stonedwizard
AirVPN client shows HUGE upload speed, drops all connections
This is something that happens every few minutes regardless of which server I attempt to connect to:
Everything will begin normally and seem to work as intended. Then suddenly the AirVPN client shows that my upload rate is 10-80 MB/s and all the connections I am working with get dropped. This outage lasts a few seconds or a few minutes. The whole time the upload rate reads impossibly high and I can't connect to anything or use the internet etc.
Using an advanced task manager utility like Process Hacker or Process Explorer confirms that the operating system believes there is this much network I/O happening, though it's completely unclear what process this behavior originates from.
If I watch all open ports when this problem happens, I notice two things. First, most connections get reset. Second, there is very little traffic on every port (no where near 10-80 MB/s up or down).  Indeed the transfer total for every port is at most a couple megabytes.
Why do Windows and the AirVPN client think there is so much uploading happening when it seems like the network connection isn't functioning at all? What could the cause of this dysfunction be to begin with?
Still happening and super annoying.  PC freezes once in awhile too when it occurs.
It only happens in Eddie and not the regular OpenVPN client.
Edit:  Issue also happens with regular non-AirVPN OpenVPN client.
Very strange and frustrating!
I only use the servers in California so I'm testing out a non-Cali server to see if that's the issue.
Anyone have any ideas?
Edit:  I stayed on California servers all day but with another port (80 UDP instead of my regular 443 UDP), but after a few hours, my PC shut down while I was AFK.  I'm pretty sure it was again due to the crazy high upload.
I'm not on the Singapore server with port 80 UDP and am hoping for the best.
If anyone has any ideas about what could be causing this issue and how to fix it, it would be very much appreciated.
My issue is identical to what the OP of this thread wrote.
No one posting logfiles here? But why?
Please post your logfile in spoiler tags or upload it here.
[spoiler]123[/spoiler]
does this
123
I too have been experience the same issue, I've downloaded various Versions of the TAP adapter to see if that would correct the issue and also tried many other trouble shooting guides but to no success, The speed off the download is fine then gradually drops till i have no download speed at all. Even tho airVPN is showing crazy download speeds, My VPN Will then disconnect to the server and reconnect shortly after and the cycle starts again every 5-10 minutes, And no my internet is not being slowed by my isp, I am able to download with no issue without using my VPN
Here are the logs
I 2016.01.25 14:33:15 - AirVPN client version: 2.10.3 / x64, System: Windows, Name: Microsoft Windows NT 6.2.9200.0 / x64
. 2016.01.25 14:33:15 - Reading options from C:\Users\Eamonn\AppData\Local\AirVPN\AirVPN.xml
. 2016.01.25 14:33:15 - Data Path: C:\Users\Eamonn\AppData\Local\AirVPN
. 2016.01.25 14:33:15 - App Path: C:\Program Files\AirVPN
. 2016.01.25 14:33:15 - Executable Path: C:\Program Files\AirVPN\AirVPN.exe
. 2016.01.25 14:33:15 - Command line arguments (1): path="home"
. 2016.01.25 14:33:15 - Operating System: Microsoft Windows NT 6.2.9200.0
. 2016.01.25 14:33:15 - Updating systems & servers data ...
W 2016.01.25 14:33:15 - Tunnel driver will be upgraded, from 9.9.2 to 9.21.1.
. 2016.01.25 14:33:16 - Systems & servers data update completed
E 2016.01.25 14:33:16 - OpenVPN Driver - Not available
I 2016.01.25 14:33:16 - OpenVPN - Version: OpenVPN 2.3.8 (C:\Program Files\AirVPN\openvpn.exe)
I 2016.01.25 14:33:16 - SSH - Version: plink 0.63 (C:\Program Files\AirVPN\plink.exe)
I 2016.01.25 14:33:16 - SSL - Version: stunnel 5.17 (C:\Program Files\AirVPN\stunnel.exe)
! 2016.01.25 14:33:16 - Ready
W 2016.01.25 14:33:30 - Tunnel driver will be upgraded, from 9.9.2 to 9.21.1.
! 2016.01.25 14:33:42 - Activation of Network Lock - Windows Firewall
I 2016.01.25 14:33:45 - Session starting.
I 2016.01.25 14:33:45 - IPv6 disabled.
I 2016.01.25 14:33:45 - Checking authorization ...
