Believer_01
VPN problems under Archlinux
Hello users,
I run Archlinux 64 bit over a LAN connection.
If I use openvpn by terminal with the command sudo openvpn --config ["path to file .ovpn"] it works correctly.
ALso in the .ovpn file I added the script to change the resolvconf file on the fly.
But after time that the connection is established, appears other messages in the terminal, like that openvpn is re-initalizing the procedure.
Sometimes also ipleak.net gives me DNS leak but it I try after some seconds, it does not. Instead by dnsleaktest I have never DNS leak.
If I use Eddie (portable)  it never works, it tries to connect then restarts and tries again indefinitely.
Here the report:
I 2014.08.12 00:14:48 - AirVPN client version: 2.3, System: Linux, Architecture: x64
. 2014.08.12 00:14:48 - Reading options from /home/slogx/Downloads/airvpn_linux_x64_portable/AirVPN.xml
. 2014.08.12 00:14:49 - Data Path: /home/slogx/Downloads/airvpn_linux_x64_portable
. 2014.08.12 00:14:49 - App Path: /home/slogx/Downloads/airvpn_linux_x64_portable
. 2014.08.12 00:14:49 - Executable Path: /home/slogx/Downloads/airvpn_linux_x64_portable/airvpn
. 2014.08.12 00:14:49 - Command line arguments:
. 2014.08.12 00:14:49 - Operating System: Unix 3.15.8.1 - Linux dhcppc1 3.15.8-1-ARCH #1 SMP PREEMPT Fri Aug 1 08:51:42 CEST 2014 x86_64 GNU/Linux
I 2014.08.12 00:14:49 - OpenVPN Driver - Found
I 2014.08.12 00:14:49 - OpenVPN - Version: OpenVPN 2.3.4 (/home/slogx/Downloads/airvpn_linux_x64_portable/openvpn)
W 2014.08.12 00:14:49 - SSH - Not available
I 2014.08.12 00:14:49 - SSL - Version: stunnel 5.01 (/home/slogx/Downloads/airvpn_linux_x64_portable/stunnel)
I 2014.08.12 00:14:49 - IPV6: Available
! 2014.08.12 00:14:49 - Ready
I 2014.08.12 00:14:53 - Session starting.
! 2014.08.12 00:14:53 - Checking environment
! 2014.08.12 00:14:53 - Waiting for latency tests
! 2014.08.12 00:15:02 - Checking authorization
I 2014.08.12 00:15:03 - DNS of the system will be updated to VPN DNS (ResolvConf method)
! 2014.08.12 00:15:03 - Connecting to Keid (Netherlands, Amsterdam)
. 2014.08.12 00:15:03 - OpenVPN > OpenVPN 2.3.4 x86_64-unknown-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [MH] [iPv6] built on Jun  9 2014
. 2014.08.12 00:15:03 - OpenVPN > library versions: OpenSSL 1.0.1g 7 Apr 2014, LZO 2.05
. 2014.08.12 00:15:03 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2014.08.12 00:15:03 - OpenVPN > NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
. 2014.08.12 00:15:03 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2014.08.12 00:15:03 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.12 00:15:03 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.12 00:15:03 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]
. 2014.08.12 00:15:03 - OpenVPN > UDPv4 link local: [undef]
. 2014.08.12 00:15:03 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.138.7:443
. 2014.08.12 00:15:03 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.138.7:443, sid=c2e12048 1f64ac91
. 2014.08.12 00:15:03 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.08.12 00:15:03 - OpenVPN > Validating certificate key usage
. 2014.08.12 00:15:03 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2014.08.12 00:15:03 - OpenVPN > VERIFY KU OK
. 2014.08.12 00:15:03 - OpenVPN > Validating certificate extended key usage
. 2014.08.12 00:15:03 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.08.12 00:15:03 - OpenVPN > VERIFY EKU OK
. 2014.08.12 00:15:03 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.08.12 00:15:04 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.12 00:15:04 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.12 00:15:04 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.12 00:15:04 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.12 00:15:04 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2014.08.12 00:15:04 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.138.7:443
. 2014.08.12 00:15:06 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2014.08.12 00:15:06 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.33.202 10.4.33.201'
. 2014.08.12 00:15:06 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2014.08.12 00:15:06 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2014.08.12 00:15:06 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2014.08.12 00:15:06 - OpenVPN > OPTIONS IMPORT: route options modified
. 2014.08.12 00:15:06 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2014.08.12 00:15:06 - OpenVPN > TUN/TAP device tun0 opened
. 2014.08.12 00:15:06 - OpenVPN > TUN/TAP TX queue length set to 100
. 2014.08.12 00:15:06 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2014.08.12 00:15:06 - OpenVPN > /sbin/ifconfig tun0 10.4.33.202 pointopoint 10.4.33.201 mtu 1500
. 2014.08.12 00:15:06 - OpenVPN > Linux ifconfig failed: could not execute external program
. 2014.08.12 00:15:06 - OpenVPN > Exiting due to fatal error
! 2014.08.12 00:15:06 - Disconnecting
. 2014.08.12 00:15:06 - Connection terminated.
