Not connected, Your IP: 3.134.102.182
aug
Tails Eddie CLI Linux - Connection Refused
I'm having difficulty running Eddie through Tails. Is there a recommended setup for Tails, or running AirVPN through TOR in general?
I'm not sure of the configuration needed to get AirVPN through TOR.
Eddie client version: 2.12.4 / linux_x64, System: Linux, Name: Debian GNU/Linux 8 \n \l, Mono/.Net Framework: v4.0.30319
Reading options from .../AirVPN.xml
Press 'X' to Cancel, 'N' to connect/reconnect to the best available server.
Use -connect to start connection when application starts
Command line arguments (3): login="..." password="..." remember="True"
Operating System: Unix 4.9.0.0 - Linux amnesia 4.9.0-0.bpo.2-amd64 #1 SMP Debian 4.9.13-1~bpo8+1 (2017-02-27) x86_64 GNU/Linux
OpenVPN Driver - Found, /dev/net/tun
OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k  26 Jan 2017, LZO 2.09
SSH - Version: OpenSSH_6.7p1 Debian-5+deb8u3, OpenSSL 1.0.1t  3 May 2016 (/usr/bin/ssh)
SSL - Version: stunnel 5.40 (.../eddie/stunnel)
curl - Version: 7.38.0 (/usr/bin/curl)
Certification Authorities: .../eddie/cacert.pem
Checking login ...
Updating systems & servers data ...
Cannot retrieve systems & servers data. (curl: (7) Failed to connect to xx.xx.xxx.xxx port 80: Connection refused)
Cannot login. (curl: (7) Failed to connect to xx.xx.xxx.xxx port 80: Connection refused)
Ready
