Guest Posted ... Dear readers, I have recently purchased a three month subscription to AirVPN and I've been using it over the past four or so days.I am having constant issues with regards to extreme jitter, occasional connection drops, and large amounts of packet loss.I have in the corner of my second monitor a (rainmeter) network meter (see first attachment).It measures my up- and downstream as well as my latency to 62.40.106.135, a perfSONAR address meant for testing latency. It tests every second. Symptoms:- Latency jitter ranges from ~20 to ~20000 milliseconds.- Occasional disconnects (latency stuck on 30000 and everything times out)- Some packet loss (often coincides with latency spikes)- Bandwidth trouble (often coincides with latency spikes and disconnects, remains for a minute or so after reconnecting) What I've tried:- Switching servers: I've tried 2 in Alblasserdam, 1 in Manchester and 1 in Germany (unsure where exactly)- Using specific protocols (top three, UDP 443, TCP 443 and UDP 80)- Increased send and receive buffer sizes to 256 and even 512 KB Background and specifications:- I am located in the Netherlands and my ISP is Ziggo (previously UPC, they merged). My subscription with them is good for 40 mb/s down and 4 mb/s up. Despite the price they ask for this I have had no trouble with their service whatsoever.- See second attachment for specifications of my computer.- See third attachment for specifications and settings of my network.- See fourth attachment for my Eddie settings. I have left out the parts I have not edited myself and are most unlikely to contain relevant settings.- See inside spoiler below for log. I have skimmed through it myself a few times over the past few days but I haven't been able to find anything. . 2017.04.27 05:29:37 - Systems & servers data update completed. 2017.04.27 05:29:56 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #2276173 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 05:35:37 - Above log line repeated 105 times more. 2017.04.27 05:35:37 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 05:35:37 - OpenVPN > Validating certificate key usage. 2017.04.27 05:35:37 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 05:35:37 - OpenVPN > VERIFY KU OK. 2017.04.27 05:35:37 - OpenVPN > Validating certificate extended key usage. 2017.04.27 05:35:37 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 05:35:37 - OpenVPN > VERIFY EKU OK. 2017.04.27 05:35:37 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 05:35:37 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 05:35:37 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 05:35:37 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 05:36:03 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #2507723 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 05:39:38 - Above log line repeated 68 times more. 2017.04.27 05:39:38 - Updating systems & servers data .... 2017.04.27 05:39:38 - Systems & servers data update completed. 2017.04.27 05:39:44 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #127983 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 05:49:38 - Above log line repeated 176 times more. 2017.04.27 05:49:38 - Updating systems & servers data .... 2017.04.27 05:49:39 - Systems & servers data update completed. 2017.04.27 05:49:41 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #566035 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 05:59:39 - Above log line repeated 159 times more. 2017.04.27 05:59:39 - Updating systems & servers data .... 2017.04.27 05:59:42 - Systems & servers data update completed. 2017.04.27 05:59:51 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #970788 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 06:09:42 - Above log line repeated 99 times more. 2017.04.27 06:09:42 - Updating systems & servers data .... 2017.04.27 06:09:43 - Systems & servers data update completed. 2017.04.27 06:09:56 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1393141 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 06:19:43 - Above log line repeated 173 times more. 2017.04.27 06:19:43 - Updating systems & servers data .... 2017.04.27 06:19:43 - Systems & servers data update completed. 2017.04.27 06:20:07 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1839699 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 06:29:43 - Above log line repeated 133 times more. 2017.04.27 06:29:43 - Updating systems & servers data .... 2017.04.27 06:29:44 - Systems & servers data update completed. 2017.04.27 06:29:55 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #2262473 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 06:35:37 - Above log line repeated 47 times more. 2017.04.27 06:35:37 - OpenVPN > TLS: soft reset sec=0 bytes=3591490463/-1 pkts=3835628/0. 2017.04.27 06:35:37 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 06:35:37 - OpenVPN > Validating certificate key usage. 2017.04.27 06:35:37 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 06:35:37 - OpenVPN > VERIFY KU OK. 2017.04.27 06:35:37 - OpenVPN > Validating certificate extended key usage. 2017.04.27 06:35:37 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 06:35:37 - OpenVPN > VERIFY EKU OK. 2017.04.27 06:35:37 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 06:35:37 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 06:35:37 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 06:35:37 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 06:35:38 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #2416729 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 06:39:45 - Above log line repeated 43 times more. 2017.04.27 06:39:45 - Updating systems & servers data .... 2017.04.27 06:39:45 - Systems & servers data update completed. 2017.04.27 06:40:11 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #55454 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 06:49:45 - Above log line repeated 94 times more. 2017.04.27 06:49:45 - Updating systems & servers data .... 2017.04.27 06:49:46 - Systems & servers data update completed. 2017.04.27 06:49:54 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #212178 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 06:59:46 - Above log line repeated 47 times more. 2017.04.27 06:59:46 - Updating systems & servers data .... 2017.04.27 06:59:48 - Systems & servers data update completed. 2017.04.27 07:00:34 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #409020 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 07:09:48 - Above log line repeated 82 times more. 2017.04.27 07:09:48 - Updating systems & servers data .... 2017.04.27 07:09:50 - Systems & servers data update completed. 2017.04.27 07:10:09 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #565707 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 07:19:50 - Above log line repeated 65 times more. 2017.04.27 07:19:51 - Updating systems & servers data .... 2017.04.27 07:19:53 - Systems & servers data update completed. 2017.04.27 07:20:10 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #767381 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 07:29:53 - Above log line repeated 121 times more. 2017.04.27 07:29:53 - Updating systems & servers data .... 2017.04.27 07:29:57 - Systems & servers data update completed. 2017.04.27 07:30:00 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1031568 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 07:35:37 - Above log line repeated 89 times more. 2017.04.27 07:35:37 - OpenVPN > TLS: soft reset sec=0 bytes=2050828597/-1 pkts=2553401/0. 2017.04.27 07:35:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 07:35:38 - OpenVPN > Validating certificate key usage. 2017.04.27 07:35:38 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 07:35:38 - OpenVPN > VERIFY KU OK. 2017.04.27 07:35:38 - OpenVPN > Validating certificate extended key usage. 2017.04.27 07:35:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 07:35:38 - OpenVPN > VERIFY EKU OK. 2017.04.27 07:35:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 07:35:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 07:35:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 07:35:39 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 07:36:01 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1268561 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 07:39:57 - Above log line repeated 73 times more. 2017.04.27 07:39:57 - Updating systems & servers data .... 2017.04.27 07:39:58 - Systems & servers data update completed. 2017.04.27 07:40:11 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #136395 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 07:49:58 - Above log line repeated 172 times more. 2017.04.27 07:49:58 - Updating systems & servers data .... 2017.04.27 07:49:59 - Systems & servers data update completed. 2017.04.27 07:51:07 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #423569 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 08:00:59 - Above log line repeated 79 times more. 2017.04.27 08:00:59 - Updating systems & servers data .... 2017.04.27 08:01:00 - Systems & servers data update completed. 2017.04.27 08:01:28 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #632108 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 08:11:00 - Above log line repeated 95 times more. 2017.04.27 08:11:00 - Updating systems & servers data .... 2017.04.27 08:11:01 - Systems & servers data update completed. 2017.04.27 08:11:10 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #833303 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 08:21:01 - Above log line repeated 82 times more. 2017.04.27 08:21:01 - Updating systems & servers data .... 2017.04.27 08:21:04 - Systems & servers data update completed. 2017.04.27 08:21:13 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1043880 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 08:31:04 - Above log line repeated 152 times more. 2017.04.27 08:31:04 - Updating systems & servers data .... 2017.04.27 08:31:06 - Systems & servers data update completed. 