Not connected, Your IP: 18.218.129.100
hackers2016
Airvpn keep disconnecting pfsense
Here is my log file. I can't make sense of it why keeps disconnecting I changed the VERB to 4
Sep 10 12:05:07 	openvpn 	6958 	MANAGEMENT: CMD 'status 2'
Sep 10 12:05:07 	openvpn 	6958 	MANAGEMENT: Client disconnected
Sep 10 12:05:17 	openvpn 	6958 	MANAGEMENT: Client connected from /var/etc/openvpn/client1.sock
Sep 10 12:05:17 	openvpn 	6958 	MANAGEMENT: CMD 'state 1'
Sep 10 12:05:17 	openvpn 	6958 	MANAGEMENT: CMD 'status 2'
Sep 10 12:05:17 	openvpn 	6958 	MANAGEMENT: Client disconnected
Sep 10 12:05:27 	openvpn 	6958 	MANAGEMENT: Client connected from /var/etc/openvpn/client1.sock
Sep 10 12:05:27 	openvpn 	6958 	MANAGEMENT: CMD 'state 1'
Sep 10 12:05:27 	openvpn 	6958 	MANAGEMENT: CMD 'status 2'
Sep 10 12:05:27 	openvpn 	6958 	MANAGEMENT: Client disconnected
Sep 10 12:05:36 	openvpn 	6958 	event_wait : Interrupted system call (code=4)
Sep 10 12:05:36 	openvpn 	6958 	SIGTERM received, sending exit notification to peer
Sep 10 12:05:37 	openvpn 	6958 	MANAGEMENT: Client connected from /var/etc/openvpn/client1.sock
Sep 10 12:05:37 	openvpn 	6958 	MANAGEMENT: CMD 'state 1'
Sep 10 12:05:37 	openvpn 	6958 	MANAGEMENT: CMD 'status 2'
Sep 10 12:05:37 	openvpn 	6958 	MANAGEMENT: Client disconnected
Sep 10 12:05:40 	openvpn 	36512 	Current Parameter Settings:
Sep 10 12:05:40 	openvpn 	36512 	config = '/var/etc/openvpn/client1.conf'
Sep 10 12:05:40 	openvpn 	36512 	mode = 0
Sep 10 12:05:40 	openvpn 	36512 	show_ciphers = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	show_digests = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	show_engines = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	genkey = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	key_pass_file = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	show_tls_ciphers = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	Connection profiles [default]:
Sep 10 12:05:40 	openvpn 	36512 	proto = udp
Sep 10 12:05:40 	openvpn 	36512 	local = '67.173.152.223'
Sep 10 12:05:40 	openvpn 	36512 	local_port = 0
Sep 10 12:05:40 	openvpn 	36512 	remote = '173.234.159.194'
Sep 10 12:05:40 	openvpn 	36512 	remote_port = 443
Sep 10 12:05:40 	openvpn 	36512 	remote_float = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	bind_defined = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	bind_local = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	connect_retry_seconds = 5
Sep 10 12:05:40 	openvpn 	36512 	connect_timeout = 10
Sep 10 12:05:40 	openvpn 	36512 	connect_retry_max = 0
Sep 10 12:05:40 	openvpn 	36512 	socks_proxy_server = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	socks_proxy_port = 0
Sep 10 12:05:40 	openvpn 	36512 	socks_proxy_retry = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	tun_mtu = 1500
Sep 10 12:05:40 	openvpn 	36512 	tun_mtu_defined = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	link_mtu = 1500
Sep 10 12:05:40 	openvpn 	36512 	link_mtu_defined = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	tun_mtu_extra = 0
Sep 10 12:05:40 	openvpn 	36512 	tun_mtu_extra_defined = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	mtu_discover_type = -1
Sep 10 12:05:40 	openvpn 	36512 	fragment = 0
Sep 10 12:05:40 	openvpn 	36512 	mssfix = 1450
Sep 10 12:05:40 	openvpn 	36512 	explicit_exit_notification = 5
Sep 10 12:05:40 	openvpn 	36512 	Connection profiles END
Sep 10 12:05:40 	openvpn 	36512 	remote_random = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	ipchange = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	dev = 'ovpnc1'
Sep 10 12:05:40 	openvpn 	36512 	dev_type = 'tun'
Sep 10 12:05:40 	openvpn 	36512 	dev_node = '/dev/tun1'
Sep 10 12:05:40 	openvpn 	36512 	lladdr = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	topology = 1
