Not connected, Your IP: 18.224.59.231
Hi guys! I'm having some problems with airvpn:
-I noticed that in airvpn client download and upload values don't increase (it's correct?)
-I can't open any forwarded port (I always receive the same error : Not reachable on server IP over the external port 5796, tcp protocol. Error : 110 - Connection timed out)
P.s.
In "speedtest.net" site I can see that I'am still in Italy and not in UK (the server that I am connected).
Seems to me as if you're not connected properly. Post your logs, please.
11/04/2014 - 18.54 AirVPN client version: 1,9
11/04/2014 - 18.54 Reading options from C:\Users\Bambini\AppData\Roaming\AirVPN\Air\1.0.0.0\AirVPN.xml
11/04/2014 - 18.54 OpenVPN bundle version: OpenVPN 2.3.2
11/04/2014 - 18.54 OpenVPN current version: OpenVPN 2.3.2
11/04/2014 - 18.54 Ready.
11/04/2014 - 18.54 Login...
11/04/2014 - 18.54 Login success.
11/04/2014 - 18.55 Contacting service...
11/04/2014 - 18.55 Connecting...
11/04/2014 - 18.55 OpenVPN 2.3.2 x86_64-w64-mingw32 [sSL (OpenSSL)] [LZO] [PKCS11] [eurephia] [iPv6] built on Aug 22 2013
11/04/2014 - 18.55 Socket Buffers: R=[8192->8192] S=[8192->8192]
11/04/2014 - 18.55 UDPv4 link local: [undef]
11/04/2014 - 18.55 UDPv4 link remote: [AF_INET]94.229.74.90:443
11/04/2014 - 18.55 TLS: Initial packet from [AF_INET]94.229.74.90:443, sid=2b2c3ad4 e0ddeda1
11/04/2014 - 18.55 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
11/04/2014 - 18.55 VERIFY OK: nsCertType=SERVER
11/04/2014 - 18.55 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
11/04/2014 - 18.55 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
11/04/2014 - 18.55 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
11/04/2014 - 18.55 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
11/04/2014 - 18.55 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
11/04/2014 - 18.55 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
11/04/2014 - 18.55 [server] Peer Connection Initiated with [AF_INET]94.229.74.90:443
11/04/2014 - 18.55 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
11/04/2014 - 18.55 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.83.66 10.4.83.65'
11/04/2014 - 18.55 OPTIONS IMPORT: timers and/or timeouts modified
11/04/2014 - 18.55 OPTIONS IMPORT: LZO parms modified
11/04/2014 - 18.55 OPTIONS IMPORT: --ifconfig/up options modified
11/04/2014 - 18.55 OPTIONS IMPORT: route options modified
11/04/2014 - 18.55 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
11/04/2014 - 18.55 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
11/04/2014 - 18.55 open_tun, tt->ipv6=0
11/04/2014 - 18.55 TAP-WIN32 device [Connessione alla rete locale (LAN) 3] opened: \\.\Global\{CF962965-3590-4971-99AD-8E88B687ECFD}.tap
11/04/2014 - 18.55 TAP-Windows Driver Version 9.9
11/04/2014 - 18.55 NETSH: C:\Windows\system32\netsh.exe interface ip set address Connessione alla rete locale (LAN) 3 dhcp
11/04/2014 - 18.55 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.83.66/255.255.255.252 on interface {CF962965-3590-4971-99AD-8E88B687ECFD} [DHCP-serv: 10.4.83.65, lease-time: 31536000]
11/04/2014 - 18.55 Successful ARP Flush on interface [14] {CF962965-3590-4971-99AD-8E88B687ECFD}
11/04/2014 - 18.55 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
11/04/2014 - 18.55 C:\Windows\system32\route.exe ADD 94.229.74.90 MASK 255.255.255.255 192.168.1.1
11/04/2014 - 18.55 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
11/04/2014 - 18.55 Route addition via IPAPI succeeded [adaptive]
11/04/2014 - 18.55 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.83.65
11/04/2014 - 18.55 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.83.65
11/04/2014 - 18.55 C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.83.65
11/04/2014 - 18.55 Initialization Sequence Completed
11/04/2014 - 18.55 Starting Management Interface...
11/04/2014 - 18.55 Checking...
11/04/2014 - 18.55 Retrieve statistics...
11/04/2014 - 18.55 Connected.
