Mombasa
airvpn tcp pfsense - invalid argument
i'm having some issues with my settings on pfsense, I'm getting an invalid argument. I will attach the log and config for you to see, since I can't solve the issue...
Does anyone experienced something similar?
I tried setting up pfsense on a virtual machine on a spare server I had (pfsense do a virtual appliance which is brilliant) and it seems to work ok ish with OpenVPN.
I followed http://forum.hidemyass.com/index.php/topic/6256-pfsense-openvpn-connection-issues/?do=findComment&comment=15634
Looking at your log. My guess would be to do with the certificate manager.
I can get the VPN tunnel working fine but I'm having trouble with the Firewall Rules and NAT.
At the moment I can get it to route everything over VPN but I can't get it to route stuff over the standard connection at the same time.
This solution VPN speed certainly blows my tomato ASUS RT-N16 out of the water.