Sep 10 12:05:40 	openvpn 	36512 	tun_ipv6 = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	ifconfig_local = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	ifconfig_remote_netmask = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	ifconfig_noexec = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	ifconfig_nowarn = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	ifconfig_ipv6_local = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	ifconfig_ipv6_netbits = 0
Sep 10 12:05:40 	openvpn 	36512 	ifconfig_ipv6_remote = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	shaper = 0
Sep 10 12:05:40 	openvpn 	36512 	mtu_test = 0
Sep 10 12:05:40 	openvpn 	36512 	mlock = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	keepalive_ping = 10
Sep 10 12:05:40 	openvpn 	36512 	keepalive_timeout = 60
Sep 10 12:05:40 	openvpn 	36512 	inactivity_timeout = 0
Sep 10 12:05:40 	openvpn 	36512 	ping_send_timeout = 10
Sep 10 12:05:40 	openvpn 	36512 	ping_rec_timeout = 60
Sep 10 12:05:40 	openvpn 	36512 	ping_rec_timeout_action = 2
Sep 10 12:05:40 	openvpn 	36512 	ping_timer_remote = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	remap_sigusr1 = 0
Sep 10 12:05:40 	openvpn 	36512 	persist_tun = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	persist_local_ip = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	persist_remote_ip = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	persist_key = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	passtos = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	resolve_retry_seconds = 1000000000
Sep 10 12:05:40 	openvpn 	36512 	username = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	groupname = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	chroot_dir = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	cd_dir = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	writepid = '/var/run/openvpn_client1.pid'
Sep 10 12:05:40 	openvpn 	36512 	up_script = '/usr/local/sbin/ovpn-linkup'
Sep 10 12:05:40 	openvpn 	36512 	down_script = '/usr/local/sbin/ovpn-linkdown'
Sep 10 12:05:40 	openvpn 	36512 	down_pre = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	up_restart = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	up_delay = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	daemon = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	inetd = 0
Sep 10 12:05:40 	openvpn 	36512 	log = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	suppress_timestamps = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	nice = 0
Sep 10 12:05:40 	openvpn 	36512 	verbosity = 4
Sep 10 12:05:40 	openvpn 	36512 	mute = 0
Sep 10 12:05:40 	openvpn 	36512 	gremlin = 0
Sep 10 12:05:40 	openvpn 	36512 	status_file = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	status_file_version = 1
Sep 10 12:05:40 	openvpn 	36512 	status_file_update_freq = 60
Sep 10 12:05:40 	openvpn 	36512 	occ = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	rcvbuf = 0
Sep 10 12:05:40 	openvpn 	36512 	sndbuf = 0
Sep 10 12:05:40 	openvpn 	36512 	sockflags = 0
Sep 10 12:05:40 	openvpn 	36512 	fast_io = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	lzo = 1
Sep 10 12:05:40 	openvpn 	36512 	route_script = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	route_default_gateway = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	route_default_metric = 0
Sep 10 12:05:40 	openvpn 	36512 	route_noexec = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	route_delay = 0
Sep 10 12:05:40 	openvpn 	36512 	route_delay_window = 30
Sep 10 12:05:40 	openvpn 	36512 	route_delay_defined = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	route_nopull = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	route_gateway_via_dhcp = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	max_routes = 100
