Not connected, Your IP: 216.73.217.100
mrfish
Multiple connection problems
I think this is too complicated for me I should be somewhere simpler.
I have tried many of the solutions even down to having a complete reinstall done on Windows 7.
Tap driver back to the old one, I can't remember the number but it is what was suggested and blocked it from automatically updating in Eddie.
Everytime I turn my back the DNS on the LA connections goes from Automatic to 10.4.0.1 so I manually reset it to automatic.
At the moment AIR is not letting me connect at all, well it connects but won't let me use the internet see speed test attached.
I have tried the reset of the firewall.
I will post this then turn off and see if I can reconnect with air.
If it makes any difference I am in Vietnam and I tether through a Blackberry Z10, on a good day I can tether at 5Mbps, this morning I was getting the same from Air on a UK server, then it went tits up again and dropped to 0.5 now as you can see there is no connection at all through Air.
Any suggestions greatly accepted but please bear in mind you are dealing with someone who can follow instructions but does not know computers.
