Not connected, Your IP: 18.218.38.125
Ok, so not that long ago I ran into problems setting up VPN for torrenting; and after help from NaDre and the AirVPN staff I was able to set it up. But, I have ran into a few more issues since then............
(Just to note I have no DNS/IP leaks what so ever... Checked with IPleak.net, dnsleaktest.com and dnsleak.com)
Issues:
When I download the IPleak.net torrent and open it up with a torrent client (Utorrent & Vuze), under the 'Tracker' tab it says: "The handle is invalid".
I setup Vuze to correctly bind to the TAP adapter; Installed the VPN Helper for AirVPN Plugin and everything seems fine....
Port Forwarding and IP Binding
VPN OK!
Vuze UDP is currently bound to I0.50.2.192 aka eth9 [TAP -Wi ndows Adapter V9)
Found bindable address 10.50.2.192 on eth9 (JAP-Windows Adapter V9) which is likely VPN's Eocal IP
Non-Vuze probably routing through /10.50.2.192 aka eth9 (JAP-Windows Adapter V9), Same as bindable address
Excellent, Vuze already bound to eth9
Port 17345 returned from AirVPN RPC matches Vuze's settings
                        Verify public address(es):
                        Last Checked 09- Nov-201 5 1 6:43:1 6
                        HTTP outbou nd - 213.152.161.20 - Netherlands
                        TCP outbound -213.152.161.20 - Netherlands
                        UDP outbound - 213.152.161.20 - Netherlands
But, when I start downloading it gives me a warning that my network IP (192.168.** ) is leaking and Vuze just drops the connection.
The AirVPN client has trouble connecting to servers and timesout multiple times and tries multiple servers before finally connecting to a server. (takes 5 mins to establish a connection)
AirVPN Log:
I 2015.11.09 18:22:10 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64
. 2015.11.09 18:22:10 - Reading options from C:\Users\Cyber\AppData\Local\AirVPN\AirVPN.xml
. 2015.11.09 18:22:11 - Data Path: C:\Users\Cyber\AppData\Local\AirVPN
. 2015.11.09 18:22:11 - App Path: C:\Program Files\AirVPN
. 2015.11.09 18:22:11 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2015.11.09 18:22:11 - Command line arguments (1): path="home"
. 2015.11.09 18:22:11 - Operating System: Microsoft Windows NT 6.2.9200.0
. 2015.11.09 18:22:11 - Updating systems & servers data ...
I 2015.11.09 18:22:11 - OpenVPN Driver - TAP-Windows Adapter V9, version 9.21.1
I 2015.11.09 18:22:11 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2015.11.09 18:22:11 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2015.11.09 18:22:11 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2015.11.09 18:22:11 - Activation of Network Lock - Windows Firewall
. 2015.11.09 18:22:13 - Systems & servers data update completed
I 2015.11.09 18:22:16 - Session starting.
I 2015.11.09 18:22:16 - IPv6 disabled.
I 2015.11.09 18:22:23 - Checking authorization ...
! 2015.11.09 18:22:24 - Connecting to Rotanev (Canada, Toronto, Ontario)
. 2015.11.09 18:22:24 - SSH > Looking up host "104.254.90.188"
. 2015.11.09 18:22:24 - SSH > Connecting to 104.254.90.188 port 53
. 2015.11.09 18:22:24 - SSH > Server version: SSH-2.0-OpenSSH_6.7p1 Debian-5
. 2015.11.09 18:22:24 - SSH > Using SSH protocol version 2
. 2015.11.09 18:22:24 - SSH > We claim version: SSH-2.0-PuTTY_Release_0.63
. 2015.11.09 18:22:24 - SSH > Doing Diffie-Hellman group exchange
. 2015.11.09 18:22:24 - SSH > Doing Diffie-Hellman key exchange with hash SHA-256
. 2015.11.09 18:22:25 - SSH > The server's host key is not cached in the registry. You
. 2015.11.09 18:22:25 - SSH > have no guarantee that the server is the computer you
. 2015.11.09 18:22:25 - SSH > think it is.
