Not connected, Your IP: 3.138.200.66
victorab
Question about LAN connection (TAP Windows)
I have a question, on network managment, I have 1 LAN connection (from my MSI motherboard, I don't use Wifi) where all the traffic go.
After Installing Eddie, it install the TAP windows Driver so I have another LAN connection : LAN connection (TAP Windows) and LAN connection 2 (MSI).
I start the VPN and I see on WireShark for LAN connection 2 encrypted datas to the server so it's OK. When I WireShark the other LAN Connection (TAP Windows) I see all the uncrypted traffic.
I think it's normal and It goes first to the TAP Windows locally and then go to the other LAN and go on my ISP  boxe ncrypted but I want to be sure that there is no leak.
Thanx
