madaBitCoin
openvpn with tor error
Thu Aug 29 04:39:41 2013 OpenVPN 2.3.2 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Jun 3 2013
Thu Aug 29 04:39:41 2013 WARNING: file '/etc/openvpn/user.key' is group or others accessible
Thu Aug 29 04:39:41 2013 Socket Buffers: R=[87380->131072] S=[16384->131072]
Thu Aug 29 04:39:41 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050 [nonblock]
Thu Aug 29 04:39:41 2013 TCP connection established with [AF_INET]127.0.0.1:9050
Thu Aug 29 04:39:41 2013 TCPv4_CLIENT link local: [undef]
Thu Aug 29 04:39:41 2013 TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:9050
Thu Aug 29 04:39:42 2013 TLS: Initial packet from [AF_INET]127.0.0.1:9050, sid=6400ef29 e5aacb84
Thu Aug 29 04:39:46 2013 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Thu Aug 29 04:39:46 2013 VERIFY OK: nsCertType=SERVER
Thu Aug 29 04:39:46 2013 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Thu Aug 29 04:39:57 2013 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Thu Aug 29 04:39:57 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Aug 29 04:39:57 2013 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Thu Aug 29 04:39:57 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Aug 29 04:39:57 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Thu Aug 29 04:39:57 2013 [server] Peer Connection Initiated with [AF_INET]127.0.0.1:9050
Thu Aug 29 04:39:59 2013 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Thu Aug 29 04:40:00 2013 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.5.0.1,comp-lzo no,route 10.5.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.5.1.250 10.5.1.249'
Thu Aug 29 04:40:00 2013 OPTIONS IMPORT: timers and/or timeouts modified
Thu Aug 29 04:40:00 2013 OPTIONS IMPORT: LZO parms modified
Thu Aug 29 04:40:00 2013 OPTIONS IMPORT: --ifconfig/up options modified
Thu Aug 29 04:40:00 2013 OPTIONS IMPORT: route options modified
Thu Aug 29 04:40:00 2013 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Thu Aug 29 04:40:00 2013 ERROR: Cannot ioctl TUNSETIFF tun: Operation not permitted (errno=1)
Thu Aug 29 04:40:00 2013 Exiting due to fatal error
ahmed@ahmed-Vostro-200:~$ sudo openvpn --config /etc/openvpn/airvpn.conf
Thu Aug 29 04:40:24 2013 OpenVPN 2.3.2 x86_64-pc-linux-gnu [sSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [iPv6] built on Jun 3 2013
Thu Aug 29 04:40:24 2013 WARNING: file '/etc/openvpn/user.key' is group or others accessible
Thu Aug 29 04:40:24 2013 Socket Buffers: R=[87380->131072] S=[16384->131072]
Thu Aug 29 04:40:24 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050 [nonblock]
Thu Aug 29 04:40:24 2013 TCP connection established with [AF_INET]127.0.0.1:9050
Thu Aug 29 04:40:24 2013 TCPv4_CLIENT link local: [undef]
Thu Aug 29 04:40:24 2013 TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:9050
Thu Aug 29 04:40:25 2013 TLS: Initial packet from [AF_INET]127.0.0.1:9050, sid=ef1dafe7 77441dd7
Thu Aug 29 04:40:30 2013 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Thu Aug 29 04:40:30 2013 VERIFY OK: nsCertType=SERVER
Thu Aug 29 04:40:30 2013 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Thu Aug 29 04:40:40 2013 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Thu Aug 29 04:40:40 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Aug 29 04:40:40 2013 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Thu Aug 29 04:40:40 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Aug 29 04:40:40 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Thu Aug 29 04:40:40 2013 [server] Peer Connection Initiated with [AF_INET]127.0.0.1:9050
Thu Aug 29 04:40:43 2013 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Thu Aug 29 04:40:43 2013 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.5.0.1,comp-lzo no,route 10.5.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.5.1.250 10.5.1.249'
Thu Aug 29 04:40:43 2013 OPTIONS IMPORT: timers and/or timeouts modified
Thu Aug 29 04:40:43 2013 OPTIONS IMPORT: LZO parms modified
Thu Aug 29 04:40:43 2013 OPTIONS IMPORT: --ifconfig/up options modified
Thu Aug 29 04:40:43 2013 OPTIONS IMPORT: route options modified
Thu Aug 29 04:40:43 2013 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Thu Aug 29 04:40:43 2013 TUN/TAP device tun0 opened
Thu Aug 29 04:40:43 2013 TUN/TAP TX queue length set to 100
Thu Aug 29 04:40:43 2013 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Thu Aug 29 04:40:43 2013 /sbin/ifconfig tun0 10.5.1.250 pointopoint 10.5.1.249 mtu 1500
Thu Aug 29 04:40:43 2013 /sbin/route add -net 127.0.0.1 netmask 255.255.255.255 gw 192.168.1.1
Thu Aug 29 04:40:43 2013 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.5.1.249