Sep 10 12:05:40 	openvpn 	36512 	allow_pull_fqdn = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	management_addr = '/var/etc/openvpn/client1.sock'
Sep 10 12:05:40 	openvpn 	36512 	management_port = 0
Sep 10 12:05:40 	openvpn 	36512 	management_user_pass = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	management_log_history_cache = 250
Sep 10 12:05:40 	openvpn 	36512 	management_echo_buffer_size = 100
Sep 10 12:05:40 	openvpn 	36512 	management_write_peer_info_file = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	management_client_user = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	management_client_group = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	management_flags = 256
Sep 10 12:05:40 	openvpn 	36512 	shared_secret_file = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	key_direction = 2
Sep 10 12:05:40 	openvpn 	36512 	ciphername_defined = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	ciphername = 'AES-256-CBC'
Sep 10 12:05:40 	openvpn 	36512 	authname_defined = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	authname = 'SHA1'
Sep 10 12:05:40 	openvpn 	36512 	prng_hash = 'SHA512'
Sep 10 12:05:40 	openvpn 	36512 	prng_nonce_secret_len = 64
Sep 10 12:05:40 	openvpn 	36512 	keysize = 32
Sep 10 12:05:40 	openvpn 	36512 	engine = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	replay = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	mute_replay_warnings = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	replay_window = 64
Sep 10 12:05:40 	openvpn 	36512 	replay_time = 15
Sep 10 12:05:40 	openvpn 	36512 	packet_id_file = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	use_iv = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	test_crypto = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	tls_server = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	tls_client = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	key_method = 2
Sep 10 12:05:40 	openvpn 	36512 	ca_file = '/var/etc/openvpn/client1.ca'
Sep 10 12:05:40 	openvpn 	36512 	ca_path = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	dh_file = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	cert_file = '/var/etc/openvpn/client1.cert'
Sep 10 12:05:40 	openvpn 	36512 	extra_certs_file = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	priv_key_file = '/var/etc/openvpn/client1.key'
Sep 10 12:05:40 	openvpn 	36512 	pkcs12_file = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	cipher_list = 'TLS-DHE-RSA-WITH-AES-256-GCM-SHA384'
Sep 10 12:05:40 	openvpn 	36512 	tls_verify = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	tls_export_cert = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	verify_x509_type = 0
Sep 10 12:05:40 	openvpn 	36512 	verify_x509_name = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	crl_file = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	ns_cert_type = 1
Sep 10 12:05:40 	openvpn 	36512 	remote_cert_ku[i] = 160
Sep 10 12:05:40 	openvpn 	36512 	remote_cert_ku[i] = 136
Sep 10 12:05:40 	openvpn 	36512 	remote_cert_ku[i] = 0
Sep 10 12:05:40 	openvpn 	36512 	remote_cert_eku = 'TLS Web Server Authentication'
Sep 10 12:05:40 	openvpn 	36512 	ssl_flags = 192
Sep 10 12:05:40 	openvpn 	36512 	tls_timeout = 2
Sep 10 12:05:40 	openvpn 	36512 	renegotiate_bytes = -1
Sep 10 12:05:40 	openvpn 	36512 	renegotiate_packets = 0
Sep 10 12:05:40 	openvpn 	36512 	renegotiate_seconds = 3600
Sep 10 12:05:40 	openvpn 	36512 	handshake_window = 60
Sep 10 12:05:40 	openvpn 	36512 	transition_window = 3600
Sep 10 12:05:40 	openvpn 	36512 	single_session = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	push_peer_info = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	tls_exit = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	tls_auth_file = '/var/etc/openvpn/client1.tls-auth'
Sep 10 12:05:40 	openvpn 	36512 	server_network = 0.0.0.0
