chuckhammerberry 2 Posted ... I had an issue with the eddie client which led me to support and then to other VPN providers to testI ended up hooking back my pfsense box and staying with airvpn, why? speeds Currently i am downloading a torrent on airvpn at 29.2 MB/s and my speedtest.net speeds on airvpn at 197Mbps / 21Mbps With torguard i was getting 35Mbps / 19Mbpsand purevpn 10Mbps / 2MbpsCactus VPN 37Mbps / 18Mbps Quote Share this post Link to post
Guest Posted ... Try this: Try to set the buffer size to 256 kB (in "AirVPN" -> "Preferences" -> "Advanced" -> "General"). Click "Save" and start a new VPN connection. This solution was given to me by the staff and it worked for me. Try it out! Quote Share this post Link to post
chuckhammerberry 2 Posted ... thanks for the reply but I'm bot using eddie client, I'm using pfsense so my entire home network is routed through the VPN And my speeds are already great I'm getting 197Mbps down (my ISP speed is 200Mbps) Quote Share this post Link to post
willieaames 3 Posted ... My Torrent speeds are 19.5 MB/s and connection speed is 25 Mbps / 21Mbps Quote Share this post Link to post
germain85 1 Posted ... With Asus N66 15/10 connection... without vpn 16/11 on speedtest... With my old PIA vpn 10/9.. and with AirvpnDown: 12.798 Mbit/s Out, 6.539 Mbit/s In (51%), 20MB - Up: 9.408 Mbit/s Out, 7.931 Mbit/s In (84%), 20MB - Date: Fri, 19 Aug 2016 14:06:59 GMT - Buffers: 20MB/20MB - Laps: 3, Time: 123.14 secs Quote Share this post Link to post
soupy 7 Posted ... Try this: Try to set the buffer size to 256 kB (in "AirVPN" -> "Preferences" -> "Advanced" -> "General"). Click "Save" and start a new VPN connection. This solution was given to me by the staff and it worked for me. Try it out! Why not set it to 512? Quote Share this post Link to post
Tech Jedi Alex 1580 Posted ... Try this: Try to set the buffer size to 256 kB (in "AirVPN" -> "Preferences" -> "Advanced" -> "General"). Click "Save" and start a new VPN connection. This solution was given to me by the staff and it worked for me. Try it out! Why not set it to 512? A high value can be counterproductive because it will wait until 512 kB of data are there to send/receive. You can try it out, though. Smaller packets or applications needing little data will have higher latency because of this. I've got a 50 MBit connection and 64 kB are more than enough to max it out with AirVPN. But every setup is different, for some people it will only work from 128 upwards. 1 soupy reacted to this Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
