Not connected, Your IP: 18.221.13.173
California1234
AirVPN won't connect to my home wifi network?
For some reason I cannot get it to work with my home network. Works at my office though. Here are the logs from it.  I have updated my mac software, tried the latest version, tried the experimental one.  Please help!
I 2017.01.20 18:55:41 - Eddie client version: 2.11.11 / osx_x64, System: OSX, Name: 10.10.5, Mono/.Net Framework: v4.0.30319
. 2017.01.20 18:55:41 - Reading options from /Users/melissababcock/.airvpn/AirVPN.xml
. 2017.01.20 18:55:42 - Data path: /Users/melissababcock/.airvpn
. 2017.01.20 18:55:42 - Application path: /Applications/Eddie.app/Contents/MacOS
. 2017.01.20 18:55:42 - Executable path: /Applications/Eddie.app/Contents/MacOS/Eddie
. 2017.01.20 18:55:43 - Command line arguments (0):
. 2017.01.20 18:55:43 - Operating System: Unix 14.5.0.0 - Darwin BlackHeart.local 14.5.0 Darwin Kernel Version 14.5.0: Sun Sep 25 22:07:15 PDT 2016; root:xnu-2782.50.9~1/RELEASE_X86_64 x86_64
I 2017.01.20 18:55:43 - OpenVPN Driver - Expected
I 2017.01.20 18:55:43 - OpenVPN - Version: 2.4.0 - OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09 (/Applications/Eddie.app/Contents/MacOS/openvpn)
I 2017.01.20 18:55:43 - SSH - Version: OpenSSH_6.2p2, OSSLShim 0.9.8r 8 Dec 2011 (/usr/bin/ssh)
I 2017.01.20 18:55:43 - SSL - Version: stunnel 5.37 (/Applications/Eddie.app/Contents/MacOS/stunnel)
! 2017.01.20 18:55:43 - Ready
. 2017.01.20 18:55:43 - Updating systems & servers data ...
. 2017.01.20 18:55:44 - Systems & servers data update completed
I 2017.01.20 18:55:56 - Session starting.
. 2017.01.20 18:55:56 - IPv6 disabled on network adapter (Bluetooth DUN)
. 2017.01.20 18:55:56 - IPv6 disabled on network adapter (Wi-Fi)
. 2017.01.20 18:55:56 - IPv6 disabled on network adapter (Bluetooth PAN)
. 2017.01.20 18:55:56 - IPv6 disabled on network adapter (Thunderbolt Bridge)
I 2017.01.20 18:55:56 - Checking authorization ...
! 2017.01.20 18:55:57 - Connecting to Sharatan (Canada, Toronto, Ontario)
. 2017.01.20 18:55:57 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan  2 2017
. 2017.01.20 18:55:57 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2017.01.20 18:55:57 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.01.20 18:55:57 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.20 18:55:57 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.20 18:55:57 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.194:443
. 2017.01.20 18:55:57 - OpenVPN > Socket Buffers: R=[196724->196724] S=[9216->9216]
. 2017.01.20 18:55:57 - OpenVPN > UDP link local: (not bound)
. 2017.01.20 18:55:57 - OpenVPN > UDP link remote: [AF_INET]104.254.90.194:443
. 2017.01.20 18:56:29 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2017.01.20 18:56:29 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.01.20 18:56:34 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2017.01.20 18:56:34 - Disconnecting
. 2017.01.20 18:56:34 - Connection terminated.
I 2017.01.20 18:56:37 - Checking authorization ...
! 2017.01.20 18:56:38 - Connecting to Naos (United Kingdom, Manchester)
. 2017.01.20 18:56:38 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan  2 2017
. 2017.01.20 18:56:38 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2017.01.20 18:56:38 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.01.20 18:56:38 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.20 18:56:38 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.20 18:56:38 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]84.39.117.56:443
. 2017.01.20 18:56:38 - OpenVPN > Socket Buffers: R=[196724->196724] S=[9216->9216]
. 2017.01.20 18:56:38 - OpenVPN > UDP link local: (not bound)
. 2017.01.20 18:56:38 - OpenVPN > UDP link remote: [AF_INET]84.39.117.56:443
. 2017.01.20 18:56:55 - Updating systems & servers data ...
. 2017.01.20 18:56:56 - Systems & servers data update completed
. 2017.01.20 18:57:10 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2017.01.20 18:57:10 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.01.20 18:57:15 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2017.01.20 18:57:15 - Disconnecting
. 2017.01.20 18:57:15 - Connection terminated.
I 2017.01.20 18:57:18 - Checking authorization ...
! 2017.01.20 18:57:18 - Connecting to Lesath (Canada, Toronto, Ontario)
. 2017.01.20 18:57:18 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan  2 2017
. 2017.01.20 18:57:18 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2017.01.20 18:57:18 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.01.20 18:57:18 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.20 18:57:18 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.20 18:57:18 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]184.75.221.2:443
. 2017.01.20 18:57:18 - OpenVPN > Socket Buffers: R=[196724->196724] S=[9216->9216]
. 2017.01.20 18:57:18 - OpenVPN > UDP link local: (not bound)
. 2017.01.20 18:57:18 - OpenVPN > UDP link remote: [AF_INET]184.75.221.2:443
. 2017.01.20 18:57:50 - OpenVPN > [uNDEF] Inactivity timeout (--ping-exit), exiting
. 2017.01.20 18:57:50 - OpenVPN > SIGTERM received, sending exit notification to peer
. 2017.01.20 18:57:55 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting
! 2017.01.20 18:57:55 - Disconnecting
. 2017.01.20 18:57:55 - Connection terminated.
I 2017.01.20 18:57:58 - Checking authorization ...
! 2017.01.20 18:57:59 - Connecting to Sharatan (Canada, Toronto, Ontario)
. 2017.01.20 18:57:59 - OpenVPN > OpenVPN 2.4.0 x86_64-apple-darwin16.3.0 [sSL (OpenSSL)] [LZO] [LZ4] [MH/RECVDA] [AEAD] built on Jan  2 2017
. 2017.01.20 18:57:59 - OpenVPN > library versions: OpenSSL 1.0.2j  26 Sep 2016, LZO 2.09
. 2017.01.20 18:57:59 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2017.01.20 18:57:59 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.20 18:57:59 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2017.01.20 18:57:59 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]104.254.90.194:443
. 2017.01.20 18:57:59 - OpenVPN > Socket Buffers: R=[196724->196724] S=[9216->9216]
. 2017.01.20 18:57:59 - OpenVPN > UDP link local: (not bound)
. 2017.01.20 18:57:59 - OpenVPN > UDP link remote: [AF_INET]104.254.90.194:443
! 2017.01.20 18:58:07 - Disconnecting
. 2017.01.20 18:58:07 - Connection terminated.
I 2017.01.20 18:58:07 - Cancel requested.
. 2017.01.20 18:58:07 - IPv6 restored on network adapter (Bluetooth DUN)
. 2017.01.20 18:58:07 - IPv6 restored on network adapter (Wi-Fi)
. 2017.01.20 18:58:07 - IPv6 restored on network adapter (Bluetooth PAN)
. 2017.01.20 18:58:08 - IPv6 restored on network adapter (Thunderbolt Bridge)
! 2017.01.20 18:58:08 - Session terminated.
