wanderingme
Problems with Eddie "checking route"
I had issues this morning using Sierra, so just updated to High Sierra. Rebooted twice. Rebooted my router and modem. Problem persists. I'm using Eddie 2.13.6. I feel every week or two weeks I run into this issue for a while, then usually rebooting my computer works to fix the issue. But not always.
Anyhow, I've seen this issue pop up a lot on the forums, but never have I seen a workable solution. Thoughts? Thanks.
Here are my logs:
I 2017.11.09 15:34:43 - Eddie version: 2.13.6 / macos_x64, System: MacOS, Name: 10.13.1, Version: Darwin XXXX.local 17.2.0 Darwin Kernel Version 17.2.0: Fri Sep 29 18:27:05 PDT 2017; root:xnu-4570.20.62~3/RELEASE_X86_64 x86_64, Mono/.Net Framework: v4.0.30319
. 2017.11.09 15:34:43 - Reading options from /Users//.airvpn/AirVPN.xml
. 2017.11.09 15:34:43 - Command line arguments (0):
I 2017.11.09 15:34:45 - OpenVPN Driver - Expected
I 2017.11.09 15:34:45 - OpenVPN - Version: 2.4.3 - OpenSSL 1.0.2l  25 May 2017, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
I 2017.11.09 15:34:45 - SSH - Version: OpenSSH_7.5p1, LibreSSL 2.5.4 (/usr/bin/ssh)
I 2017.11.09 15:34:45 - SSL - Version: stunnel 5.40 (/Applications/Eddie.app/Contents/MacOS/stunnel)
I 2017.11.09 15:34:45 - curl - Version: 7.54.0 (/usr/bin/curl)
I 2017.11.09 15:34:45 - Certification Authorities: /Applications/Eddie.app/Contents/MacOS/cacert.pem
! 2017.11.09 15:34:45 - Activation of Network Lock - OS X - PF
. 2017.11.09 15:34:45 - OS X - PF rules updated, reloading
. 2017.11.09 15:34:45 - Updating systems & servers data ...
I 2017.11.09 15:34:46 - Session starting.
. 2017.11.09 15:34:46 - IPv6 disabled on network adapter (cineMoco)
. 2017.11.09 15:34:46 - IPv6 disabled on network adapter (802.11 n WLAN)
. 2017.11.09 15:34:46 - IPv6 disabled on network adapter (Wi-Fi)
. 2017.11.09 15:34:46 - IPv6 disabled on network adapter (iPhone USB)
. 2017.11.09 15:34:46 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2017.11.09 15:34:46 - IPv6 disabled on network adapter (Thunderbolt Bridge)
. 2017.11.09 15:34:47 - Systems & servers data update completed
. 2017.11.09 15:34:47 - IPv6 disabled on network adapter (Apple USB Ethernet Adapter)
I 2017.11.09 15:34:54 - Checking authorization ...
