BeepBeep 1 Posted ... Hi everyone I don't understand this problem but it's really frustrating me now! I'll try and summarise: If the connection is idle it's rock solid - 13 hours uptime when I've just testedStandard traffic - I tried browsing the net / playing Youtube videos etc., all fine.Load Tixati - within a minute the connection disconnects and will then be trapped in a connection/disconnection cycle without ever establishing a connection again. I have to reboot the computer to make it connect again, and then it'll do the same thing. I don't know if any of this information will be useful:I'm running Windows 7 64bitI do have network lock on (at least I should do)I have followed the Tixati guide to make sure if the connection drops Tixati does as well Here's my latest logs. Any logs before this set are just the standard checks and updates as the connection was idle. 2017.06.02 22:52:42 - Updating systems & servers data .... 2017.06.02 22:52:43 - Systems & servers data update completed. 2017.06.02 23:02:43 - Updating systems & servers data .... 2017.06.02 23:02:44 - Systems & servers data update completed. 2017.06.02 23:13:44 - Updating systems & servers data .... 2017.06.02 23:13:48 - Systems & servers data update completed. 2017.06.02 23:23:48 - Updating systems & servers data .... 2017.06.02 23:23:53 - Systems & servers data update completed. 2017.06.02 23:33:53 - Updating systems & servers data .... 2017.06.02 23:33:54 - Systems & servers data update completed. 2017.06.02 23:43:54 - Updating systems & servers data .... 2017.06.02 23:43:56 - Systems & servers data update completedI 2017.06.02 23:51:44 - Renewing TLS key. 2017.06.02 23:51:44 - OpenVPN > TLS: tls_process: killed expiring key. 2017.06.02 23:51:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.06.02 23:51:45 - OpenVPN > Validating certificate key usage. 2017.06.02 23:51:45 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.06.02 23:51:45 - OpenVPN > VERIFY KU OK. 2017.06.02 23:51:45 - OpenVPN > Validating certificate extended key usage. 2017.06.02 23:51:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.06.02 23:51:45 - OpenVPN > VERIFY EKU OK. 2017.06.02 23:51:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.06.02 23:51:45 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.02 23:51:45 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.02 23:51:45 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.02 23:51:45 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.02 23:51:45 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.06.02 23:53:57 - Updating systems & servers data .... 2017.06.02 23:53:57 - Systems & servers data update completed. 2017.06.03 00:03:58 - Updating systems & servers data .... 2017.06.03 00:03:58 - Systems & servers data update completed. 2017.06.03 00:13:58 - Updating systems & servers data .... 2017.06.03 00:14:26 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting. 2017.06.03 00:14:26 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting. 2017.06.03 00:14:26 - OpenVPN > Restart pause, 5 second(s)! 2017.06.03 00:14:26 - Disconnecting. 2017.06.03 00:14:26 - Management - Send 'signal SIGTERM'. 2017.06.03 00:14:26 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.06.03 00:14:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 109.202.103.169 MASK 255.255.255.255 192.168.1.1. 2017.06.03 00:14:26 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2017.06.03 00:14:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.06.03 00:14:26 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2017.06.03 00:14:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.06.03 00:14:26 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2017.06.03 00:14:26 - OpenVPN > Closing TUN/TAP interface. 2017.06.03 00:14:34 - Systems & servers data update completed. 2017.06.03 00:14:36 - Management - Send 'signal SIGTERM'. 2017.06.03 00:14:36 - OpenVpn Management > SUCCESS: signal SIGTERM thrown. 2017.06.03 00:14:46 - Management - Send 'signal SIGTERM' Thanks to anyone who writes a reply. I'm not very technical in all honesty so these errors etc., are far out of my league of understanding! Quote Share this post Link to post
OpenSourcerer 1360 Posted ... Which Tixati guide do you refer to? Sent via Tapatalk. Means, I don't have a computer available now. Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
jean claud 45 Posted ... Hi everyone I don't understand this problem but it's really frustrating me now! I'll try and summarise: If the connection is idle it's rock solid - 13 hours uptime when I've just testedStandard traffic - I tried browsing the net / playing Youtube videos etc., all fine.Load Tixati - within a minute the connection disconnects and will then be trapped in a connection/disconnection cycle without ever establishing a connection again. I have to reboot the computer to make it connect again, and then it'll do the same thing. I don't know if any of this information will be useful:I'm running Windows 7 64bitI do have network lock on (at least I should do)I have followed the Tixati guide to make sure if the connection drops Tixati does as well Here's my latest logs. Any logs before this set are just the standard checks and updates as the connection was idle. 2017.06.02 22:52:42 - Updating systems & servers data .... 2017.06.02 22:52:43 - Systems & servers data update completed. 2017.06.02 23:02:43 - Updating systems & servers data .... 2017.06.02 23:02:44 - Systems & servers data update completed. 2017.06.02 23:13:44 - Updating systems & servers data .... 2017.06.02 23:13:48 - Systems & servers data update completed. 2017.06.02 23:23:48 - Updating systems & servers data .... 2017.06.02 23:23:53 - Systems & servers data update completed. 2017.06.02 23:33:53 - Updating systems & servers data .... 2017.06.02 23:33:54 - Systems & servers data update completed. 2017.06.02 23:43:54 - Updating systems & servers data .... 2017.06.02 23:43:56 - Systems & servers data update completedI 2017.06.02 23:51:44 - Renewing TLS key. 2017.06.02 23:51:44 - OpenVPN > TLS: tls_process: killed expiring key. 2017.06.02 23:51:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.06.02 23:51:45 - OpenVPN > Validating certificate key usage. 