nocturnoz 0 Posted ... Hello! I'm getting disconnects and tried some solutions. But obviously nothing helped. Infos:Windows 10 (up-to-date)TAP 9.9.2_3 (9.21.2 changes nothing, Updating deactivated)TAP V9 Options -> Advanced -> Media Status: Always ConnectedEddy 2.11.3Driver Update DisabledBuffer Size: 256 KB I uninstalled Eddy and deleted all Files several times and resetted the Windows Firewall Settings to default. Went into Windows Safe Mode to uninstall the TAP Driver and installed TAP 9.9.2_3. Then rebooted normally and installed Eddy 2.11.3 again. But I'm still getting disconnects ... or 0 bit/s I 2016.10.06 17:22:56 - Eddie client version: 2.11.3 / x64, System: Windows, Name: Microsoft Windows NT 10.0.10586.0 / x64 . 2016.10.06 17:22:56 - Reading options from C:\Users\-Nocturnoz-\AppData\Local\AirVPN\AirVPN.xml . 2016.10.06 17:22:57 - Data Path: C:\Users\-Nocturnoz-\AppData\Local\AirVPN . 2016.10.06 17:22:57 - App Path: C:\Program Files\AirVPN . 2016.10.06 17:22:57 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe . 2016.10.06 17:22:57 - Command line arguments (1): path="home" . 2016.10.06 17:22:57 - Operating System: Microsoft Windows NT 10.0.10586.0 W 2016.10.06 17:22:57 - Tunnel driver will be upgraded, from 9.9.2 to 9.21.2. E 2016.10.06 17:22:57 - OpenVPN Driver - Not available - Will be installed at next connection. I 2016.10.06 17:22:57 - OpenVPN - Version: OpenVPN 2.3.11 (C:\Program Files\AirVPN\openvpn.exe) I 2016.10.06 17:22:57 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe) I 2016.10.06 17:22:57 - SSL - Version: stunnel 5.32 (C:\Program Files\AirVPN\stunnel.exe) ! 2016.10.06 17:22:57 - Ready . 2016.10.06 17:22:57 - Updating systems & servers data ... . 2016.10.06 17:22:57 - Cannot retrieve systems & servers data. Please retry later or contact us for help. (Die Verbindung mit dem Remoteserver kann nicht hergestellt werden.) W 2016.10.06 17:23:05 - Tunnel driver will be upgraded, from 9.9.2 to 9.21.2. I 2016.10.06 17:24:31 - Checking login ... F 2016.10.06 17:24:31 - Cannot login. (Die Verbindung mit dem Remoteserver kann nicht hergestellt werden.) I 2016.10.06 17:24:44 - Checking login ... ! 2016.10.06 17:24:45 - Logged in. ! 2016.10.06 17:24:47 - Activation of Network Lock - Windows Filtering Platform I 2016.10.06 17:24:49 - Session starting. I 2016.10.06 17:24:49 - IPv6 disabled with packet filtering. I 2016.10.06 17:24:49 - Checking authorization ... ! 2016.10.06 17:24:50 - Connecting to Hassaleh (Netherlands, Alblasserdam) . 2016.10.06 17:24:50 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Jun 1 2016 . 2016.10.06 17:24:50 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2016.10.06 17:24:50 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09 . 2016.10.06 17:24:50 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.10.06 17:24:50 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.10.06 17:24:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 17:24:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 17:24:50 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2016.10.06 17:24:50 - OpenVPN > UDPv4 link local: [undef] . 2016.10.06 17:24:50 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.39:443 . 2016.10.06 17:24:50 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.39:443, sid=b94c2548 a6c8f076 . 2016.10.06 17:24:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.10.06 17:24:50 - OpenVPN > Validating certificate key usage . 2016.10.06 17:24:50 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.10.06 17:24:50 - OpenVPN > VERIFY KU OK . 2016.10.06 17:24:50 - OpenVPN > Validating certificate extended key usage . 2016.10.06 17:24:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.10.06 17:24:50 - OpenVPN > VERIFY EKU OK . 2016.10.06 17:24:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.10.06 17:24:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 17:24:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 17:24:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 17:24:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 17:24:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.10.06 17:24:50 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.39:443 . 2016.10.06 17:24:52 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.10.06 17:24:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.165 255.255.0.0' . 2016.10.06 17:24:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.10.06 17:24:52 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.10.06 17:24:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.10.06 17:24:52 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.10.06 17:24:52 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.10.06 17:24:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.10.06 17:24:52 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=98:de:d0:0d:c8:98 . 2016.10.06 17:24:52 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.10.06 17:24:52 - OpenVPN > open_tun, tt->ipv6=0 . 2016.10.06 17:24:53 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B93D7467-D877-4F52-84BF-612D7A286F22}.tap . 2016.10.06 17:24:53 - OpenVPN > TAP-Windows Driver Version 9.9 . 2016.10.06 17:24:53 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.1.165/255.255.0.0 [SUCCEEDED] . 2016.10.06 17:24:53 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.1.165/255.255.0.0 on interface {B93D7467-D877-4F52-84BF-612D7A286F22} [DHCP-serv: 10.4.255.254, lease-time: 31536000] . 2016.10.06 17:24:53 - OpenVPN > Successful ARP Flush on interface [32] {B93D7467-D877-4F52-84BF-612D7A286F22} . 2016.10.06 17:24:57 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2016.10.06 17:24:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.39 MASK 255.255.255.255 192.168.0.1 . 2016.10.06 17:24:57 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4 . 2016.10.06 17:24:57 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 17:24:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.10.06 17:24:57 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 . 2016.10.06 17:24:57 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 17:24:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.10.06 17:24:57 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 . 2016.10.06 17:24:57 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 17:24:57 - Starting Management Interface . 2016.10.06 17:24:57 - OpenVPN > Initialization Sequence Completed I 2016.10.06 17:24:57 - DNS leak protection with packet filtering enabled. I 2016.10.06 17:24:57 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1) I 2016.10.06 17:24:57 - Flushing DNS I 2016.10.06 17:24:57 - Checking route I 2016.10.06 17:25:06 - Checking DNS ! 2016.10.06 17:25:06 - Connected. . 2016.10.06 17:25:06 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2016.10.06 17:25:06 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info . 2016.10.06 17:30:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #5557 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:30:50 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #5558 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:31:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #12565 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:31:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #12660 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:31:56 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #12661 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:33:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #17498 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:33:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #17499 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:33:28 - Updating systems & servers data ... . 2016.10.06 17:33:28 - Systems & servers data update completed . 2016.10.06 17:34:21 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #26903 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:34:21 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #26904 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:35:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #35154 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:35:38 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #35155 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:35:52 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #36961 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:35:52 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #36962 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:36:02 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #38162 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:36:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #45107 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:36:59 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #45108 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:41:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #70478 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:41:11 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #70479 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:41:58 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #73553 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:41:58 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #73554 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:42:08 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #74219 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:42:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #76696 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 17:43:40 - Updating systems & servers data ... . 2016.10.06 17:43:41 - Systems & servers data update completed . 2016.10.06 17:53:47 - Updating systems & servers data ... . 2016.10.06 17:53:47 - Systems & servers data update completed . 2016.10.06 18:03:51 - Updating systems & servers data ... . 2016.10.06 18:03:52 - Systems & servers data update completed . 2016.10.06 18:13:55 - Updating systems & servers data ... . 2016.10.06 18:13:55 - Systems & servers data update completed . 2016.10.06 18:16:44 - OpenVPN > TUN/TAP I/O operation aborted, restarting . 2016.10.06 18:16:44 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.39 MASK 255.255.255.255 192.168.0.1 . 2016.10.06 18:16:44 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.10.06 18:16:44 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1 W 2016.10.06 18:16:44 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1 . 2016.10.06 18:16:44 - OpenVPN > Route deletion via IPAPI failed [adaptive] . 2016.10.06 18:16:44 - OpenVPN > Route deletion fallback to route.exe . 2016.10.06 18:16:44 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2016.10.06 18:16:44 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1 W 2016.10.06 18:16:44 - OpenVPN > Warning: route gateway is not reachable on any active network adapters: 10.4.0.1 . 2016.10.06 18:16:44 - OpenVPN > Route deletion via IPAPI failed [adaptive] . 2016.10.06 18:16:44 - OpenVPN > Route deletion fallback to route.exe . 2016.10.06 18:16:44 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2016.10.06 18:16:44 - OpenVPN > Closing TUN/TAP interface . 2016.10.06 18:16:44 - OpenVPN > SIGHUP[soft,tun-abort] received, process restarting . 2016.10.06 18:16:44 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Jun 1 2016 . 2016.10.06 18:16:44 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2016.10.06 18:16:44 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09 . 2016.10.06 18:16:44 - OpenVPN > Restart pause, 10 second(s) ! 2016.10.06 18:16:44 - Disconnecting . 2016.10.06 18:16:44 - Management - Send 'signal SIGTERM' . 2016.10.06 18:16:44 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2016.10.06 18:16:44 - OpenVPN > SIGTERM[hard,init_instance] received, process exiting . 2016.10.06 18:16:44 - OpenVpn Management > SUCCESS: signal SIGTERM thrown . 2016.10.06 18:16:44 - Connection terminated. I 2016.10.06 18:16:44 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic) I 2016.10.06 18:16:44 - DNS leak protection with packet filtering disabled. I 2016.10.06 18:16:49 - Checking authorization ... ! 2016.10.06 18:16:49 - Connecting to Gienah (Netherlands, Alblasserdam) . 2016.10.06 18:16:49 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Jun 1 2016 . 2016.10.06 18:16:49 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2016.10.06 18:16:49 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09 . 2016.10.06 18:16:49 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.10.06 18:16:50 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.10.06 18:16:50 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 18:16:50 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 18:16:50 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2016.10.06 18:16:50 - OpenVPN > UDPv4 link local: [undef] . 2016.10.06 18:16:50 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.95:53 . 2016.10.06 18:16:50 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.95:53, sid=1e8e0b6a 828336bd . 2016.10.06 18:16:50 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.10.06 18:16:50 - OpenVPN > Validating certificate key usage . 2016.10.06 18:16:50 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.10.06 18:16:50 - OpenVPN > VERIFY KU OK . 2016.10.06 18:16:50 - OpenVPN > Validating certificate extended key usage . 2016.10.06 18:16:50 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.10.06 18:16:50 - OpenVPN > VERIFY EKU OK . 2016.10.06 18:16:50 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.10.06 18:16:50 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 18:16:50 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 18:16:50 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 18:16:50 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 18:16:50 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.10.06 18:16:50 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.95:53 . 2016.10.06 18:16:52 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.10.06 18:16:52 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.8.0.1,comp-lzo no,route-gateway 10.8.