! 2017.11.09 15:34:54 - Connecting to Cynosura (Canada, Vancouver)
. 2017.11.09 15:34:55 - OpenVPN > OpenVPN 2.4.3 x86_64-apple-darwin16.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jun 23 2017
. 2017.11.09 15:34:55 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2017.11.09 15:34:55 - Connection to OpenVPN Management Interface
. 2017.11.09 15:34:55 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3110
. 2017.11.09 15:34:55 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.11.09 15:34:55 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.11.09 15:34:55 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]71.19.252.21:443
. 2017.11.09 15:34:55 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.11.09 15:34:55 - OpenVPN > UDP link local: (not bound)
. 2017.11.09 15:34:55 - OpenVPN > UDP link remote: [AF_INET]71.19.252.21:443
. 2017.11.09 15:34:55 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.21:443, sid=27b9357c 4348fa2e
. 2017.11.09 15:34:55 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.11.09 15:34:55 - OpenVPN > VERIFY KU OK
. 2017.11.09 15:34:55 - OpenVPN > Validating certificate extended key usage
. 2017.11.09 15:34:55 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.11.09 15:34:55 - OpenVPN > VERIFY EKU OK
. 2017.11.09 15:34:55 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cynosura, emailAddress=info@airvpn.org
. 2017.11.09 15:34:55 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3110
. 2017.11.09 15:34:55 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.11.09 15:34:55 - OpenVPN > [Cynosura] Peer Connection Initiated with [AF_INET]71.19.252.21:443
. 2017.11.09 15:34:56 - OpenVPN > SENT CONTROL [Cynosura]: 'PUSH_REQUEST' (status=1)
. 2017.11.09 15:34:58 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.17.50 255.255.0.0,peer-id 23,cipher AES-256-GCM'
. 2017.11.09 15:34:58 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.11.09 15:34:58 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.11.09 15:34:58 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.11.09 15:34:58 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.11.09 15:34:58 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.11.09 15:34:58 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.11.09 15:34:58 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2017.11.09 15:34:58 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2017.11.09 15:34:58 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2017.11.09 15:34:58 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2017.11.09 15:34:58 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.11.09 15:34:58 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.11.09 15:34:58 - OpenVPN > ROUTE_GATEWAY 10.0.1.1/255.255.255.0 IFACE=en0 HWADDR=14:10:9f:d2:79:6d
. 2017.11.09 15:34:58 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2017.11.09 15:34:58 - OpenVPN > Opened utun device utun1
. 2017.11.09 15:34:58 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.11.09 15:34:58 - OpenVPN > /sbin/ifconfig utun1 delete
. 2017.11.09 15:34:58 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.11.09 15:34:58 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.11.09 15:34:58 - OpenVPN > /sbin/ifconfig utun1 10.4.17.50 10.4.17.50 netmask 255.255.0.0 mtu 1500 up
. 2017.11.09 15:34:58 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.17.50 255.255.0.0
. 2017.11.09 15:34:58 - OpenVPN > add net 10.4.0.0: gateway 10.4.17.50
. 2017.11.09 15:34:58 - OpenVPN > /sbin/route add -net 71.19.252.21 10.0.1.1 255.255.255.255
. 2017.11.09 15:34:58 - OpenVPN > add net 71.19.252.21: gateway 10.0.1.1
. 2017.11.09 15:34:58 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.11.09 15:34:58 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.11.09 15:34:58 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.11.09 15:34:58 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.11.09 15:34:59 - DNS of a network adapter forced (cineMoco, from Automatic to 10.4.0.1)
. 2017.11.09 15:34:59 - DNS of a network adapter forced (802.11 n WLAN, from Automatic to 10.4.0.1)
. 2017.11.09 15:34:59 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.4.0.1)
. 2017.11.09 15:34:59 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.4.0.1)
. 2017.11.09 15:34:59 - DNS of a network adapter forced (Bluetooth PAN, from Automatic to 10.4.0.1)
. 2017.11.09 15:34:59 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2017.11.09 15:34:59 - DNS of a network adapter forced (Apple USB Ethernet Adapter, from Automatic to 10.4.0.1)
. 2017.11.09 15:34:59 - Flushing DNS
. 2017.11.09 15:35:00 - OS X - PF rules updated, reloading
I 2017.11.09 15:35:00 - Checking route
I 2017.11.09 15:35:03 - Checking DNS
. 2017.11.09 15:35:06 - Checking DNS failed: ajmxsjycvihkolsjlsdcxncxhkkazpnj
. 2017.11.09 15:35:06 - Checking DNS (2° try)
. 2017.11.09 15:35:09 - Checking DNS failed: ajmxsjycvihkolsjlsdcxncxhkkazpnj
. 2017.11.09 15:35:09 - Checking DNS (3° try)
. 2017.11.09 15:35:12 - Checking DNS failed: ajmxsjycvihkolsjlsdcxncxhkkazpnj
E 2017.11.09 15:35:12 - Checking DNS failed.