! 2014.08.12 00:15:09 - Checking authorization
I 2014.08.12 00:15:10 - DNS of the system will be updated to VPN DNS (ResolvConf method)
! 2014.08.12 00:15:10 - Connecting to Keid (Netherlands, Amsterdam)
. 2014.08.12 00:15:10 - OpenVPN > OpenVPN 2.3.4 x86_64-unknown-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [MH] [iPv6] built on Jun  9 2014
. 2014.08.12 00:15:10 - OpenVPN > library versions: OpenSSL 1.0.1g 7 Apr 2014, LZO 2.05
. 2014.08.12 00:15:10 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2014.08.12 00:15:10 - OpenVPN > NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
. 2014.08.12 00:15:10 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2014.08.12 00:15:10 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.12 00:15:10 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.12 00:15:10 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]
. 2014.08.12 00:15:10 - OpenVPN > UDPv4 link local: [undef]
. 2014.08.12 00:15:10 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.138.7:443
. 2014.08.12 00:15:10 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.138.7:443, sid=2a061df0 64aa0e81
. 2014.08.12 00:15:10 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.08.12 00:15:10 - OpenVPN > Validating certificate key usage
. 2014.08.12 00:15:10 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2014.08.12 00:15:10 - OpenVPN > VERIFY KU OK
. 2014.08.12 00:15:10 - OpenVPN > Validating certificate extended key usage
. 2014.08.12 00:15:10 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.08.12 00:15:10 - OpenVPN > VERIFY EKU OK
. 2014.08.12 00:15:10 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.08.12 00:15:15 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.12 00:15:15 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.12 00:15:15 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.12 00:15:15 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.12 00:15:15 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2014.08.12 00:15:15 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.138.7:443
. 2014.08.12 00:15:18 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2014.08.12 00:15:18 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.33.202 10.4.33.201'
. 2014.08.12 00:15:18 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2014.08.12 00:15:18 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2014.08.12 00:15:18 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2014.08.12 00:15:18 - OpenVPN > OPTIONS IMPORT: route options modified
. 2014.08.12 00:15:18 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2014.08.12 00:15:18 - OpenVPN > TUN/TAP device tun0 opened
. 2014.08.12 00:15:18 - OpenVPN > TUN/TAP TX queue length set to 100
. 2014.08.12 00:15:18 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2014.08.12 00:15:18 - OpenVPN > /sbin/ifconfig tun0 10.4.33.202 pointopoint 10.4.33.201 mtu 1500
. 2014.08.12 00:15:18 - OpenVPN > Linux ifconfig failed: could not execute external program
. 2014.08.12 00:15:18 - OpenVPN > Exiting due to fatal error
! 2014.08.12 00:15:18 - Disconnecting
. 2014.08.12 00:15:18 - Connection terminated.
