Not connected, Your IP: 216.73.217.142
Shift
Problem with Network Lock on Qube OS
I've setup AirVPN on a Fedora VM in Qubes OS, as a Proxy VM.
Unfortunately with Network Lock on, the traffic is blocked from the VM trying to proxy through the AirVPN VM.
I will outline bellow for clarity.
0. The internet.
1. sys-net VM
2. sys-firewall VM
3. Sys-AirVPN proxy VM
4. Browsing VM
With network lock on, 4 can not access the internet.
With network lock off, 4. can surf internet, but FAILS Leak tests. Revealing real IP.
Obviously some type of configuration needs changing in with the network lock config to allow traffic from 3 to 4, and 4 to 3. But locking down any leaks from 3 still.
This is beyond my knowledge of linux. I hope someone more knowledgeable can solve. Thx.
Enable private networks in the advanced settings.
Thanks for the suggestion.
Unfortunately this hasn't fixed the problem
Under Advanced>Network lock,  "allow lan/private" was already ticked.
the AirVPN proxy VM is on 10.137.2.16
While the Browser VM is on 10.137.4.9
I added both IP's to allowed addressed
Also under routes tab;
I tried adding 10.137.4.9 as an "inside" & "outside" IP.
Where to next?
Bump
Ive been trying everything i can to solve this, but still unable to get the Browser VM proxy thought the AirVPN Proxy VM when network lock is on. Leaks when network lock is off.
For colaberation, ive started a thread on the Qubes OS Google group here >
https://groups.google.com/forum/#!topic/qubes-users/T0wbCuIgISg
Perhaps there is a way to leave the lock off, and set the IP Tables manually? Or perhaps setup some firewall rules? Unfortunately this is currently beyond my Linux/Qubes skill level.
Cheers.