Sep 10 12:05:40 	openvpn 	36512 	server_netmask = 0.0.0.0
Sep 10 12:05:40 	openvpn 	36512 	server_network_ipv6 = ::
Sep 10 12:05:40 	openvpn 	36512 	server_netbits_ipv6 = 0
Sep 10 12:05:40 	openvpn 	36512 	server_bridge_ip = 0.0.0.0
Sep 10 12:05:40 	openvpn 	36512 	server_bridge_netmask = 0.0.0.0
Sep 10 12:05:40 	openvpn 	36512 	server_bridge_pool_start = 0.0.0.0
Sep 10 12:05:40 	openvpn 	36512 	server_bridge_pool_end = 0.0.0.0
Sep 10 12:05:40 	openvpn 	36512 	ifconfig_pool_defined = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	ifconfig_pool_start = 0.0.0.0
Sep 10 12:05:40 	openvpn 	36512 	ifconfig_pool_end = 0.0.0.0
Sep 10 12:05:40 	openvpn 	36512 	ifconfig_pool_netmask = 0.0.0.0
Sep 10 12:05:40 	openvpn 	36512 	ifconfig_pool_persist_filename = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	ifconfig_pool_persist_refresh_freq = 600
Sep 10 12:05:40 	openvpn 	36512 	ifconfig_ipv6_pool_defined = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	ifconfig_ipv6_pool_base = ::
Sep 10 12:05:40 	openvpn 	36512 	ifconfig_ipv6_pool_netbits = 0
Sep 10 12:05:40 	openvpn 	36512 	n_bcast_buf = 256
Sep 10 12:05:40 	openvpn 	36512 	tcp_queue_limit = 64
Sep 10 12:05:40 	openvpn 	36512 	real_hash_size = 256
Sep 10 12:05:40 	openvpn 	36512 	virtual_hash_size = 256
Sep 10 12:05:40 	openvpn 	36512 	client_connect_script = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	learn_address_script = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	client_disconnect_script = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	client_config_dir = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	ccd_exclusive = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	tmp_dir = '/tmp'
Sep 10 12:05:40 	openvpn 	36512 	push_ifconfig_defined = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	push_ifconfig_local = 0.0.0.0
Sep 10 12:05:40 	openvpn 	36512 	push_ifconfig_remote_netmask = 0.0.0.0
Sep 10 12:05:40 	openvpn 	36512 	push_ifconfig_ipv6_defined = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	push_ifconfig_ipv6_local = ::/0
Sep 10 12:05:40 	openvpn 	36512 	push_ifconfig_ipv6_remote = ::
Sep 10 12:05:40 	openvpn 	36512 	enable_c2c = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	duplicate_cn = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	cf_max = 0
Sep 10 12:05:40 	openvpn 	36512 	cf_per = 0
Sep 10 12:05:40 	openvpn 	36512 	max_clients = 1024
Sep 10 12:05:40 	openvpn 	36512 	max_routes_per_client = 256
Sep 10 12:05:40 	openvpn 	36512 	auth_user_pass_verify_script = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	auth_user_pass_verify_script_via_file = DISABLED
Sep 10 12:05:40 	openvpn 	36512 	port_share_host = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	port_share_port = 0
Sep 10 12:05:40 	openvpn 	36512 	client = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	pull = ENABLED
Sep 10 12:05:40 	openvpn 	36512 	auth_user_pass_file = '[UNDEF]'
Sep 10 12:05:40 	openvpn 	36512 	OpenVPN 2.3.14 amd64-portbld-freebsd10.3 [SSL (OpenSSL)] [LZO] [MH] [IPv6] built on May 3 2017
Sep 10 12:05:40 	openvpn 	36512 	library versions: OpenSSL 1.0.1s-freebsd 1 Mar 2016, LZO 2.10
Sep 10 12:05:40 	openvpn 	36593 	MANAGEMENT: unix domain socket listening on /var/etc/openvpn/client1.sock
Sep 10 12:05:40 	openvpn 	36593 	mlockall call succeeded
Sep 10 12:05:40 	openvpn 	36593 	NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sep 10 12:05:40 	openvpn 	36593 	Initializing OpenSSL support for engine 'cryptodev'
Sep 10 12:05:40 	openvpn 	36593 	Control Channel Authentication: using '/var/etc/openvpn/client1.tls-auth' as a OpenVPN static key file
Sep 10 12:05:40 	openvpn 	36593 	Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Sep 10 12:05:40 	openvpn 	36593 	Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
Sep 10 12:05:40 	openvpn 	36593 	LZO compression initialized