. 2017.11.09 15:35:12 - OpenVPN > Initialization Sequence Completed
! 2017.11.09 15:35:13 - Disconnecting
. 2017.11.09 15:35:13 - Sending management termination signal
. 2017.11.09 15:35:13 - Management - Send 'signal SIGTERM'
. 2017.11.09 15:35:18 - Connection terminated.
. 2017.11.09 15:35:18 - DNS of a network adapter restored to original settings (cineMoco, to Automatic)
. 2017.11.09 15:35:18 - DNS of a network adapter restored to original settings (802.11 n WLAN, to Automatic)
. 2017.11.09 15:35:19 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic)
. 2017.11.09 15:35:19 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic)
. 2017.11.09 15:35:19 - DNS of a network adapter restored to original settings (Bluetooth PAN, to Automatic)
. 2017.11.09 15:35:19 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2017.11.09 15:35:19 - DNS of a network adapter restored to original settings (Apple USB Ethernet Adapter, to Automatic)
I 2017.11.09 15:35:22 - Checking authorization ...
! 2017.11.09 15:35:23 - Connecting to Homam (Canada, Vancouver)
. 2017.11.09 15:35:23 - OpenVPN > OpenVPN 2.4.3 x86_64-apple-darwin16.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jun 23 2017
. 2017.11.09 15:35:23 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2017.11.09 15:35:23 - Connection to OpenVPN Management Interface
. 2017.11.09 15:35:23 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3110
. 2017.11.09 15:35:23 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.11.09 15:35:23 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.11.09 15:35:23 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]71.19.252.26:443
. 2017.11.09 15:35:23 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.11.09 15:35:23 - OpenVPN > UDP link local: (not bound)
. 2017.11.09 15:35:23 - OpenVPN > UDP link remote: [AF_INET]71.19.252.26:443
. 2017.11.09 15:35:23 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.26:443, sid=828ebeba c0a02a2e
. 2017.11.09 15:35:23 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3110
. 2017.11.09 15:35:23 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.11.09 15:35:23 - OpenVPN > VERIFY KU OK
. 2017.11.09 15:35:23 - OpenVPN > Validating certificate extended key usage
. 2017.11.09 15:35:23 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.11.09 15:35:23 - OpenVPN > VERIFY EKU OK
. 2017.11.09 15:35:23 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Homam, emailAddress=info@airvpn.org
. 2017.11.09 15:35:23 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.11.09 15:35:23 - OpenVPN > [Homam] Peer Connection Initiated with [AF_INET]71.19.252.26:443
. 2017.11.09 15:35:24 - OpenVPN > SENT CONTROL [Homam]: 'PUSH_REQUEST' (status=1)
. 2017.11.09 15:35:24 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.157 255.255.0.0,peer-id 26,cipher AES-256-GCM'
. 2017.11.09 15:35:24 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.11.09 15:35:24 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.11.09 15:35:24 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.11.09 15:35:24 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.11.09 15:35:24 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.11.09 15:35:24 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.11.09 15:35:24 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2017.11.09 15:35:24 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2017.11.09 15:35:24 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2017.11.09 15:35:24 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2017.11.09 15:35:24 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.11.09 15:35:24 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.11.09 15:35:24 - OpenVPN > ROUTE_GATEWAY 10.0.1.1/255.255.255.0 IFACE=en0 HWADDR=14:10:9f:d2:79:6d
. 2017.11.09 15:35:24 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2017.11.09 15:35:24 - OpenVPN > Opened utun device utun1
. 2017.11.09 15:35:24 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.11.09 15:35:24 - OpenVPN > /sbin/ifconfig utun1 delete