! 2014.08.12 00:15:21 - Checking authorization
I 2014.08.12 00:15:21 - DNS of the system will be updated to VPN DNS (ResolvConf method)
! 2014.08.12 00:15:21 - Connecting to Keid (Netherlands, Amsterdam)
. 2014.08.12 00:15:21 - OpenVPN > OpenVPN 2.3.4 x86_64-unknown-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [MH] [iPv6] built on Jun  9 2014
. 2014.08.12 00:15:21 - OpenVPN > library versions: OpenSSL 1.0.1g 7 Apr 2014, LZO 2.05
. 2014.08.12 00:15:21 - OpenVPN > MANAGEMENT: TCP Socket listening on [AF_INET]127.0.0.1:3100
. 2014.08.12 00:15:21 - OpenVPN > NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
. 2014.08.12 00:15:21 - OpenVPN > Control Channel Authentication: tls-auth using INLINE static key file
. 2014.08.12 00:15:21 - OpenVPN > Outgoing Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.12 00:15:21 - OpenVPN > Incoming Control Channel Authentication: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.12 00:15:21 - OpenVPN > Socket Buffers: R=[212992->131072] S=[212992->131072]
. 2014.08.12 00:15:21 - OpenVPN > UDPv4 link local: [undef]
. 2014.08.12 00:15:21 - OpenVPN > UDPv4 link remote: [AF_INET]95.211.138.7:443
. 2014.08.12 00:15:21 - OpenVPN > TLS: Initial packet from [AF_INET]95.211.138.7:443, sid=95deeabc 3051d88f
. 2014.08.12 00:15:22 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2014.08.12 00:15:22 - OpenVPN > Validating certificate key usage
. 2014.08.12 00:15:22 - OpenVPN > ++ Certificate has key usage  00a0, expects 00a0
. 2014.08.12 00:15:22 - OpenVPN > VERIFY KU OK
. 2014.08.12 00:15:22 - OpenVPN > Validating certificate extended key usage
. 2014.08.12 00:15:22 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2014.08.12 00:15:22 - OpenVPN > VERIFY EKU OK
. 2014.08.12 00:15:22 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
. 2014.08.12 00:15:26 - OpenVPN > Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.12 00:15:26 - OpenVPN > Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.12 00:15:26 - OpenVPN > Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
. 2014.08.12 00:15:26 - OpenVPN > Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
. 2014.08.12 00:15:26 - OpenVPN > Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 4096 bit RSA
. 2014.08.12 00:15:26 - OpenVPN > [server] Peer Connection Initiated with [AF_INET]95.211.138.7:443
. 2014.08.12 00:15:28 - OpenVPN > SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
. 2014.08.12 00:15:28 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.33.202 10.4.33.201'
. 2014.08.12 00:15:28 - OpenVPN > OPTIONS IMPORT: timers and/or timeouts modified
. 2014.08.12 00:15:28 - OpenVPN > OPTIONS IMPORT: LZO parms modified
. 2014.08.12 00:15:28 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2014.08.12 00:15:28 - OpenVPN > OPTIONS IMPORT: route options modified
. 2014.08.12 00:15:28 - OpenVPN > OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
. 2014.08.12 00:15:28 - OpenVPN > TUN/TAP device tun0 opened
. 2014.08.12 00:15:28 - OpenVPN > TUN/TAP TX queue length set to 100
. 2014.08.12 00:15:28 - OpenVPN > do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
. 2014.08.12 00:15:28 - OpenVPN > /sbin/ifconfig tun0 10.4.33.202 pointopoint 10.4.33.201 mtu 1500
. 2014.08.12 00:15:28 - OpenVPN > Linux ifconfig failed: could not execute external program
. 2014.08.12 00:15:28 - OpenVPN > Exiting due to fatal error
! 2014.08.12 00:15:28 - Disconnecting
. 2014.08.12 00:15:28 - Connection terminated.
I 2014.08.12 00:15:28 - Cancel requested.
I 2014.08.12 00:15:28 - Session terminated.
What shall I do?
Do I really leak?
"Do I really leak?" -
If you don't use a firewall to rule out leaking (check AirVPN's howto/faq section), you probably are.
On Arch, I would use ufw.
"What shall I do?" -
Fix the problem (and configure a firewall).
This means that openvpn was able to connect and now tries to use "ifconfig" to configure your VPN device (tun0).
It fails because "ifconfig" is part of "net-tools", a package that Arch has thrown out back in 2011:
https://www.archlinux.org/news/deprecation-of-net-tools/
You have two options:
The easier, but deprecated way: Install the "net-tools" package from the Arch repos.
The harder, but true-to-Arch way: Configure openvpn to use iproute2 instead of ifconfig. This bug report should point you in the right direction:
https://bugs.archlinux.org/task/24797