2017.06.02 23:51:45 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.06.02 23:51:45 - OpenVPN > VERIFY KU OK. 2017.06.02 23:51:45 - OpenVPN > Validating certificate extended key usage. 2017.06.02 23:51:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.06.02 23:51:45 - OpenVPN > VERIFY EKU OK. 2017.06.02 23:51:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.06.02 23:51:45 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.02 23:51:45 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.02 23:51:45 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.02 23:51:45 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.02 23:51:45 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.06.02 23:53:57 - Updating systems & servers data .... 2017.06.02 23:53:57 - Systems & servers data update completed. 2017.06.03 00:03:58 - Updating systems & servers data .... 2017.06.03 00:03:58 - Systems & servers data update completed. 2017.06.03 00:13:58 - Updating systems & servers data .... 2017.06.03 00:14:26 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting. 2017.06.03 00:14:26 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting. 2017.06.03 00:14:26 - OpenVPN > Restart pause, 5 second(s)! 2017.06.03 00:14:26 - Disconnecting. 2017.06.03 00:14:26 - Management - Send 'signal SIGTERM'. 2017.06.03 00:14:26 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.06.03 00:14:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 109.202.103.169 MASK 255.255.255.255 192.168.1.1. 2017.06.03 00:14:26 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2017.06.03 00:14:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.06.03 00:14:26 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2017.06.03 00:14:26 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.06.03 00:14:26 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2017.06.03 00:14:26 - OpenVPN > Closing TUN/TAP interface. 2017.06.03 00:14:34 - Systems & servers data update completed. 2017.06.03 00:14:36 - Management - Send 'signal SIGTERM'. 2017.06.03 00:14:36 - OpenVpn Management > SUCCESS: signal SIGTERM thrown. 2017.06.03 00:14:46 - Management - Send 'signal SIGTERM' Thanks to anyone who writes a reply. I'm not very technical in all honesty so these errors etc., are far out of my league of understanding!Weird, Tixati is working well "out of the box" with no particular settingsDownload , install and do a test under Qbittorrent . If all is Ok your Tixati settings are wrong 1 BeepBeep reacted to this Quote Share this post Link to post
serenacat 83 Posted ... Got a bit curious about Tixati, I use qBittorrent and had occasionally seen it in swarms.Seems to offer some interesting features, such as encrypted chat and torrent sharing between clients, and detailed traffic control, but more things to "go wrong" than basic bittorrent protocol.In the Troubleshooting section of https://tixati.com/ it mentions "In the Settings View under the Event Logging tab, ...", so the logs may show what is upsetting it, and causing it to recycle the vpn connection. The Tixati forums do not seem to have your problem, and would expect other users to have vpns, but you could query there anything in your Tixati logs. I have my doubts about software which is closed source and under a proprietary license that offers extra security and interactive encrypted chat etc. The website screenshots show seeding Alex Jones, and downloading something "Invisible.Empire.A.New.World.Order.D..."You probably should be careful the company you keep in todays USA. 1 OpenSourcerer reacted to this Quote Share this post Link to post
BeepBeep 1 Posted ... Thank you for the posts guys. Treiberschreiber, I can't seem to find the post just now, but it was a guide to close all connections if the VPN is lost so the real IP isn't revealed. *EDIT* - this is the link to the tutorial for changing settings serenacat, I understand your concern, it has been mentioned before but from the research I've done, Tixati seems to be safe enough. I will have a look into qbittorrent though! I think I spoke too soon yesterday with what I posted. Turns out it IS dropping connection when Tixati isn't running., but the difference is it will re-establish connection without being stuck in a loop. Here's some extra logs from todays activity. I've just been leaving it idle all day today. I 2017.06.03 08:55:13 - Eddie client version: 2.12.4 / windows_x64, System: Windows, Name: Microsoft Windows NT 6.1.7601 Service Pack 1, Mono/.Net Framework: v2.0.50727. 2017.06.03 08:55:13 - Reading options from C:\Users\TV\AppData\Local\AirVPN\AirVPN.xml. 2017.06.03 08:55:14 - Data path: C:\Users\TV\AppData\Local\AirVPN. 2017.06.03 08:55:14 - Application path: C:\Z\AirVPN. 2017.06.03 08:55:14 - Executable path: C:\Z\AirVPN\AirVPN.exe. 2017.06.03 08:55:14 - Command line arguments (1): path="home". 2017.06.03 08:55:14 - Operating System: Microsoft Windows NT 6.1.7601 Service Pack 1I 2017.06.03 08:55:39 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.2I 2017.06.03 08:55:39 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09 (C:\Z\AirVPN\openvpn.exe)I 2017.06.03 08:55:39 - SSH - Version: plink 0.67 (C:\Z\AirVPN\plink.exe)I 2017.06.03 08:55:39 - SSL - Version: stunnel 5.40 (C:\Z\AirVPN\stunnel.exe)I 2017.06.03 08:55:39 - curl - Version: 7.34.0 (C:\Z\AirVPN\curl.exe)I 2017.06.03 08:55:39 - Certification Authorities: C:\Z\AirVPN\cacert.pem! 2017.06.03 08:55:43 - Activation of Network Lock - Windows Filtering Platform. 2017.06.03 08:55:43 - Updating systems & servers data ...I 2017.06.03 08:55:43 - Session starting.. 2017.06.03 08:55:43 - IPv6 disabled with packet filtering.. 2017.06.03 08:55:48 - Systems & servers data update completedI 2017.06.03 08:55:49 - Checking authorization ...! 2017.06.03 08:55:49 - Connecting to Orion (Netherlands, Alblasserdam). 2017.06.03 08:55:49 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017. 2017.06.03 08:55:49 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2017.06.03 08:55:49 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.06.03 08:55:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3104. 