2017.04.27 08:31:29 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1225094 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 08:35:37 - Above log line repeated 55 times moreI 2017.04.27 08:35:37 - Renewing TLS key. 2017.04.27 08:35:37 - OpenVPN > TLS: tls_process: killed expiring key. 2017.04.27 08:35:38 - OpenVPN > TLS: soft reset sec=0 bytes=2083452371/-1 pkts=2632045/0. 2017.04.27 08:35:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 08:35:38 - OpenVPN > Validating certificate key usage. 2017.04.27 08:35:38 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 08:35:38 - OpenVPN > VERIFY KU OK. 2017.04.27 08:35:38 - OpenVPN > Validating certificate extended key usage. 2017.04.27 08:35:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 08:35:38 - OpenVPN > VERIFY EKU OK. 2017.04.27 08:35:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 08:35:39 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 08:35:39 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 08:35:39 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 08:35:44 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1291027 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 08:41:06 - Above log line repeated 31 times more. 2017.04.27 08:41:06 - Updating systems & servers data .... 2017.04.27 08:41:07 - Systems & servers data update completed. 2017.04.27 08:41:26 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #77449 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 08:51:07 - Above log line repeated 85 times more. 2017.04.27 08:51:07 - Updating systems & servers data .... 2017.04.27 08:51:08 - Systems & servers data update completed. 2017.04.27 08:51:20 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #241065 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 09:01:08 - Above log line repeated 108 times more. 2017.04.27 09:01:08 - Updating systems & servers data .... 2017.04.27 09:01:11 - Systems & servers data update completed. 2017.04.27 09:01:11 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #400156 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 09:11:11 - Above log line repeated 101 times more. 2017.04.27 09:11:11 - Updating systems & servers data .... 2017.04.27 09:11:12 - Systems & servers data update completed. 2017.04.27 09:11:24 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #570869 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 09:21:12 - Above log line repeated 68 times more. 2017.04.27 09:21:12 - Updating systems & servers data .... 2017.04.27 09:21:13 - Systems & servers data update completed. 2017.04.27 09:21:46 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #737520 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 09:31:13 - Above log line repeated 167 times more. 2017.04.27 09:31:13 - Updating systems & servers data .... 2017.04.27 09:31:13 - Systems & servers data update completed. 2017.04.27 09:31:46 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #924825 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 09:35:38 - Above log line repeated 86 times moreI 2017.04.27 09:35:38 - Renewing TLS key. 2017.04.27 09:35:38 - OpenVPN > TLS: tls_process: killed expiring key. 2017.04.27 09:35:39 - OpenVPN > TLS: soft reset sec=0 bytes=1822007608/-1 pkts=2185273/0. 2017.04.27 09:35:39 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 09:35:39 - OpenVPN > Validating certificate key usage. 2017.04.27 09:35:39 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 09:35:39 - OpenVPN > VERIFY KU OK. 2017.04.27 09:35:39 - OpenVPN > Validating certificate extended key usage. 2017.04.27 09:35:39 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 09:35:39 - OpenVPN > VERIFY EKU OK. 2017.04.27 09:35:39 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 09:35:39 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 09:35:39 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 09:35:39 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 09:36:07 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1003521 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 09:41:13 - Above log line repeated 84 times more. 2017.04.27 09:41:13 - Updating systems & servers data .... 2017.04.27 09:41:14 - Systems & servers data update completed. 2017.04.27 09:41:34 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #77111 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 09:52:14 - Above log line repeated 101 times more. 2017.04.27 09:52:14 - Updating systems & servers data .... 2017.04.27 09:52:15 - Systems & servers data update completed. 2017.04.27 09:52:45 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #276736 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 10:02:15 - Above log line repeated 85 times more. 2017.04.27 10:02:15 - Updating systems & servers data .... 2017.04.27 10:02:16 - Systems & servers data update completed. 2017.04.27 10:02:45 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #441301 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 10:13:16 - Above log line repeated 82 times more. 2017.04.27 10:13:16 - Updating systems & servers data .... 2017.04.27 10:13:17 - Systems & servers data update completed. 2017.04.27 10:13:19 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #621012 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 10:23:17 - Above log line repeated 61 times more. 2017.04.27 10:23:17 - Updating systems & servers data .... 2017.04.27 10:23:18 - Systems & servers data update completed. 2017.04.27 10:24:19 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #806524 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 10:33:18 - Above log line repeated 96 times more. 2017.04.27 10:33:18 - Updating systems & servers data .... 2017.04.27 10:33:19 - Systems & servers data update completed. 2017.04.27 10:33:31 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #963534 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 10:35:38 - Above log line repeated 15 times more. 2017.04.27 10:35:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 10:35:38 - OpenVPN > Validating certificate key usage. 2017.04.27 10:35:38 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 10:35:38 - OpenVPN > VERIFY KU OK. 2017.04.27 10:35:38 - OpenVPN > Validating certificate extended key usage. 2017.04.27 10:35:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 10:35:38 - OpenVPN > VERIFY EKU OK. 2017.04.27 10:35:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 10:35:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 10:35:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 10:35:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 10:36:08 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1005198 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 10:43:19 - Above log line repeated 65 times more. 2017.04.27 10:43:19 - Updating systems & servers data .... 2017.04.27 10:43:20 - Systems & servers data update completed. 2017.04.27 10:44:08 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #130275 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 10:53:20 - Above log line repeated 95 times more. 2017.04.27 10:53:20 - Updating systems & servers data .... 2017.04.27 10:53:21 - Systems & servers data update completed. 2017.04.27 10:53:30 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #275681 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 11:04:21 - Above log line repeated 45 times more. 2017.04.27 11:04:21 - Updating systems & servers data .... 2017.04.27 11:04:21 - Systems & servers data update completed. 2017.04.27 11:04:27 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #381983 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 11:14:21 - Above log line repeated 47 times more. 2017.04.27 11:14:21 - Updating systems & servers data .... 2017.04.27 11:14:22 - Systems & servers data update completed. 2017.04.27 11:15:53 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #453609 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 11:24:22 - Above log line repeated 97 times more. 2017.04.27 11:24:22 - Updating systems & servers data .... 2017.04.27 11:24:23 - Systems & servers data update completed. 2017.04.27 11:24:53 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #575893 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 11:34:23 - Above log line repeated 77 times more. 2017.04.27 11:34:23 - Updating systems & servers data .... 2017.04.27 11:34:24 - Systems & servers data update completed. 2017.04.27 11:34:58 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #730610 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 11:35:38 - Above log line repeated 20 times more. 2017.04.27 11:35:38 - OpenVPN > TLS: soft reset sec=0 bytes=1313761859/-1 pkts=1693408/0. 2017.04.27 11:35:39 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 11:35:39 - OpenVPN > Validating certificate key usage. 2017.04.27 11:35:39 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 11:35:39 - OpenVPN > VERIFY KU OK. 2017.04.27 11:35:39 - OpenVPN > Validating certificate extended key usage. 2017.04.27 11:35:39 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 11:35:39 - OpenVPN > VERIFY EKU OK. 2017.04.27 11:35:39 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 11:35:39 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 11:35:39 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 11:35:39 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 11:36:08 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #747644 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 11:44:24 - Above log line repeated 76 times more. 2017.04.27 11:44:24 - Updating systems & servers data .... 2017.04.27 11:44:25 - Systems & servers data update completed. 2017.04.27 11:45:40 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #108965 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 11:54:25 - Above log line repeated 24 times more. 2017.04.27 11:54:25 - Updating systems & servers data .... 2017.04.27 11:54:26 - Systems & servers data update completed. 2017.04.27 11:55:14 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #196542 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 12:04:26 - Above log line repeated 53 times more. 2017.04.27 12:04:26 - Updating systems & servers data .... 2017.04.27 12:04:27 - Systems & servers data update completed. 2017.04.27 12:06:04 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #320944 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 12:15:27 - Above log line repeated 65 times more. 2017.04.27 12:15:27 - Updating systems & servers data .... 