. 2015.11.09 18:22:25 - SSH > The server's rsa2 key fingerprint is:
. 2015.11.09 18:22:25 - SSH > ssh-rsa 2048 a2:6d:14:ae:ff:7d:41:ff:f5:7b:21:ea:97:e0:30:c0
. 2015.11.09 18:22:25 - SSH > If you trust this host, enter "y" to add the key to
. 2015.11.09 18:22:25 - SSH > PuTTY's cache and carry on connecting.
. 2015.11.09 18:22:25 - SSH > If you want to carry on connecting just once, without
. 2015.11.09 18:22:25 - SSH > adding the key to the cache, enter "n".
. 2015.11.09 18:22:25 - SSH > If you do not trust this host, press Return to abandon the
. 2015.11.09 18:22:25 - SSH > connection.
. 2015.11.09 18:22:25 - SSH > Store key in cache? (y/n) Host key fingerprint is:
. 2015.11.09 18:22:25 - SSH > Initialised AES-256 SDCTR client->server encryption
. 2015.11.09 18:22:25 - SSH > Initialised HMAC-SHA-256 client->server MAC algorithm
. 2015.11.09 18:22:25 - SSH > Initialised AES-256 SDCTR server->client encryption
. 2015.11.09 18:22:25 - SSH > Initialised HMAC-SHA-256 server->client MAC algorithm
. 2015.11.09 18:22:25 - SSH > Reading private key file "C:\Users\Cyber\AppData\Local\AirVPN\420f43c9520d71a49aaf9cbfdbd05db525a75d77532624eb83a60738f875d71c.tmp.ppk"
. 2015.11.09 18:22:25 - SSH > Using username "sshtunnel".
. 2015.11.09 18:22:25 - SSH > Offered public key
. 2015.11.09 18:22:25 - SSH > Offer of public key accepted
. 2015.11.09 18:22:25 - SSH > Authenticating with public key ""
. 2015.11.09 18:22:25 - SSH > Sent public key signature
. 2015.11.09 18:22:25 - SSH > Access granted
. 2015.11.09 18:22:25 - SSH > Local port 21180 forwarding to 127.0.0.1:2018
. 2015.11.09 18:22:25 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2015.11.09 18:22:25 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2015.11.09 18:22:25 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2015.11.09 18:22:25 - SSH > Remote debug message: Pty allocation disabled.
. 2015.11.09 18:22:25 - SSH > Remote debug message: X11 forwarding disabled.
. 2015.11.09 18:22:25 - SSH > Remote debug message: Forced command.
. 2015.11.09 18:22:25 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2015.11.09 18:22:25 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.09 18:22:25 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.09 18:22:25 - OpenVPN > Socket Buffers: R=[65536->131072] S=[65536->131072]
. 2015.11.09 18:22:25 - OpenVPN > Attempting to establish TCP connection with [AF_INET]127.0.0.1:21180 [nonblock]
. 2015.11.09 18:22:25 - OpenVPN > TCP connection established with [AF_INET]127.0.0.1:21180
. 2015.11.09 18:22:25 - SSH > Opening connection to 127.0.0.1:2018 for forwarding
. 2015.11.09 18:22:25 - OpenVPN > TCPv4_CLIENT link local: [undef]
. 2015.11.09 18:22:25 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:21180
. 2015.11.09 18:22:26 - OpenVPN > TLS: Initial packet from [AF_INET]127.0.0.1:21180, sid=070205a9 64117de4
. 2015.11.09 18:22:27 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2015.11.09 18:22:27 - OpenVPN > Validating certificate key usage
. 2015.11.09 18:22:27 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2015.11.09 18:22:27 - OpenVPN > VERIFY KU OK
. 2015.11.09 18:22:27 - OpenVPN > Validating certificate extended key usage
. 2015.11.09 18:22:27 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2015.11.09 18:22:27 - OpenVPN > VERIFY EKU OK
