Not connected, Your IP: 3.15.5.183
georgejohn
Unhandled exception thrown when exiting with Ctrl+C twice.
Using OpenSUSE 13.2, through terminal (because the GUI simply does not open) when I exit the process with Ctrl+C twice I get:
Unhandled Exception:
System.TypeInitializationException: An exception was thrown by the type initializer for System.Drawing.GDIPlus ---> System.DllNotFoundException: libgdiplus.so
  at (wrapper managed-to-native) System.Drawing.GDIPlus:GdiplusStartup (ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&)
  at System.Drawing.GDIPlus..cctor () [0x00000] in <filename unknown>:0
  --- End of inner exception stack trace ---
  at System.Drawing.Icon.Dispose () [0x00000] in <filename unknown>:0
  at (wrapper remoting-invoke-with-check) System.Drawing.Icon:Dispose ()
  at System.Drawing.Icon.Finalize () [0x00000] in <filename unknown>:0
This should be fixed. Btw is the package maintained? I haven't seen any updates or anything. Do I have to add a repo?
Since I apparently can't open a second issue until this gets approved I'd like to ask about the GUI that doesn't work. Is it only me? Are there logs somewhere I can see? I don't see anything in /var/log/. Is any other opensuse user having the same problem with the GUI? When I press the shortcut it simply does nothing.