2017.04.27 12:15:27 - Systems & servers data update completed. 2017.04.27 12:15:51 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #445585 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 12:25:28 - Above log line repeated 52 times more. 2017.04.27 12:25:28 - Updating systems & servers data .... 2017.04.27 12:25:28 - Systems & servers data update completed. 2017.04.27 12:26:01 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #569672 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 12:35:28 - Above log line repeated 91 times more. 2017.04.27 12:35:28 - Updating systems & servers data .... 2017.04.27 12:35:30 - Systems & servers data update completedI 2017.04.27 12:35:38 - Renewing TLS key. 2017.04.27 12:35:38 - OpenVPN > TLS: tls_process: killed expiring key. 2017.04.27 12:35:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 12:35:38 - OpenVPN > Validating certificate key usage. 2017.04.27 12:35:38 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 12:35:38 - OpenVPN > VERIFY KU OK. 2017.04.27 12:35:38 - OpenVPN > Validating certificate extended key usage. 2017.04.27 12:35:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 12:35:38 - OpenVPN > VERIFY EKU OK. 2017.04.27 12:35:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 12:35:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 12:35:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 12:35:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 12:35:50 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #699939 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 12:45:30 - Above log line repeated 73 times more. 2017.04.27 12:45:30 - Updating systems & servers data .... 2017.04.27 12:45:32 - Systems & servers data update completed. 2017.04.27 12:46:57 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #140145 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 12:55:32 - Above log line repeated 47 times more. 2017.04.27 12:55:32 - Updating systems & servers data .... 2017.04.27 12:55:33 - Systems & servers data update completed. 2017.04.27 12:55:49 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #276234 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 13:05:33 - Above log line repeated 84 times more. 2017.04.27 13:05:33 - Updating systems & servers data .... 2017.04.27 13:05:34 - Systems & servers data update completed. 2017.04.27 13:05:37 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #452499 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 13:15:34 - Above log line repeated 102 times more. 2017.04.27 13:15:34 - Updating systems & servers data .... 2017.04.27 13:15:35 - Systems & servers data update completed. 2017.04.27 13:16:36 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #617079 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 13:26:35 - Above log line repeated 77 times more. 2017.04.27 13:26:35 - Updating systems & servers data .... 2017.04.27 13:26:36 - Systems & servers data update completed. 2017.04.27 13:26:54 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #737474 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 13:35:38 - Above log line repeated 71 times more. 2017.04.27 13:35:38 - OpenVPN > TLS: soft reset sec=0 bytes=1388300030/-1 pkts=1931236/0. 2017.04.27 13:35:38 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 13:35:38 - OpenVPN > Validating certificate key usage. 2017.04.27 13:35:38 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 13:35:38 - OpenVPN > VERIFY KU OK. 2017.04.27 13:35:38 - OpenVPN > Validating certificate extended key usage. 2017.04.27 13:35:38 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 13:35:38 - OpenVPN > VERIFY EKU OK. 2017.04.27 13:35:38 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 13:35:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 13:35:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 13:35:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 13:36:14 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #858577 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 13:36:36 - Updating systems & servers data .... 2017.04.27 13:36:36 - Systems & servers data update completed. 2017.04.27 13:37:24 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #2113 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 13:46:36 - Above log line repeated 49 times more. 2017.04.27 13:46:36 - Updating systems & servers data .... 2017.04.27 13:46:37 - Systems & servers data update completed. 2017.04.27 13:47:10 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #86468 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 13:56:37 - Above log line repeated 46 times more. 2017.04.27 13:56:37 - Updating systems & servers data .... 2017.04.27 13:56:38 - Systems & servers data update completed. 2017.04.27 13:56:50 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #175017 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 14:07:38 - Above log line repeated 56 times more. 2017.04.27 14:07:38 - Updating systems & servers data .... 2017.04.27 14:07:39 - Systems & servers data update completed. 2017.04.27 14:07:47 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #277842 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 14:17:40 - Above log line repeated 80 times more. 2017.04.27 14:17:40 - Updating systems & servers data .... 2017.04.27 14:17:40 - Systems & servers data update completed. 2017.04.27 14:18:03 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #412127 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 14:27:40 - Above log line repeated 72 times more. 2017.04.27 14:27:40 - Updating systems & servers data .... 2017.04.27 14:27:41 - Systems & servers data update completed. 2017.04.27 14:28:00 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #539818 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 14:35:37 - Above log line repeated 68 times more. 2017.04.27 14:35:37 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 14:35:37 - OpenVPN > Validating certificate key usage. 2017.04.27 14:35:37 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 14:35:37 - OpenVPN > VERIFY KU OK. 2017.04.27 14:35:37 - OpenVPN > Validating certificate extended key usage. 2017.04.27 14:35:37 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 14:35:37 - OpenVPN > VERIFY EKU OK. 2017.04.27 14:35:37 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 14:35:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 14:35:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 14:35:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 14:36:34 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #629465 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 14:38:41 - Above log line repeated 15 times more. 2017.04.27 14:38:41 - Updating systems & servers data .... 2017.04.27 14:38:42 - Systems & servers data update completed. 2017.04.27 14:39:02 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #24906 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 14:48:42 - Above log line repeated 213 times more. 2017.04.27 14:48:42 - Updating systems & servers data .... 2017.04.27 14:48:45 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #105302 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 14:48:45 - Above log line repeated 16 times more. 2017.04.27 14:48:45 - Systems & servers data update completed. 2017.04.27 14:49:34 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #108534 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 14:58:45 - Above log line repeated 609 times more. 2017.04.27 14:58:45 - Updating systems & servers data .... 2017.04.27 14:58:46 - Systems & servers data update completed. 2017.04.27 14:58:53 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #154350 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 15:08:46 - Above log line repeated 249 times more. 2017.04.27 15:08:46 - Updating systems & servers data .... 2017.04.27 15:08:50 - Systems & servers data update completed. 2017.04.27 15:09:24 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #351513 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 15:18:50 - Above log line repeated 334 times more. 2017.04.27 15:18:50 - Updating systems & servers data .... 2017.04.27 15:18:52 - Systems & servers data update completed. 2017.04.27 15:19:07 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #519983 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 15:28:52 - Above log line repeated 248 times more. 2017.04.27 15:28:52 - Updating systems & servers data .... 2017.04.27 15:28:52 - Systems & servers data update completed. 2017.04.27 15:28:55 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #707203 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 15:35:37 - Above log line repeated 95 times moreI 2017.04.27 15:35:37 - Renewing TLS key. 2017.04.27 15:35:37 - OpenVPN > TLS: tls_process: killed expiring key. 2017.04.27 15:35:37 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 15:35:37 - OpenVPN > Validating certificate key usage. 2017.04.27 15:35:37 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 15:35:37 - OpenVPN > VERIFY KU OK. 2017.04.27 15:35:37 - OpenVPN > Validating certificate extended key usage. 2017.04.27 15:35:37 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 15:35:37 - OpenVPN > VERIFY EKU OK. 2017.04.27 15:35:37 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 15:35:38 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 15:35:38 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 15:35:38 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 15:35:51 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #832304 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 15:38:52 - Above log line repeated 55 times more. 2017.04.27 15:38:52 - Updating systems & servers data .... 2017.04.27 15:38:55 - Systems & servers data update completed. 2017.04.27 15:39:36 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #65620 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 15:48:55 - Above log line repeated 152 times more. 2017.04.27 15:48:55 - Updating systems & servers data .... 2017.04.27 15:48:56 - Systems & servers data update completed. 