Not connected, Your IP: 18.191.234.62
smegma
DNS leaks running OpenVPN directly
I want to run openvpn directly because Eddie is too cpu intensive on my machine but I keep getting dns leaks. I am on manjaro linux 17.01 and have tried a number of methods: update-systemd-resolved scripts, adding 10.4.0.1 directly to the resolv.conf, etc. I've tried to read the arch wiki but I just end up frustrated and confused every single time.
OK then try this
Add this to your ovpn file
script-security 2
up /etc/openvpn/add_rule.sh
down /etc/openvpn/del_rule.sh
Create the file /etc/openvpn/add_rule.sh with:
#!/bin/sh
iptables -t nat -A OUTPUT -p udp --dport 53 -j DNAT --to-destination 10.4.0.1:53
iptables -t nat -A OUTPUT -p tcp --dport 53 -j DNAT --to-destination 10.4.0.1:53
And create the file /etc/openvpn/del_rule.sh with:
#!/bin/sh
iptables -t nat -D OUTPUT -p udp --dport 53 -j DNAT --to-destination 10.4.0.1:53
iptables -t nat -D OUTPUT -p tcp --dport 53 -j DNAT --to-destination 10.4.0.1:53
Type these in a terminal window:
sudo chmod +x /etc/openvpn/add_rule.sh
sudo chmod +x /etc/openvpn/del_rule.sh
Re-try with ipleak.net, it should work now.
I tried and its not resolving dns now. Do I need to open ports for the dns? I was just doing generic UDP 443 for the config
Have you modified your DNS setup?
Does your system check for DNSSEC or anything specifically?
Otherwise that must work
No I haven't. I got your method working by prepending 10.4.0.1 to my resolv.conf file so far. I didn't realise it wasn't doing that automatically. How do I go about automating the overwrite?
Same problem here. Using Parabola Arch 4.10.3
There seems to be a problem with OpenVPN and DNS in Arch/Manjaro. See here.
I don't use Arch so I can't be of any help!
Unless someone else here knows how Arch works you're more likely to get help from Arch users in its forums, they surely know how it handles DNS when using OpenVPN.
My method of manually prepending 10.4.0.1 to the resolv.conf after adding your solution seems to have been working all day, I have tested on ipleak multiple times and haven't seen any dns leaks
Very surprising but I'm glad you carried it off!
As I said, I don't know how Arch works but in most distributions there's a process (generally network-manager) that regularly overwrites changes in resolv.conf
So be careful.
This solved it also for me thank you! Basically prepending the dns server seems to work. However what happens when I am not connected to the vpn? Does the system not find the dns server of airvpn?
I assume it just skips over the 10.4.0.1 and uses whatever default dns you had set up under that. When you reset you may have to prepend again or use chattr +i or one of the other methods in arch wiki