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.8.0.8 255.255.0.0' . 2016.10.06 18:16:52 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.10.06 18:16:52 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.10.06 18:16:52 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.10.06 18:16:52 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.10.06 18:16:52 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.10.06 18:16:52 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.10.06 18:16:52 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=98:de:d0:0d:c8:98 . 2016.10.06 18:16:52 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.10.06 18:16:52 - OpenVPN > open_tun, tt->ipv6=0 . 2016.10.06 18:16:52 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B93D7467-D877-4F52-84BF-612D7A286F22}.tap . 2016.10.06 18:16:52 - OpenVPN > TAP-Windows Driver Version 9.9 . 2016.10.06 18:16:52 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.8.0.0/10.8.0.8/255.255.0.0 [SUCCEEDED] . 2016.10.06 18:16:52 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.8.0.8/255.255.0.0 on interface {B93D7467-D877-4F52-84BF-612D7A286F22} [DHCP-serv: 10.8.255.254, lease-time: 31536000] . 2016.10.06 18:16:52 - OpenVPN > Successful ARP Flush on interface [32] {B93D7467-D877-4F52-84BF-612D7A286F22} . 2016.10.06 18:16:58 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 18:16:58 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 18:16:58 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 18:17:02 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2016.10.06 18:17:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.95 MASK 255.255.255.255 192.168.0.1 . 2016.10.06 18:17:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4 . 2016.10.06 18:17:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 18:17:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 18:17:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 . 2016.10.06 18:17:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 18:17:02 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 18:17:02 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 . 2016.10.06 18:17:02 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 18:17:02 - Starting Management Interface . 2016.10.06 18:17:02 - OpenVPN > Initialization Sequence Completed I 2016.10.06 18:17:02 - DNS leak protection with packet filtering enabled. I 2016.10.06 18:17:02 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.8.0.1) to 10.8.0.1) I 2016.10.06 18:17:02 - Flushing DNS I 2016.10.06 18:17:02 - Checking route I 2016.10.06 18:17:05 - Checking DNS ! 2016.10.06 18:17:05 - Connected. . 2016.10.06 18:17:05 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info . 2016.10.06 18:17:05 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2016.10.06 18:19:50 - Updating systems & servers data ... ! 2016.10.06 18:19:52 - Disconnecting . 2016.10.06 18:19:52 - Management - Send 'signal SIGTERM' . 2016.10.06 18:19:52 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2016.10.06 18:19:52 - OpenVPN > SIGTERM received, sending exit notification to peer . 2016.10.06 18:19:57 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.162.95 MASK 255.255.255.255 192.168.0.1 . 2016.10.06 18:19:57 - OpenVPN > ROUTE: route deletion failed using DeleteIpForwardEntry: Element nicht gefunden. . 2016.10.06 18:19:57 - OpenVPN > Route deletion via IPAPI failed [adaptive] . 2016.10.06 18:19:57 - OpenVPN > Route deletion fallback to route.exe . 2016.10.06 18:19:57 - OpenVPN > env_block: add PATH=C:\WINDOWS\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem . 2016.10.06 18:19:57 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 18:19:57 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.10.06 18:19:57 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 18:19:57 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.10.06 18:19:57 - OpenVPN > Closing TUN/TAP interface . 2016.10.06 18:19:57 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2016.10.06 18:19:57 - Connection terminated. I 2016.10.06 18:19:57 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic) I 2016.10.06 18:19:57 - DNS leak protection with packet filtering disabled. I 2016.10.06 18:20:00 - Checking authorization ... ! 2016.10.06 18:20:00 - Connecting to Gienah (Netherlands, Alblasserdam) . 2016.10.06 18:20:00 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Jun 1 2016 . 2016.10.06 18:20:00 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2016.10.06 18:20:00 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09 . 2016.10.06 18:20:00 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.10.06 18:20:00 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.10.06 18:20:00 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 18:20:00 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 18:20:00 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2016.10.06 18:20:00 - OpenVPN > UDPv4 link local: [undef] . 2016.10.06 18:20:00 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.95:53 . 2016.10.06 18:20:00 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.95:53, sid=de2d5383 0a0313f2 . 2016.10.06 18:20:00 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.10.06 18:20:00 - OpenVPN > Validating certificate key usage . 2016.10.06 18:20:00 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.10.06 18:20:00 - OpenVPN > VERIFY KU OK . 2016.10.06 18:20:00 - OpenVPN > Validating certificate extended key usage . 2016.10.06 18:20:00 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.10.06 18:20:00 - OpenVPN > VERIFY EKU OK . 2016.10.06 18:20:00 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.10.06 18:20:01 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 18:20:01 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 18:20:01 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 18:20:01 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 18:20:01 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.10.06 18:20:01 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.95:53 . 2016.10.06 18:20:03 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.10.06 18:20:03 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.8.0.1,comp-lzo no,route-gateway 10.8.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.8.0.8 255.255.0.0' . 2016.10.06 18:20:03 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.10.06 18:20:03 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.10.06 18:20:03 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.10.06 18:20:03 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.10.06 18:20:03 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.10.06 18:20:03 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.10.06 18:20:03 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=98:de:d0:0d:c8:98 . 2016.10.06 18:20:03 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.10.06 18:20:03 - OpenVPN > open_tun, tt->ipv6=0 . 2016.10.06 18:20:03 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B93D7467-D877-4F52-84BF-612D7A286F22}.tap . 2016.10.06 18:20:03 - OpenVPN > TAP-Windows Driver Version 9.9 . 2016.10.06 18:20:03 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.8.0.0/10.8.0.8/255.255.0.0 [SUCCEEDED] . 2016.10.06 18:20:03 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.8.0.8/255.255.0.0 on interface {B93D7467-D877-4F52-84BF-612D7A286F22} [DHCP-serv: 10.8.255.254, lease-time: 31536000] . 2016.10.06 18:20:03 - OpenVPN > Successful ARP Flush on interface [32] {B93D7467-D877-4F52-84BF-612D7A286F22} . 2016.10.06 18:20:06 - Systems & servers data update completed . 2016.10.06 18:20:08 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2016.10.06 18:20:08 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.95 MASK 255.255.255.255 192.168.0.1 . 2016.10.06 18:20:08 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4 . 2016.10.06 18:20:08 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 18:20:08 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 18:20:08 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 . 2016.10.06 18:20:08 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 18:20:08 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 18:20:08 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 . 2016.10.06 18:20:08 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 18:20:08 - Starting Management Interface . 2016.10.06 18:20:08 - OpenVPN > Initialization Sequence Completed I 2016.10.06 18:20:08 - DNS leak protection with packet filtering enabled. I 2016.10.06 18:20:08 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.8.0.1) to 10.8.0.1) I 2016.10.06 18:20:08 - Flushing DNS I 2016.10.06 18:20:08 - Checking route I 2016.10.06 18:20:09 - Checking DNS ! 2016.10.06 18:20:09 - Connected. . 2016.10.06 18:20:09 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2016.10.06 18:20:09 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info . 2016.10.06 18:20:34 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1483 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 18:20:34 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1733 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 18:20:34 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1734 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 18:20:34 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1939 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 18:20:34 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1940 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 18:20:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2282 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 18:24:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14928 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 18:26:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23716 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 18:30:17 - Updating systems & servers data ... . 2016.10.06 18:30:17 - Systems & servers data update completed . 2016.10.06 18:40:20 - Updating systems & servers data ... . 2016.10.06 18:40:54 - Systems & servers data update completed Quote Share this post Link to post
nocturnoz 0 Posted ... AirVPN Support Report - Generated 06.10.2016 18:29 UTC -- Important options not at defaults -- login: nocturnoz password: (omissis) remember: True servers.scoretype: Latency log.file.enabled: True openvpn.sndbuf: 262144 openvpn.rcvbuf: 262144 windows.disable_driver_upgrade: True -- Logs -- . 2016.10.06 20:02:44 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:02:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:02:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:02:46 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:02:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:02:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:02:47 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:02:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:02:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:02:48 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:02:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:02:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:02:49 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:02:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:02:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:02:50 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:02:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:02:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:02:51 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:02:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:02:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:02:52 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:02:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:02:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:02:53 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:02:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:02:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:02:54 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:02:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:02:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:02:55 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:02:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:02:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:02:56 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:02:57 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:02:57 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:02:57 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:02:58 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:02:58 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:02:58 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:02:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:02:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:02:59 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:00 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:00 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:00 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:01 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:01 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:01 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:02 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:02 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:02 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:03 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:03 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:03 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:04 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:04 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:04 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:06 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:06 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.161.166 MASK 255.255.255.255 192.168.0.1 . 