2017.06.03 08:55:49 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 08:55:49 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 08:55:49 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.238:443. 2017.06.03 08:55:49 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2017.06.03 08:55:49 - OpenVPN > UDP link local: (not bound). 2017.06.03 08:55:49 - OpenVPN > UDP link remote: [AF_INET]213.152.161.238:443. 2017.06.03 08:55:49 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.238:443, sid=c5e09e25 8af9dd91. 2017.06.03 08:55:49 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.06.03 08:55:49 - OpenVPN > Validating certificate key usage. 2017.06.03 08:55:49 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.06.03 08:55:49 - OpenVPN > VERIFY KU OK. 2017.06.03 08:55:49 - OpenVPN > Validating certificate extended key usage. 2017.06.03 08:55:49 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.06.03 08:55:49 - OpenVPN > VERIFY EKU OK. 2017.06.03 08:55:49 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.06.03 08:55:49 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.06.03 08:55:49 - OpenVPN > [Orion] Peer Connection Initiated with [AF_INET]213.152.161.238:443. 2017.06.03 08:55:50 - OpenVPN > SENT CONTROL [Orion]: 'PUSH_REQUEST' (status=1). 2017.06.03 08:55:50 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.18.106 255.255.0.0,peer-id 50,cipher AES-256-GCM'. 2017.06.03 08:55:50 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.06.03 08:55:50 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2017.06.03 08:55:50 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.06.03 08:55:50 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.06.03 08:55:50 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.06.03 08:55:50 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.06.03 08:55:50 - OpenVPN > OPTIONS IMPORT: peer-id set. 2017.06.03 08:55:50 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625. 2017.06.03 08:55:50 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified. 2017.06.03 08:55:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.06.03 08:55:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.06.03 08:55:50 - OpenVPN > interactive service msg_channel=0. 2017.06.03 08:55:50 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=fc:aa:14:0b:e9:58. 2017.06.03 08:55:50 - OpenVPN > open_tun. 2017.06.03 08:55:50 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{D1C1DFE0-AA73-4C72-9E5D-8E5757209C58}.tap. 2017.06.03 08:55:50 - OpenVPN > TAP-Windows Driver Version 9.21. 2017.06.03 08:55:50 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.18.106/255.255.0.0 [sUCCEEDED]. 2017.06.03 08:55:50 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.18.106/255.255.0.0 on interface {D1C1DFE0-AA73-4C72-9E5D-8E5757209C58} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2017.06.03 08:55:50 - OpenVPN > Successful ARP Flush on interface [14] {D1C1DFE0-AA73-4C72-9E5D-8E5757209C58}. 2017.06.03 08:55:50 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0. 2017.06.03 08:55:55 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2017.06.03 08:55:55 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.238 MASK 255.255.255.255 192.168.1.1. 2017.06.03 08:55:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4. 2017.06.03 08:55:55 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.06.03 08:55:55 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.06.03 08:55:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2017.06.03 08:55:55 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.06.03 08:55:55 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.06.03 08:55:55 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2017.06.03 08:55:55 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.06.03 08:55:55 - Starting Management Interface. 2017.06.03 08:55:55 - OpenVPN > Initialization Sequence Completed. 2017.06.03 08:55:55 - DNS leak protection with packet filtering enabled.. 2017.06.03 08:55:55 - Flushing DNSI 2017.06.03 08:56:01 - Checking routeI 2017.06.03 08:56:02 - Checking DNS! 2017.06.03 08:56:03 - Connected.. 2017.06.03 08:56:03 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3104. 2017.06.03 08:56:03 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.06.03 09:05:49 - Updating systems & servers data .... 2017.06.03 09:05:49 - Systems & servers data update completed. 2017.06.03 09:15:50 - Updating systems & servers data .... 2017.06.03 09:15:50 - Systems & servers data update completed. 2017.06.03 09:25:50 - Updating systems & servers data .... 2017.06.03 09:25:51 - Systems & servers data update completed. 2017.06.03 09:31:54 - OpenVPN > TUN/TAP I/O operation aborted, restarting. 2017.06.03 09:31:54 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.238 MASK 255.255.255.255 192.168.1.1W 2017.06.03 09:31:54 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 192.168.1.1. 2017.06.03 09:31:54 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2017.06.03 09:31:54 - OpenVPN > Route deletion fallback to route.exe. 2017.06.03 09:31:54 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2017.06.03 09:31:54 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1W 2017.06.03 09:31:54 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2017.06.03 09:31:54 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2017.06.03 09:31:54 - OpenVPN > Route deletion fallback to route.exe. 2017.06.03 09:31:54 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2017.06.03 09:31:54 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1W 2017.06.03 09:31:54 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2017.06.03 09:31:54 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2017.06.03 09:31:54 - OpenVPN > Route deletion fallback to route.exe. 2017.06.03 09:31:54 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2017.06.03 09:31:54 - OpenVPN > Closing TUN/TAP interface. 2017.06.03 09:31:54 - OpenVPN > SIGHUP[soft,tun-abort] received, process restarting. 2017.06.03 09:31:54 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017. 