Not connected, Your IP: 3.145.12.242
Riddick
AirVPN Client 2.11.15 Network lock blocks access to LAN, mapped network drives and even RDP?
Hi all,
basically the subject says it all ?
Computer one, using OS : Windows 7 Pro x64 with AirVPN client 2.11.15 installed, issues with accessing LAN, mapped network drives and RDP
Computer two, using OS : Window 7 Pro x64 with AirVPN client 2.10.3 installed, no issues at all.
AirVPN client 2.11.15 Computer One I had to allow my internal ip address to be able to get access using RDP to remote Computer two, connecting to home > network drives
still did not work.
Adding new rule(s) inbound to windows firewall regarding file and printer sharing did not work either?
I had to revert back using client 2.10.3 to able to fix this, other solution disabling network lock on client 2.11.15.
I rather or prefer using client 2.11.15, is there a solution for my problem, do other members experiencing the same problem that I have.
Any help or advise, will be highly appreciated. Thank you.
See screens below please regarding the enabled/allowed preferences  :
You're not afraid of the dark web, are you ?