2016.10.06 20:03:06 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4 . 2016.10.06 20:03:06 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 20:03:06 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 20:03:06 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 . 2016.10.06 20:03:06 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 20:03:06 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 20:03:06 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 . 2016.10.06 20:03:06 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 20:03:06 - OpenVPN > SYSTEM ROUTING TABLE . 2016.10.06 20:03:06 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.0.1 p=0 i=15 t=4 pr=3 a=342 h=0 m=10/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 0.0.0.0 128.0.0.0 10.8.0.1 p=0 i=15 t=4 pr=3 a=249 h=0 m=11/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 0.0.0.0 128.0.0.0 10.8.0.1 p=0 i=32 t=4 pr=3 a=0 h=0 m=30/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 10.8.0.0 255.255.0.0 10.8.0.8 p=0 i=32 t=3 pr=2 a=6181 h=0 m=286/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 10.8.0.8 255.255.255.255 10.8.0.8 p=0 i=32 t=3 pr=2 a=6181 h=0 m=286/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 10.8.255.255 255.255.255.255 10.8.0.8 p=0 i=32 t=3 pr=2 a=6181 h=0 m=286/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=9714 h=0 m=306/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=9714 h=0 m=306/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=9714 h=0 m=306/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 128.0.0.0 128.0.0.0 10.8.0.1 p=0 i=15 t=4 pr=3 a=249 h=0 m=11/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 128.0.0.0 128.0.0.0 10.8.0.1 p=0 i=32 t=4 pr=3 a=0 h=0 m=30/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 192.168.0.0 255.255.255.0 192.168.0.31 p=0 i=15 t=3 pr=2 a=342 h=0 m=266/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 192.168.0.31 255.255.255.255 192.168.0.31 p=0 i=15 t=3 pr=2 a=342 h=0 m=266/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 192.168.0.255 255.255.255.255 192.168.0.31 p=0 i=15 t=3 pr=2 a=342 h=0 m=266/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 213.152.161.166 255.255.255.255 192.168.0.1 p=0 i=15 t=4 pr=3 a=0 h=0 m=10/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=9714 h=0 m=306/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 224.0.0.0 240.0.0.0 10.8.0.8 p=0 i=32 t=3 pr=2 a=6381 h=0 m=286/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.0.31 p=0 i=15 t=3 pr=2 a=352 h=0 m=266/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=9714 h=0 m=306/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 255.255.255.255 255.255.255.255 10.8.0.8 p=0 i=32 t=3 pr=2 a=6381 h=0 m=286/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.0.31 p=0 i=15 t=3 pr=2 a=352 h=0 m=266/0/0/0/0 . 2016.10.06 20:03:06 - OpenVPN > SYSTEM ADAPTER LIST . 2016.10.06 20:03:06 - OpenVPN > Microsoft Wi-Fi Direct Virtual Adapter . 2016.10.06 20:03:06 - OpenVPN > Index = 4 . 2016.10.06 20:03:06 - OpenVPN > GUID = {257EFA03-889F-4C0E-A51F-B9AEEE7E03CA} . 2016.10.06 20:03:06 - OpenVPN > IP = 0.0.0.0/0.0.0.0 . 2016.10.06 20:03:06 - OpenVPN > MAC = 98:de:d0:0d:c8:9a . 2016.10.06 20:03:06 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255 . 2016.10.06 20:03:06 - OpenVPN > DHCP SERV = . 2016.10.06 20:03:06 - OpenVPN > DHCP LEASE OBTAINED = Thu Oct 06 20:03:06 2016 . 2016.10.06 20:03:06 - OpenVPN > DHCP LEASE EXPIRES = Thu Oct 06 20:03:06 2016 . 2016.10.06 20:03:06 - OpenVPN > DNS SERV = . 2016.10.06 20:03:06 - OpenVPN > Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller . 2016.10.06 20:03:06 - OpenVPN > Index = 8 . 2016.10.06 20:03:06 - OpenVPN > GUID = {4DA09635-AF32-40AB-ACFC-03EF8BE45744} . 2016.10.06 20:03:06 - OpenVPN > IP = 0.0.0.0/0.0.0.0 . 2016.10.06 20:03:06 - OpenVPN > MAC = 00:23:54:4a:84:47 . 2016.10.06 20:03:06 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255 . 2016.10.06 20:03:06 - OpenVPN > DHCP SERV = . 2016.10.06 20:03:06 - OpenVPN > DHCP LEASE OBTAINED = Thu Oct 06 20:03:06 2016 . 2016.10.06 20:03:06 - OpenVPN > DHCP LEASE EXPIRES = Thu Oct 06 20:03:06 2016 . 2016.10.06 20:03:06 - OpenVPN > DNS SERV = . 2016.10.06 20:03:06 - OpenVPN > TP-LINK Wireless USB Adapter . 2016.10.06 20:03:06 - OpenVPN > Index = 15 . 2016.10.06 20:03:06 - OpenVPN > GUID = {B0F0E5A7-5A33-43F6-BDC9-4EC4F01B45E4} . 2016.10.06 20:03:06 - OpenVPN > IP = 192.168.0.31/255.255.255.0 . 2016.10.06 20:03:06 - OpenVPN > MAC = 98:de:d0:0d:c8:98 . 2016.10.06 20:03:06 - OpenVPN > GATEWAY = 192.168.0.1/255.255.255.255 . 2016.10.06 20:03:06 - OpenVPN > DHCP SERV = 192.168.0.1/255.255.255.255 . 2016.10.06 20:03:06 - OpenVPN > DHCP LEASE OBTAINED = Thu Oct 06 19:57:23 2016 . 2016.10.06 20:03:06 - OpenVPN > DHCP LEASE EXPIRES = Thu Oct 06 20:57:23 2016 . 2016.10.06 20:03:06 - OpenVPN > DNS SERV = 192.168.0.1/255.255.255.255 . 2016.10.06 20:03:06 - OpenVPN > Microsoft Hosted Network Virtual Adapter #2 . 2016.10.06 20:03:06 - OpenVPN > Index = 18 . 2016.10.06 20:03:06 - OpenVPN > GUID = {C171488E-B8A4-43D1-9731-1DFCD086224B} . 2016.10.06 20:03:06 - OpenVPN > IP = 0.0.0.0/0.0.0.0 . 2016.10.06 20:03:06 - OpenVPN > MAC = 98:de:d0:0d:c8:99 . 2016.10.06 20:03:06 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255 . 2016.10.06 20:03:06 - OpenVPN > DHCP SERV = . 2016.10.06 20:03:06 - OpenVPN > DHCP LEASE OBTAINED = Thu Oct 06 20:03:06 2016 . 2016.10.06 20:03:06 - OpenVPN > DHCP LEASE EXPIRES = Thu Oct 06 20:03:06 2016 . 2016.10.06 20:03:06 - OpenVPN > DNS SERV = . 2016.10.06 20:03:06 - OpenVPN > TAP-Windows Adapter V9 . 2016.10.06 20:03:06 - OpenVPN > Index = 32 . 2016.10.06 20:03:06 - OpenVPN > GUID = {B93D7467-D877-4F52-84BF-612D7A286F22} . 2016.10.06 20:03:06 - OpenVPN > IP = 10.8.0.8/255.255.0.0 . 2016.10.06 20:03:06 - OpenVPN > MAC = 00:ff:b9:3d:74:67 . 2016.10.06 20:03:06 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255 . 2016.10.06 20:03:07 - OpenVPN > DHCP SERV = 10.8.255.254/255.255.255.255 . 2016.10.06 20:03:07 - OpenVPN > DHCP LEASE OBTAINED = Thu Oct 06 18:20:08 2016 . 2016.10.06 20:03:07 - OpenVPN > DHCP LEASE EXPIRES = Fri Oct 06 18:20:08 2017 . 2016.10.06 20:03:07 - OpenVPN > DNS SERV = 10.8.0.1/255.255.255.255 . 2016.10.06 20:03:07 - Starting Management Interface . 2016.10.06 20:03:07 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv ) I 2016.10.06 20:03:07 - DNS leak protection with packet filtering enabled. I 2016.10.06 20:03:07 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.8.0.1) to 10.8.0.1) ! 2016.10.06 20:03:07 - Disconnecting . 2016.10.06 20:03:07 - Management - Send 'signal SIGTERM' . 2016.10.06 20:03:07 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info I 2016.10.06 20:03:07 - Flushing DNS . 2016.10.06 20:03:07 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2016.10.06 20:03:07 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2016.10.06 20:03:07 - OpenVPN > SIGTERM received, sending exit notification to peer . 2016.10.06 20:03:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 213.152.161.166 MASK 255.255.255.255 192.168.0.1 . 2016.10.06 20:03:12 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.10.06 20:03:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 20:03:12 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.10.06 20:03:12 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 20:03:12 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.10.06 20:03:12 - OpenVPN > Closing TUN/TAP interface . 2016.10.06 20:03:12 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting . 2016.10.06 20:03:12 - Connection terminated. I 2016.10.06 20:03:13 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic) I 2016.10.06 20:03:13 - DNS leak protection with packet filtering disabled. I 2016.10.06 20:03:13 - Cancel requested. I 2016.10.06 20:03:13 - IPv6 restored with packet filtering. ! 2016.10.06 20:03:13 - Session terminated. ! 2016.10.06 20:03:14 - Deactivation of Network Lock I 2016.10.06 20:03:16 - Session starting. I 2016.10.06 20:03:16 - IPv6 disabled with packet filtering. I 2016.10.06 20:03:16 - Checking authorization ... ! 2016.10.06 20:03:16 - Connecting to Menkib (Germany, Frankfurt) . 2016.10.06 20:03:17 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Jun 1 2016 . 2016.10.06 20:03:17 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2016.10.06 20:03:17 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09 . 2016.10.06 20:03:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.10.06 20:03:17 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.10.06 20:03:17 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:03:17 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:03:17 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2016.10.06 20:03:17 - OpenVPN > UDPv4 link local: [undef] . 2016.10.06 20:03:17 - OpenVPN > UDPv4 link remote: [AF_INET]178.162.198.46:53 . 2016.10.06 20:03:17 - OpenVPN > TLS: Initial packet from [AF_INET]178.162.198.46:53, sid=a314cfda 2e5b6bb3 . 2016.10.06 20:03:18 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.10.06 20:03:18 - OpenVPN > Validating certificate key usage . 2016.10.06 20:03:18 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.10.06 20:03:18 - OpenVPN > VERIFY KU OK . 2016.10.06 20:03:18 - OpenVPN > Validating certificate extended key usage . 2016.10.06 20:03:18 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.10.06 20:03:18 - OpenVPN > VERIFY EKU OK . 2016.10.06 20:03:18 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.10.06 20:03:19 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 20:03:19 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:03:19 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 20:03:19 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:03:19 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.10.06 20:03:19 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]178.162.198.46:53 . 2016.10.06 20:03:21 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.10.06 20:03:21 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.8.0.1,comp-lzo no,route-gateway 10.8.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.8.0.169 255.255.0.0' . 2016.10.06 20:03:21 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.10.06 20:03:21 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.10.06 20:03:21 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.10.06 20:03:21 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.10.06 20:03:21 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.10.06 20:03:21 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.10.06 20:03:21 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=98:de:d0:0d:c8:98 . 2016.10.06 20:03:21 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.10.06 20:03:21 - OpenVPN > open_tun, tt->ipv6=0 . 2016.10.06 20:03:21 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B93D7467-D877-4F52-84BF-612D7A286F22}.tap . 2016.10.06 20:03:21 - OpenVPN > TAP-Windows Driver Version 9.9 . 2016.10.06 20:03:21 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.8.0.0/10.8.0.169/255.255.0.0 [SUCCEEDED] . 2016.10.06 20:03:21 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.8.0.169/255.255.0.0 on interface {B93D7467-D877-4F52-84BF-612D7A286F22} [DHCP-serv: 10.8.255.254, lease-time: 31536000] . 2016.10.06 20:03:21 - OpenVPN > Successful ARP Flush on interface [32] {B93D7467-D877-4F52-84BF-612D7A286F22} . 2016.10.06 20:03:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:26 - Updating systems & servers data ... . 2016.10.06 20:03:26 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:26 - Systems & servers data update completed . 2016.10.06 20:03:27 - Updating systems & servers data ... . 2016.10.06 20:03:27 - Systems & servers data update completed . 2016.10.06 20:03:29 - Updating systems & servers data ... . 2016.10.06 20:03:29 - Systems & servers data update completed . 2016.10.06 20:03:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:32 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:33 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:34 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:35 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:36 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:37 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:38 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:39 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:40 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:41 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:42 - Updating systems & servers data ... . 2016.10.06 20:03:42 - Systems & servers data update completed . 2016.10.06 20:03:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:42 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:44 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:45 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:45 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:45 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:46 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:47 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:48 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:48 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:48 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:49 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:50 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:51 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:52 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:53 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:54 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:03:55 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:03:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:03:56 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 178.162.198.46 MASK 255.255.255.255 192.168.0.1 . 2016.10.06 20:03:56 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4 . 2016.10.06 20:03:56 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 20:03:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 20:03:57 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 . 