2017.06.03 09:31:54 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2017.06.03 09:31:54 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.06.03 09:31:54 - OpenVPN > Restart pause, 10 second(s)! 2017.06.03 09:31:54 - Disconnecting. 2017.06.03 09:31:54 - Management - Send 'signal SIGTERM'. 2017.06.03 09:31:54 - OpenVpn Management > SUCCESS: signal SIGTERM thrown. 2017.06.03 09:31:54 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.06.03 09:31:54 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting. 2017.06.03 09:31:54 - Connection terminated.. 2017.06.03 09:31:55 - DNS leak protection with packet filtering disabled.I 2017.06.03 09:37:17 - Checking authorization ...! 2017.06.03 09:37:17 - Connecting to Phaet (Netherlands, Alblasserdam). 2017.06.03 09:37:17 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017. 2017.06.03 09:37:17 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2017.06.03 09:37:17 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.06.03 09:37:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3104. 2017.06.03 09:37:17 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 09:37:17 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 09:37:17 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]109.232.227.148:443. 2017.06.03 09:37:17 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2017.06.03 09:37:17 - OpenVPN > UDP link local: (not bound). 2017.06.03 09:37:17 - OpenVPN > UDP link remote: [AF_INET]109.232.227.148:443. 2017.06.03 09:37:17 - OpenVPN > TLS: Initial packet from [AF_INET]109.232.227.148:443, sid=e9c02797 e8350c26. 2017.06.03 09:37:17 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.06.03 09:37:17 - OpenVPN > Validating certificate key usage. 2017.06.03 09:37:17 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.06.03 09:37:17 - OpenVPN > VERIFY KU OK. 2017.06.03 09:37:17 - OpenVPN > Validating certificate extended key usage. 2017.06.03 09:37:17 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.06.03 09:37:17 - OpenVPN > VERIFY EKU OK. 2017.06.03 09:37:17 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Phaet, emailAddress=info@airvpn.org. 2017.06.03 09:37:17 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.06.03 09:37:17 - OpenVPN > [Phaet] Peer Connection Initiated with [AF_INET]109.232.227.148:443. 2017.06.03 09:37:18 - OpenVPN > SENT CONTROL [Phaet]: 'PUSH_REQUEST' (status=1). 2017.06.03 09:37:18 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.25.6 255.255.0.0,peer-id 90,cipher AES-256-GCM'. 2017.06.03 09:37:18 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.06.03 09:37:18 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2017.06.03 09:37:18 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.06.03 09:37:18 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.06.03 09:37:18 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.06.03 09:37:18 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.06.03 09:37:18 - OpenVPN > OPTIONS IMPORT: peer-id set. 2017.06.03 09:37:18 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625. 2017.06.03 09:37:18 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified. 2017.06.03 09:37:18 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.06.03 09:37:18 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.06.03 09:37:18 - OpenVPN > interactive service msg_channel=0. 2017.06.03 09:37:18 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=fc:aa:14:0b:e9:58. 2017.06.03 09:37:18 - OpenVPN > open_tun. 2017.06.03 09:37:18 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{D1C1DFE0-AA73-4C72-9E5D-8E5757209C58}.tap. 2017.06.03 09:37:18 - OpenVPN > TAP-Windows Driver Version 9.21. 2017.06.03 09:37:18 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.25.6/255.255.0.0 [sUCCEEDED]. 2017.06.03 09:37:18 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.25.6/255.255.0.0 on interface {D1C1DFE0-AA73-4C72-9E5D-8E5757209C58} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2017.06.03 09:37:18 - OpenVPN > Successful ARP Flush on interface [14] {D1C1DFE0-AA73-4C72-9E5D-8E5757209C58}. 2017.06.03 09:37:18 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0. 2017.06.03 09:37:23 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2017.06.03 09:37:23 - OpenVPN > C:\Windows\system32\route.exe ADD 109.232.227.148 MASK 255.255.255.255 192.168.1.1. 2017.06.03 09:37:23 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4. 2017.06.03 09:37:23 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.06.03 09:37:23 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.06.03 09:37:23 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2017.06.03 09:37:23 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.06.03 09:37:23 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.06.03 09:37:23 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2017.06.03 09:37:23 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.06.03 09:37:23 - Starting Management Interface. 2017.06.03 09:37:23 - OpenVPN > Initialization Sequence Completed. 2017.06.03 09:37:23 - DNS leak protection with packet filtering enabled.. 2017.06.03 09:37:23 - Flushing DNSI 2017.06.03 09:37:29 - Checking routeI 2017.06.03 09:37:30 - Checking DNS! 2017.06.03 09:37:30 - Connected.. 2017.06.03 09:37:30 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3104. 2017.06.03 09:37:30 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.06.03 09:38:03 - Updating systems & servers data .... 2017.06.03 09:38:04 - Systems & servers data update completed. 2017.06.03 09:48:04 - Updating systems & servers data .... 2017.06.03 09:48:05 - Systems & servers data update completed. 2017.06.03 09:58:05 - Updating systems & servers data .... 2017.06.03 09:58:06 - Systems & servers data update completed. 2017.06.03 10:07:35 - OpenVPN > TUN/TAP I/O operation aborted, restarting. 2017.06.03 10:07:35 - OpenVPN > C:\Windows\system32\route.exe DELETE 109.232.227.148 MASK 255.255.255.255 192.168.1.1W 2017.06.03 10:07:35 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 192.168.1.1. 