Not connected, Your IP: 216.73.217.151
I noticed my VPN getting disconnected every now and then  showing this :
SSL_READ: CONECTION RESET BY PEER ( wsawconnreset) ( 10054)
Connection reset, restarting
I'm connected via Ethernet plugs, just wondering if its something i've setup wrong, or possibility just a drop in connection via the plugs.
Any help appreciated
I am also having this issue, it is fairly frustrating. The problem is I can't even login to my account, let alone connect to a server, because it says "Connection reset by peer". What does this mean?? I haven't done anything to the settings as far as I can remember. Does anyone know how to fix this tragedy? Any help would be greatly appreciated