2016.10.06 20:03:57 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 20:03:57 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 20:03:57 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 . 2016.10.06 20:03:57 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 20:03:57 - OpenVPN > SYSTEM ROUTING TABLE . 2016.10.06 20:03:57 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.0.1 p=0 i=15 t=4 pr=3 a=393 h=0 m=10/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 0.0.0.0 128.0.0.0 10.8.0.1 p=0 i=15 t=4 pr=3 a=300 h=0 m=11/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 0.0.0.0 128.0.0.0 10.8.0.1 p=0 i=32 t=4 pr=3 a=0 h=0 m=30/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 10.8.0.0 255.255.0.0 10.8.0.8 p=0 i=32 t=3 pr=2 a=6232 h=0 m=286/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 10.8.0.8 255.255.255.255 10.8.0.8 p=0 i=32 t=3 pr=2 a=6232 h=0 m=286/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 10.8.255.255 255.255.255.255 10.8.0.8 p=0 i=32 t=3 pr=2 a=6232 h=0 m=286/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=9765 h=0 m=306/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=9765 h=0 m=306/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=9765 h=0 m=306/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 128.0.0.0 128.0.0.0 10.8.0.1 p=0 i=15 t=4 pr=3 a=300 h=0 m=11/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 128.0.0.0 128.0.0.0 10.8.0.1 p=0 i=32 t=4 pr=3 a=0 h=0 m=30/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 178.162.198.46 255.255.255.255 192.168.0.1 p=0 i=15 t=4 pr=3 a=0 h=0 m=10/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 192.168.0.0 255.255.255.0 192.168.0.31 p=0 i=15 t=3 pr=2 a=393 h=0 m=266/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 192.168.0.31 255.255.255.255 192.168.0.31 p=0 i=15 t=3 pr=2 a=393 h=0 m=266/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 192.168.0.255 255.255.255.255 192.168.0.31 p=0 i=15 t=3 pr=2 a=393 h=0 m=266/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=9765 h=0 m=306/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 224.0.0.0 240.0.0.0 10.8.0.8 p=0 i=32 t=3 pr=2 a=6432 h=0 m=286/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.0.31 p=0 i=15 t=3 pr=2 a=403 h=0 m=266/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=9765 h=0 m=306/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 255.255.255.255 255.255.255.255 10.8.0.8 p=0 i=32 t=3 pr=2 a=6432 h=0 m=286/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.0.31 p=0 i=15 t=3 pr=2 a=403 h=0 m=266/0/0/0/0 . 2016.10.06 20:03:57 - OpenVPN > SYSTEM ADAPTER LIST . 2016.10.06 20:03:57 - OpenVPN > Microsoft Wi-Fi Direct Virtual Adapter . 2016.10.06 20:03:57 - OpenVPN > Index = 4 . 2016.10.06 20:03:57 - OpenVPN > GUID = {257EFA03-889F-4C0E-A51F-B9AEEE7E03CA} . 2016.10.06 20:03:57 - OpenVPN > IP = 0.0.0.0/0.0.0.0 . 2016.10.06 20:03:57 - OpenVPN > MAC = 98:de:d0:0d:c8:9a . 2016.10.06 20:03:57 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255 . 2016.10.06 20:03:57 - OpenVPN > DHCP SERV = . 2016.10.06 20:03:57 - OpenVPN > DHCP LEASE OBTAINED = Thu Oct 06 20:03:56 2016 . 2016.10.06 20:03:57 - OpenVPN > DHCP LEASE EXPIRES = Thu Oct 06 20:03:56 2016 . 2016.10.06 20:03:57 - OpenVPN > DNS SERV = . 2016.10.06 20:03:57 - OpenVPN > Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller . 2016.10.06 20:03:57 - OpenVPN > Index = 8 . 2016.10.06 20:03:57 - OpenVPN > GUID = {4DA09635-AF32-40AB-ACFC-03EF8BE45744} . 2016.10.06 20:03:57 - OpenVPN > IP = 0.0.0.0/0.0.0.0 . 2016.10.06 20:03:57 - OpenVPN > MAC = 00:23:54:4a:84:47 . 2016.10.06 20:03:57 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255 . 2016.10.06 20:03:57 - OpenVPN > DHCP SERV = . 2016.10.06 20:03:57 - OpenVPN > DHCP LEASE OBTAINED = Thu Oct 06 20:03:56 2016 . 2016.10.06 20:03:57 - OpenVPN > DHCP LEASE EXPIRES = Thu Oct 06 20:03:56 2016 . 2016.10.06 20:03:57 - OpenVPN > DNS SERV = . 2016.10.06 20:03:57 - OpenVPN > TP-LINK Wireless USB Adapter . 2016.10.06 20:03:57 - OpenVPN > Index = 15 . 2016.10.06 20:03:57 - OpenVPN > GUID = {B0F0E5A7-5A33-43F6-BDC9-4EC4F01B45E4} . 2016.10.06 20:03:57 - OpenVPN > IP = 192.168.0.31/255.255.255.0 . 2016.10.06 20:03:57 - OpenVPN > MAC = 98:de:d0:0d:c8:98 . 2016.10.06 20:03:57 - OpenVPN > GATEWAY = 192.168.0.1/255.255.255.255 . 2016.10.06 20:03:57 - OpenVPN > DHCP SERV = 192.168.0.1/255.255.255.255 . 2016.10.06 20:03:57 - OpenVPN > DHCP LEASE OBTAINED = Thu Oct 06 19:57:23 2016 . 2016.10.06 20:03:57 - OpenVPN > DHCP LEASE EXPIRES = Thu Oct 06 20:57:23 2016 . 2016.10.06 20:03:57 - OpenVPN > DNS SERV = 192.168.0.1/255.255.255.255 . 2016.10.06 20:03:57 - OpenVPN > Microsoft Hosted Network Virtual Adapter #2 . 2016.10.06 20:03:57 - OpenVPN > Index = 18 . 2016.10.06 20:03:57 - OpenVPN > GUID = {C171488E-B8A4-43D1-9731-1DFCD086224B} . 2016.10.06 20:03:57 - OpenVPN > IP = 0.0.0.0/0.0.0.0 . 2016.10.06 20:03:57 - OpenVPN > MAC = 98:de:d0:0d:c8:99 . 2016.10.06 20:03:57 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255 . 2016.10.06 20:03:57 - OpenVPN > DHCP SERV = . 2016.10.06 20:03:57 - OpenVPN > DHCP LEASE OBTAINED = Thu Oct 06 20:03:56 2016 . 2016.10.06 20:03:57 - OpenVPN > DHCP LEASE EXPIRES = Thu Oct 06 20:03:56 2016 . 2016.10.06 20:03:57 - OpenVPN > DNS SERV = . 2016.10.06 20:03:57 - OpenVPN > TAP-Windows Adapter V9 . 2016.10.06 20:03:57 - OpenVPN > Index = 32 . 2016.10.06 20:03:57 - OpenVPN > GUID = {B93D7467-D877-4F52-84BF-612D7A286F22} . 2016.10.06 20:03:57 - OpenVPN > IP = 10.8.0.8/255.255.0.0 . 2016.10.06 20:03:57 - OpenVPN > MAC = 00:ff:b9:3d:74:67 . 2016.10.06 20:03:57 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255 . 2016.10.06 20:03:57 - OpenVPN > DHCP SERV = 10.8.255.254/255.255.255.255 . 2016.10.06 20:03:57 - OpenVPN > DHCP LEASE OBTAINED = Thu Oct 06 18:20:08 2016 . 2016.10.06 20:03:57 - OpenVPN > DHCP LEASE EXPIRES = Fri Oct 06 18:20:08 2017 . 2016.10.06 20:03:57 - OpenVPN > DNS SERV = 10.8.0.1/255.255.255.255 . 2016.10.06 20:03:57 - Starting Management Interface . 2016.10.06 20:03:57 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv ) I 2016.10.06 20:03:57 - DNS leak protection with packet filtering enabled. I 2016.10.06 20:03:57 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.8.0.1) to 10.8.0.1) ! 2016.10.06 20:03:57 - Disconnecting . 2016.10.06 20:03:57 - Management - Send 'signal SIGTERM' . 2016.10.06 20:03:57 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info I 2016.10.06 20:03:57 - Flushing DNS . 2016.10.06 20:03:58 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2016.10.06 20:03:58 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2016.10.06 20:03:58 - OpenVPN > SIGTERM received, sending exit notification to peer . 2016.10.06 20:04:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 178.162.198.46 MASK 255.255.255.255 192.168.0.1 . 2016.10.06 20:04:02 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.10.06 20:04:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 20:04:02 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.10.06 20:04:02 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 20:04:02 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.10.06 20:04:02 - OpenVPN > Closing TUN/TAP interface . 2016.10.06 20:04:02 - Connection terminated. . 2016.10.06 20:04:02 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting I 2016.10.06 20:04:04 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic) I 2016.10.06 20:04:04 - DNS leak protection with packet filtering disabled. I 2016.10.06 20:04:04 - Cancel requested. I 2016.10.06 20:04:04 - IPv6 restored with packet filtering. ! 2016.10.06 20:04:04 - Session terminated. . 2016.10.06 20:04:18 - Updating systems & servers data ... . 2016.10.06 20:04:18 - Systems & servers data update completed I 2016.10.06 20:04:20 - Session starting. I 2016.10.06 20:04:20 - IPv6 disabled with packet filtering. I 2016.10.06 20:04:20 - Checking authorization ... ! 2016.10.06 20:04:20 - Connecting to Virginis (Switzerland, Bern) . 2016.10.06 20:04:20 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Jun 1 2016 . 2016.10.06 20:04:20 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2016.10.06 20:04:20 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09 . 2016.10.06 20:04:20 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.10.06 20:04:21 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.10.06 20:04:21 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:04:21 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:04:21 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2016.10.06 20:04:21 - OpenVPN > UDPv4 link local: [undef] . 2016.10.06 20:04:21 - OpenVPN > UDPv4 link remote: [AF_INET]46.19.137.115:53 . 2016.10.06 20:04:21 - OpenVPN > TLS: Initial packet from [AF_INET]46.19.137.115:53, sid=821560f5 9bbf179b . 2016.10.06 20:04:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.10.06 20:04:22 - OpenVPN > Validating certificate key usage . 2016.10.06 20:04:22 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.10.06 20:04:22 - OpenVPN > VERIFY KU OK . 2016.10.06 20:04:22 - OpenVPN > Validating certificate extended key usage . 2016.10.06 20:04:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.10.06 20:04:22 - OpenVPN > VERIFY EKU OK . 2016.10.06 20:04:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.10.06 20:04:23 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 20:04:23 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:04:23 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 20:04:23 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:04:23 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.10.06 20:04:23 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.19.137.115:53 . 2016.10.06 20:04:25 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.10.06 20:04:25 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.8.0.1,comp-lzo no,route-gateway 10.8.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.8.0.215 255.255.0.0' . 2016.10.06 20:04:25 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.10.06 20:04:25 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.10.06 20:04:25 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.10.06 20:04:25 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.10.06 20:04:25 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.10.06 20:04:25 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.10.06 20:04:25 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=98:de:d0:0d:c8:98 . 2016.10.06 20:04:25 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.10.06 20:04:25 - OpenVPN > open_tun, tt->ipv6=0 . 2016.10.06 20:04:25 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B93D7467-D877-4F52-84BF-612D7A286F22}.tap . 2016.10.06 20:04:25 - OpenVPN > TAP-Windows Driver Version 9.9 . 2016.10.06 20:04:25 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.8.0.0/10.8.0.215/255.255.0.0 [SUCCEEDED] . 2016.10.06 20:04:25 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.8.0.215/255.255.0.0 on interface {B93D7467-D877-4F52-84BF-612D7A286F22} [DHCP-serv: 10.8.255.254, lease-time: 31536000] . 2016.10.06 20:04:25 - OpenVPN > Successful ARP Flush on interface [32] {B93D7467-D877-4F52-84BF-612D7A286F22} . 2016.10.06 20:04:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:30 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:35 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:36 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:37 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:38 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:39 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:40 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:41 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:42 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:43 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:43 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:43 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:44 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:44 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:44 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:44 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:45 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:45 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:45 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:46 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:46 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:46 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:47 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:47 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:48 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:49 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:49 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:49 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:50 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:50 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:50 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:51 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:51 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:51 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:52 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:52 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:52 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:53 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:53 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:53 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:54 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:54 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:54 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:55 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:55 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:55 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:56 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:56 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:56 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:57 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:57 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:57 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:58 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:58 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:58 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:04:59 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:04:59 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:04:59 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:00 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 46.19.137.115 MASK 255.255.255.255 192.168.0.1 . 