2017.04.27 15:49:16 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #269927 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 15:58:56 - Above log line repeated 217 times more. 2017.04.27 15:58:56 - Updating systems & servers data .... 2017.04.27 15:58:57 - Systems & servers data update completed. 2017.04.27 15:59:09 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #530662 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 16:08:57 - Above log line repeated 155 times more. 2017.04.27 16:08:57 - Updating systems & servers data .... 2017.04.27 16:08:58 - Systems & servers data update completed. 2017.04.27 16:09:17 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #800405 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 16:18:59 - Above log line repeated 253 times more. 2017.04.27 16:18:59 - Updating systems & servers data .... 2017.04.27 16:19:01 - Systems & servers data update completed. 2017.04.27 16:19:09 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1060662 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 16:29:01 - Above log line repeated 260 times more. 2017.04.27 16:29:01 - Updating systems & servers data .... 2017.04.27 16:29:07 - Systems & servers data update completed. 2017.04.27 16:29:13 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1307533 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 16:35:37 - Above log line repeated 179 times moreI 2017.04.27 16:35:37 - Renewing TLS key. 2017.04.27 16:35:37 - OpenVPN > TLS: tls_process: killed expiring key. 2017.04.27 16:35:37 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 16:35:37 - OpenVPN > Validating certificate key usage. 2017.04.27 16:35:37 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 16:35:37 - OpenVPN > VERIFY KU OK. 2017.04.27 16:35:37 - OpenVPN > Validating certificate extended key usage. 2017.04.27 16:35:37 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 16:35:37 - OpenVPN > VERIFY EKU OK. 2017.04.27 16:35:37 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 16:35:37 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 16:35:37 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 16:35:37 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 16:35:38 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1509697 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 16:39:07 - Above log line repeated 269 times more. 2017.04.27 16:39:07 - Updating systems & servers data .... 2017.04.27 16:39:10 - Systems & servers data update completed. 2017.04.27 16:39:22 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #81204 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 16:49:10 - Above log line repeated 303 times more. 2017.04.27 16:49:10 - Updating systems & servers data .... 2017.04.27 16:49:11 - Systems & servers data update completed. 2017.04.27 16:49:36 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #379800 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 16:59:12 - Above log line repeated 680 times more. 2017.04.27 16:59:12 - Updating systems & servers data .... 2017.04.27 16:59:13 - Systems & servers data update completed. 2017.04.27 16:59:31 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #658154 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 17:09:13 - Above log line repeated 235 times more. 2017.04.27 17:09:13 - Updating systems & servers data .... 2017.04.27 17:09:19 - Systems & servers data update completed. 2017.04.27 17:09:35 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #899270 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 17:17:42 - Above log line repeated 99 times more. 2017.04.27 17:17:43 - OpenVPN > write to TUN/TAP : The system cannot find the file specified. (code=2). 2017.04.27 17:17:43 - OpenVPN > write to TUN/TAP : The system cannot find the file specified. (code=2). 2017.04.27 17:17:43 - Above log line repeated 70 times more. 2017.04.27 17:17:43 - OpenVPN > TUN/TAP I/O operation aborted, restarting. 2017.04.27 17:17:43 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.238 MASK 255.255.255.255 192.168.178.1. 2017.04.27 17:17:43 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2017.04.27 17:17:43 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1W 2017.04.27 17:17:43 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2017.04.27 17:17:43 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2017.04.27 17:17:43 - OpenVPN > Route deletion fallback to route.exe. 2017.04.27 17:17:43 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2017.04.27 17:17:43 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1W 2017.04.27 17:17:43 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2017.04.27 17:17:43 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2017.04.27 17:17:43 - OpenVPN > Route deletion fallback to route.exe. 2017.04.27 17:17:43 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2017.04.27 17:17:43 - OpenVPN > Closing TUN/TAP interface. 2017.04.27 17:17:43 - OpenVPN > SIGHUP[soft,tun-abort] received, process restarting. 2017.04.27 17:17:43 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017. 2017.04.27 17:17:43 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2017.04.27 17:17:43 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.04.27 17:17:43 - OpenVPN > Restart pause, 10 second(s)! 2017.04.27 17:17:43 - Disconnecting. 2017.04.27 17:17:43 - Management - Send 'signal SIGTERM'. 2017.04.27 17:17:43 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.04.27 17:17:43 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting. 2017.04.27 17:17:43 - Connection terminated.. 2017.04.27 17:17:44 - DNS of a network adapter restored to original settings (TP-LINK Wireless USB Adapter, to automatic). 2017.04.27 17:17:44 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic). 2017.04.27 17:17:44 - DNS leak protection with packet filtering disabled.I 2017.04.27 17:17:55 - Checking authorization ...! 2017.04.27 17:17:59 - Connecting to Orion (Netherlands, Alblasserdam). 2017.04.27 17:17:59 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017. 2017.04.27 17:17:59 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2017.04.27 17:17:59 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.04.27 17:17:59 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.04.27 17:17:59 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.27 17:17:59 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.27 17:17:59 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.238:443. 2017.04.27 17:17:59 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2017.04.27 17:17:59 - OpenVPN > UDP link local: (not bound). 2017.04.27 17:17:59 - OpenVPN > UDP link remote: [AF_INET]213.152.161.238:443. 2017.04.27 17:17:59 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.238:443, sid=e50e5614 1046685e. 2017.04.27 17:17:59 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 17:17:59 - OpenVPN > Validating certificate key usage. 2017.04.27 17:17:59 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 17:17:59 - OpenVPN > VERIFY KU OK. 2017.04.27 17:17:59 - OpenVPN > Validating certificate extended key usage. 2017.04.27 17:17:59 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 17:17:59 - OpenVPN > VERIFY EKU OK. 2017.04.27 17:17:59 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 17:18:00 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 17:18:00 - OpenVPN > [Orion] Peer Connection Initiated with [AF_INET]213.152.161.238:443. 2017.04.27 17:18:01 - OpenVPN > SENT CONTROL [Orion]: 'PUSH_REQUEST' (status=1). 2017.04.27 17:18:01 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.20.93 255.255.0.0,peer-id 35,cipher AES-256-GCM'. 2017.04.27 17:18:01 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.04.27 17:18:01 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2017.04.27 17:18:01 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.04.27 17:18:01 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.04.27 17:18:01 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.04.27 17:18:01 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.04.27 17:18:01 - OpenVPN > OPTIONS IMPORT: peer-id set. 2017.04.27 17:18:01 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625. 2017.04.27 17:18:01 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified. 2017.04.27 17:18:01 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 17:18:01 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 17:18:01 - OpenVPN > interactive service msg_channel=0. 2017.04.27 17:18:01 - OpenVPN > ROUTE_GATEWAY 192.168.178.1/255.255.255.0 I=20 HWADDR=98:de:d0:05:ef:b4. 2017.04.27 17:18:01 - OpenVPN > open_tun. 2017.04.27 17:18:01 - OpenVPN > TAP-WIN32 device [Local Area Connection 4] opened: \\.\Global\{DB8AF0B6-7E73-488B-906D-B6B7E05129C0}.tap. 2017.04.27 17:18:01 - OpenVPN > TAP-Windows Driver Version 9.9. 2017.04.27 17:18:01 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.20.93/255.255.0.0 [sUCCEEDED]. 2017.04.27 17:18:01 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.20.93/255.255.0.0 on interface {DB8AF0B6-7E73-488B-906D-B6B7E05129C0} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2017.04.27 17:18:01 - OpenVPN > Successful ARP Flush on interface [24] {DB8AF0B6-7E73-488B-906D-B6B7E05129C0}. 2017.04.27 17:18:01 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0. 2017.04.27 17:18:06 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2017.04.27 17:18:06 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.238 MASK 255.255.255.255 192.168.178.1. 2017.04.27 17:18:06 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2017.04.27 17:18:06 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.04.27 17:18:06 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.04.27 17:18:06 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4. 2017.04.27 17:18:06 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.04.27 17:18:06 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.04.27 17:18:06 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4. 2017.04.27 17:18:06 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.04.27 17:18:06 - Starting Management Interface. 2017.04.27 17:18:06 - OpenVPN > Initialization Sequence Completed. 2017.04.27 17:18:06 - DNS leak protection with packet filtering enabled.. 