Hi
I have been using AirVPN for 6 months now, works great. However I need to travel to China occasionally and regular OpenVPN just will not work. I have been trying to setup a SSL as explained in https://airvpn.org/ssl/ but I just cannot seem to work out exactly what the last step means
openvpn "AirVPN <..> - SSL <..>.ovpn"
I have no idea what file the "AirVPN <..>"  file is though I can guess that the ovpn file is the same as that selected in the previous step to setup the stunnel.exe. In addition openvpn is expecting a double dash "--" not a single dash "-"
It would help emensly if you could clarify and update your webpage for others.
I am doing this in windows 7 bty.
Thanks for a great service.
Best
R
I like how they keep it as simple (little verbiage) as possible but it is a little confusing.
You can run the OpenVPN Gui (wrapper) and select the SSL .ovpn
or from a command line:
If your server/ .ovpn file is AirVPN_NL-Nekkar_SSL-443.ovpn then the cmd would be
openvpn "AirVPN_NL-Nekkar_SSL-443.ovpn"
Run this cmd from the directory your .ovpn file is in.
If you'd like to log try this:
openvpn --log <drive\directory you have write access to>\AirVPN_NL-Nekkar_SSL-443.log --config AirVPN_NL-Nekkar_SSL-443.ovpn