2016.10.06 20:05:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4 . 2016.10.06 20:05:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 20:05:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 20:05:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 . 2016.10.06 20:05:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 20:05:00 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 20:05:00 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4 . 2016.10.06 20:05:00 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 20:05:00 - OpenVPN > SYSTEM ROUTING TABLE . 2016.10.06 20:05:00 - OpenVPN > 0.0.0.0 0.0.0.0 192.168.0.1 p=0 i=15 t=4 pr=3 a=457 h=0 m=10/0/0/0/0 . 2016.10.06 20:05:00 - OpenVPN > 0.0.0.0 128.0.0.0 10.8.0.1 p=0 i=15 t=4 pr=3 a=364 h=0 m=11/0/0/0/0 . 2016.10.06 20:05:00 - OpenVPN > 0.0.0.0 128.0.0.0 10.8.0.1 p=0 i=32 t=4 pr=3 a=0 h=0 m=30/0/0/0/0 . 2016.10.06 20:05:00 - OpenVPN > 10.8.0.0 255.255.0.0 10.8.0.8 p=0 i=32 t=3 pr=2 a=6295 h=0 m=286/0/0/0/0 . 2016.10.06 20:05:00 - OpenVPN > 10.8.0.8 255.255.255.255 10.8.0.8 p=0 i=32 t=3 pr=2 a=6295 h=0 m=286/0/0/0/0 . 2016.10.06 20:05:00 - OpenVPN > 10.8.255.255 255.255.255.255 10.8.0.8 p=0 i=32 t=3 pr=2 a=6295 h=0 m=286/0/0/0/0 . 2016.10.06 20:05:00 - OpenVPN > 46.19.137.115 255.255.255.255 192.168.0.1 p=0 i=15 t=4 pr=3 a=0 h=0 m=10/0/0/0/0 . 2016.10.06 20:05:00 - OpenVPN > 127.0.0.0 255.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=9829 h=0 m=306/0/0/0/0 . 2016.10.06 20:05:00 - OpenVPN > 127.0.0.1 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=9829 h=0 m=306/0/0/0/0 . 2016.10.06 20:05:00 - OpenVPN > 127.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=9829 h=0 m=306/0/0/0/0 . 2016.10.06 20:05:00 - OpenVPN > 128.0.0.0 128.0.0.0 10.8.0.1 p=0 i=15 t=4 pr=3 a=364 h=0 m=11/0/0/0/0 . 2016.10.06 20:05:00 - OpenVPN > 128.0.0.0 128.0.0.0 10.8.0.1 p=0 i=32 t=4 pr=3 a=0 h=0 m=30/0/0/0/0 . 2016.10.06 20:05:00 - OpenVPN > 192.168.0.0 255.255.255.0 192.168.0.31 p=0 i=15 t=3 pr=2 a=457 h=0 m=266/0/0/0/0 . 2016.10.06 20:05:01 - OpenVPN > 192.168.0.31 255.255.255.255 192.168.0.31 p=0 i=15 t=3 pr=2 a=457 h=0 m=266/0/0/0/0 . 2016.10.06 20:05:01 - OpenVPN > 192.168.0.255 255.255.255.255 192.168.0.31 p=0 i=15 t=3 pr=2 a=457 h=0 m=266/0/0/0/0 . 2016.10.06 20:05:01 - OpenVPN > 224.0.0.0 240.0.0.0 127.0.0.1 p=0 i=1 t=3 pr=2 a=9829 h=0 m=306/0/0/0/0 . 2016.10.06 20:05:01 - OpenVPN > 224.0.0.0 240.0.0.0 10.8.0.8 p=0 i=32 t=3 pr=2 a=6495 h=0 m=286/0/0/0/0 . 2016.10.06 20:05:01 - OpenVPN > 224.0.0.0 240.0.0.0 192.168.0.31 p=0 i=15 t=3 pr=2 a=466 h=0 m=266/0/0/0/0 . 2016.10.06 20:05:01 - OpenVPN > 255.255.255.255 255.255.255.255 127.0.0.1 p=0 i=1 t=3 pr=2 a=9829 h=0 m=306/0/0/0/0 . 2016.10.06 20:05:01 - OpenVPN > 255.255.255.255 255.255.255.255 10.8.0.8 p=0 i=32 t=3 pr=2 a=6495 h=0 m=286/0/0/0/0 . 2016.10.06 20:05:01 - OpenVPN > 255.255.255.255 255.255.255.255 192.168.0.31 p=0 i=15 t=3 pr=2 a=466 h=0 m=266/0/0/0/0 . 2016.10.06 20:05:01 - OpenVPN > SYSTEM ADAPTER LIST . 2016.10.06 20:05:01 - OpenVPN > Microsoft Wi-Fi Direct Virtual Adapter . 2016.10.06 20:05:01 - OpenVPN > Index = 4 . 2016.10.06 20:05:01 - OpenVPN > GUID = {257EFA03-889F-4C0E-A51F-B9AEEE7E03CA} . 2016.10.06 20:05:01 - OpenVPN > IP = 0.0.0.0/0.0.0.0 . 2016.10.06 20:05:01 - OpenVPN > MAC = 98:de:d0:0d:c8:9a . 2016.10.06 20:05:01 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255 . 2016.10.06 20:05:01 - OpenVPN > DHCP SERV = . 2016.10.06 20:05:01 - OpenVPN > DHCP LEASE OBTAINED = Thu Oct 06 20:05:00 2016 . 2016.10.06 20:05:01 - OpenVPN > DHCP LEASE EXPIRES = Thu Oct 06 20:05:00 2016 . 2016.10.06 20:05:01 - OpenVPN > DNS SERV = . 2016.10.06 20:05:01 - OpenVPN > Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller . 2016.10.06 20:05:01 - OpenVPN > Index = 8 . 2016.10.06 20:05:01 - OpenVPN > GUID = {4DA09635-AF32-40AB-ACFC-03EF8BE45744} . 2016.10.06 20:05:01 - OpenVPN > IP = 0.0.0.0/0.0.0.0 . 2016.10.06 20:05:01 - OpenVPN > MAC = 00:23:54:4a:84:47 . 2016.10.06 20:05:01 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255 . 2016.10.06 20:05:01 - OpenVPN > DHCP SERV = . 2016.10.06 20:05:01 - OpenVPN > DHCP LEASE OBTAINED = Thu Oct 06 20:05:00 2016 . 2016.10.06 20:05:01 - OpenVPN > DHCP LEASE EXPIRES = Thu Oct 06 20:05:00 2016 . 2016.10.06 20:05:01 - OpenVPN > DNS SERV = . 2016.10.06 20:05:01 - OpenVPN > TP-LINK Wireless USB Adapter . 2016.10.06 20:05:01 - OpenVPN > Index = 15 . 2016.10.06 20:05:01 - OpenVPN > GUID = {B0F0E5A7-5A33-43F6-BDC9-4EC4F01B45E4} . 2016.10.06 20:05:01 - OpenVPN > IP = 192.168.0.31/255.255.255.0 . 2016.10.06 20:05:01 - OpenVPN > MAC = 98:de:d0:0d:c8:98 . 2016.10.06 20:05:01 - OpenVPN > GATEWAY = 192.168.0.1/255.255.255.255 . 2016.10.06 20:05:01 - OpenVPN > DHCP SERV = 192.168.0.1/255.255.255.255 . 2016.10.06 20:05:01 - OpenVPN > DHCP LEASE OBTAINED = Thu Oct 06 19:57:23 2016 . 2016.10.06 20:05:01 - OpenVPN > DHCP LEASE EXPIRES = Thu Oct 06 20:57:23 2016 . 2016.10.06 20:05:01 - OpenVPN > DNS SERV = 192.168.0.1/255.255.255.255 . 2016.10.06 20:05:01 - OpenVPN > Microsoft Hosted Network Virtual Adapter #2 . 2016.10.06 20:05:01 - OpenVPN > Index = 18 . 2016.10.06 20:05:01 - OpenVPN > GUID = {C171488E-B8A4-43D1-9731-1DFCD086224B} . 2016.10.06 20:05:01 - OpenVPN > IP = 0.0.0.0/0.0.0.0 . 2016.10.06 20:05:01 - OpenVPN > MAC = 98:de:d0:0d:c8:99 . 2016.10.06 20:05:01 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255 . 2016.10.06 20:05:01 - OpenVPN > DHCP SERV = . 2016.10.06 20:05:01 - OpenVPN > DHCP LEASE OBTAINED = Thu Oct 06 20:05:00 2016 . 2016.10.06 20:05:01 - OpenVPN > DHCP LEASE EXPIRES = Thu Oct 06 20:05:00 2016 . 2016.10.06 20:05:01 - OpenVPN > DNS SERV = . 2016.10.06 20:05:01 - OpenVPN > TAP-Windows Adapter V9 . 2016.10.06 20:05:01 - OpenVPN > Index = 32 . 2016.10.06 20:05:01 - OpenVPN > GUID = {B93D7467-D877-4F52-84BF-612D7A286F22} . 2016.10.06 20:05:01 - OpenVPN > IP = 10.8.0.8/255.255.0.0 . 2016.10.06 20:05:01 - OpenVPN > MAC = 00:ff:b9:3d:74:67 . 2016.10.06 20:05:01 - OpenVPN > GATEWAY = 0.0.0.0/255.255.255.255 . 2016.10.06 20:05:01 - OpenVPN > DHCP SERV = 10.8.255.254/255.255.255.255 . 2016.10.06 20:05:01 - OpenVPN > DHCP LEASE OBTAINED = Thu Oct 06 18:20:08 2016 . 2016.10.06 20:05:01 - OpenVPN > DHCP LEASE EXPIRES = Fri Oct 06 18:20:08 2017 . 2016.10.06 20:05:01 - OpenVPN > DNS SERV = 10.8.0.1/255.255.255.255 . 2016.10.06 20:05:01 - Starting Management Interface . 2016.10.06 20:05:01 - OpenVPN > Initialization Sequence Completed With Errors ( see http://openvpn.net/faq.html#dhcpclientserv ) ! 2016.10.06 20:05:01 - Disconnecting I 2016.10.06 20:05:01 - DNS leak protection with packet filtering enabled. . 2016.10.06 20:05:01 - Management - Send 'signal SIGTERM' . 2016.10.06 20:05:01 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info I 2016.10.06 20:05:01 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.8.0.1) to 10.8.0.1) I 2016.10.06 20:05:01 - Flushing DNS . 2016.10.06 20:05:01 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2016.10.06 20:05:01 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2016.10.06 20:05:01 - OpenVPN > SIGTERM received, sending exit notification to peer . 2016.10.06 20:05:07 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 46.19.137.115 MASK 255.255.255.255 192.168.0.1 . 2016.10.06 20:05:07 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.10.06 20:05:07 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 20:05:07 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.10.06 20:05:07 - Connection terminated. . 2016.10.06 20:05:07 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.8.0.1 . 2016.10.06 20:05:07 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.10.06 20:05:07 - OpenVPN > Closing TUN/TAP interface . 2016.10.06 20:05:07 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting I 2016.10.06 20:05:08 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic) I 2016.10.06 20:05:08 - DNS leak protection with packet filtering disabled. I 2016.10.06 20:05:11 - Checking authorization ... ! 2016.10.06 20:05:11 - Connecting to Kajam (Netherlands, Alblasserdam) . 2016.10.06 20:05:11 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Jun 1 2016 . 2016.10.06 20:05:11 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2016.10.06 20:05:11 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09 . 2016.10.06 20:05:11 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.10.06 20:05:11 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.10.06 20:05:11 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:05:11 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:05:11 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2016.10.06 20:05:11 - OpenVPN > UDPv4 link local: [undef] . 2016.10.06 20:05:11 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.86:53 . 2016.10.06 20:05:11 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.86:53, sid=3b1596c5 548cc44f . 2016.10.06 20:05:12 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.10.06 20:05:12 - OpenVPN > Validating certificate key usage . 2016.10.06 20:05:12 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.10.06 20:05:12 - OpenVPN > VERIFY KU OK . 2016.10.06 20:05:12 - OpenVPN > Validating certificate extended key usage . 2016.10.06 20:05:12 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.10.06 20:05:12 - OpenVPN > VERIFY EKU OK . 2016.10.06 20:05:12 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.10.06 20:05:12 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 20:05:12 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:05:12 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 20:05:12 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:05:12 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.10.06 20:05:12 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.86:53 . 2016.10.06 20:05:14 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.10.06 20:05:14 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.8.0.1,comp-lzo no,route-gateway 10.8.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.8.0.6 255.255.0.0' . 2016.10.06 20:05:14 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.10.06 20:05:14 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.10.06 20:05:14 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.10.06 20:05:14 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.10.06 20:05:14 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.10.06 20:05:14 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.10.06 20:05:14 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=98:de:d0:0d:c8:98 . 2016.10.06 20:05:14 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.10.06 20:05:14 - OpenVPN > open_tun, tt->ipv6=0 . 2016.10.06 20:05:14 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{B93D7467-D877-4F52-84BF-612D7A286F22}.tap . 2016.10.06 20:05:14 - OpenVPN > TAP-Windows Driver Version 9.9 . 2016.10.06 20:05:14 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.8.0.0/10.8.0.6/255.255.0.0 [SUCCEEDED] . 2016.10.06 20:05:14 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.8.0.6/255.255.0.0 on interface {B93D7467-D877-4F52-84BF-612D7A286F22} [DHCP-serv: 10.8.255.254, lease-time: 31536000] . 2016.10.06 20:05:14 - OpenVPN > Successful ARP Flush on interface [32] {B93D7467-D877-4F52-84BF-612D7A286F22} . 2016.10.06 20:05:19 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:19 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:19 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:24 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:24 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:24 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:25 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:25 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:25 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:26 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:26 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:27 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:27 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:28 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:28 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:29 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:29 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:29 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:30 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:30 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:30 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:31 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:31 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:31 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:32 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:32 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:32 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:33 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:33 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:33 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:34 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:34 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:34 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:35 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:35 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:35 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:36 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:36 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:36 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:37 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:37 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:37 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:38 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:38 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:38 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:39 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:39 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:39 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:40 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:40 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:40 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:41 - OpenVPN > TEST ROUTES: 0/0 succeeded len=0 ret=0 a=0 u/d=down . 