Not connected, Your IP: 216.73.216.37
OpenVPN with macOS - Tunnelblick
1
Generate and download AirVPN configuration file(s) (.ovpn) with our Config Generator.
2
Download and Install Tunnelblick from official website Tunnelblick official download page.
3
Open Tunnelblick application. Click on the icon on top right and select "VPN Detail"
4
Drag the .ovpn configuration file in the configuration section of Tunnellblick application.
5
Choose Only Me and enter your macOS password in order to install the configuration file.
6
Click the Tunnelblick icon and select the configuration file you installed. Once the connection is successfully established you will see a pop-up message