2017.04.27 17:18:06 - DNS of a network adapter forced (TP-LINK Wireless USB Adapter, from automatic (213.46.228.196,62.179.104.196) to 10.4.0.1). 2017.04.27 17:18:06 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1). 2017.04.27 17:18:06 - Flushing DNS. 2017.04.27 17:18:06 - Shell of 'cmd.exe','/c ipconfig /flushdns' done sync in 421 ms, Output: Windows IP Configuration. 2017.04.27 17:18:06 - Successfully flushed the DNS Resolver Cache.. 2017.04.27 17:18:12 - Shell of 'cmd.exe','/c ipconfig /registerdns' done sync in 6038 ms, Output: Windows IP Configuration. 2017.04.27 17:18:12 - Registration of the DNS resource records for all adapters of this computer has been initiated. Any errors will be reported in the Event Viewer in 15 minutes.I 2017.04.27 17:18:13 - Checking routeI 2017.04.27 17:18:13 - Checking DNS! 2017.04.27 17:18:14 - Connected.. 2017.04.27 17:18:14 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.04.27 17:18:14 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2017.04.27 17:19:19 - Updating systems & servers data .... 2017.04.27 17:19:20 - Systems & servers data update completed. 2017.04.27 17:19:30 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #8822 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 17:29:20 - Above log line repeated 662 times more. 2017.04.27 17:29:20 - Updating systems & servers data .... 2017.04.27 17:29:22 - Systems & servers data update completed. 2017.04.27 17:29:37 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #254700 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 17:39:22 - Above log line repeated 153 times more. 2017.04.27 17:39:22 - Updating systems & servers data .... 2017.04.27 17:39:23 - Systems & servers data update completed. 2017.04.27 17:39:37 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #428449 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 17:49:41 - Above log line repeated 85 times more. 2017.04.27 17:49:41 - Updating systems & servers data .... 2017.04.27 17:49:43 - Systems & servers data update completed. 2017.04.27 17:49:48 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #664254 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 17:59:43 - Above log line repeated 248 times more. 2017.04.27 17:59:43 - Updating systems & servers data .... 2017.04.27 17:59:43 - Systems & servers data update completed. 2017.04.27 18:05:00 - OpenVPN > write to TUN/TAP : The system cannot find the file specified. (code=2). 2017.04.27 18:05:01 - Above log line repeated 80 times more. 2017.04.27 18:05:01 - OpenVPN > TUN/TAP I/O operation aborted, restarting. 2017.04.27 18:05:01 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.238 MASK 255.255.255.255 192.168.178.1. 2017.04.27 18:05:01 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2017.04.27 18:05:01 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1W 2017.04.27 18:05:01 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2017.04.27 18:05:01 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2017.04.27 18:05:01 - OpenVPN > Route deletion fallback to route.exe. 2017.04.27 18:05:01 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2017.04.27 18:05:01 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1W 2017.04.27 18:05:01 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1. 2017.04.27 18:05:01 - OpenVPN > Route deletion via IPAPI failed [adaptive]. 2017.04.27 18:05:01 - OpenVPN > Route deletion fallback to route.exe. 2017.04.27 18:05:01 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\Windows;C:\Windows\System32\Wbem. 2017.04.27 18:05:01 - OpenVPN > Closing TUN/TAP interface. 2017.04.27 18:05:01 - OpenVPN > SIGHUP[soft,tun-abort] received, process restarting. 2017.04.27 18:05:01 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017. 2017.04.27 18:05:01 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2017.04.27 18:05:01 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.04.27 18:05:01 - OpenVPN > Restart pause, 10 second(s)! 2017.04.27 18:05:01 - Disconnecting. 2017.04.27 18:05:01 - Management - Send 'signal SIGTERM'. 2017.04.27 18:05:01 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.04.27 18:05:01 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting. 2017.04.27 18:05:01 - Connection terminated.. 2017.04.27 18:05:01 - DNS of a network adapter restored to original settings (TP-LINK Wireless USB Adapter, to automatic). 2017.04.27 18:05:01 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic). 2017.04.27 18:05:01 - DNS leak protection with packet filtering disabled.I 2017.04.27 18:05:12 - Checking authorization ...! 2017.04.27 18:05:12 - Connecting to Orion (Netherlands, Alblasserdam). 2017.04.27 18:05:12 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017. 2017.04.27 18:05:12 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2017.04.27 18:05:12 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.04.27 18:05:12 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.04.27 18:05:12 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.27 18:05:12 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.27 18:05:12 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.238:443. 2017.04.27 18:05:12 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2017.04.27 18:05:12 - OpenVPN > UDP link local: (not bound). 2017.04.27 18:05:12 - OpenVPN > UDP link remote: [AF_INET]213.152.161.238:443. 2017.04.27 18:05:12 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.238:443, sid=dc7d0595 6fa020ae. 2017.04.27 18:05:13 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 18:05:13 - OpenVPN > Validating certificate key usage. 2017.04.27 18:05:13 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 18:05:13 - OpenVPN > VERIFY KU OK. 2017.04.27 18:05:13 - OpenVPN > Validating certificate extended key usage. 2017.04.27 18:05:13 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 18:05:13 - OpenVPN > VERIFY EKU OK. 2017.04.27 18:05:13 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 18:05:13 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 18:05:13 - OpenVPN > [Orion] Peer Connection Initiated with [AF_INET]213.152.161.238:443. 2017.04.27 18:05:14 - OpenVPN > SENT CONTROL [Orion]: 'PUSH_REQUEST' (status=1). 2017.04.27 18:05:14 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.20.93 255.255.0.0,peer-id 78,cipher AES-256-GCM'. 2017.04.27 18:05:14 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.04.27 18:05:14 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2017.04.27 18:05:14 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.04.27 18:05:14 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.04.27 18:05:14 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.04.27 18:05:14 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.04.27 18:05:14 - OpenVPN > OPTIONS IMPORT: peer-id set. 2017.04.27 18:05:14 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625. 2017.04.27 18:05:14 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified. 2017.04.27 18:05:14 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 18:05:14 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 18:05:14 - OpenVPN > interactive service msg_channel=0. 2017.04.27 18:05:14 - OpenVPN > ROUTE_GATEWAY 192.168.178.1/255.255.255.0 I=20 HWADDR=98:de:d0:05:ef:b4. 2017.04.27 18:05:14 - OpenVPN > open_tun. 2017.04.27 18:05:14 - OpenVPN > TAP-WIN32 device [Local Area Connection 4] opened: \\.\Global\{DB8AF0B6-7E73-488B-906D-B6B7E05129C0}.tap. 2017.04.27 18:05:14 - OpenVPN > TAP-Windows Driver Version 9.9. 2017.04.27 18:05:14 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.20.93/255.255.0.0 [sUCCEEDED]. 2017.04.27 18:05:14 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.20.93/255.255.0.0 on interface {DB8AF0B6-7E73-488B-906D-B6B7E05129C0} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2017.04.27 18:05:14 - OpenVPN > Successful ARP Flush on interface [24] {DB8AF0B6-7E73-488B-906D-B6B7E05129C0}. 2017.04.27 18:05:14 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0. 2017.04.27 18:05:19 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2017.04.27 18:05:19 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.238 MASK 255.255.255.255 192.168.178.1. 2017.04.27 18:05:19 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2017.04.27 18:05:19 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.04.27 18:05:19 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.04.27 18:05:19 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4. 2017.04.27 18:05:19 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.04.27 18:05:19 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.04.27 18:05:19 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4. 2017.04.27 18:05:19 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.04.27 18:05:19 - Starting Management Interface. 2017.04.27 18:05:19 - OpenVPN > Initialization Sequence Completed. 2017.04.27 18:05:19 - DNS leak protection with packet filtering enabled.. 2017.04.27 18:05:19 - DNS of a network adapter forced (TP-LINK Wireless USB Adapter, from automatic (213.46.228.196,62.179.104.196) to 10.4.0.1). 2017.04.27 18:05:19 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1). 2017.04.27 18:05:19 - Flushing DNS. 2017.04.27 18:05:19 - Shell of 'cmd.exe','/c ipconfig /flushdns' done sync in 437 ms, Output: Windows IP Configuration. 2017.04.27 18:05:19 - Successfully flushed the DNS Resolver Cache.. 2017.04.27 18:05:25 - Shell of 'cmd.exe','/c ipconfig /registerdns' done sync in 6021 ms, Output: Windows IP Configuration. 2017.04.27 18:05:25 - Registration of the DNS resource records for all adapters of this computer has been initiated. Any errors will be reported in the Event Viewer in 15 minutes.I 2017.04.27 18:05:25 - Checking routeI 2017.04.27 18:05:26 - Checking DNS! 2017.04.27 18:05:26 - Connected.. 2017.04.27 18:05:26 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2017.04.27 18:05:26 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.04.27 18:05:46 - Updating systems & servers data .... 2017.04.27 18:05:47 - Systems & servers data update completed. 2017.04.27 18:07:49 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #8482 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 18:15:48 - Above log line repeated 422 times more. 2017.04.27 18:15:48 - Updating systems & servers data .... 