. 2017.11.09 15:35:24 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.11.09 15:35:24 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.11.09 15:35:24 - OpenVPN > /sbin/ifconfig utun1 10.4.1.157 10.4.1.157 netmask 255.255.0.0 mtu 1500 up
. 2017.11.09 15:35:24 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.1.157 255.255.0.0
. 2017.11.09 15:35:24 - OpenVPN > add net 10.4.0.0: gateway 10.4.1.157
. 2017.11.09 15:35:24 - OpenVPN > /sbin/route add -net 71.19.252.26 10.0.1.1 255.255.255.255
. 2017.11.09 15:35:24 - OpenVPN > add net 71.19.252.26: gateway 10.0.1.1
. 2017.11.09 15:35:24 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.11.09 15:35:24 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.11.09 15:35:24 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.11.09 15:35:24 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.11.09 15:35:24 - DNS of a network adapter forced (cineMoco, from Automatic to 10.4.0.1)
. 2017.11.09 15:35:25 - DNS of a network adapter forced (802.11 n WLAN, from Automatic to 10.4.0.1)
. 2017.11.09 15:35:25 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.4.0.1)
. 2017.11.09 15:35:25 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.4.0.1)
. 2017.11.09 15:35:25 - DNS of a network adapter forced (Bluetooth PAN, from Automatic to 10.4.0.1)
. 2017.11.09 15:35:25 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2017.11.09 15:35:25 - DNS of a network adapter forced (Apple USB Ethernet Adapter, from Automatic to 10.4.0.1)
. 2017.11.09 15:35:25 - Flushing DNS
I 2017.11.09 15:35:25 - Checking route
. 2017.11.09 15:35:55 - curl: (28) Connection timed out after 30001 milliseconds
. 2017.11.09 15:35:55 - Checking route (2° try)
. 2017.11.09 15:36:27 - curl: (28) Connection timed out after 30001 milliseconds
. 2017.11.09 15:36:27 - Checking route (3° try)
. 2017.11.09 15:36:59 - curl: (28) Connection timed out after 30001 milliseconds
E 2017.11.09 15:36:59 - Checking route failed.
. 2017.11.09 15:36:59 - OpenVPN > Initialization Sequence Completed
! 2017.11.09 15:36:59 - Disconnecting
. 2017.11.09 15:36:59 - Sending management termination signal
. 2017.11.09 15:36:59 - Management - Send 'signal SIGTERM'
. 2017.11.09 15:37:05 - Connection terminated.
. 2017.11.09 15:37:05 - DNS of a network adapter restored to original settings (cineMoco, to Automatic)
. 2017.11.09 15:37:05 - DNS of a network adapter restored to original settings (802.11 n WLAN, to Automatic)
. 2017.11.09 15:37:05 - DNS of a network adapter restored to original settings (Wi-Fi, to Automatic)
. 2017.11.09 15:37:05 - DNS of a network adapter restored to original settings (iPhone USB, to Automatic)
. 2017.11.09 15:37:05 - DNS of a network adapter restored to original settings (Bluetooth PAN, to Automatic)
. 2017.11.09 15:37:05 - DNS of a network adapter restored to original settings (Thunderbolt Bridge, to Automatic)
. 2017.11.09 15:37:05 - DNS of a network adapter restored to original settings (Apple USB Ethernet Adapter, to Automatic)
I 2017.11.09 15:37:06 - Cancel requested.
. 2017.11.09 15:37:06 - IPv6 restored on network adapter (cineMoco)
. 2017.11.09 15:37:06 - IPv6 restored on network adapter (802.11 n WLAN)
. 2017.11.09 15:37:06 - IPv6 restored on network adapter (Wi-Fi)
. 2017.11.09 15:37:06 - IPv6 restored on network adapter (iPhone USB)
. 2017.11.09 15:37:06 - IPv6 restored on network adapter (Bluetooth PAN)
. 2017.11.09 15:37:06 - IPv6 restored on network adapter (Thunderbolt Bridge)
. 2017.11.09 15:37:06 - IPv6 restored on network adapter (Apple USB Ethernet Adapter)
! 2017.11.09 15:37:06 - Session terminated.
! 2017.11.09 15:37:07 - Deactivation of Network Lock
A solution that has worked for me is disabling network lock.
Disabling network lock seems to work when I tried it, but this makes me wonder why network lock would be blocking the VPN from working as expected. It'd be nice to keep the network lock on so you have complete protection even while it's switching servers, which it does periodically.
Having loads of trouble with AirVPN over the past year.