11/04/2014 - 19.00 [server] Inactivity timeout (--ping-restart), restarting
11/04/2014 - 19.00 C:\Windows\system32\route.exe DELETE 10.4.0.1 MASK 255.255.255.255 10.4.83.65
11/04/2014 - 19.00 Route deletion via IPAPI succeeded [adaptive]
11/04/2014 - 19.00 C:\Windows\system32\route.exe DELETE 94.229.74.90 MASK 255.255.255.255 192.168.1.1
11/04/2014 - 19.00 Warning: route gateway is not reachable on any active network adapters: 192.168.1.1
11/04/2014 - 19.00 Route deletion via IPAPI failed [adaptive]
11/04/2014 - 19.00 Route deletion fallback to route.exe
11/04/2014 - 19.00 env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
11/04/2014 - 19.00 C:\Windows\system32\route.exe DELETE 0.0.0.0 MASK 128.0.0.0 10.4.83.65
11/04/2014 - 19.00 C:\Windows\system32\route.exe DELETE 128.0.0.0 MASK 128.0.0.0 10.4.83.65
11/04/2014 - 19.00 Closing TUN/TAP interface
11/04/2014 - 19.00 SIGUSR1[soft,ping-restart] received, process restarting
11/04/2014 - 19.00 Restart pause, 2 second(s)
11/04/2014 - 19.00 Socket Buffers: R=[8192->8192] S=[8192->8192]
11/04/2014 - 19.00 UDPv4 link local: [undef]
11/04/2014 - 19.00 UDPv4 link remote: [AF_INET]94.229.74.90:443
11/04/2014 - 19.00 TLS: Initial packet from [AF_INET]94.229.74.90:443, sid=5bad865c 50b4802c
11/04/2014 - 19.00 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
11/04/2014 - 19.00 VERIFY OK: nsCertType=SERVER
11/04/2014 - 19.00 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
11/04/2014 - 19.00 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
11/04/2014 - 19.00 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
11/04/2014 - 19.00 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
11/04/2014 - 19.00 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
11/04/2014 - 19.00 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
11/04/2014 - 19.00 [server] Peer Connection Initiated with [AF_INET]94.229.74.90:443
11/04/2014 - 19.00 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
11/04/2014 - 19.00 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.4.0.1,comp-lzo no,route 10.4.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.4.83.66 10.4.83.65'
11/04/2014 - 19.00 OPTIONS IMPORT: timers and/or timeouts modified
11/04/2014 - 19.00 OPTIONS IMPORT: LZO parms modified
11/04/2014 - 19.00 OPTIONS IMPORT: --ifconfig/up options modified
11/04/2014 - 19.00 OPTIONS IMPORT: route options modified
11/04/2014 - 19.00 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
11/04/2014 - 19.00 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
11/04/2014 - 19.00 open_tun, tt->ipv6=0
11/04/2014 - 19.00 TAP-WIN32 device [Connessione alla rete locale (LAN) 3] opened: \\.\Global\{CF962965-3590-4971-99AD-8E88B687ECFD}.tap
11/04/2014 - 19.00 TAP-Windows Driver Version 9.9
11/04/2014 - 19.00 Notified TAP-Windows driver to set a DHCP IP/netmask of 10.4.83.66/255.255.255.252 on interface {CF962965-3590-4971-99AD-8E88B687ECFD} [DHCP-serv: 10.4.83.65, lease-time: 31536000]
11/04/2014 - 19.00 Successful ARP Flush on interface [14] {CF962965-3590-4971-99AD-8E88B687ECFD}
11/04/2014 - 19.00 TEST ROUTES: 2/2 succeeded len=1 ret=1 a=0 u/d=up
11/04/2014 - 19.00 C:\Windows\system32\route.exe ADD 94.229.74.90 MASK 255.255.255.255 192.168.1.1
11/04/2014 - 19.00 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=40 and dwForwardType=4
11/04/2014 - 19.00 Route addition via IPAPI succeeded [adaptive]
11/04/2014 - 19.00 C:\Windows\system32\route.exe ADD 0.0.0.0 MASK 128.0.0.0 10.4.83.65
11/04/2014 - 19.00 ROUTE: CreateIpForwardEntry succeeded with dwForwardMetric1=30 and dwForwardType=4
11/04/2014 - 19.00 C:\Windows\system32\route.exe ADD 128.0.0.0 MASK 128.0.0.0 10.4.83.65
11/04/2014 - 19.00 C:\Windows\system32\route.exe ADD 10.4.0.1 MASK 255.255.255.255 10.4.83.65
11/04/2014 - 19.00 Initialization Sequence Completed
11/04/2014 - 19.00 Starting Management Interface...
11/04/2014 - 19.00 Checking...
11/04/2014 - 19.00 Retrieve statistics...
11/04/2014 - 19.00 Connected.
Here's my log.
I don't now what happened but now I am really connected to the server. Speedtest tell me that I'm in UK too . In particulary the internet was disconnected (I was using the airvpn client) so I reconnect it (wifi) and when I'have done it I was using the server.
BUT the ports are still closed (I receive the the same error ;( ), why?? Thanks for help