2017.04.27 18:15:50 - Systems & servers data update completed. 2017.04.27 18:15:53 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #320681 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 18:25:58 - Above log line repeated 52 times more. 2017.04.27 18:25:58 - Updating systems & servers data .... 2017.04.27 18:26:00 - Systems & servers data update completed. 2017.04.27 18:26:20 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #466910 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 18:36:00 - Above log line repeated 67 times more. 2017.04.27 18:36:00 - Updating systems & servers data .... 2017.04.27 18:36:02 - Systems & servers data update completed. 2017.04.27 18:36:07 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #646832 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 18:46:10 - Above log line repeated 185 times more. 2017.04.27 18:46:10 - Updating systems & servers data .... 2017.04.27 18:46:11 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #859648 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 18:46:11 - Above log line repeated 1 times more. 2017.04.27 18:46:11 - Systems & servers data update completed. 2017.04.27 18:46:51 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #880040 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 18:56:12 - Above log line repeated 792 times more. 2017.04.27 18:56:12 - Updating systems & servers data .... 2017.04.27 18:56:12 - Systems & servers data update completed. 2017.04.27 18:56:31 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1206881 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 19:05:13 - Above log line repeated 775 times more. 2017.04.27 19:05:13 - OpenVPN > TLS: soft reset sec=0 bytes=2102133928/-1 pkts=2734150/0. 2017.04.27 19:05:15 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 19:05:15 - OpenVPN > Validating certificate key usage. 2017.04.27 19:05:15 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 19:05:15 - OpenVPN > VERIFY KU OK. 2017.04.27 19:05:15 - OpenVPN > Validating certificate extended key usage. 2017.04.27 19:05:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 19:05:15 - OpenVPN > VERIFY EKU OK. 2017.04.27 19:05:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 19:05:15 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 19:05:15 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 19:05:15 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 19:05:43 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1527376 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 19:06:13 - Above log line repeated 46 times more. 2017.04.27 19:06:13 - Updating systems & servers data .... 2017.04.27 19:06:13 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1540168 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 19:06:14 - Systems & servers data update completed. 2017.04.27 19:06:22 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #4934 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 19:16:32 - Above log line repeated 899 times more. 2017.04.27 19:16:32 - Updating systems & servers data .... 2017.04.27 19:16:33 - Systems & servers data update completed. 2017.04.27 19:16:42 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #409896 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 19:26:33 - Above log line repeated 489 times more. 2017.04.27 19:26:33 - Updating systems & servers data .... 2017.04.27 19:26:35 - Systems & servers data update completed. 2017.04.27 19:26:53 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #770551 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 19:36:35 - Above log line repeated 436 times more. 2017.04.27 19:36:35 - Updating systems & servers data .... 2017.04.27 19:36:35 - Systems & servers data update completed. 2017.04.27 19:36:57 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1235479 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 19:46:35 - Above log line repeated 139 times more. 2017.04.27 19:46:35 - Updating systems & servers data .... 2017.04.27 19:46:36 - Systems & servers data update completed. 2017.04.27 19:46:54 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1424456 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 19:56:36 - Above log line repeated 115 times more. 2017.04.27 19:56:36 - Updating systems & servers data .... 2017.04.27 19:56:37 - Systems & servers data update completed. 2017.04.27 19:56:44 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1621608 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 20:05:13 - Above log line repeated 39 times moreI 2017.04.27 20:05:13 - Renewing TLS key. 2017.04.27 20:05:13 - OpenVPN > TLS: tls_process: killed expiring key. 2017.04.27 20:05:15 - OpenVPN > TLS: soft reset sec=0 bytes=2461165245/-1 pkts=3072589/0. 2017.04.27 20:05:15 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 20:05:15 - OpenVPN > Validating certificate key usage. 2017.04.27 20:05:15 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 20:05:15 - OpenVPN > VERIFY KU OK. 2017.04.27 20:05:15 - OpenVPN > Validating certificate extended key usage. 2017.04.27 20:05:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 20:05:15 - OpenVPN > VERIFY EKU OK. 2017.04.27 20:05:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 20:05:15 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 20:05:15 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 20:05:15 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 20:05:46 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1784356 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 20:07:37 - Above log line repeated 31 times more. 2017.04.27 20:07:37 - Updating systems & servers data .... 2017.04.27 20:07:39 - Systems & servers data update completed. 2017.04.27 20:08:05 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #38438 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 20:17:39 - Above log line repeated 87 times more. 2017.04.27 20:17:39 - Updating systems & servers data .... 2017.04.27 20:17:40 - Systems & servers data update completed. 2017.04.27 20:17:46 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #256556 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 20:27:40 - Above log line repeated 94 times more. 2017.04.27 20:27:40 - Updating systems & servers data .... 2017.04.27 20:27:41 - Systems & servers data update completed. 2017.04.27 20:28:07 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #496612 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 20:38:41 - Above log line repeated 131 times more. 2017.04.27 20:38:41 - Updating systems & servers data .... 2017.04.27 20:38:44 - Systems & servers data update completed. 2017.04.27 20:38:47 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #713707 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 20:48:44 - Above log line repeated 151 times more. 2017.04.27 20:48:44 - Updating systems & servers data .... 2017.04.27 20:48:45 - Systems & servers data update completed. 2017.04.27 20:49:27 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #963631 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 20:58:45 - Above log line repeated 177 times more. 2017.04.27 20:58:45 - Updating systems & servers data .... 2017.04.27 20:58:47 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1156281 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 20:58:47 - Above log line repeated 1 times more. 2017.04.27 20:58:47 - Systems & servers data update completed. 2017.04.27 20:58:57 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1160703 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 21:05:15 - Above log line repeated 80 times more. 2017.04.27 21:05:15 - OpenVPN > TLS: soft reset sec=0 bytes=1974258904/-1 pkts=2595305/0. 2017.04.27 21:05:15 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 21:05:15 - OpenVPN > Validating certificate key usage. 2017.04.27 21:05:15 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 21:05:15 - OpenVPN > VERIFY KU OK. 2017.04.27 21:05:15 - OpenVPN > Validating certificate extended key usage. 2017.04.27 21:05:15 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 21:05:15 - OpenVPN > VERIFY EKU OK. 2017.04.27 21:05:15 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 21:05:16 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 21:05:16 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 21:05:16 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 21:05:28 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1344923 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 21:08:47 - Above log line repeated 39 times more. 2017.04.27 21:08:47 - Updating systems & servers data .... 2017.04.27 21:08:49 - Systems & servers data update completed. 2017.04.27 21:08:52 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #90502 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 21:18:49 - Above log line repeated 203 times more. 2017.04.27 21:18:49 - Updating systems & servers data .... 2017.04.27 21:18:51 - Systems & servers data update completed. 2017.04.27 21:19:08 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #422275 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 21:28:51 - Above log line repeated 375 times more. 2017.04.27 21:28:51 - Updating systems & servers data .... 2017.04.27 21:28:54 - Systems & servers data update completed. 2017.04.27 21:28:59 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #733500 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 21:38:54 - Above log line repeated 391 times more. 2017.04.27 21:38:54 - Updating systems & servers data .... 2017.04.27 21:38:57 - Systems & servers data update completed. 2017.04.27 21:39:00 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #995814 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 21:48:57 - Above log line repeated 400 times more. 2017.04.27 21:48:57 - Updating systems & servers data .... 2017.04.27 21:48:58 - Systems & servers data update completed. 2017.04.27 21:49:00 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1215242 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 21:58:58 - Above log line repeated 679 times more. 2017.04.27 21:58:58 - Updating systems & servers data .... 