2017.06.03 10:07:35 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2017.06.03 10:07:35 - OpenVPN > Route deletion fallback to route.exe. 2017.06.03 10:07:35 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2017.06.03 10:07:35 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1W 2017.06.03 10:07:35 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2017.06.03 10:07:35 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2017.06.03 10:07:35 - OpenVPN > Route deletion fallback to route.exe. 2017.06.03 10:07:35 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2017.06.03 10:07:35 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1W 2017.06.03 10:07:35 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2017.06.03 10:07:35 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2017.06.03 10:07:35 - OpenVPN > Route deletion fallback to route.exe. 2017.06.03 10:07:35 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2017.06.03 10:07:35 - OpenVPN > Closing TUN/TAP interface. 2017.06.03 10:07:35 - OpenVPN > SIGHUP[soft,tun-abort] received, process restarting. 2017.06.03 10:07:35 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017. 2017.06.03 10:07:35 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2017.06.03 10:07:35 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.06.03 10:07:35 - OpenVPN > Restart pause, 10 second(s)! 2017.06.03 10:07:35 - Disconnecting. 2017.06.03 10:07:35 - Management - Send 'signal SIGTERM'. 2017.06.03 10:07:35 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.06.03 10:07:35 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting. 2017.06.03 10:07:35 - Connection terminated.. 2017.06.03 10:07:35 - DNS leak protection with packet filtering disabled.I 2017.06.03 10:07:39 - Checking authorization ...W 2017.06.03 10:07:39 - Authorization check failed, continue anyway (curl: (7) Failed to connect to 52.48.66.85 port 80: Host unreachable)! 2017.06.03 10:07:39 - Connecting to Chara (Netherlands, Alblasserdam). 2017.06.03 10:07:39 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017. 2017.06.03 10:07:39 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2017.06.03 10:07:39 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.06.03 10:07:39 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3104. 2017.06.03 10:07:39 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 10:07:39 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 10:07:39 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]109.232.227.132:443. 2017.06.03 10:07:39 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2017.06.03 10:07:39 - OpenVPN > UDP link local: (not bound). 2017.06.03 10:07:39 - OpenVPN > UDP link remote: [AF_INET]109.232.227.132:443. 2017.06.03 10:08:42 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting. 2017.06.03 10:08:42 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.06.03 10:08:42 - OpenVPN > TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity). 2017.06.03 10:08:42 - OpenVPN > TLS Error: TLS handshake failed. 2017.06.03 10:08:42 - OpenVPN > Converting soft SIGUSR1 received during exit notification to SIGTERM. 2017.06.03 10:08:42 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting! 2017.06.03 10:08:42 - Disconnecting. 2017.06.03 10:08:42 - Connection terminated.I 2017.06.03 10:08:45 - Checking authorization ...! 2017.06.03 10:08:46 - Connecting to Salm (Netherlands, Alblasserdam). 2017.06.03 10:08:46 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017. 2017.06.03 10:08:46 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2017.06.03 10:08:46 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.06.03 10:08:46 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3104. 2017.06.03 10:08:46 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 10:08:46 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 10:08:46 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.19:443. 2017.06.03 10:08:46 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2017.06.03 10:08:46 - OpenVPN > UDP link local: (not bound). 2017.06.03 10:08:46 - OpenVPN > UDP link remote: [AF_INET]213.152.161.19:443. 2017.06.03 10:08:46 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.19:443, sid=0120f647 ec556c70. 2017.06.03 10:08:46 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.06.03 10:08:46 - OpenVPN > Validating certificate key usage. 2017.06.03 10:08:46 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.06.03 10:08:46 - OpenVPN > VERIFY KU OK. 2017.06.03 10:08:46 - OpenVPN > Validating certificate extended key usage. 2017.06.03 10:08:46 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.06.03 10:08:46 - OpenVPN > VERIFY EKU OK. 2017.06.03 10:08:46 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.06.03 10:08:46 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.06.03 10:08:46 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.19:443. 2017.06.03 10:08:47 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.06.03 10:08:47 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.47.163 255.255.0.0'. 2017.06.03 10:08:47 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.06.03 10:08:47 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2017.06.03 10:08:47 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.06.03 10:08:47 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.06.03 10:08:47 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.06.03 10:08:47 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.06.03 10:08:47 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.03 10:08:47 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 10:08:47 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.03 10:08:47 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 10:08:47 - OpenVPN > interactive service msg_channel=0. 2017.06.03 10:08:47 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=fc:aa:14:0b:e9:58. 2017.06.03 10:08:47 - OpenVPN > open_tun. 2017.06.03 10:08:47 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{D1C1DFE0-AA73-4C72-9E5D-8E5757209C58}.tap. 2017.06.03 10:08:47 - OpenVPN > TAP-Windows Driver Version 9.21. 2017.06.03 10:08:47 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.47.163/255.255.0.0 [sUCCEEDED]. 