! 2016.01.25 14:33:45 - Connecting to Ancha (Netherlands, Alblasserdam)
. 2016.01.25 14:33:45 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.01.25 14:33:45 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.01.25 14:33:45 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.01.25 14:33:45 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.01.25 14:33:45 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.01.25 14:33:45 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.01.25 14:33:45 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2016.01.25 14:33:45 - OpenVPN > UDPv4 link local: [undef]
. 2016.01.25 14:33:45 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.164:443
. 2016.01.25 14:33:45 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.164:443, sid=e6b5512f 3fa66bc1
. 2016.01.25 14:33:45 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.01.25 14:33:45 - OpenVPN > Validating certificate key usage
. 2016.01.25 14:33:45 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.01.25 14:33:45 - OpenVPN > VERIFY KU OK
. 2016.01.25 14:33:45 - OpenVPN > Validating certificate extended key usage
. 2016.01.25 14:33:45 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.01.25 14:33:45 - OpenVPN > VERIFY EKU OK
. 2016.01.25 14:33:45 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.01.25 14:33:46 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.01.25 14:33:46 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.01.25 14:33:46 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.01.25 14:33:46 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.01.25 14:33:46 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.01.25 14:33:46 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.164:443
. 2016.01.25 14:33:48 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.01.25 14:33:48 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.25.124 255.255.0.0'
. 2016.01.25 14:33:48 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.01.25 14:33:48 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.01.25 14:33:48 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.01.25 14:33:48 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.01.25 14:33:48 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.01.25 14:33:48 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.01.25 14:33:48 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.01.25 14:33:48 - OpenVPN > open_tun, tt->ipv6=0
. 2016.01.25 14:33:48 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{DF432D56-DD26-4FD8-8C60-1A6C8D671B0E}.tap
. 2016.01.25 14:33:48 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{5B223D3D-2264-4914-8C48-7D806BDC72E2}.tap
. 2016.01.25 14:33:48 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{9888B2BF-2F76-4805-BEF1-983505A648B6}.tap
. 2016.01.25 14:33:48 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{EEAC311D-272A-4C6A-89A2-7BF36A02EA2A}.tap
. 2016.01.25 14:33:48 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{D8636779-7D2B-42DF-AAB4-08BD43E3BC71}.tap
. 2016.01.25 14:33:48 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.01.25 14:33:48 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.25.124/255.255.0.0 [sUCCEEDED]
. 2016.01.25 14:33:48 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.25.124/255.255.0.0 on interface {D8636779-7D2B-42DF-AAB4-08BD43E3BC71} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.01.25 14:33:48 - OpenVPN > Successful ARP Flush on interface [14] {D8636779-7D2B-42DF-AAB4-08BD43E3BC71}
. 2016.01.25 14:33:53 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.01.25 14:33:53 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.164 MASK 255.255.255.255 192.168.1.254
. 2016.01.25 14:33:53 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=20 and dwForwardType=4
. 2016.01.25 14:33:53 - OpenVPN > Route addition via IPAPI succeeded [adaptive]
. 2016.01.25 14:33:53 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 6
. 2016.01.25 14:33:53 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.01.25 14:33:53 - OpenVPN > ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
. 2016.01.25 14:33:53 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.01.25 14:33:53 - Starting Management Interface
. 2016.01.25 14:33:53 - OpenVPN > Initialization Sequence Completed
I 2016.01.25 14:33:53 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.01.25 14:33:53 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.01.25 14:33:53 - Flushing DNS
I 2016.01.25 14:33:53 - Checking route
I 2016.01.25 14:34:17 - Checking DNS
! 2016.01.25 14:34:17 - Connected.
. 2016.01.25 14:34:17 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.01.25 14:34:17 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
. 2016.01.25 14:41:11 - OpenVPN > [server] Inactivity timeout (--ping-restart), restarting
. 2016.01.25 14:41:11 - OpenVPN > SIGUSR1[soft,ping-restart] received, process restarting
. 2016.01.25 14:41:11 - OpenVPN > Restart pause, 2 second(s)
! 2016.01.25 14:41:11 - Disconnecting
. 2016.01.25 14:41:11 - Management - Send 'signal SIGTERM'
. 2016.01.25 14:41:11 - OpenVPN > MANAGEMENT: CMD 'signal SIGTERM'
. 2016.01.25 14:41:11 - OpenVPN > MANAGEMENT: Client disconnected
. 2016.01.25 14:41:11 - OpenVPN > Assertion failed at misc.c:779
. 2016.01.25 14:41:11 - OpenVPN > Exiting due to fatal error
. 2016.01.25 14:41:11 - Connection terminated.