. 2015.11.09 18:22:27 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2015.11.09 18:22:30 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.09 18:22:30 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.09 18:22:30 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2015.11.09 18:22:30 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2015.11.09 18:22:30 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2015.11.09 18:22:30 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]127.0.0.1:21180
. 2015.11.09 18:22:33 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2015.11.09 18:22:33 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.50.0.1,comp-lzo no,route-gateway 10.50.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.50.2.192 255.255.0.0'
. 2015.11.09 18:22:33 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2015.11.09 18:22:33 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2015.11.09 18:22:33 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2015.11.09 18:22:33 - OpenVPN > OPTIONS IMPORT: route options modified
. 2015.11.09 18:22:33 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2015.11.09 18:22:33 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2015.11.09 18:22:33 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2015.11.09 18:22:33 - OpenVPN > open_tun, tt->ipv6=0
. 2015.11.09 18:22:34 - OpenVPN > TAP-WIN32 device [Ethernet 5] opened: \\.\Global\{D7834FFF-EAD5-4C41-96CA-DE9A2E26C12D}.tap
. 2015.11.09 18:22:34 - OpenVPN > TAP-Windows Driver Version 9.21
. 2015.11.09 18:22:34 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.50.0.0/10.50.2.192/255.255.0.0 [sUCCEEDED]
. 2015.11.09 18:22:34 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.50.2.192/255.255.0.0 on interface {D7834FFF-EAD5-4C41-96CA-DE9A2E26C12D} [DHCP-serv: 10.50.255.254, lease-time: 31536000]
. 2015.11.09 18:22:34 - OpenVPN > Successful ARP Flush on interface [23] {D7834FFF-EAD5-4C41-96CA-DE9A2E26C12D}
. 2015.11.09 18:22:38 - OpenVPN > TEST ROUTES: 2/2 succeeded len=1 ret=1 a=1 u/d=up
. 2015.11.09 18:22:38 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 192.168.0.1
. 2015.11.09 18:22:38 - OpenVPN > Warning: route gateway is ambiguous: 192.168.0.1 (2 matches)
. 2015.11.09 18:22:38 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2015.11.09 18:22:38 - OpenVPN > Route addition fallback to route.exe
. 2015.11.09 18:22:38 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2015.11.09 18:22:38 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.0.1 MASK 255.255.255.255 192.168.0.1 IF 8
. 2015.11.09 18:22:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=10 and dwForwardType=4
. 2015.11.09 18:22:38 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2015.11.09 18:22:38 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2015.11.09 18:22:38 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2015.11.09 18:22:38 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.50.0.1
. 2015.11.09 18:22:38 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 104.254.90.188 MASK 255.255.255.255 192.168.0.1
. 2015.11.09 18:22:38 - Starting Management Interface
. 2015.11.09 18:22:38 - OpenVPN > Initialization Sequence Completed
I 2015.11.09 18:22:39 - DNS of a network adapter forced (Intel® 82579V Gigabit Network Connection)
I 2015.11.09 18:22:39 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2015.11.09 18:22:39 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2015.11.09 18:22:39 - Flushing DNS
I 2015.11.09 18:22:39 - Checking route
W 2015.11.09 18:22:51 - Checking route, 1° try failed (The operation has timed out)
W 2015.11.09 18:23:04 - Checking info, 1° try failed (The operation has timed out)
I 2015.11.09 18:23:04 - Checking DNS
! 2015.11.09 18:23:05 - Connected.