2017.06.03 10:08:47 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.47.163/255.255.0.0 on interface {D1C1DFE0-AA73-4C72-9E5D-8E5757209C58} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2017.06.03 10:08:47 - OpenVPN > Successful ARP Flush on interface [14] {D1C1DFE0-AA73-4C72-9E5D-8E5757209C58}. 2017.06.03 10:08:47 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0. 2017.06.03 10:08:52 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2017.06.03 10:08:52 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.19 MASK 255.255.255.255 192.168.1.1. 2017.06.03 10:08:52 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4. 2017.06.03 10:08:52 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.06.03 10:08:52 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.06.03 10:08:52 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2017.06.03 10:08:52 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.06.03 10:08:52 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.06.03 10:08:52 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2017.06.03 10:08:52 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.06.03 10:08:52 - Starting Management Interface. 2017.06.03 10:08:52 - OpenVPN > Initialization Sequence Completed. 2017.06.03 10:08:52 - DNS leak protection with packet filtering enabled.. 2017.06.03 10:08:52 - Flushing DNSI 2017.06.03 10:08:58 - Checking routeI 2017.06.03 10:08:59 - Checking DNS! 2017.06.03 10:08:59 - Connected.. 2017.06.03 10:08:59 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3104. 2017.06.03 10:08:59 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.06.03 10:09:03 - Updating systems & servers data .... 2017.06.03 10:09:04 - Systems & servers data update completed. 2017.06.03 10:20:04 - Updating systems & servers data .... 2017.06.03 10:20:05 - Systems & servers data update completed. 2017.06.03 10:30:05 - Updating systems & servers data .... 2017.06.03 10:30:06 - Systems & servers data update completed. 2017.06.03 10:39:04 - OpenVPN > TUN/TAP I/O operation aborted, restarting. 2017.06.03 10:39:04 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.19 MASK 255.255.255.255 192.168.1.1. 2017.06.03 10:39:04 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2017.06.03 10:39:04 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1W 2017.06.03 10:39:04 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2017.06.03 10:39:04 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2017.06.03 10:39:04 - OpenVPN > Route deletion fallback to route.exe. 2017.06.03 10:39:04 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2017.06.03 10:39:04 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1W 2017.06.03 10:39:04 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2017.06.03 10:39:04 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2017.06.03 10:39:04 - OpenVPN > Route deletion fallback to route.exe. 2017.06.03 10:39:04 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2017.06.03 10:39:04 - OpenVPN > Closing TUN/TAP interface. 2017.06.03 10:39:04 - OpenVPN > SIGHUP[soft,tun-abort] received, process restarting. 2017.06.03 10:39:04 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017. 2017.06.03 10:39:04 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2017.06.03 10:39:04 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.06.03 10:39:04 - OpenVPN > Restart pause, 10 second(s)! 2017.06.03 10:39:04 - Disconnecting. 2017.06.03 10:39:04 - Management - Send 'signal SIGTERM'. 2017.06.03 10:39:04 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.06.03 10:39:04 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting. 2017.06.03 10:39:04 - Connection terminated.. 2017.06.03 10:39:15 - DNS leak protection with packet filtering disabled.I 2017.06.03 10:39:25 - Checking authorization ...! 2017.06.03 10:39:25 - Connecting to Sheliak (Netherlands, Alblasserdam). 2017.06.03 10:39:25 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017. 2017.06.03 10:39:25 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2017.06.03 10:39:25 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.06.03 10:39:25 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3104. 2017.06.03 10:39:25 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 10:39:25 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 10:39:25 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.162.113:443. 2017.06.03 10:39:25 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2017.06.03 10:39:25 - OpenVPN > UDP link local: (not bound). 2017.06.03 10:39:25 - OpenVPN > UDP link remote: [AF_INET]213.152.162.113:443. 2017.06.03 10:39:25 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.113:443, sid=3f6edb94 ca31f183. 2017.06.03 10:39:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.06.03 10:39:25 - OpenVPN > Validating certificate key usage. 2017.06.03 10:39:25 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.06.03 10:39:25 - OpenVPN > VERIFY KU OK. 2017.06.03 10:39:25 - OpenVPN > Validating certificate extended key usage. 2017.06.03 10:39:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.06.03 10:39:25 - OpenVPN > VERIFY EKU OK. 2017.06.03 10:39:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.06.03 10:39:25 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.06.03 10:39:25 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.113:443. 2017.06.03 10:39:27 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1). 2017.06.03 10:39:27 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.51.114 255.255.0.0'. 2017.06.03 10:39:27 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.06.03 10:39:27 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2017.06.03 10:39:27 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.06.03 10:39:27 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.06.03 10:39:27 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.06.03 10:39:27 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.06.03 10:39:27 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.03 10:39:27 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 10:39:27 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.03 10:39:27 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 10:39:27 - OpenVPN > interactive service msg_channel=0. 