2016.10.06 20:05:41 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:41 - Eddie Windows Interface Hack executed (Ethernet 2) . 2016.10.06 20:05:42 - OpenVPN > TEST ROUTES: 0/1 succeeded len=0 ret=0 a=0 u/d=up . 2016.10.06 20:05:42 - OpenVPN > Route: Waiting for TUN/TAP interface to come up... . 2016.10.06 20:05:42 - OpenVPN > TUN/TAP I/O operation aborted, restarting . 2016.10.06 20:05:43 - OpenVPN > Closing TUN/TAP interface . 2016.10.06 20:05:43 - OpenVPN > SIGHUP[soft,tun-abort] received, process restarting ! 2016.10.06 20:05:43 - Disconnecting . 2016.10.06 20:05:43 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Jun 1 2016 . 2016.10.06 20:05:43 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2016.10.06 20:05:43 - Connection terminated. . 2016.10.06 20:05:43 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09 . 2016.10.06 20:05:43 - OpenVPN > Restart pause, 10 second(s) . 2016.10.06 20:05:45 - Cannot find tunnel adapter. I 2016.10.06 20:05:46 - Checking authorization ... ! 2016.10.06 20:05:46 - Connecting to Aquilae (Germany, Frankfurt) . 2016.10.06 20:05:46 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Jun 1 2016 . 2016.10.06 20:05:46 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2016.10.06 20:05:46 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09 . 2016.10.06 20:05:46 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.10.06 20:05:46 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.10.06 20:05:46 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:05:46 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:05:46 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2016.10.06 20:05:46 - OpenVPN > UDPv4 link local: [undef] . 2016.10.06 20:05:46 - OpenVPN > UDPv4 link remote: [AF_INET]46.165.208.70:443 . 2016.10.06 20:05:46 - OpenVPN > TLS: Initial packet from [AF_INET]46.165.208.70:443, sid=5a195697 10eb52b9 . 2016.10.06 20:05:46 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.10.06 20:05:46 - OpenVPN > Validating certificate key usage . 2016.10.06 20:05:46 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.10.06 20:05:46 - OpenVPN > VERIFY KU OK . 2016.10.06 20:05:46 - OpenVPN > Validating certificate extended key usage . 2016.10.06 20:05:46 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.10.06 20:05:47 - OpenVPN > VERIFY EKU OK . 2016.10.06 20:05:47 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.10.06 20:05:47 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 20:05:47 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:05:47 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 20:05:47 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:05:47 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.10.06 20:05:47 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.165.208.70:443 . 2016.10.06 20:05:49 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.10.06 20:05:49 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.47 255.255.0.0' . 2016.10.06 20:05:49 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.10.06 20:05:49 - OpenVPN > OPTIONS IMPORT: LZO parms modified ! 2016.10.06 20:05:49 - Disconnecting . 2016.10.06 20:05:49 - Connection terminated. . 2016.10.06 20:05:49 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.10.06 20:05:49 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.10.06 20:05:49 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.10.06 20:05:49 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.10.06 20:05:49 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=98:de:d0:0d:c8:98 . 2016.10.06 20:05:49 - OpenVPN > There are no TAP-Windows adapters on this system. You should be able to create a TAP-Windows adapter by going to Start -> All Programs -> TAP-Windows -> Utilities -> Add a new TAP-Windows virtual ethernet adapter. . 2016.10.06 20:05:49 - OpenVPN > Exiting due to fatal error I 2016.10.06 20:05:52 - Checking authorization ... ! 2016.10.06 20:05:52 - Connecting to Hassaleh (Netherlands, Alblasserdam) . 2016.10.06 20:05:52 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Jun 1 2016 . 2016.10.06 20:05:52 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2016.10.06 20:05:52 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09 . 2016.10.06 20:05:52 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.10.06 20:05:53 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.10.06 20:05:53 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:05:53 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:05:53 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2016.10.06 20:05:53 - OpenVPN > UDPv4 link local: [undef] . 2016.10.06 20:05:53 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.161.39:443 . 2016.10.06 20:05:53 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.161.39:443, sid=2a5f0c90 863298ae . 2016.10.06 20:05:53 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.10.06 20:05:53 - OpenVPN > Validating certificate key usage . 2016.10.06 20:05:53 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.10.06 20:05:53 - OpenVPN > VERIFY KU OK . 2016.10.06 20:05:53 - OpenVPN > Validating certificate extended key usage . 2016.10.06 20:05:53 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.10.06 20:05:53 - OpenVPN > VERIFY EKU OK . 2016.10.06 20:05:53 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.10.06 20:05:53 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 20:05:53 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:05:53 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 20:05:53 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:05:53 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.10.06 20:05:53 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.161.39:443 . 2016.10.06 20:05:55 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.10.06 20:05:55 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.1.165 255.255.0.0' . 2016.10.06 20:05:55 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.10.06 20:05:55 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.10.06 20:05:55 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.10.06 20:05:55 - OpenVPN > OPTIONS IMPORT: route options modified ! 2016.10.06 20:05:55 - Disconnecting . 2016.10.06 20:05:55 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.10.06 20:05:55 - Connection terminated. . 2016.10.06 20:05:55 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.10.06 20:05:55 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=98:de:d0:0d:c8:98 . 2016.10.06 20:05:55 - OpenVPN > There are no TAP-Windows adapters on this system. You should be able to create a TAP-Windows adapter by going to Start -> All Programs -> TAP-Windows -> Utilities -> Add a new TAP-Windows virtual ethernet adapter. . 2016.10.06 20:05:55 - OpenVPN > Exiting due to fatal error I 2016.10.06 20:05:58 - Checking authorization ... I 2016.10.06 20:06:00 - Cancel requested. I 2016.10.06 20:06:00 - IPv6 restored with packet filtering. ! 2016.10.06 20:06:00 - Session terminated. ! 2016.10.06 20:06:03 - Activation of Network Lock - Windows Filtering Platform I 2016.10.06 20:06:08 - Session starting. . 2016.10.06 20:06:08 - Cannot find tunnel adapter. ! 2016.10.06 20:06:08 - Installing tunnel driver I 2016.10.06 20:06:12 - IPv6 disabled with packet filtering. I 2016.10.06 20:06:12 - Checking authorization ... I 2016.10.06 20:06:49 - Cancel requested. I 2016.10.06 20:06:49 - IPv6 restored with packet filtering. ! 2016.10.06 20:06:49 - Session terminated. ! 2016.10.06 20:06:50 - Deactivation of Network Lock . 2016.10.06 20:07:09 - Updating systems & servers data ... . 2016.10.06 20:07:09 - Systems & servers data update completed ! 2016.10.06 20:07:12 - Activation of Network Lock - Windows Filtering Platform I 2016.10.06 20:07:17 - Session starting. I 2016.10.06 20:07:17 - IPv6 disabled with packet filtering. I 2016.10.06 20:07:17 - Checking authorization ... ! 2016.10.06 20:07:17 - Connecting to Virginis (Switzerland, Bern) . 2016.10.06 20:07:17 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Jun 1 2016 . 2016.10.06 20:07:17 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2016.10.06 20:07:17 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09 . 2016.10.06 20:07:17 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.10.06 20:07:17 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.10.06 20:07:17 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:07:17 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:07:17 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2016.10.06 20:07:17 - OpenVPN > UDPv4 link local: [undef] . 2016.10.06 20:07:17 - OpenVPN > UDPv4 link remote: [AF_INET]46.19.137.114:443 . 2016.10.06 20:07:17 - OpenVPN > TLS: Initial packet from [AF_INET]46.19.137.114:443, sid=46e77099 c8e83ee5 . 2016.10.06 20:07:17 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.10.06 20:07:17 - OpenVPN > Validating certificate key usage . 2016.10.06 20:07:17 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.10.06 20:07:17 - OpenVPN > VERIFY KU OK . 2016.10.06 20:07:17 - OpenVPN > Validating certificate extended key usage . 2016.10.06 20:07:17 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.10.06 20:07:17 - OpenVPN > VERIFY EKU OK . 2016.10.06 20:07:17 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.10.06 20:07:18 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 20:07:18 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:07:18 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 20:07:18 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:07:18 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.10.06 20:07:18 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]46.19.137.114:443 . 2016.10.06 20:07:20 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.10.06 20:07:20 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.7.129 255.255.0.0' . 2016.10.06 20:07:20 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.10.06 20:07:20 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.10.06 20:07:20 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.10.06 20:07:20 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.10.06 20:07:20 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.10.06 20:07:20 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.10.06 20:07:20 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=98:de:d0:0d:c8:98 . 2016.10.06 20:07:20 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.10.06 20:07:20 - OpenVPN > open_tun, tt->ipv6=0 . 2016.10.06 20:07:20 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{DD4EF667-959B-4849-AEAF-8BC1A1A505D6}.tap . 2016.10.06 20:07:20 - OpenVPN > TAP-Windows Driver Version 9.21 . 2016.10.06 20:07:20 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.7.129/255.255.0.0 [SUCCEEDED] . 2016.10.06 20:07:20 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.7.129/255.255.0.0 on interface {DD4EF667-959B-4849-AEAF-8BC1A1A505D6} [DHCP-serv: 10.4.255.254, lease-time: 31536000] . 2016.10.06 20:07:20 - OpenVPN > Successful ARP Flush on interface [11] {DD4EF667-959B-4849-AEAF-8BC1A1A505D6} . 2016.10.06 20:07:25 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2016.10.06 20:07:25 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 46.19.137.114 MASK 255.255.255.255 192.168.0.1 . 2016.10.06 20:07:26 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4 . 2016.10.06 20:07:26 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 20:07:26 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.10.06 20:07:26 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 . 2016.10.06 20:07:26 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 20:07:26 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.10.06 20:07:26 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 . 2016.10.06 20:07:26 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 20:07:26 - Starting Management Interface . 2016.10.06 20:07:26 - OpenVPN > Initialization Sequence Completed I 2016.10.06 20:07:26 - DNS leak protection with packet filtering enabled. I 2016.10.06 20:07:26 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1) I 2016.10.06 20:07:26 - Flushing DNS I 2016.10.06 20:07:26 - Checking route W 2016.10.06 20:08:16 - Timeout für Vorgang überschritten ! 2016.10.06 20:08:16 - Disconnecting . 2016.10.06 20:08:16 - Management - Send 'signal SIGTERM' . 2016.10.06 20:08:16 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info . 2016.10.06 20:08:16 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM' . 2016.10.06 20:08:16 - OpenVPN > SIGTERM received, sending exit notification to peer . 2016.10.06 20:08:21 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 46.19.137.114 MASK 255.255.255.255 192.168.0.1 . 2016.10.06 20:08:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.10.06 20:08:22 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.10.06 20:08:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.10.06 20:08:22 - OpenVPN > C:\WINDOWS\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.10.06 20:08:22 - OpenVPN > Route deletion via IPAPI succeeded [adaptive] . 2016.10.06 20:08:22 - Connection terminated. . 2016.10.06 20:08:22 - OpenVPN > Closing TUN/TAP interface . 