Try this. Under "Network Lock" uncheck "allow lan/private" and "allow ping". Or check them if they are not checked. Save settings. Shut down and restart Eddie and see if that makes a difference.
Thanks for the advice, however it didn't work. It got stuck on "Checking DNS." I do appreciate the help, though.
Here are the logs when I followed your instructions:
I 2017.11.14 11:05:14 - Eddie version: 2.13.6 / macos_x64, System: MacOS, Name: 10.13.1, Version: Darwin XXXXX.local 17.2.0 Darwin Kernel Version 17.2.0: Fri Sep 29 18:27:05 PDT 2017; root:xnu-4570.20.62~3/RELEASE_X86_64 x86_64, Mono/.Net Framework: v4.0.30319
. 2017.11.14 11:05:14 - Reading options from /Users//.airvpn/AirVPN.xml
. 2017.11.14 11:05:15 - Command line arguments (0):
I 2017.11.14 11:05:16 - OpenVPN Driver - Expected
I 2017.11.14 11:05:16 - OpenVPN - Version: 2.4.3 - OpenSSL 1.0.2l  25 May 2017, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
I 2017.11.14 11:05:16 - SSH - Version: OpenSSH_7.5p1, LibreSSL 2.5.4 (/usr/bin/ssh)
I 2017.11.14 11:05:16 - SSL - Version: stunnel 5.40 (/Applications/Eddie.app/Contents/MacOS/stunnel)
I 2017.11.14 11:05:16 - curl - Version: 7.54.0 (/usr/bin/curl)
I 2017.11.14 11:05:16 - Certification Authorities: /Applications/Eddie.app/Contents/MacOS/cacert.pem
! 2017.11.14 11:05:16 - Activation of Network Lock - OS X - PF
. 2017.11.14 11:05:16 - OS X - PF rules updated, reloading
. 2017.11.14 11:05:17 - Updating systems & servers data ...
. 2017.11.14 11:05:17 - OS X - PF rules updated, reloading
I 2017.11.14 11:05:17 - Session starting.
. 2017.11.14 11:05:17 - IPv6 disabled on network adapter (cineMoco)
. 2017.11.14 11:05:17 - IPv6 disabled on network adapter (802.11 n WLAN)
. 2017.11.14 11:05:17 - IPv6 disabled on network adapter (Wi-Fi)
. 2017.11.14 11:05:18 - IPv6 disabled on network adapter (iPhone USB)
. 2017.11.14 11:05:18 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2017.11.14 11:05:18 - IPv6 disabled on network adapter (Thunderbolt Bridge)
. 2017.11.14 11:05:18 - IPv6 disabled on network adapter (Apple USB Ethernet Adapter)
. 2017.11.14 11:05:19 - Systems & servers data update completed
I 2017.11.14 11:05:25 - Checking authorization ...
