hAndrew
Sequence of AUTH_FAILED when trying to connect
Hi, Currently I am experiencing a series of authentication failures when trying to connect. At the bottom of this message I have pasted a Tunnelblick log of one of these events.
In the past, this has happened a number of times when I was using Viscosity. After a while (~minutes) it seems to resolve itself without me doing anything. I have a superstition that quitting and restarting Viscosity helped.
But now I am trying out using Tunnelblick and it too has reported a sequence of authentication failures.
- Quitting and restarting the Tunnelblick app hasn't helped so far.
- I've tried ~10 times to reconnect.
- Curious Tunnelblick gets past the "Authorizing" step to the "Getting Configuration" step before reporting the authentication failure.
Any ideas?
Full log follows:
2013-03-31 19:50:06 *Tunnelblick: OS X 10.8.3; Tunnelblick 3.3beta36 (build 3228)
2013-03-31 19:50:06 *Tunnelblick: Attempting connection with Air VPN - All Earth; Set nameserver = 1; monitoring connection
2013-03-31 19:50:06 *Tunnelblick: openvpnstart start Air\ VPN\ -\ All\ Earth.tblk 1337 1 0 3 0 305 -atADGNWradsgnw
2013-03-31 19:50:06 *Tunnelblick: openvpnstart log:
OpenVPN started successfully. Command used to start OpenVPN (one argument per displayed line):
/Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn
--cd
/Library/Application Support/Tunnelblick/Shared/Air VPN - All Earth.tblk/Contents/Resources
--daemon
--management
127.0.0.1
1337
--config
/Library/Application Support/Tunnelblick/Shared/Air VPN - All Earth.tblk/Contents/Resources/config.ovpn
--log
/Library/Application Support/Tunnelblick/Logs/-SLibrary-SApplication Support-STunnelblick-SShared-SAir VPN -- All Earth.tblk-SContents-SResources-Sconfig.ovpn.1_0_3_0_305.1337.openvpn.log
--management-query-passwords
--management-hold
--script-security
2
--up
/Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -f -atADGNWradsgnw
--down
/Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -f -atADGNWradsgnw
--up-restart
2013-03-31 19:50:06 *Tunnelblick: Established communication with OpenVPN
2013-03-31 19:50:06 *Tunnelblick: openvpnstart starting OpenVPN:
* /Applications/Tunnelblick.app/Contents/Resources/openvpn/openvpn-2.2.1/openvpn --cd /Library/Application Support/Tunnelblick/Shared/Air VPN - All Earth.tblk/Contents/Resources --daemon --management 127.0.0.1 1337 --config /Library/Application Support/Tunnelblick/Shared/Air VPN - All Earth.tblk/Contents/Resources/config.ovpn --log /Library/Application Support/Tunnelblick/Logs/-SLibrary-SApplication Support-STunnelblick-SShared-SAir VPN -- All Earth.tblk-SContents-SResources-Sconfig.ovpn.1_0_3_0_305.1337.openvpn.log --management-query-passwords --management-hold --script-security 2 --up /Applications/Tunnelblick.app/Contents/Resources/client.up.tunnelblick.sh -m -w -d -f -atADGNWradsgnw --down /Applications/Tunnelblick.app/Contents/Resources/client.down.tunnelblick.sh -m -w -d -f -atADGNWradsgnw --up-restart
2013-03-31 19:50:06 OpenVPN 2.2.1 i386-apple-darwin10.8.0 [sSL] [LZO2] [PKCS11] [eurephia] built on Feb 14 2013
2013-03-31 19:50:06 MANAGEMENT: TCP Socket listening on 127.0.0.1:1337
2013-03-31 19:50:06 Need hold release from management interface, waiting...
2013-03-31 19:50:06 MANAGEMENT: Client connected from 127.0.0.1:1337
2013-03-31 19:50:06 MANAGEMENT: CMD 'pid'
2013-03-31 19:50:06 MANAGEMENT: CMD 'state on'
2013-03-31 19:50:06 MANAGEMENT: CMD 'state'
2013-03-31 19:50:06 MANAGEMENT: CMD 'bytecount 1'
2013-03-31 19:50:06 MANAGEMENT: CMD 'hold release'
2013-03-31 19:50:06 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2013-03-31 19:50:06 LZO compression initialized
2013-03-31 19:50:06 Control Channel MTU parms [ L:1558 D:138 EF:38 EB:0 ET:0 EL:0 ]
2013-03-31 19:50:06 Socket Buffers: R=[196724->65536] S=[9216->65536]
2013-03-31 19:50:06 Data Channel MTU parms [ L:1558 D:1450 EF:58 EB:135 ET:0 EL:0 AF:3/1 ]
2013-03-31 19:50:06 Local Options hash (VER=V4): '22188c5b'
2013-03-31 19:50:06 Expected Remote Options hash (VER=V4): 'a8f55717'
2013-03-31 19:50:06 UDPv4 link local: [undef]
2013-03-31 19:50:06 UDPv4 link remote: 95.211.186.65:443
2013-03-31 19:50:06 MANAGEMENT: >STATE:1364784606,WAIT,,,
2013-03-31 19:50:06 MANAGEMENT: >STATE:1364784606,AUTH,,,
2013-03-31 19:50:06 TLS: Initial packet from 95.211.186.65:443, sid=b0e536b4 bd6c19fe
2013-03-31 19:50:08 VERIFY OK: depth=1, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=airvpn.org_CA/emailAddress=info@airvpn.org
2013-03-31 19:50:08 VERIFY OK: nsCertType=SERVER
2013-03-31 19:50:08 VERIFY OK: depth=0, /C=IT/ST=IT/L=Perugia/O=airvpn.org/CN=server/emailAddress=info@airvpn.org
2013-03-31 19:50:11 Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-03-31 19:50:11 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-03-31 19:50:11 Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
2013-03-31 19:50:11 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
2013-03-31 19:50:11 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 2048 bit RSA
2013-03-31 19:50:11 [server] Peer Connection Initiated with 95.211.186.65:443
2013-03-31 19:50:12 MANAGEMENT: >STATE:1364784612,GET_CONFIG,,,
2013-03-31 19:50:13 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
2013-03-31 19:50:14 AUTH: Received AUTH_FAILED control message
2013-03-31 19:50:14 SIGTERM received, sending exit notification to peer
2013-03-31 19:50:17 *Tunnelblick: Disconnecting; user cancelled authorization or there was an error obtaining authorization
2013-03-31 19:50:17 *Tunnelblick: Disconnecting using 'killall'
2013-03-31 19:50:17 event_wait : Interrupted system call (code=4)
2013-03-31 19:50:17 TCP/UDP: Closing socket
2013-03-31 19:50:17 SIGTERM[hard,] received, process exiting
2013-03-31 19:50:17 MANAGEMENT: >STATE:1364784617,EXITING,SIGTERM,,