2016.10.06 20:08:22 - OpenVPN > SIGTERM[soft,exit-with-notification] received, process exiting I 2016.10.06 20:08:22 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9, to automatic) I 2016.10.06 20:08:22 - DNS leak protection with packet filtering disabled. I 2016.10.06 20:08:25 - Checking authorization ... ! 2016.10.06 20:08:25 - Connecting to Thuban (France, Paris) . 2016.10.06 20:08:25 - OpenVPN > OpenVPN 2.3.11 x86_64-w64-mingw32 [SSL (OpenSSL)] [LZO] [IPv6] built on Jun 1 2016 . 2016.10.06 20:08:25 - OpenVPN > Windows version 6.2 (Windows 8 or greater) 64bit . 2016.10.06 20:08:25 - OpenVPN > library versions: OpenSSL 1.0.2h 3 May 2016, LZO 2.09 . 2016.10.06 20:08:25 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100 . 2016.10.06 20:08:25 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file . 2016.10.06 20:08:25 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:08:25 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:08:25 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144] . 2016.10.06 20:08:25 - OpenVPN > UDPv4 link local: [undef] . 2016.10.06 20:08:25 - OpenVPN > UDPv4 link remote: [AF_INET]195.154.188.113:443 . 2016.10.06 20:08:25 - OpenVPN > TLS: Initial packet from [AF_INET]195.154.188.113:443, sid=5d63eec6 f0104354 . 2016.10.06 20:08:25 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org . 2016.10.06 20:08:25 - OpenVPN > Validating certificate key usage . 2016.10.06 20:08:25 - OpenVPN > ++ Certificate has key usage 00a0, expects 00a0 . 2016.10.06 20:08:25 - OpenVPN > VERIFY KU OK . 2016.10.06 20:08:25 - OpenVPN > Validating certificate extended key usage . 2016.10.06 20:08:26 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication . 2016.10.06 20:08:26 - OpenVPN > VERIFY EKU OK . 2016.10.06 20:08:26 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org . 2016.10.06 20:08:26 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 20:08:26 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:08:26 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key . 2016.10.06 20:08:26 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication . 2016.10.06 20:08:26 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA . 2016.10.06 20:08:26 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]195.154.188.113:443 . 2016.10.06 20:08:28 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1) . 2016.10.06 20:08:28 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.19.10 255.255.0.0' . 2016.10.06 20:08:28 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified . 2016.10.06 20:08:28 - OpenVPN > OPTIONS IMPORT: LZO parms modified . 2016.10.06 20:08:28 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified . 2016.10.06 20:08:28 - OpenVPN > OPTIONS IMPORT: route options modified . 2016.10.06 20:08:28 - OpenVPN > OPTIONS IMPORT: route-related options modified . 2016.10.06 20:08:28 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified . 2016.10.06 20:08:28 - OpenVPN > ROUTE_GATEWAY 192.168.0.1/255.255.255.0 I=15 HWADDR=98:de:d0:0d:c8:98 . 2016.10.06 20:08:28 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0 . 2016.10.06 20:08:28 - OpenVPN > open_tun, tt->ipv6=0 . 2016.10.06 20:08:28 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{DD4EF667-959B-4849-AEAF-8BC1A1A505D6}.tap . 2016.10.06 20:08:29 - OpenVPN > TAP-Windows Driver Version 9.21 . 2016.10.06 20:08:29 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.19.10/255.255.0.0 [SUCCEEDED] . 2016.10.06 20:08:29 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.19.10/255.255.0.0 on interface {DD4EF667-959B-4849-AEAF-8BC1A1A505D6} [DHCP-serv: 10.4.255.254, lease-time: 31536000] . 2016.10.06 20:08:29 - OpenVPN > Successful ARP Flush on interface [11] {DD4EF667-959B-4849-AEAF-8BC1A1A505D6} . 2016.10.06 20:08:33 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up . 2016.10.06 20:08:33 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 195.154.188.113 MASK 255.255.255.255 192.168.0.1 . 2016.10.06 20:08:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4 . 2016.10.06 20:08:33 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 20:08:33 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.10.06 20:08:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 . 2016.10.06 20:08:33 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 20:08:33 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1 . 2016.10.06 20:08:33 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4 . 2016.10.06 20:08:33 - OpenVPN > Route addition via IPAPI succeeded [adaptive] . 2016.10.06 20:08:33 - Starting Management Interface . 2016.10.06 20:08:33 - OpenVPN > Initialization Sequence Completed I 2016.10.06 20:08:33 - DNS leak protection with packet filtering enabled. I 2016.10.06 20:08:33 - DNS of a network adapter forced (TAP-Windows Adapter V9, from automatic (10.4.0.1) to 10.4.0.1) I 2016.10.06 20:08:33 - Flushing DNS I 2016.10.06 20:08:33 - Checking route I 2016.10.06 20:09:04 - Checking DNS ! 2016.10.06 20:09:05 - Connected. . 2016.10.06 20:09:05 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100 . 2016.10.06 20:09:05 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2085 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2128 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2130 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2132 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2134 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2135 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2137 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2138 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2139 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2141 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2142 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2143 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2144 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2145 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2146 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2148 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:10:51 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2149 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:17:20 - Updating systems & servers data ... . 2016.10.06 20:17:21 - Systems & servers data update completed . 2016.10.06 20:18:27 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #79647 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:19:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #81147 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:19:20 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #81148 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:19:40 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #81731 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 20:24:51 - Updating systems & servers data ... . 2016.10.06 20:24:51 - Systems & servers data update completed -- System -- Operating System: Microsoft Windows NT 10.0.10586.0 System font: Segoe UI,9 System monospace font: Consolas,9 Network Interface: Ethernet (Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller, ID:{4DA09635-AF32-40AB-ACFC-03EF8BE45744}) - Ethernet - Down Network Interface: LAN-Verbindung* 11 (Microsoft Hosted Network Virtual Adapter #2, ID:{C171488E-B8A4-43D1-9731-1DFCD086224B}) - Wireless80211 - Down Network Interface: LAN-Verbindung* 12 (Microsoft Wi-Fi Direct Virtual Adapter, ID:{257EFA03-889F-4C0E-A51F-B9AEEE7E03CA}) - Wireless80211 - Down Network Interface: WLAN (TP-LINK Wireless USB Adapter, ID:{B0F0E5A7-5A33-43F6-BDC9-4EC4F01B45E4}) - Wireless80211 - Up Network Interface: Ethernet 2 (TAP-Windows Adapter V9, ID:{DD4EF667-959B-4849-AEAF-8BC1A1A505D6}) - Ethernet - Up Network Interface: Loopback Pseudo-Interface 1 (Software Loopback Interface 1, ID:{F37CA41E-E415-11E5-B45A-806E6F6E6963}) - Loopback - Up Network Interface: isatap.home (Microsoft ISATAP Adapter, ID:{C70A0B22-CA34-4998-9072-832CC82D6785}) - Tunnel - Down Network Interface: isatap.{DD4EF667-959B-4849-AEAF-8BC1A1A505D6} (Microsoft ISATAP Adapter #2, ID:{9444F601-7219-4D1E-8E17-8BA973167074}) - Tunnel - Down Network Interface: Teredo Tunneling Pseudo-Interface (Teredo Tunneling Pseudo-Interface, ID:{963E20B9-AFBD-4487-AE1C-62258F0095C5}) - Tunnel - Down Routing: Address: 0.0.0.0, Mask: 0.0.0.0, Gateway: 192.168.0.1, Interface: 15, Metrics: 10, Flags: , Mss: , Window: , Irtt: Address: 0.0.0.0, Mask: 128.0.0.0, Gateway: 10.8.0.1, Interface: 15, Metrics: 11, Flags: , Mss: , Window: , Irtt: Address: 0.0.0.0, Mask: 128.0.0.0, Gateway: 10.4.0.1, Interface: 11, Metrics: 20, Flags: , Mss: , Window: , Irtt: Address: 128.0.0.0, Mask: 128.0.0.0, Gateway: 10.8.0.1, Interface: 15, Metrics: 11, Flags: , Mss: , Window: , Irtt: Address: 128.0.0.0, Mask: 128.0.0.0, Gateway: 10.4.0.1, Interface: 11, Metrics: 20, Flags: , Mss: , Window: , Irtt: Address: 195.154.188.113, Mask: 255.255.255.255, Gateway: 192.168.0.1, Interface: 15, Metrics: 10, Flags: , Mss: , Window: , Irtt: Default gateways: 192.168.0.1, TP-LINK Wireless USB Adapter -- Windows-Only specific -- ipconfig /all Windows-IP-Konfiguration Hostname . . . . . . . . . . . . : Nocturnoz Prim„res DNS-Suffix . . . . . . . : Knotentyp . . . . . . . . . . . . : Hybrid IP-Routing aktiviert . . . . . . : Nein WINS-Proxy aktiviert . . . . . . : Nein DNS-Suffixsuchliste . . . . . . . : home Ethernet-Adapter Ethernet: Medienstatus. . . . . . . . . . . : Medium getrennt Verbindungsspezifisches DNS-Suffix: Beschreibung. . . . . . . . . . . : Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller Physische Adresse . . . . . . . . : 00-23-54-4A-84-47 DHCP aktiviert. . . . . . . . . . : Ja Autokonfiguration aktiviert . . . : Ja Drahtlos-LAN-Adapter LAN-Verbindung* 11: Medienstatus. . . . . . . . . . . : Medium getrennt Verbindungsspezifisches DNS-Suffix: Beschreibung. . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter #2 Physische Adresse . . . . . . . . : 98-DE-D0-0D-C8-99 DHCP aktiviert. . . . . . . . . . : Ja Autokonfiguration aktiviert . . . : Ja Drahtlos-LAN-Adapter LAN-Verbindung* 12: Medienstatus. . . . . . . . . . . : Medium getrennt Verbindungsspezifisches DNS-Suffix: Beschreibung. . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter Physische Adresse . . . . . . . . : 98-DE-D0-0D-C8-9A DHCP aktiviert. . . . . . . . . . : Ja Autokonfiguration aktiviert . . . : Ja Drahtlos-LAN-Adapter WLAN: Verbindungsspezifisches DNS-Suffix: home Beschreibung. . . . . . . . . . . : TP-LINK Wireless USB Adapter Physische Adresse . . . . . . . . : 98-DE-D0-0D-C8-98 DHCP aktiviert. . . . . . . . . . : Ja Autokonfiguration aktiviert . . . : Ja Verbindungslokale IPv6-Adresse . : fe80::cd66:f6aa:ff13:c026%15(Bevorzugt) IPv4-Adresse . . . . . . . . . . : 192.168.0.31(Bevorzugt) Subnetzmaske . . . . . . . . . . : 255.255.255.0 Lease erhalten. . . . . . . . . . : Donnerstag, 6. Oktober 2016 18:57:23 Lease l„uft ab. . . . . . . . . . : Donnerstag, 6. Oktober 2016 20:27:22 Standardgateway . . . . . . . . . : 192.168.0.1 DHCP-Server . . . . . . . . . . . : 192.168.0.1 DHCPv6-IAID . . . . . . . . . . . : 563666640 DHCPv6-Client-DUID. . . . . . . . : 00-01-00-01-1E-6E-0C-CD-00-23-54-4A-84-47 DNS-Server . . . . . . . . . . . : 192.168.0.1 NetBIOS ber TCP/IP . . . . . . . : Aktiviert Ethernet-Adapter Ethernet 2: Verbindungsspezifisches DNS-Suffix: Beschreibung. . . . . . . . . . . : TAP-Windows Adapter V9 Physische Adresse . . . . . . . . : 00-FF-DD-4E-F6-67 DHCP aktiviert. . . . . . . . . . : Ja Autokonfiguration aktiviert . . . : Ja Verbindungslokale IPv6-Adresse . : fe80::8d69:c0df:acd5:d763%11(Bevorzugt) IPv4-Adresse . . . . . . . . . . : 10.4.19.10(Bevorzugt) Subnetzmaske . . . . . . . . . . : 255.255.0.0 Lease erhalten. . . . . . . . . . : Donnerstag, 6. Oktober 2016 19:08:28 Lease l„uft ab. . . . . . . . . . : Freitag, 6. Oktober 2017 19:08:32 Standardgateway . . . . . . . . . : DHCP-Server . . . . . . . . . . . : 10.4.255.254 DHCPv6-IAID . . . . . . . . . . . : 184614877 DHCPv6-Client-DUID. . . . . . . . : 00-01-00-01-1E-6E-0C-CD-00-23-54-4A-84-47 DNS-Server . . . . . . . . . . . : 10.4.0.1 NetBIOS ber TCP/IP . . . . . . . : Aktiviert Tunneladapter isatap.home: Medienstatus. . . . . . . . . . . : Medium getrennt Verbindungsspezifisches DNS-Suffix: home Beschreibung. . . . . . . . . . . : Microsoft ISATAP Adapter Physische Adresse . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP aktiviert. . . . . . . . . . : Nein Autokonfiguration aktiviert . . . : Ja Tunneladapter isatap.{DD4EF667-959B-4849-AEAF-8BC1A1A505D6}: Medienstatus. . . . . . . . . . . : Medium getrennt Verbindungsspezifisches DNS-Suffix: Beschreibung. . . . . . . . . . . : Microsoft ISATAP Adapter #2 Physische Adresse . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP aktiviert. . . . . . . . . . : Nein Autokonfiguration aktiviert . . . : Ja Tunneladapter Teredo Tunneling Pseudo-Interface: Medienstatus. . . . . . . . . . . : Medium getrennt Verbindungsspezifisches DNS-Suffix: Beschreibung. . . . . . . . . . . : Teredo Tunneling Pseudo-Interface Physische Adresse . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP aktiviert. . . . . . . . . . : Nein Autokonfiguration aktiviert . . . : Ja -- NetworkAdapterConfiguration Network Adapter: [00000000] Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000000] Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller DHCPEnabled: true DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 0 InterfaceIndex: 8 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: 00:23:54:4A:84:47 MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: L1E SettingID: {4DA09635-AF32-40AB-ACFC-03EF8BE45744} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000001] Microsoft Kernel Debug Network Adapter DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000001] Microsoft Kernel Debug Network Adapter DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: Microsoft Kernel Debug Network Adapter DHCPEnabled: true DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 1 InterfaceIndex: 23 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: kdnic SettingID: {EB966A22-0E64-46C1-AAAF-C695A09B0F27} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000002] Realtek RTL8191SU Wireless LAN 802.11n USB 2.0 Network Adapter DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000002] Realtek RTL8191SU Wireless LAN 802.11n USB 2.0 Network Adapter DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: Realtek RTL8191SU Wireless LAN 802.11n USB 2.0 Network Adapter DHCPEnabled: true DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 2 InterfaceIndex: 17 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: RTL8192su SettingID: {BC984767-DE01-4844-B79E-C1F8693FC84A} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000003] HTC Remote NDIS based Device DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000003] HTC Remote NDIS based Device DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: HTC Remote NDIS based Device DHCPEnabled: true DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 3 InterfaceIndex: 10 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: usb_rndisx SettingID: {61B2C7C7-DEA5-474E-BCB8-BFAECE72D6B4} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000004] WAN Miniport (SSTP) DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000004] WAN Miniport (SSTP) DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: WAN Miniport (SSTP) DHCPEnabled: false DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 4 InterfaceIndex: 7 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: RasSstp SettingID: {3A6EE019-DC31-4F43-B031-D82B2752BB0A} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000005] Microsoft Hosted Network Virtual Adapter DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000005] Microsoft Hosted Network Virtual Adapter DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: Microsoft Hosted Network Virtual Adapter DHCPEnabled: true DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 5 InterfaceIndex: 3 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: vwifimp SettingID: {0D617EF4-CF39-4ECE-91E3-03989188B485} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000006] WAN Miniport (IKEv2) DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000006] WAN Miniport (IKEv2) DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: WAN Miniport (IKEv2) DHCPEnabled: false DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 6 InterfaceIndex: 2 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: RasAgileVpn SettingID: {054D4025-D95D-45C0-A242-D51938F4C3EE} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000007] TAP-Windows Adapter V9 DNS: 10.4.0.1 Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000007] TAP-Windows Adapter V9 DatabasePath: %SystemRoot%\System32\drivers\etc DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: TAP-Windows Adapter V9 DHCPEnabled: true DHCPLeaseExpires: 20171006190833.000000+060 DHCPLeaseObtained: 20161006190833.000000+060 DHCPServer: 10.4.255.254 DNSDomain: null DNSDomainSuffixSearchOrder: home DNSEnabledForWINSResolution: false DNSHostName: Nocturnoz DNSServerSearchOrder: 10.4.0.1 DomainDNSRegistrationEnabled: false ForwardBufferMemory: null FullDNSRegistrationEnabled: true GatewayCostMetric: null IGMPLevel: null Index: 7 InterfaceIndex: 11 IPAddress: 10.4.19.10,fe80::8d69:c0df:acd5:d763 IPConnectionMetric: 20 IPEnabled: true IPFilterSecurityEnabled: false IPPortSecurityEnabled: null IPSecPermitIPProtocols: IPSecPermitTCPPorts: IPSecPermitUDPPorts: IPSubnet: 255.255.0.0,64 IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: 00:FF:DD:4E:F6:67 MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: tap0901 SettingID: {DD4EF667-959B-4849-AEAF-8BC1A1A505D6} TcpipNetbiosOptions: 0 TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: true WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: WINSSecondaryServer: null Network Adapter: [00000008] WAN Miniport (L2TP) DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000008] WAN Miniport (L2TP) DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: WAN Miniport (L2TP) DHCPEnabled: false DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 8 InterfaceIndex: 20 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: Rasl2tp SettingID: {D17C1F7C-9A64-412B-B8E0-6ED04AD34AFE} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000009] WAN Miniport (PPTP) DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000009] WAN Miniport (PPTP) DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: WAN Miniport (PPTP) DHCPEnabled: false DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 9 InterfaceIndex: 21 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: PptpMiniport SettingID: {DC7AFD7C-0074-4E91-841B-E2646C7EB7CF} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000010] WAN Miniport (PPPOE) DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000010] WAN Miniport (PPPOE) DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: WAN Miniport (PPPOE) DHCPEnabled: false DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 10 InterfaceIndex: 22 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: RasPppoe SettingID: {E91B7F26-739F-4394-8433-9981953282A5} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000011] WAN Miniport (IP) DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000011] WAN Miniport (IP) DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: WAN Miniport (IP) DHCPEnabled: false DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 11 InterfaceIndex: 6 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: NdisWan SettingID: {398D1031-13DF-453F-A204-6644D336F52F} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000012] WAN Miniport (IPv6) DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000012] WAN Miniport (IPv6) DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: WAN Miniport (IPv6) DHCPEnabled: false DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 12 InterfaceIndex: 9 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: NdisWan SettingID: {52B5CD31-9B2B-466A-A4F3-177D6ED4672B} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000013] WAN Miniport (Network Monitor) DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000013] WAN Miniport (Network Monitor) DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: WAN Miniport (Network Monitor) DHCPEnabled: false DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 13 InterfaceIndex: 14 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: NdisWan SettingID: {99261D59-8033-4F05-A447-E6EF760D5EBB} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000014] Microsoft ISATAP Adapter DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000014] Microsoft ISATAP Adapter DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: Microsoft ISATAP Adapter DHCPEnabled: false DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 14 InterfaceIndex: 19 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: tunnel SettingID: {C70A0B22-CA34-4998-9072-832CC82D6785} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000015] Microsoft ISATAP Adapter DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000015] Microsoft ISATAP Adapter DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: Microsoft ISATAP Adapter DHCPEnabled: false DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 15 InterfaceIndex: 12 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: tunnel SettingID: {9444F601-7219-4D1E-8E17-8BA973167074} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000016] Microsoft Teredo Tunneling Adapter DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000016] Microsoft Teredo Tunneling Adapter DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: Microsoft Teredo Tunneling Adapter DHCPEnabled: false DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 16 InterfaceIndex: 13 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: tunnel SettingID: {963E20B9-AFBD-4487-AE1C-62258F0095C5} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000017] Cisco AnyConnect Secure Mobility Client Virtual Miniport Adapter for Windows x64 DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000017] Cisco AnyConnect Secure Mobility Client Virtual Miniport Adapter for Windows x64 DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: Cisco AnyConnect Secure Mobility Client Virtual Miniport Adapter for Windows x64 DHCPEnabled: false DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 17 InterfaceIndex: 16 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: vpnva SettingID: {B7B47DFF-3B4F-4978-B4DF-DECD641C7F6C} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000018] Microsoft ISATAP Adapter DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000018] Microsoft ISATAP Adapter DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: Microsoft ISATAP Adapter DHCPEnabled: false DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 18 InterfaceIndex: 5 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: null MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: tunnel SettingID: {29E55215-2A22-4D70-A842-1BDC670A9BF8} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000019] TP-LINK Wireless USB Adapter DNS: 192.168.0.1 Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000019] TP-LINK Wireless USB Adapter DatabasePath: %SystemRoot%\System32\drivers\etc DeadGWDetectEnabled: null DefaultIPGateway: 192.168.0.1 DefaultTOS: null DefaultTTL: null Description: TP-LINK Wireless USB Adapter DHCPEnabled: true DHCPLeaseExpires: 20161006202723.000000+060 DHCPLeaseObtained: 20161006192723.000000+060 DHCPServer: 192.168.0.1 DNSDomain: home DNSDomainSuffixSearchOrder: home DNSEnabledForWINSResolution: false DNSHostName: Nocturnoz DNSServerSearchOrder: 192.168.0.1 DomainDNSRegistrationEnabled: false ForwardBufferMemory: null FullDNSRegistrationEnabled: true GatewayCostMetric: System.UInt16[] IGMPLevel: null Index: 19 InterfaceIndex: 15 IPAddress: 192.168.0.31,fe80::cd66:f6aa:ff13:c026 IPConnectionMetric: 10 IPEnabled: true IPFilterSecurityEnabled: false IPPortSecurityEnabled: null IPSecPermitIPProtocols: IPSecPermitTCPPorts: IPSecPermitUDPPorts: IPSubnet: 255.255.255.0,64 IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: 98:DE:D0:0D:C8:98 MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: netr28ux SettingID: {B0F0E5A7-5A33-43F6-BDC9-4EC4F01B45E4} TcpipNetbiosOptions: 0 TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: true WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: WINSSecondaryServer: null Network Adapter: [00000020] Microsoft Hosted Network Virtual Adapter DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000020] Microsoft Hosted Network Virtual Adapter DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: Microsoft Hosted Network Virtual Adapter DHCPEnabled: true DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 20 InterfaceIndex: 18 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: 98:DE:D0:0D:C8:99 MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: vwifimp SettingID: {C171488E-B8A4-43D1-9731-1DFCD086224B} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Network Adapter: [00000021] Microsoft Wi-Fi Direct Virtual Adapter DNS: null Details: ArpAlwaysSourceRoute: null ArpUseEtherSNAP: null Caption: [00000021] Microsoft Wi-Fi Direct Virtual Adapter DatabasePath: null DeadGWDetectEnabled: null DefaultIPGateway: null DefaultTOS: null DefaultTTL: null Description: Microsoft Wi-Fi Direct Virtual Adapter DHCPEnabled: true DHCPLeaseExpires: null DHCPLeaseObtained: null DHCPServer: null DNSDomain: null DNSDomainSuffixSearchOrder: null DNSEnabledForWINSResolution: null DNSHostName: null DNSServerSearchOrder: null DomainDNSRegistrationEnabled: null ForwardBufferMemory: null FullDNSRegistrationEnabled: null GatewayCostMetric: null IGMPLevel: null Index: 21 InterfaceIndex: 4 IPAddress: null IPConnectionMetric: null IPEnabled: false IPFilterSecurityEnabled: null IPPortSecurityEnabled: null IPSecPermitIPProtocols: null IPSecPermitTCPPorts: null IPSecPermitUDPPorts: null IPSubnet: null IPUseZeroBroadcast: null IPXAddress: null IPXEnabled: null IPXFrameType: null IPXMediaType: null IPXNetworkNumber: null IPXVirtualNetNumber: null KeepAliveInterval: null KeepAliveTime: null MACAddress: 98:DE:D0:0D:C8:9A MTU: null NumForwardPackets: null PMTUBHDetectEnabled: null PMTUDiscoveryEnabled: null ServiceName: vwifimp SettingID: {257EFA03-889F-4C0E-A51F-B9AEEE7E03CA} TcpipNetbiosOptions: null TcpMaxConnectRetransmissions: null TcpMaxDataRetransmissions: null TcpNumConnections: null TcpUseRFC1122UrgentPointer: null TcpWindowSize: null WINSEnableLMHostsLookup: null WINSHostLookupFile: null WINSPrimaryServer: null WINSScopeID: null WINSSecondaryServer: null Updated Logfile Quote Share this post Link to post
me.moo@posteo.me 80 Posted ... Try using spoiler tags, people would be more likely to respond. Uninstalling/Reinstalling software is almost always a waste of time, a backward step, solves nothing. I would open a support ticket unless anyone can spot something here ? Quote Share this post Link to post
OpenSourcerer 1360 Posted ... . 2016.10.06 18:20:34 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1483 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 18:20:34 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1733 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 18:20:34 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1734 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 18:20:34 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1939 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 18:20:34 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #1940 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 18:20:35 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #2282 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 18:24:22 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #14928 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings . 2016.10.06 18:26:26 - OpenVPN > Authenticate/Decrypt packet error: bad packet ID (may be a replay): [ #23716 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings Have a look at Weird log entries. Quote Hide OpenSourcerer's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
