Not connected, Your IP: 3.128.198.21
Tixati is avery complete  and hyper fast torrent client , but do you know what are its best settings for torrenting  ?
Thank you !
Honestly, for me and most other users, no change to the default settings is necessary at all. I don't even have to forward ports or bind the TAP adapter for everything to work out of the box (with no leaks - extensive testing).
But best practices would dictate binding the TAP adapter.  If you plug Tixati into the search box in the upper-right hand corner, you will find some good discussions about it.  Particularly posts from ~Daniel~