I 2016.01.25 14:41:11 - DNS of a network adapter restored to original settings (Realtek PCIe GBE Family Controller)
I 2016.01.25 14:41:11 - DNS of a network adapter restored to original settings (TAP-Windows Adapter V9)
I 2016.01.25 14:41:14 - Checking authorization ...
! 2016.01.25 14:41:14 - Connecting to Ancha (Netherlands, Alblasserdam)
. 2016.01.25 14:41:14 - OpenVPN > OpenVPN 2.3.8 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [iPv6] built on Aug 13 2015
. 2016.01.25 14:41:14 - OpenVPN > library versions: OpenSSL 1.0.2d 9 Jul 2015, LZO 2.08
. 2016.01.25 14:41:14 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2016.01.25 14:41:14 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2016.01.25 14:41:14 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.01.25 14:41:14 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.01.25 14:41:14 - OpenVPN > Socket Buffers: R=[65536->262144] S=[65536->262144]
. 2016.01.25 14:41:14 - OpenVPN > UDPv4 link local: [undef]
. 2016.01.25 14:41:14 - OpenVPN > UDPv4 link remote: [AF_INET]213.152.162.164:443
. 2016.01.25 14:41:14 - OpenVPN > TLS: Initial packet from [AF_INET]213.152.162.164:443, sid=0c88b7cb 8119641b
. 2016.01.25 14:41:14 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2016.01.25 14:41:14 - OpenVPN > Validating certificate key usage
. 2016.01.25 14:41:14 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2016.01.25 14:41:14 - OpenVPN > VERIFY KU OK
. 2016.01.25 14:41:14 - OpenVPN > Validating certificate extended key usage
. 2016.01.25 14:41:14 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2016.01.25 14:41:14 - OpenVPN > VERIFY EKU OK
. 2016.01.25 14:41:14 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2016.01.25 14:41:15 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.01.25 14:41:15 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.01.25 14:41:15 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2016.01.25 14:41:15 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2016.01.25 14:41:15 - OpenVPN > Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
. 2016.01.25 14:41:15 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]213.152.162.164:443
. 2016.01.25 14:41:17 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2016.01.25 14:41:17 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 10.4.0.1,comp-lzo no,route-gateway 10.4.0.1,topology subnet,ping 10,ping-restart 60,ifconfig 10.4.25.124 255.255.0.0'
. 2016.01.25 14:41:17 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2016.01.25 14:41:17 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2016.01.25 14:41:17 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2016.01.25 14:41:17 - OpenVPN > OPTIONS IMPORT: route options modified
. 2016.01.25 14:41:17 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2016.01.25 14:41:17 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2016.01.25 14:41:17 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2016.01.25 14:41:17 - OpenVPN > open_tun, tt->ipv6=0
. 2016.01.25 14:41:17 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{DF432D56-DD26-4FD8-8C60-1A6C8D671B0E}.tap
. 2016.01.25 14:41:17 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{5B223D3D-2264-4914-8C48-7D806BDC72E2}.tap
. 2016.01.25 14:41:17 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{9888B2BF-2F76-4805-BEF1-983505A648B6}.tap
. 2016.01.25 14:41:17 - OpenVPN > CreateFile failed on TAP device: \\.\Global\{EEAC311D-272A-4C6A-89A2-7BF36A02EA2A}.tap
. 2016.01.25 14:41:17 - OpenVPN > TAP-WIN32 device [Ethernet 2] opened: \\.\Global\{D8636779-7D2B-42DF-AAB4-08BD43E3BC71}.tap
. 2016.01.25 14:41:17 - OpenVPN > TAP-Windows Driver Version 9.9
. 2016.01.25 14:41:17 - OpenVPN > Set TAP-Windows TUN subnet mode network/local/netmask = 10.4.0.0/10.4.25.124/255.255.0.0 [sUCCEEDED]
. 2016.01.25 14:41:17 - OpenVPN > Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.25.124/255.255.0.0 on interface {D8636779-7D2B-42DF-AAB4-08BD43E3BC71} [DHCP-serv: 10.4.255.254, lease-time: 31536000]
. 2016.01.25 14:41:17 - OpenVPN > Successful ARP Flush on interface [14] {D8636779-7D2B-42DF-AAB4-08BD43E3BC71}