! 2017.11.14 11:05:26 - Connecting to Cynosura (Canada, Vancouver)
. 2017.11.14 11:05:27 - OpenVPN > OpenVPN 2.4.3 x86_64-apple-darwin16.6.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jun 23 2017
. 2017.11.14 11:05:27 - OpenVPN > library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
. 2017.11.14 11:05:27 - Connection to OpenVPN Management Interface
. 2017.11.14 11:05:27 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3110
. 2017.11.14 11:05:27 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.11.14 11:05:27 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.11.14 11:05:27 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]71.19.252.21:443
. 2017.11.14 11:05:27 - OpenVPN > Socket Buffers: R=[196724->262144] S=[9216->262144]
. 2017.11.14 11:05:27 - OpenVPN > UDP link local: (not bound)
. 2017.11.14 11:05:27 - OpenVPN > UDP link remote: [AF_INET]71.19.252.21:443
. 2017.11.14 11:05:27 - OpenVPN > TLS: Initial packet from [AF_INET]71.19.252.21:443, sid=dada319d 056fa242
. 2017.11.14 11:05:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2017.11.14 11:05:27 - OpenVPN > VERIFY KU OK
. 2017.11.14 11:05:27 - OpenVPN > Validating certificate extended key usage
. 2017.11.14 11:05:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2017.11.14 11:05:27 - OpenVPN > VERIFY EKU OK
. 2017.11.14 11:05:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Cynosura, emailAddress=info@airvpn.org
. 2017.11.14 11:05:27 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3110
. 2017.11.14 11:05:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2017.11.14 11:05:27 - OpenVPN > [Cynosura] Peer Connection Initiated with [AF_INET]71.19.252.21:443
. 2017.11.14 11:05:28 - OpenVPN > SENT CONTROL [Cynosura]: 'PUSH_REQUEST' (status=1)
. 2017.11.14 11:05:28 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.17.50 255.255.0.0,peer-id 109,cipher AES-256-GCM'
. 2017.11.14 11:05:28 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2017.11.14 11:05:28 - OpenVPN > OPTIONS IMPORT: compression parms modified
. 2017.11.14 11:05:28 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2017.11.14 11:05:28 - OpenVPN > OPTIONS IMPORT: route options modified
. 2017.11.14 11:05:28 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2017.11.14 11:05:28 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2017.11.14 11:05:28 - OpenVPN > OPTIONS IMPORT: peer-id set
. 2017.11.14 11:05:28 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625
. 2017.11.14 11:05:28 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified
. 2017.11.14 11:05:28 - OpenVPN > Data Channel: using negotiated cipher 'AES-256-GCM'
. 2017.11.14 11:05:28 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.11.14 11:05:28 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key
. 2017.11.14 11:05:28 - OpenVPN > ROUTE_GATEWAY 10.0.1.1/255.255.255.0 IFACE=en0 HWADDR=14:10:9f:d2:79:6d
. 2017.11.14 11:05:28 - OpenVPN > Opening utun (connect(AF_SYS_CONTROL)): Resource busy
. 2017.11.14 11:05:28 - Above log line repeated 1 times more
. 2017.11.14 11:05:28 - OpenVPN > Opened utun device utun2
. 2017.11.14 11:05:28 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0
. 2017.11.14 11:05:28 - OpenVPN > /sbin/ifconfig utun2 delete
. 2017.11.14 11:05:28 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2017.11.14 11:05:28 - OpenVPN > ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2017.11.14 11:05:28 - OpenVPN > /sbin/ifconfig utun2 10.4.17.50 10.4.17.50 netmask 255.255.0.0 mtu 1500 up
. 2017.11.14 11:05:28 - OpenVPN > /sbin/route add -net 10.4.0.0 10.4.17.50 255.255.0.0
. 2017.11.14 11:05:28 - OpenVPN > add net 10.4.0.0: gateway 10.4.17.50
. 2017.11.14 11:05:28 - OpenVPN > /sbin/route add -net 71.19.252.21 10.0.1.1 255.255.255.255
. 2017.11.14 11:05:28 - OpenVPN > add net 71.19.252.21: gateway 10.0.1.1
. 2017.11.14 11:05:28 - OpenVPN > /sbin/route add -net 0.0.0.0 10.4.0.1 128.0.0.0
. 2017.11.14 11:05:28 - OpenVPN > add net 0.0.0.0: gateway 10.4.0.1
. 2017.11.14 11:05:28 - OpenVPN > /sbin/route add -net 128.0.0.0 10.4.0.1 128.0.0.0
. 2017.11.14 11:05:28 - OpenVPN > add net 128.0.0.0: gateway 10.4.0.1
. 2017.11.14 11:05:28 - DNS of a network adapter forced (cineMoco, from Automatic to 10.4.0.1)