2017.04.27 21:59:01 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1498726 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 21:59:05 - Above log line repeated 3 times more. 2017.04.27 21:59:05 - Systems & servers data update completed. 2017.04.27 21:59:11 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1503297 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 22:05:15 - Above log line repeated 599 times moreI 2017.04.27 22:05:15 - Renewing TLS key. 2017.04.27 22:05:15 - OpenVPN > TLS: tls_process: killed expiring key. 2017.04.27 22:05:16 - OpenVPN > TLS: soft reset sec=0 bytes=2387745470/-1 pkts=2950263/0. 2017.04.27 22:05:16 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 22:05:16 - OpenVPN > Validating certificate key usage. 2017.04.27 22:05:16 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 22:05:16 - OpenVPN > VERIFY KU OK. 2017.04.27 22:05:16 - OpenVPN > Validating certificate extended key usage. 2017.04.27 22:05:16 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 22:05:16 - OpenVPN > VERIFY EKU OK. 2017.04.27 22:05:16 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 22:05:17 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 22:05:17 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 22:05:17 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 22:05:21 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1699186 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 22:09:06 - Above log line repeated 382 times more. 2017.04.27 22:09:06 - Updating systems & servers data .... 2017.04.27 22:09:07 - Systems & servers data update completed. 2017.04.27 22:09:11 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #102194 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 22:19:07 - Above log line repeated 1146 times more. 2017.04.27 22:19:07 - Updating systems & servers data .... 2017.04.27 22:19:10 - Systems & servers data update completed. 2017.04.27 22:19:12 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #583386 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 22:29:10 - Above log line repeated 2112 times more. 2017.04.27 22:29:10 - Updating systems & servers data .... 2017.04.27 22:29:13 - Systems & servers data update completed. 2017.04.27 22:29:29 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1518607 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 22:39:14 - Above log line repeated 3234 times more. 2017.04.27 22:39:14 - Updating systems & servers data .... 2017.04.27 22:39:15 - Systems & servers data update completed. 2017.04.27 22:39:16 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #2517231 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 22:49:15 - Above log line repeated 3098 times more. 2017.04.27 22:49:15 - Updating systems & servers data .... 2017.04.27 22:49:17 - Systems & servers data update completed. 2017.04.27 22:49:19 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #3506690 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 22:59:18 - Above log line repeated 3121 times more. 2017.04.27 22:59:18 - Updating systems & servers data .... 2017.04.27 22:59:18 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #4505608 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 22:59:19 - Above log line repeated 10 times more. 2017.04.27 22:59:19 - Systems & servers data update completed. 2017.04.27 22:59:19 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #4506839 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 23:05:16 - Above log line repeated 2433 times moreI 2017.04.27 23:05:16 - Renewing TLS key. 2017.04.27 23:05:16 - OpenVPN > TLS: tls_process: killed expiring key. 2017.04.27 23:05:17 - OpenVPN > TLS: soft reset sec=0 bytes=6594705080/-1 pkts=7783489/0. 2017.04.27 23:05:17 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.27 23:05:17 - OpenVPN > Validating certificate key usage. 2017.04.27 23:05:17 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.27 23:05:17 - OpenVPN > VERIFY KU OK. 2017.04.27 23:05:17 - OpenVPN > Validating certificate extended key usage. 2017.04.27 23:05:17 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.27 23:05:17 - OpenVPN > VERIFY EKU OK. 2017.04.27 23:05:17 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.27 23:05:18 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 23:05:18 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.27 23:05:18 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.27 23:05:24 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #5130911 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 23:09:19 - Above log line repeated 702 times more. 2017.04.27 23:09:19 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #264926 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 23:09:19 - Updating systems & servers data .... 2017.04.27 23:09:20 - Above log line repeated 8 times more. 2017.04.27 23:09:20 - Systems & servers data update completed. 2017.04.27 23:09:22 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #273058 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 23:19:20 - Above log line repeated 3371 times more. 2017.04.27 23:19:20 - Updating systems & servers data .... 2017.04.27 23:19:21 - Systems & servers data update completed. 2017.04.27 23:19:24 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1222775 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 23:29:21 - Above log line repeated 1430 times more. 2017.04.27 23:29:21 - Updating systems & servers data .... 2017.04.27 23:29:25 - Systems & servers data update completed. 2017.04.27 23:29:28 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1979276 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 23:39:25 - Above log line repeated 431 times more. 2017.04.27 23:39:25 - Updating systems & servers data .... 2017.04.27 23:39:26 - Systems & servers data update completed. 2017.04.27 23:39:56 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #2366454 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 23:49:28 - Above log line repeated 425 times more. 2017.04.27 23:49:28 - Updating systems & servers data .... 2017.04.27 23:49:30 - Systems & servers data update completed. 2017.04.27 23:49:42 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #2821669 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.27 23:59:30 - Above log line repeated 946 times more. 2017.04.27 23:59:30 - Updating systems & servers data .... 2017.04.27 23:59:32 - Systems & servers data update completed. 2017.04.27 23:59:34 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #3475696 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.28 00:02:52 - Above log line repeated 251 times more! 2017.04.28 00:02:52 - Disconnecting. 2017.04.28 00:02:52 - Management - Send 'signal SIGTERM'. 2017.04.28 00:02:52 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'. 2017.04.28 00:02:52 - OpenVPN > SIGTERM received, sending exit notification to peer. 2017.04.28 00:02:57 - OpenVPN > C:\Windows\system32\route.exe DELETE 213.152.161.238 MASK 255.255.255.255 192.168.178.1. 2017.04.28 00:02:57 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2017.04.28 00:02:57 - OpenVPN > C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.04.28 00:02:57 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2017.04.28 00:02:57 - OpenVPN > C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.04.28 00:02:57 - OpenVPN > Route deletion via IPAPI succeeded [adaptive]. 2017.04.28 00:02:57 - OpenVPN > Closing TUN/TAP interface. 2017.04.28 00:02:57 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting. 2017.04.28 00:02:57 - Connection terminated.. 2017.04.28 00:02:57 - DNS of a network adapter restored to original settings (TP-LINK Wireless USB Adapter, to automatic). 2017.04.28 00:02:57 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic). 2017.04.28 00:02:57 - DNS leak protection with packet filtering disabled.I 2017.04.28 00:02:57 - Checking authorization ...! 2017.04.28 00:02:57 - Connecting to Orion (Netherlands, Alblasserdam). 2017.04.28 00:02:57 - OpenVPN > OpenVPN 2.4.0 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [AEAD] built on Jan 29 2017. 2017.04.28 00:02:57 - OpenVPN > Windows version 6.1 (Windows 7) 64bit. 2017.04.28 00:02:57 - OpenVPN > library versions: OpenSSL 1.0.2k 26 Jan 2017, LZO 2.09. 2017.04.28 00:02:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100. 2017.04.28 00:02:58 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.28 00:02:58 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication. 2017.04.28 00:02:58 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]213.152.161.238:443. 2017.04.28 00:02:58 - OpenVPN > Socket Buffers: R=[8192->262144] S=[8192->262144]. 2017.04.28 00:02:58 - OpenVPN > UDP link local: (not bound). 2017.04.28 00:02:58 - OpenVPN > UDP link remote: [AF_INET]213.152.161.238:443. 2017.04.28 00:03:27 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.238:443, sid=bf870299 c25ee78a. 2017.04.28 00:03:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org. 2017.04.28 00:03:27 - OpenVPN > Validating certificate key usage. 2017.04.28 00:03:27 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0. 2017.04.28 00:03:27 - OpenVPN > VERIFY KU OK. 2017.04.28 00:03:27 - OpenVPN > Validating certificate extended key usage. 2017.04.28 00:03:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication. 2017.04.28 00:03:27 - OpenVPN > VERIFY EKU OK. 2017.04.28 00:03:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Orion, emailAddress=info@airvpn.org. 2017.04.28 00:03:27 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA. 2017.04.28 00:03:27 - OpenVPN > [Orion] Peer Connection Initiated with [AF_INET]213.152.161.238:443. 2017.04.28 00:03:28 - OpenVPN > SENT CONTROL [Orion]: 'PUSH_REQUEST' (status=1). 2017.04.28 00:03:28 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.20.93 255.255.0.0,peer-id 37,cipher AES-256-GCM'. 2017.04.28 00:03:28 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified. 2017.04.28 00:03:28 - OpenVPN > OPTIONS IMPORT: compression parms modified. 2017.04.28 00:03:28 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified. 2017.04.28 00:03:28 - OpenVPN > OPTIONS IMPORT: route options modified. 2017.04.28 00:03:28 - OpenVPN > OPTIONS IMPORT: route-related options modified. 2017.04.28 00:03:28 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified. 