2017.06.03 10:39:27 - OpenVPN > ROUTE_GATEWAY 192.168.1.1/255.255.255.0 I=11 HWADDR=fc:aa:14:0b:e9:58. 2017.06.03 10:39:27 - OpenVPN > open_tun. 2017.06.03 10:39:27 - OpenVPN > TAP-WIN32 device [Local Area Connection 2] opened: \\.\Global\{D1C1DFE0-AA73-4C72-9E5D-8E5757209C58}.tap. 2017.06.03 10:39:27 - OpenVPN > TAP-Windows Driver Version 9.21. 2017.06.03 10:39:27 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.51.114/255.255.0.0 [sUCCEEDED]. 2017.06.03 10:39:27 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.51.114/255.255.0.0 on interface {D1C1DFE0-AA73-4C72-9E5D-8E5757209C58} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2017.06.03 10:39:27 - OpenVPN > Successful ARP Flush on interface [14] {D1C1DFE0-AA73-4C72-9E5D-8E5757209C58}. 2017.06.03 10:39:27 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0. 2017.06.03 10:39:32 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2017.06.03 10:39:32 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.162.113 MASK 255.255.255.255 192.168.1.1. 2017.06.03 10:39:32 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4. 2017.06.03 10:39:32 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.06.03 10:39:32 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.06.03 10:39:32 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2017.06.03 10:39:32 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.06.03 10:39:32 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.06.03 10:39:32 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4. 2017.06.03 10:39:32 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.06.03 10:39:32 - Starting Management Interface. 2017.06.03 10:39:32 - OpenVPN > Initialization Sequence Completed. 2017.06.03 10:39:32 - DNS leak protection with packet filtering enabled.. 2017.06.03 10:39:32 - Flushing DNSI 2017.06.03 10:39:38 - Checking routeI 2017.06.03 10:39:39 - Checking DNS! 2017.06.03 10:39:40 - Connected.. 2017.06.03 10:39:40 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3104. 2017.06.03 10:39:40 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.06.03 10:40:16 - Updating systems & servers data .... 2017.06.03 10:40:17 - Systems & servers data update completed. 2017.06.03 10:51:17 - Updating systems & servers data .... 2017.06.03 10:51:18 - Systems & servers data update completed. 2017.06.03 11:01:19 - Updating systems & servers data .... 2017.06.03 11:01:20 - Systems & servers data update completed. 2017.06.03 11:11:20 - Updating systems & servers data .... 2017.06.03 11:11:21 - Systems & servers data update completed. 2017.06.03 11:21:21 - Updating systems & servers data .... 2017.06.03 11:21:22 - Systems & servers data update completed. 2017.06.03 11:31:22 - Updating systems & servers data .... 2017.06.03 11:31:23 - Systems & servers data update completed. 2017.06.03 11:39:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.06.03 11:39:25 - OpenVPN > Validating certificate key usage. 2017.06.03 11:39:25 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.06.03 11:39:25 - OpenVPN > VERIFY KU OK. 2017.06.03 11:39:25 - OpenVPN > Validating certificate extended key usage. 2017.06.03 11:39:25 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.06.03 11:39:25 - OpenVPN > VERIFY EKU OK. 2017.06.03 11:39:25 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.06.03 11:39:25 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.03 11:39:25 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 11:39:25 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.03 11:39:25 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 11:39:25 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.06.03 11:41:23 - Updating systems & servers data .... 2017.06.03 11:41:24 - Systems & servers data update completed. 2017.06.03 11:51:24 - Updating systems & servers data .... 2017.06.03 11:51:25 - Systems & servers data update completed. 2017.06.03 12:01:26 - Updating systems & servers data .... 2017.06.03 12:01:27 - Systems & servers data update completed. 2017.06.03 12:11:27 - Updating systems & servers data .... 2017.06.03 12:11:28 - Systems & servers data update completed. 2017.06.03 12:21:28 - Updating systems & servers data .... 2017.06.03 12:21:29 - Systems & servers data update completed. 2017.06.03 12:31:29 - Updating systems & servers data .... 2017.06.03 12:31:30 - Systems & servers data update completed. 2017.06.03 12:39:26 - OpenVPN > TLS: soft reset sec=-1 bytes=812428/-1 pkts=2412/0. 2017.06.03 12:39:26 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.06.03 12:39:26 - OpenVPN > Validating certificate key usage. 2017.06.03 12:39:26 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.06.03 12:39:26 - OpenVPN > VERIFY KU OK. 2017.06.03 12:39:26 - OpenVPN > Validating certificate extended key usage. 2017.06.03 12:39:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.06.03 12:39:26 - OpenVPN > VERIFY EKU OK. 2017.06.03 12:39:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.06.03 12:39:26 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.03 12:39:26 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 12:39:26 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.03 12:39:26 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 12:39:26 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.06.03 12:41:30 - Updating systems & servers data .... 2017.06.03 12:41:31 - Systems & servers data update completed. 2017.06.03 12:51:32 - Updating systems & servers data .... 2017.06.03 12:51:33 - Systems & servers data update completed. 2017.06.03 13:01:33 - Updating systems & servers data .... 2017.06.03 13:01:34 - Systems & servers data update completed. 2017.06.03 13:11:34 - Updating systems & servers data .... 2017.06.03 13:11:35 - Systems & servers data update completed. 2017.06.03 13:21:35 - Updating systems & servers data .... 2017.06.03 13:21:36 - Systems & servers data update completed. 2017.06.03 13:31:36 - Updating systems & servers data .... 2017.06.03 13:31:37 - Systems & servers data update completed. 