petrow.karli
Setting up AirVPN with Ubuntu and EuroDocsiss Router
Hey everybody,
I am using ubuntu 16.04 and used to connect to airvpn via openvpn and everything always worked quiet well. But now I had to buy a new router, which is a EuroDocsiss router, and it seems that vpn does not work behind this thing. When I connect in the terminal via openvpn everything works just fine and I get "Initialization Sequence Completed" but when I try to connect to any site nothing works. Does anyone have any suggestions how to nail down the problem?
I am far from being a crack in handling ubuntu and stuff alike so please be patient with me
Thanks for the help!
Here are some terminal outputs that might be helpful?!
This is without vpn connection:
sterome@Sterome:~$ ifconfig
eth0      Link encap:Ethernet  HWaddr b8:88:e3:eb:38:c7
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0   TX bytes:0 (0.0
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:17605 errors:0 dropped:0 overruns:0 frame:0
          TX packets:17605 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:2395916 (2.3 MB)  TX bytes:2395916 (2.3 MB)
wlan0     Link encap:Ethernet  HWaddr 60:36:dd:c3:34:1c
          inet addr:192.168.0.2  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: 2a02:2450:103a:a6a:5c97:d6ce:4d4a:59e/64 Scope:Global
          inet6 addr: 2a02:2450:103a:a6a:6236:ddff:fec3:341c/64 Scope:Global
          inet6 addr: fe80::6236:ddff:fec3:341c/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:715983 errors:0 dropped:0 overruns:0 frame:0
          TX packets:394160 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:987194124 (987.1 MB)  TX bytes:38882147 (38.8 MB)
sterome@Sterome:~$ route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
0.0.0.0         192.168.0.1     0.0.0.0         UG    0      0        0 wlan0
192.168.0.0     0.0.0.0         255.255.255.0   U     9      0        0 wlan0
sterome@Sterome:~$ ping -c3 airvpn.org
PING airvpn.org (5.196.64.52) 56(84) bytes of data.
64 bytes from ns334629.ip-5-196-64.eu (5.196.64.52): icmp_seq=1 ttl=51 time=34.1 ms
64 bytes from ns334629.ip-5-196-64.eu (5.196.64.52): icmp_seq=2 ttl=51 time=33.2 ms
64 bytes from ns334629.ip-5-196-64.eu (5.196.64.52): icmp_seq=3 ttl=51 time=39.3 ms
--- airvpn.org ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 33.242/35.559/39.318/2.686 ms
This comes up after connecting to the vpn:
          RX packets:17661 errors:0 dropped:0 overruns:0 frame:0
          TX packets:17661 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:2404286 (2.4 MB)  TX bytes:2404286 (2.4 MB)
tun0      Link encap:UNSPEC  HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          inet addr:10.4.22.129  P-t-P:10.4.22.129  Mask:255.255.0.0
          UP POINTOPOINT RUNNING NOARP MULTICAST  MTU:1500  Metric:1
          TX packets:14 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0   TX bytes:3224 (3.2 KB)
          RX packets:716130 errors:0 dropped:0 overruns:0 frame:0
          TX packets:394305 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:987220501 (987.2 MB)  TX bytes:38906803 (38.9 MB)
0.0.0.0         10.4.0.1        128.0.0.0       UG    0      0        0 tun0
10.4.0.0        0.0.0.0         255.255.0.0     U     0      0        0 tun0
62.102.148.143  192.168.0.1     255.255.255.255 UGH   0      0        0 wlan0
128.0.0.0       10.4.0.1        128.0.0.0       UG    0      0        0 tun0
ping: unknown host airvpn.org
