:30 - Updating systems & servers data ...
! 2018.01.06 16:42:32 - Ready
. 2018.01.06 16:42:32 - Systems & servers data update completed
I 2018.01.06 16:43:11 - Session starting.
I 2018.01.06 16:43:11 - Checking authorization ...
! 2018.01.06 16:43:12 - Connecting to Hatysa (Sweden, Uppsala)
. 2018.01.06 16:43:12 - OpenVPN > OpenVPN 2.4.0 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Jul 18 2017
. 2018.01.06 16:43:12 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.08
. 2018.01.06 16:43:12 - Connection to OpenVPN Management Interface
. 2018.01.06 16:43:12 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.01.06 16:43:12 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.06 16:43:12 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.06 16:43:12 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]62.102.148.144:443
. 2018.01.06 16:43:12 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2018.01.06 16:43:12 - OpenVPN > UDP link local: (not bound)
. 2018.01.06 16:43:12 - OpenVPN > UDP link remote: [AF_INET]62.102.148.144:443
. 2018.01.06 16:43:12 - OpenVPN > TLS: Initial packet from [AF_INET]62.102.148.144:443, sid=8c8ab379 ed36b17a
. 2018.01.06 16:43:12 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.01.06 16:43:43 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.01.06 16:43:43 - OpenVPN > Validating certificate key usage
. 2018.01.06 16:43:43 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2018.01.06 16:43:43 - OpenVPN > VERIFY KU OK
. 2018.01.06 16:43:43 - OpenVPN > Validating certificate extended key usage
. 2018.01.06 16:43:43 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.01.06 16:43:43 - OpenVPN > VERIFY EKU OK
. 2018.01.06 16:43:43 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Hatysa, emailAddress=info@airvpn.org
. 2018.01.06 16:43:43 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.01.06 16:43:43 - OpenVPN > [Hatysa] Peer Connection Initiated with [AF_INET]62.102.148.144:443
. 2018.01.06 16:43:44 - OpenVPN > SENT CONTROL [Hatysa]: 'PUSH_REQUEST' (status=1)
! 2018.01.06 16:43:47 - Disconnecting
. 2018.01.06 16:43:47 - Connection terminated.
I 2018.01.06 16:43:50 - Checking authorization ...
! 2018.01.06 16:43:50 - Connecting to Alderamin (Austria, Vienna)
. 2018.01.06 16:43:50 - OpenVPN > OpenVPN 2.4.0 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on Jul 18 2017
. 2018.01.06 16:43:50 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.08
. 2018.01.06 16:43:50 - Connection to OpenVPN Management Interface
. 2018.01.06 16:43:50 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2018.01.06 16:43:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.06 16:43:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2018.01.06 16:43:50 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.9.19.106:443
. 2018.01.06 16:43:50 - OpenVPN > Socket Buffers: R=[212992->212992] S=[212992->212992]
. 2018.01.06 16:43:50 - OpenVPN > UDP link local: (not bound)
. 2018.01.06 16:43:50 - OpenVPN > UDP link remote: [AF_INET]185.9.19.106:443
. 2018.01.06 16:43:50 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2018.01.06 16:43:50 - OpenVPN > TLS: Initial packet from [AF_INET]185.9.19.106:443, sid=32fd6ae0 0d662232
. 2018.01.06 16:43:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2018.01.06 16:43:50 - OpenVPN > Validating certificate key usage
. 2018.01.06 16:43:50 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2018.01.06 16:43:50 - OpenVPN > VERIFY KU OK
. 2018.01.06 16:43:50 - OpenVPN > Validating certificate extended key usage
. 2018.01.06 16:43:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2018.01.06 16:43:50 - OpenVPN > VERIFY EKU OK
. 2018.01.06 16:43:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Alderamin, emailAddress=info@airvpn.org
. 2018.01.06 16:43:51 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2018.01.06 16:43:51 - OpenVPN > [Alderamin] Peer Connection Initiated with [AF_INET]185.9.19.106:443
. 2018.01.06 16:43:52 - OpenVPN > SENT CONTROL [Alderamin]: 'PUSH_REQUEST' (status=1)
! 2018.01.06 16:43:52 - Disconnecting
. 2018.01.06 16:43:52 - Connection terminated.
I 2018.01.06 16:43:54 - Cancel requested.
! 2018.01.06 16:43:54 - Session terminated.
I 2018.01.06 16:44:07 - Session starting.
I 2018.01.06 16:44:07 - Checking authorization ...
Im no expert.
When this happens to me its because my internet connection has dropped. I usually have to restart my router for it to connect successfully. Most times it will.
But, sometimes it, will only connect again after shutting down and restarting my PC completely.
Sorry, no technical explanation, but something along the lines of, my machine forgets its last DCHP and cannot reconnect, therefore the loop.
I have found this issue on both Linux and Microsoft machines. I blame my ISP for the dropouts