. 2015.11.09 18:23:05 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2015.11.09 18:23:05 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
IPConfig/Routing Table:
Microsoft Windows [Version 10.0.10565]
© 2016 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>Ipconfig /all
Windows IP Configuration
   Host Name . . . . . . . . . . . . : CyberPCNet
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Local Area Connection* 2:
   Media State . . . . . . . . . . . : Media disconnected
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
   Physical Address. . . . . . . . . : 96-DB-C9-AC-37-74
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Ethernet:
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . : C8-60-00-CC-C7-46
   Link-local IPv6 Address . . . . . : fe80::d061:5bc4:fea:ce23%12(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.0.2(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Monday, November 9, 2015 3:36:10 PM
   Lease Expires . . . . . . . . . . : Monday, November 9, 2015 7:22:40 PM
   Default Gateway . . . . . . . . . : 192.168.0.1
   DHCP Server . . . . . . . . . . . : 192.168.0.1
   DHCPv6 IAID . . . . . . . . . . . : 63463424
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1D-C1-41-B9-C8-60-00-CC-C7-46
   DNS Servers . . . . . . . . . . . : 10.50.0.1
   NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Ethernet 2:
   Description . . . . . . . . . . . : Intel® 82579V Gigabit Network Connection
   Physical Address. . . . . . . . . : C8-60-00-CC-CA-FC
   Link-local IPv6 Address . . . . . : fe80::cda5:b46:5dd5:d5c%8(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.0.4(Preferred)
   Lease Obtained. . . . . . . . . . : Monday, November 9, 2015 3:37:26 PM
   DHCPv6 IAID . . . . . . . . . . . : 130572288
Ethernet adapter Ethernet 3:
   Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet1
   Physical Address. . . . . . . . . : 00-50-56-C0-00-01
   DHCP Enabled. . . . . . . . . . . : No
   Link-local IPv6 Address . . . . . : fe80::4da6:bdbf:5d17:336a%9(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.254.1(Preferred)
   DHCPv6 IAID . . . . . . . . . . . : 100683862
   DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Ethernet adapter Ethernet 4:
   Description . . . . . . . . . . . : VMware Virtual Ethernet Adapter for VMnet8
   Physical Address. . . . . . . . . : 00-50-56-C0-00-08
   Link-local IPv6 Address . . . . . : fe80::6581:6a28:a206:2d7f%22(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.149.1(Preferred)
   DHCPv6 IAID . . . . . . . . . . . : 167792726
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
Ethernet adapter Ethernet 5:
   Description . . . . . . . . . . . : TAP-Windows Adapter V9
   Physical Address. . . . . . . . . : 00-FF-D7-83-4F-FF
   Link-local IPv6 Address . . . . . : fe80::3424:4f4a:74bd:9d21%23(Preferred)
   IPv4 Address. . . . . . . . . . . : 10.50.2.192(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.0.0
   Lease Obtained. . . . . . . . . . : Monday, November 9, 2015 6:22:33 PM
   Lease Expires . . . . . . . . . . : Tuesday, November 8, 2016 6:22:39 PM
   DHCP Server . . . . . . . . . . . : 10.50.255.254
   DHCPv6 IAID . . . . . . . . . . . : 385941463
Wireless LAN adapter Wi-Fi:
   Description . . . . . . . . . . . : Broadcom 802.11n Network Adapter
   Physical Address. . . . . . . . . : 94-DB-C9-AC-37-74
Ethernet adapter Ethernet 6:
   Description . . . . . . . . . . . : TeamViewer VPN Adapter
   Physical Address. . . . . . . . . : 00-FF-D2-CD-A7-4A
Ethernet adapter Bluetooth Network Connection:
   Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
   Physical Address. . . . . . . . . : 94-DB-C9-8A-D1-47
Tunnel adapter isatap.{D3B30A45-68EF-4D0F-85D6-9ED44F31C017}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Tunnel adapter isatap.{427EAB2C-0BB1-4746-91E9-E903E5D9306C}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Tunnel adapter isatap.{45D386AF-707D-46CB-B058-BED362623267}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Tunnel adapter isatap.{D7834FFF-EAD5-4C41-96CA-DE9A2E26C12D}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #5
Tunnel adapter isatap.{8C27365F-A185-42FA-824A-DD93FF3BCD99}:
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter #6
C:\WINDOWS\system32>route print
Interface List
 27...96 db c9 ac 37 74 ......Microsoft Wi-Fi Direct Virtual Adapter
 12...c8 60 00 cc c7 46 ......Realtek PCIe GBE Family Controller
  8...c8 60 00 cc ca fc ......Intel® 82579V Gigabit Network Connection
  9...00 50 56 c0 00 01 ......VMware Virtual Ethernet Adapter for VMnet1
 22...00 50 56 c0 00 08 ......VMware Virtual Ethernet Adapter for VMnet8