. 2017.11.14 11:05:28 - DNS of a network adapter forced (802.11 n WLAN, from Automatic to 10.4.0.1)
. 2017.11.14 11:05:29 - DNS of a network adapter forced (Wi-Fi, from Automatic to 10.4.0.1)
. 2017.11.14 11:05:29 - DNS of a network adapter forced (iPhone USB, from Automatic to 10.4.0.1)
. 2017.11.14 11:05:29 - DNS of a network adapter forced (Bluetooth PAN, from Automatic to 10.4.0.1)
. 2017.11.14 11:05:29 - DNS of a network adapter forced (Thunderbolt Bridge, from Automatic to 10.4.0.1)
. 2017.11.14 11:05:29 - DNS of a network adapter forced (Apple USB Ethernet Adapter, from Automatic to 10.4.0.1)
. 2017.11.14 11:05:29 - Flushing DNS
. 2017.11.14 11:05:29 - OS X - PF rules updated, reloading
I 2017.11.14 11:05:29 - Checking route
I 2017.11.14 11:05:30 - Checking DNS
. 2017.11.14 11:05:31 - Checking DNS failed: ajmxsjycvihkolsjlsdcxncxhkkazpnj
. 2017.11.14 11:05:31 - Checking DNS (2° try)
. 2017.11.14 11:06:12 - curl: (28) Operation timed out after 30002 milliseconds with 0 out of 0 bytes received
. 2017.11.14 11:06:12 - Checking DNS (3° try)
. 2017.11.14 11:06:16 - Checking DNS failed: ajmxsjycvihkolsjlsdcxncxhkkazpnj
E 2017.11.14 11:06:16 - Checking DNS failed.
. 2017.11.14 11:06:16 - OpenVPN > Initialization Sequence Completed
! 2017.11.14 11:06:16 - Disconnecting
. 2017.11.14 11:06:16 - Sending management termination signal
. 2017.11.14 11:06:16 - Management - Send 'signal SIGTERM'
Are you running Little Snitch? If so, make sure mDNSResponder is allowing outgoing connections.
I am running Little Snitch. I checked, and mDNSResponder's rule is already set to allow any outgoing connections.
Hmm. Perhaps if you have not done so yet, submit a ticket to Staff explaining the problem and include both regular log and log system information. I was having the same problem on my Macbook Pro running Sierra, but it seems to be fine now. All I remember doing is shutting down both the Pro and my router and rebooting both. On my iMac running El Capitan, however, I am having a few problems that may or may not be related. Submit a ticket. It won't hurt to see what they say.
was there a response to your ticket?  I have the same problem -- with network lock, can't connect.
Have you tried unchecking the "Check AirVPN DNS:" option in the DNS section of the Preferences menu? That cured the failure to connect issues for me,
cse
Same here, been having this problem with Air VPN client eddie 2.11.15.
None of the above suggestions work for me. Any other suggestions?
SAME.
Same here.
MacOS 10.12.6 (Sierra)
Same Checking Route - Checking DNS - Restarting Loop.
Turning OFF the Network lock, I get instant connection immediately.
However I wont use it in that way.
In the end I just went with another company and when I realised that it worked with them - now want to sort this out here.
Have tried unchecking the "Check Dns" and it DOES seem to work so far (1 try) - but does that make it insecure?
Thank you
T.
Disabling the "Check DNS" option usually just means that your system will not be forced to use the DNS server of the VPN. This can be a good thing if you are willing to take an extra step after connecting to the VPN to start DNSCrypt with one of the many free servers they have. But it is annoying to have to do this. However, some ISPs force you to install what they claim is required software to use the Internet service they sell to you. In every case I have seen, the only thing this junk software does is force you to use their DNS server so they can spy on you.
Here is a link to DNSCrypt. I do not have a Mac, so I cannot really advise you about it. But I suspect it will work just fine even if you have that junk software from your ISP messing things up. And if not, you can easily remove it.
https://dnscrypt.org/#dnscrypt-macos
Good luck.
Good luck.
Thank you very much for your answer. I understand some of it - but I certainly understand your warning! I will install it.
As I understand, I just need to run it - which I now am when AirVPN/Eddie is running? What is the recommended DNS (resolver)  to connect to in this case?
I like okTurtles. They may not have all the features of some of the other DNS options, but they are very fast for me here in the USA. Usually, any server near to you will work well. And if it does not, you can switch them out very quickly with no problems.