Sep 10 12:05:40 	openvpn 	36593 	Control Channel MTU parms [ L:1558 D:1184 EF:66 EB:0 ET:0 EL:3 ]
Sep 10 12:05:40 	openvpn 	36593 	Socket Buffers: R=[42080->42080] S=[57344->57344]
Sep 10 12:05:40 	openvpn 	36593 	Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:143 ET:0 EL:3 AF:3/1 ]
Sep 10 12:05:40 	openvpn 	36593 	Local Options String: 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 1,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-client'
Sep 10 12:05:40 	openvpn 	36593 	Expected Remote Options String: 'V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,keydir 0,cipher AES-256-CBC,auth SHA1,keysize 256,tls-auth,key-method 2,tls-server'
Sep 10 12:05:40 	openvpn 	36593 	Local Options hash (VER=V4): '9e7066d2'
Sep 10 12:05:40 	openvpn 	36593 	Expected Remote Options hash (VER=V4): '162b04de'
Sep 10 12:05:40 	openvpn 	36593 	UDPv4 link local (bound): [AF_INET]67.173.152.223
Sep 10 12:05:40 	openvpn 	36593 	UDPv4 link remote: [AF_INET]173.234.159.194:443
Sep 10 12:05:40 	openvpn 	36593 	TLS: Initial packet from [AF_INET]173.234.159.194:443, sid=50645ec5 49590908
Sep 10 12:05:40 	openvpn 	36593 	VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Sep 10 12:05:40 	openvpn 	36593 	VERIFY OK: nsCertType=SERVER
Sep 10 12:05:40 	openvpn 	36593 	Validating certificate key usage
Sep 10 12:05:40 	openvpn 	36593 	++ Certificate has key usage 00a0, expects 00a0
Sep 10 12:05:40 	openvpn 	36593 	VERIFY KU OK
Sep 10 12:05:40 	openvpn 	36593 	Validating certificate extended key usage
Sep 10 12:05:40 	openvpn 	36593 	++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Sep 10 12:05:40 	openvpn 	36593 	VERIFY EKU OK
Sep 10 12:05:40 	openvpn 	36593 	VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Miaplacidus, emailAddress=info@airvpn.org
Sep 10 12:05:40 	openvpn 	36593 	Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sep 10 12:05:40 	openvpn 	36593 	Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sep 10 12:05:40 	openvpn 	36593 	Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Sep 10 12:05:40 	openvpn 	36593 	Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sep 10 12:05:40 	openvpn 	36593 	Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Sep 10 12:05:40 	openvpn 	36593 	[Miaplacidus] Peer Connection Initiated with [AF_INET]173.234.159.194:443
Sep 10 12:05:42 	openvpn 	36593 	SENT CONTROL [Miaplacidus]: 'PUSH_REQUEST' (status=1)
Sep 10 12:05:42 	openvpn 	36593 	PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.6.126 255.255.0.0,peer-id 68'
Sep 10 12:05:42 	openvpn 	36593 	Options error: option 'redirect-gateway' cannot be used in this context ([PUSH-OPTIONS])
Sep 10 12:05:42 	openvpn 	36593 	Options error: option 'dhcp-option' cannot be used in this context ([PUSH-OPTIONS])
Sep 10 12:05:42 	openvpn 	36593 	OPTIONS IMPORT: timers and/or timeouts modified
Sep 10 12:05:42 	openvpn 	36593 	OPTIONS IMPORT: LZO parms modified
Sep 10 12:05:42 	openvpn 	36593 	OPTIONS IMPORT: --ifconfig/up options modified
Sep 10 12:05:42 	openvpn 	36593 	OPTIONS IMPORT: route-related options modified
Sep 10 12:05:42 	openvpn 	36593 	OPTIONS IMPORT: peer-id set
Sep 10 12:05:42 	openvpn 	36593 	OPTIONS IMPORT: adjusting link_mtu to 1561
Sep 10 12:05:42 	openvpn 	36593 	TUN/TAP device ovpnc1 exists previously, keep at program end
Sep 10 12:05:42 	openvpn 	36593 	TUN/TAP device /dev/tun1 opened
Sep 10 12:05:42 	openvpn 	36593 	do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Sep 10 12:05:42 	openvpn 	36593 	/sbin/ifconfig ovpnc1 10.4.6.126 10.4.0.1 mtu 1500 netmask 255.255.0.0 up
Sep 10 12:05:42 	openvpn 	36593 	/sbin/route add -net 10.4.0.0 10.4.0.1 255.255.0.0
Sep 10 12:05:42 	openvpn 	36593 	/usr/local/sbin/ovpn-linkup ovpnc1 1500 1561 10.4.6.126 255.255.0.0 init
Sep 10 12:05:42 	openvpn 	36593 	Initialization Sequence Completed