2017.04.28 00:03:28 - OpenVPN > OPTIONS IMPORT: peer-id set. 2017.04.28 00:03:28 - OpenVPN > OPTIONS IMPORT: adjusting link_mtu to 1625. 2017.04.28 00:03:28 - OpenVPN > OPTIONS IMPORT: data channel crypto options modified. 2017.04.28 00:03:28 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.28 00:03:28 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-GCM' initialized with 256 bit key. 2017.04.28 00:03:28 - OpenVPN > interactive service msg_channel=0. 2017.04.28 00:03:28 - OpenVPN > ROUTE_GATEWAY 192.168.178.1/255.255.255.0 I=20 HWADDR=98:de:d0:05:ef:b4. 2017.04.28 00:03:28 - OpenVPN > open_tun. 2017.04.28 00:03:28 - OpenVPN > TAP-WIN32 device [Local Area Connection 4] opened: \\.\Global\{DB8AF0B6-7E73-488B-906D-B6B7E05129C0}.tap. 2017.04.28 00:03:28 - OpenVPN > TAP-Windows Driver Version 9.9. 2017.04.28 00:03:28 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.20.93/255.255.0.0 [sUCCEEDED]. 2017.04.28 00:03:28 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.20.93/255.255.0.0 on interface {DB8AF0B6-7E73-488B-906D-B6B7E05129C0} [DHCP-serv: 10.4.255.254, lease-time: 31536000]. 2017.04.28 00:03:28 - OpenVPN > Successful ARP Flush on interface [24] {DB8AF0B6-7E73-488B-906D-B6B7E05129C0}. 2017.04.28 00:03:28 - OpenVPN > do_ifconfig, tt->did_ifconfig_ipv6_setup=0. 2017.04.28 00:03:33 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up. 2017.04.28 00:03:33 - OpenVPN > C:\Windows\system32\route.exe ADD 213.152.161.238 MASK 255.255.255.255 192.168.178.1. 2017.04.28 00:03:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=25 and dwForwardType=4. 2017.04.28 00:03:33 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.04.28 00:03:33 - OpenVPN > C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.04.28 00:03:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4. 2017.04.28 00:03:33 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.04.28 00:03:33 - OpenVPN > C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1. 2017.04.28 00:03:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4. 2017.04.28 00:03:33 - OpenVPN > Route addition via IPAPI succeeded [adaptive]. 2017.04.28 00:03:33 - Starting Management Interface. 2017.04.28 00:03:33 - OpenVPN > Initialization Sequence Completed. 2017.04.28 00:03:33 - DNS leak protection with packet filtering enabled.. 2017.04.28 00:03:33 - DNS of a network adapter forced (TP-LINK Wireless USB Adapter, from automatic (213.46.228.196,62.179.104.196) to 10.4.0.1). 2017.04.28 00:03:33 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1). 2017.04.28 00:03:33 - Flushing DNS. 2017.04.28 00:03:33 - Shell of 'cmd.exe','/c ipconfig /flushdns' done sync in 421 ms, Output: Windows IP Configuration. 2017.04.28 00:03:33 - Successfully flushed the DNS Resolver Cache.. 2017.04.28 00:03:39 - Shell of 'cmd.exe','/c ipconfig /registerdns' done sync in 6022 ms, Output: Windows IP Configuration. 2017.04.28 00:03:39 - Registration of the DNS resource records for all adapters of this computer has been initiated. Any errors will be reported in the Event Viewer in 15 minutes.I 2017.04.28 00:03:39 - Checking routeI 2017.04.28 00:03:40 - Checking DNS! 2017.04.28 00:03:40 - Connected.. 2017.04.28 00:03:40 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info. 2017.04.28 00:03:40 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100. 2017.04.28 00:06:42 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #125026 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.28 00:09:32 - Above log line repeated 47 times more. 2017.04.28 00:09:32 - Updating systems & servers data .... 2017.04.28 00:09:35 - Systems & servers data update completed. 2017.04.28 00:10:31 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #330255 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.28 00:19:35 - Above log line repeated 86 times more. 2017.04.28 00:19:35 - Updating systems & servers data .... 2017.04.28 00:19:38 - Systems & servers data update completed. 2017.04.28 00:19:39 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #851976 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.28 00:29:38 - Above log line repeated 153 times more. 2017.04.28 00:29:38 - Updating systems & servers data .... 2017.04.28 00:29:40 - Systems & servers data update completed. 2017.04.28 00:30:18 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1271942 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.28 00:39:41 - Above log line repeated 115 times more. 2017.04.28 00:39:41 - Updating systems & servers data .... 2017.04.28 00:39:42 - Systems & servers data update completed. 2017.04.28 00:40:09 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1620746 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings. 2017.04.28 00:49:42 - Above log line repeated 131 times more. 2017.04.28 00:49:42 - Updating systems & servers data .... 2017.04.28 00:49:43 - Systems & servers data update completed. 2017.04.28 00:50:19 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #1848282 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings I hope I have provided enough information to figure out what's going on. It is getting on rather late here and I do have a rather busy day tomorrow so it may be a while until I'll be back here to respond again. I think AirVPN is a great service and I absolutely will want to continue using it for the foreseeable future if these issues can be resolved. Thank you in advance,Jurriaany, excited yet troubled customer. Quote Share this post Link to post
OpenSourcerer 1360 Posted ... . 2017.04.27 05:29:56 - OpenVPN > AEAD Decrypt error: bad packet ID (may be a replay): [ #2276173 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2017.04.27 05:35:37 - Above log line repeated 105 times more Lines 2 and 3. Please don't tell me you see such errors as normal!?It's a sign that something is interfering with the OpenVPN connection. Latency spikes and download/upload throughput loss are common with such errors, so there's no need to troubleshoot these symptoms. You are using WLAN which is by itself prone to interference, either by other WLAN networks or by someone actively disrupting it (which is less likely). You could try to increase signal strength by moving the computer nearer to the access point. If you have another WLAN device you can try on your computer, try a connection with that one. I think you perfectly know that a LAN connection via cable is much more stable than a WLAN connection. Try a connection with a wired connection to your router. Completely disable all internet security suites you may run, especially their firewalls or other third party firewalls. You could try resetting Windows Firewall, too, to be sure.That network meter you run and those pings you do - stop them for a while. They only add bias to your troubleshooting attempts. Update your TCP/IP settings. TCP Optimizer can do this with a few clicks. Launch it as admin and make sure your primary network interface is selected. Set the slider to your internet speed, select "Optimal", Apply and reboot. Also check out your router and make sure it does not tinker with VPN traffic (we've had some kind of QoS settings in the past on ASUS routers or so). Look out for keywords such as TCP, UDP, VPN, QoS, etc. Maybe a firmware update might help as well. Good luck, and report what you did, what it did and everything else you can add. Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
Guest Posted ... Thanks for your fast and insightful response. My experience with the information you provided: With regards to the errors in the log: No, I don't see these errors as normal, but they appear to coincide with the packet loss and appear to be more of a consequence of rather than a cause for the problem. Thanks for confirming that I am, indeed, suffering packet loss. With regards to your points on using WLAN: Yes, I am aware a cable connection utilizing collision detection is superior to a wireless connection utilizing collision avoidance, however I have ruled out WLAN being part of my problem. I have run extensive ping tests to my router over long periods of time and the vast majority of them echoed back within 4 milliseconds, with rare peaks of up to 20 milliseconds.I am for the time being still unable to run a cabled connection to my router as it is in a centralized location where my housemates access it and I have not yet renovated this part of the house to include CAT5 cables running through the wall. With regards to disabling firewall and the ping test, I have done so but to no avail. I have also rebooted several times between to make sure. With regards to the TCP/IP settings tool, thank you for informing me of this great tool, I will definitely continue to use it in the future, but I have come to the conclusion that currently my network adapter is operating as it should, so ultimately it wasn't necessary. What I did find out in the meantime: I have ran additional tests, such as pinging directly from my router to several internet addresses, both near and far, and both with and without using AirVPN, and I found out that the issue is in fact most likely to be with my ISP rather than with my freshly installed VPN service. This was quite confusing as the problems appeared exactly at the time I first started using AirVPN, and it did for a while appear that the issues were bigger while using the VPN than when I wasn't using it. In addition to this I found the same issues on my other devices, on which I haven't installed a VPN service yet. After monitoring for a while longer I can now say that the issues at this time aren't bigger when I am using AirVPN over when I am not, so with that I can conclusively say that my problems aren't AirVPN's fault. And that I will close this thread (if possible) and continue my search for answers with my ISP. Thanks again for providing help though, if anything it increased my understanding of this problem and aided in my troubleshooting attempts. Thank you,Jurryaany, now mostly excited customer upset with their ISP Quote Share this post Link to post
Guest Posted ... It appears I am unable to close or lock this thread. Quote Share this post Link to post
OpenSourcerer 1360 Posted ... It appears I am unable to close or lock this thread. That power remains with the moderators and higher folk. Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