. 2016.01.25 14:41:22 - OpenVPN > TEST ROUTES: 1/1 succeeded len=0 ret=1 a=0 u/d=up
. 2016.01.25 14:41:22 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 213.152.162.164 MASK 255.255.255.255 192.168.1.254
. 2016.01.25 14:41:22 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=6]
. 2016.01.25 14:41:22 - OpenVPN > Route addition via IPAPI failed [adaptive]
. 2016.01.25 14:41:22 - OpenVPN > Route addition fallback to route.exe
. 2016.01.25 14:41:22 - OpenVPN > env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
. 2016.01.25 14:41:22 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 192.168.1.254 MASK 255.255.255.255 192.168.1.254 IF 6
. 2016.01.25 14:41:22 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.01.25 14:41:22 - OpenVPN > ROUTE: route addition failed using CreateIpForwardEntry: The object already exists.   [status=5010 if_index=14]
. 2016.01.25 14:41:22 - OpenVPN > C:\WINDOWS\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.0.1
. 2016.01.25 14:41:22 - Starting Management Interface
. 2016.01.25 14:41:22 - OpenVPN > Initialization Sequence Completed
I 2016.01.25 14:41:22 - DNS of a network adapter forced (Realtek PCIe GBE Family Controller)
I 2016.01.25 14:41:22 - DNS of a network adapter forced (TAP-Windows Adapter V9)
I 2016.01.25 14:41:22 - Flushing DNS
I 2016.01.25 14:41:22 - Checking route
I 2016.01.25 14:41:46 - Checking DNS
! 2016.01.25 14:41:46 - Connected.
. 2016.01.25 14:41:46 - OpenVPN > MANAGEMENT: Client connected from [AF_INET]127.0.0.1:3100
. 2016.01.25 14:41:46 - OpenVpn Management > >INFO:OpenVPN Management Interface Version 1 -- type 'help' for more info
Relevant line. There are so many topics on that one, I cannot count them. Luckily, a search counted 120. Here's a selection of possible solutions, try one or more of these.
Restart Problem
AirVPN keeps re-connecting every few minutes
Connection last 1 minute, then no speed...
Disconnection for ping timeout
Random disconnects <-- more links from my side - a linkception
question about Inactivity timeout
It will take some time to go through all of them, but please let us know if something helped so we have a resource to link to in the future.
Someone somewhere at some point 'lol' posted a thread saying the high upload stuff happened when they were having connection problems.
Eg. Connection problem occurs, then it shows high or random speeds.
@aaronosaka
If you're pc is freezing or crashing you've got other issues.
Could be a firewall conflict, tap driver conflict, other drivers even or the OS is just hosed. Its windows so who knows, things break.
You're right that it could be something non-VPN related.
I decided to screw it and just upgraded my router to DD-WRT and am using that to connect to Air.
nice
The state windows is in running it via the router is probably a safer bet.
Well, when I need to be on the road I will have to stick with OpenVPN with Eddie running on my laptop, but who knows:  the problem could resolve itself on its own eventually or at least not freeze randomly.  It's a top of the line Alienware laptop from about 1.5 years ago so I'm surprised it has an issue like this, but it sounds software-related so there's that.
It is eddie itself i believe, it seems to torrent itself out when you leave the installer on your computer. if you can hunt down anywhere eddie is at and remove it then the problem should rectify itself. Eddie is supposed to uninstall and delete the loader or at least give the option but depending on how you downloaded it and loaded it, it may not do this. i think airvpn is well aware and its some kind of bs way to get free hosting for their client. not cool. i say this because i had a hunch this was the issue and removing the zip seems to have fixed the issue.
Without going much into details how torrents work, you are aware that a torrent file with tracker information should be created first in order for peers to download it, right?
The Eddie client is not officially distributed via torrents, so what you said here makes no sense.
This is one of the weirdest conspiracies of the month
Transmitting nearly 40Gbit of bandwidth per second. Trying to save a few megabytes per hour.