2017.06.03 13:39:26 - OpenVPN > TLS: soft reset sec=0 bytes=840905/-1 pkts=2751/0. 2017.06.03 13:39:26 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.06.03 13:39:26 - OpenVPN > Validating certificate key usage. 2017.06.03 13:39:26 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.06.03 13:39:26 - OpenVPN > VERIFY KU OK. 2017.06.03 13:39:26 - OpenVPN > Validating certificate extended key usage. 2017.06.03 13:39:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.06.03 13:39:26 - OpenVPN > VERIFY EKU OK. 2017.06.03 13:39:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.06.03 13:39:27 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.03 13:39:27 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 13:39:27 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.03 13:39:27 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 13:39:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.06.03 13:41:37 - Updating systems & servers data .... 2017.06.03 13:41:38 - Systems & servers data update completed. 2017.06.03 13:51:38 - Updating systems & servers data .... 2017.06.03 13:51:39 - Systems & servers data update completed. 2017.06.03 14:01:40 - Updating systems & servers data .... 2017.06.03 14:01:41 - Systems & servers data update completed. 2017.06.03 14:11:41 - Updating systems & servers data .... 2017.06.03 14:11:42 - Systems & servers data update completed. 2017.06.03 14:21:42 - Updating systems & servers data .... 2017.06.03 14:21:43 - Systems & servers data update completed. 2017.06.03 14:31:43 - Updating systems & servers data .... 2017.06.03 14:31:44 - Systems & servers data update completedI 2017.06.03 14:39:26 - Renewing TLS key. 2017.06.03 14:39:26 - OpenVPN > TLS: tls_process: killed expiring key. 2017.06.03 14:39:27 - OpenVPN > TLS: soft reset sec=0 bytes=816611/-1 pkts=2492/0. 2017.06.03 14:39:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.06.03 14:39:27 - OpenVPN > Validating certificate key usage. 2017.06.03 14:39:27 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.06.03 14:39:27 - OpenVPN > VERIFY KU OK. 2017.06.03 14:39:27 - OpenVPN > Validating certificate extended key usage. 2017.06.03 14:39:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.06.03 14:39:27 - OpenVPN > VERIFY EKU OK. 2017.06.03 14:39:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.06.03 14:39:27 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.03 14:39:27 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 14:39:27 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.03 14:39:27 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 14:39:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.06.03 14:41:44 - Updating systems & servers data .... 2017.06.03 14:41:45 - Systems & servers data update completed. 2017.06.03 14:51:45 - Updating systems & servers data .... 2017.06.03 14:51:46 - Systems & servers data update completed. 2017.06.03 15:01:46 - Updating systems & servers data .... 2017.06.03 15:01:48 - Systems & servers data update completed. 2017.06.03 15:11:48 - Updating systems & servers data .... 2017.06.03 15:11:49 - Systems & servers data update completed. 2017.06.03 15:21:49 - Updating systems & servers data .... 2017.06.03 15:21:54 - Systems & servers data update completed. 2017.06.03 15:31:54 - Updating systems & servers data .... 2017.06.03 15:31:55 - Systems & servers data update completed. 2017.06.03 15:39:28 - OpenVPN > TLS: soft reset sec=-1 bytes=801918/-1 pkts=2465/0. 2017.06.03 15:39:28 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.06.03 15:39:28 - OpenVPN > Validating certificate key usage. 2017.06.03 15:39:28 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.06.03 15:39:28 - OpenVPN > VERIFY KU OK. 2017.06.03 15:39:28 - OpenVPN > Validating certificate extended key usage. 2017.06.03 15:39:28 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.06.03 15:39:28 - OpenVPN > VERIFY EKU OK. 2017.06.03 15:39:28 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org. 2017.06.03 15:39:28 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.03 15:39:28 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 15:39:28 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key. 2017.06.03 15:39:28 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.06.03 15:39:28 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.06.03 15:41:55 - Updating systems & servers data .... 2017.06.03 15:41:56 - Systems & servers data update completed. 2017.06.03 15:51:57 - Updating systems & servers data .... 2017.06.03 15:51:58 - Systems & servers data update completed. 2017.06.03 16:01:58 - Updating systems & servers data .... 2017.06.03 16:01:59 - Systems & servers data update completed I'll try and find that guide I originally mentioned. Quote Share this post Link to post
BeepBeep 1 Posted ... HI guys, I've got a bit of an update I have to thank jean claud actually! I've been testing with qbittorrent tonight and have had a rock solid connection for several hours now! As you said, it must be something that's changed with Tixati, maybe with an update that has caused problems with it. It's a shame, I'll miss that software and it's bright colours, but I don't have a lot of time to check and change things and QBit seems to work virtually out of the box with (from what others have said on here), just needing to change the network adapter to TAP and it's then all secure. Result! Thanks again! Quote Share this post Link to post
jean claud 45 Posted ... HI guys, I've got a bit of an update I have to thank jean claud actually! I've been testing with qbittorrent tonight and have had a rock solid connection for several hours now! As you said, it must be something that's changed with Tixati, maybe with an update that has caused problems with it. It's a shame, I'll miss that software and it's bright colours, but I don't have a lot of time to check and change things and QBit seems to work virtually out of the box with (from what others have said on here), just needing to change the network adapter to TAP and it's then all secure. Result! Thanks again! My pleasure , mate Quote Share this post Link to post