Thu Aug 29 04:40:43 2013 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.5.1.249
Thu Aug 29 04:40:43 2013 /sbin/route add -net 10.5.0.1 netmask 255.255.255.255 gw 10.5.1.249
Thu Aug 29 04:40:43 2013 Initialization Sequence Completed
Thu Aug 29 04:41:43 2013 [server] Inactivity timeout (--ping-restart), restarting
Thu Aug 29 04:41:43 2013 /sbin/route del -net 10.5.0.1 netmask 255.255.255.255
Thu Aug 29 04:41:43 2013 /sbin/route del -net 127.0.0.1 netmask 255.255.255.255
Thu Aug 29 04:41:43 2013 /sbin/route del -net 0.0.0.0 netmask 128.0.0.0
Thu Aug 29 04:41:43 2013 /sbin/route del -net 128.0.0.0 netmask 128.0.0.0
Thu Aug 29 04:41:43 2013 Closing TUN/TAP interface
Thu Aug 29 04:41:43 2013 /sbin/ifconfig tun0 0.0.0.0
Thu Aug 29 04:41:43 2013 SIGUSR1[soft,ping-restart] received, process restarting
Thu Aug 29 04:41:43 2013 Restart pause, 5 second(s)
Thu Aug 29 04:41:48 2013 WARNING: file '/etc/openvpn/user.key' is group or others accessible
Thu Aug 29 04:41:48 2013 Socket Buffers: R=[87380->131072] S=[16384->131072]
Thu Aug 29 04:41:48 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050 [nonblock]
Thu Aug 29 04:41:48 2013 TCP connection established with [AF_INET]127.0.0.1:9050
Thu Aug 29 04:41:49 2013 TCPv4_CLIENT link local: [undef]
Thu Aug 29 04:41:49 2013 TCPv4_CLIENT link remote: [AF_INET]127.0.0.1:9050
Thu Aug 29 04:41:49 2013 TLS: Initial packet from [AF_INET]127.0.0.1:9050, sid=7f7a3865 f917034e
Thu Aug 29 04:41:54 2013 VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
Thu Aug 29 04:41:54 2013 VERIFY OK: nsCertType=SERVER
Thu Aug 29 04:41:54 2013 VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=server, emailAddress=info@airvpn.org
Thu Aug 29 04:42:04 2013 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Thu Aug 29 04:42:04 2013 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Aug 29 04:42:04 2013 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Thu Aug 29 04:42:04 2013 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Thu Aug 29 04:42:04 2013 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
Thu Aug 29 04:42:04 2013 [server] Peer Connection Initiated with [AF_INET]127.0.0.1:9050
Thu Aug 29 04:42:06 2013 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Thu Aug 29 04:42:06 2013 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 10.5.0.1,comp-lzo no,route 10.5.0.1,topology net30,ping 10,ping-restart 60,ifconfig 10.5.1.250 10.5.1.249'
Thu Aug 29 04:42:06 2013 OPTIONS IMPORT: timers and/or timeouts modified
Thu Aug 29 04:42:06 2013 OPTIONS IMPORT: LZO parms modified
Thu Aug 29 04:42:06 2013 OPTIONS IMPORT: --ifconfig/up options modified
Thu Aug 29 04:42:06 2013 OPTIONS IMPORT: route options modified
Thu Aug 29 04:42:06 2013 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Thu Aug 29 04:42:06 2013 TUN/TAP device tun0 opened
Thu Aug 29 04:42:06 2013 TUN/TAP TX queue length set to 100
Thu Aug 29 04:42:06 2013 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Thu Aug 29 04:42:06 2013 /sbin/ifconfig tun0 10.5.1.250 pointopoint 10.5.1.249 mtu 1500
Thu Aug 29 04:42:06 2013 /sbin/route add -net 127.0.0.1 netmask 255.255.255.255 gw 192.168.1.1
Thu Aug 29 04:42:07 2013 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.5.1.249
Thu Aug 29 04:42:07 2013 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.5.1.249
Thu Aug 29 04:42:07 2013 /sbin/route add -net 10.5.0.1 netmask 255.255.255.255 gw 10.5.1.249
Thu Aug 29 04:42:07 2013 Initialization Sequence Completed
Thu Aug 29 04:43:06 2013 [server] Inactivity timeout (--ping-restart), restarting
Thu Aug 29 04:43:06 2013 /sbin/route del -net 10.5.0.1 netmask 255.255.255.255
Thu Aug 29 04:43:06 2013 /sbin/route del -net 127.0.0.1 netmask 255.255.255.255
Thu Aug 29 04:43:06 2013 /sbin/route del -net 0.0.0.0 netmask 128.0.0.0
Thu Aug 29 04:43:06 2013 /sbin/route del -net 128.0.0.0 netmask 128.0.0.0
Thu Aug 29 04:43:06 2013 Closing TUN/TAP interface
Thu Aug 29 04:43:06 2013 /sbin/ifconfig tun0 0.0.0.0
Thu Aug 29 04:43:06 2013 SIGUSR1[soft,ping-restart] received, process restarting
Thu Aug 29 04:43:06 2013 Restart pause, 5 second(s)
Thu Aug 29 04:43:11 2013 WARNING: file '/etc/openvpn/user.key' is group or others accessible
Thu Aug 29 04:43:11 2013 Socket Buffers: R=[87380->131072] S=[16384->131072]
Thu Aug 29 04:43:11 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:9050 [nonblock]
Thu Aug 29 04:43:11 2013 TCP connection established with [AF_INET]127.0.0.1:9050
Thu Aug 29 04:43:16 2013 recv_socks_reply: TCP port read timeout expired: Operation now in progress (errno=115)
Thu Aug 29 04:43:16 2013 SIGTERM[soft,init_instance] received, process exiting