 23...00 ff d7 83 4f ff ......TAP-Windows Adapter V9
  2...94 db c9 ac 37 74 ......Broadcom 802.11n Network Adapter
 21...00 ff d2 cd a7 4a ......TeamViewer VPN Adapter
 17...94 db c9 8a d1 47 ......Bluetooth Device (Personal Area Network)
  1...........................Software Loopback Interface 1
  5...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
 20...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
 18...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #4
 13...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #5
 11...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #6
IPv4 Route Table
Active Routes:
Network Destination        Netmask          Gateway       Interface  Metric
          0.0.0.0          0.0.0.0      192.168.0.1      192.168.0.2     10
          0.0.0.0          0.0.0.0      192.168.0.1      192.168.0.4     10
          0.0.0.0        128.0.0.0        10.50.0.1      10.50.2.192     20
        10.50.0.0      255.255.0.0         On-link       10.50.2.192    276
      10.50.2.192  255.255.255.255         On-link       10.50.2.192    276
    10.50.255.255  255.255.255.255         On-link       10.50.2.192    276
   104.254.90.188  255.255.255.255      192.168.0.1      192.168.0.4     11
        127.0.0.0        255.0.0.0         On-link         127.0.0.1    306
        127.0.0.1  255.255.255.255         On-link         127.0.0.1    306
        127.0.0.1  255.255.255.255      192.168.0.1      192.168.0.2     11
  127.255.255.255  255.255.255.255         On-link         127.0.0.1    306
        128.0.0.0        128.0.0.0        10.50.0.1      10.50.2.192     20
      192.168.0.0    255.255.255.0         On-link       192.168.0.2    266
      192.168.0.0    255.255.255.0         On-link       192.168.0.4    266
      192.168.0.1  255.255.255.255      192.168.0.1      192.168.0.4     10
      192.168.0.2  255.255.255.255         On-link       192.168.0.2    266
      192.168.0.4  255.255.255.255         On-link       192.168.0.4    266
    192.168.0.255  255.255.255.255         On-link       192.168.0.2    266
    192.168.0.255  255.255.255.255         On-link       192.168.0.4    266
    192.168.149.0    255.255.255.0         On-link     192.168.149.1    276
    192.168.149.1  255.255.255.255         On-link     192.168.149.1    276
  192.168.149.255  255.255.255.255         On-link     192.168.149.1    276
    192.168.254.0    255.255.255.0         On-link     192.168.254.1    276
    192.168.254.1  255.255.255.255         On-link     192.168.254.1    276
  192.168.254.255  255.255.255.255         On-link     192.168.254.1    276
        224.0.0.0        240.0.0.0         On-link         127.0.0.1    306
        224.0.0.0        240.0.0.0         On-link       10.50.2.192    276
        224.0.0.0        240.0.0.0         On-link     192.168.254.1    276
        224.0.0.0        240.0.0.0         On-link     192.168.149.1    276
        224.0.0.0        240.0.0.0         On-link       192.168.0.2    266
        224.0.0.0        240.0.0.0         On-link       192.168.0.4    266
  255.255.255.255  255.255.255.255         On-link         127.0.0.1    306
  255.255.255.255  255.255.255.255         On-link       10.50.2.192    276
  255.255.255.255  255.255.255.255         On-link     192.168.254.1    276
  255.255.255.255  255.255.255.255         On-link     192.168.149.1    276
  255.255.255.255  255.255.255.255         On-link       192.168.0.2    266
  255.255.255.255  255.255.255.255         On-link       192.168.0.4    266
Persistent Routes:
  Network Address          Netmask  Gateway Address  Metric
IPv6 Route Table
Active Routes:
 If Metric Network Destination      Gateway
  1    306 ::1/128                  On-link
 23    276 fe80::/64                On-link
  9    276 fe80::/64                On-link
 22    276 fe80::/64                On-link
 12    266 fe80::/64                On-link
  8    266 fe80::/64                On-link
 23    276 fe80::3424:4f4a:74bd:9d21/128
                                    On-link
  9    276 fe80::4da6:bdbf:5d17:336a/128
                                    On-link
 22    276 fe80::6581:6a28:a206:2d7f/128
                                    On-link
  8    266 fe80::cda5:b46:5dd5:d5c/128
                                    On-link
 12    266 fe80::d061:5bc4:fea:ce23/128
                                    On-link
  1    306 ff00::/8                 On-link
 23    276 ff00::/8                 On-link
  9    276 ff00::/8                 On-link
 22    276 ff00::/8                 On-link
 12    266 ff00::/8                 On-link
  8    266 ff00::/8                 On-link
Persistent Routes:
  None
