Not connected, Your IP: 18.223.134.29
Every time I connect to a server, 2-3 minutes later I lose the speed completely, unable to connect to anything, and another 2 minutes later, I get disconnected.
Does anyone have any ideas?
Log:
! 2017.05.22 10:23:58 - Connected.
. 2017.05.22 10:23:58 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2017.05.22 10:23:59 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2017.05.22 10:24:47 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #48169 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
. 2017.05.22 10:28:55 - Above log line repeated 1545 times more
. 2017.05.22 10:28:55 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2017.05.22 10:28:55 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2017.05.22 10:28:55 - OpenVPN > Restart pause, 5 second(s)
! 2017.05.22 10:28:55 - Disconnecting
. 2017.05.22 10:28:55 - Management - Send 'signal SIGTERM'
. 2017.05.22 10:28:55 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2017.05.22 10:28:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.108 MASK 255.255.255.255 192.168.1.254
. 2017.05.22 10:28:55 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]
. 2017.05.22 10:28:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.05.22 10:28:55 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2017.05.22 10:28:55 - OpenVPN > Closing TUN/TAP interface
. 2017.05.22 10:28:55 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting
. 2017.05.22 10:28:55 - Connection terminated.
. 2017.05.22 10:28:55 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic)
. 2017.05.22 10:28:55 - DNS leak protection with packet filtering disabled.
I 2017.05.22 10:28:58 - Checking authorization ...
! 2017.05.22 10:28:58 - Connecting to Caph (Netherlands, Alblasserdam)
This only happens if I do any intense downloading, but if I'm just browsing or doing anything light, it seems to be holding up fine.
Update: It only happens when the downloading is through uTorrent. Tested it through Steam and the connection was stable.
TCP/443 will work around it.
Are you using some antivirus? What's your router name and firmware (version)?
I've had the exact same problem with uTorrent. I've seen people mention the 443/TCP deal but not sure what to do to apply this work around.
Are you using the Eddie-Client? Click on "AirVPN" in the upper left corner, go to Preferences - Protocols, unselect "Automatic", mark the line with "TCP 443" and save.
Seems to have fixed it! Thank you all. As for the router name- it's the UK's BT Hub. I wasn't running any anti-viruses at the time.
