glitchgod 0 Posted ... Simple old computer, Ubuntu Desktop 24.04.4lts that is now my media server, Jellyfin. It DID have Eddie-gui installed when it had a working GPU, gpu got damaged while installing a new HDDso switch to the IGPU. Eddie refused to boot noting missing gtk, audio drivers, and something else i cant remember, and so i purge uninstalled the eddie-gui. Switched to Eddie-cli from the actual download page (not the one that came with Eddie-gui). So the command im running is as followed and does connect and runs fine eddie-cli -login=********* -password='*********' connect --server='Helvetios' --netlock --remember --event.vpn.up.filename='qbittorrent' --log.file.enabled Log is as followed (after changing the command alot ) Eddie version: 2.24.6 / linux_x64, System: Linux, Name: Ubuntu 24.04.4 LTS, Version: 24.04.4 LTS (Noble Numbat), Framework: .NET 8.0.11 . 2026.02.23 12:18:00 - Command line arguments (11): path.resources="/usr/share/eddie-cli" login="*********" password="***********" connect="True" server="Helvetios" netlock="True" remember="True" event.vpn.up.filename="qbittorrent" log.file.enabled="True" . 2026.02.23 12:18:01 - Elevated: Command:session-key . 2026.02.23 12:18:01 - Elevated: Command:bin-path-add . 2026.02.23 12:18:01 - Collect network information . 2026.02.23 12:18:01 - Reading options from /home/hp-printer/.config/eddie/default.profile . 2026.02.23 12:18:02 - OpenVPN - Version: 2.6.14 - OpenSSL 3.0.13 30 Jan 2024, LZO 2.10 (/usr/sbin/openvpn) . 2026.02.23 12:18:02 - SSH - Version: OpenSSH_9.6p1 Ubuntu-3ubuntu13.14, OpenSSL 3.0.13 30 Jan 2024 (/usr/bin/ssh) . 2026.02.23 12:18:02 - SSL - Version: 5.72 (/usr/bin/stunnel4) . 2026.02.23 12:18:02 - Service systemd-resolved restarted . 2026.02.23 12:18:02 - Activation of Network Lock - Linux nftables I 2026.02.23 12:18:23 - Press 'X' to exit (or disconnect), 'N' to connect/reconnect to the best available server. I 2026.02.23 12:18:23 - Ready I 2026.02.23 12:18:23 - Checking login ... ! 2026.02.23 12:18:23 - Logged in. . 2026.02.23 12:18:25 - Collect information about AirVPN completed I 2026.02.23 12:18:25 - Session starting. I 2026.02.23 12:18:25 - Checking authorization ... ! 2026.02.23 12:18:26 - Connecting to Helvetios (United States of America, Dallas, Texas) (server is called printer cause case looks like a printer... dont think to much about it lol however eddie-cli reverts back to the program asking for my login details. eddie-cli . 2026.02.23 12:37:26 - Eddie version: 2.24.6 / linux_x64, System: Linux, Name: Ubuntu 24.04.4 LTS, Version: 24.04.4 LTS (Noble Numbat), Framework: .NET 8.0.11 . 2026.02.23 12:37:26 - Command line arguments (1): path.resources="/usr/share/eddie-cli" . 2026.02.23 12:37:27 - Collect network information . 2026.02.23 12:37:27 - Reading options from /home/hp-printer/.config/eddie/default.profile . 2026.02.23 12:37:28 - OpenVPN - Version: 2.6.14 - OpenSSL 3.0.13 30 Jan 2024, LZO 2.10 (/usr/sbin/openvpn) . 2026.02.23 12:37:28 - SSH - Version: OpenSSH_9.6p1 Ubuntu-3ubuntu13.14, OpenSSL 3.0.13 30 Jan 2024 (/usr/bin/ssh) . 2026.02.23 12:37:28 - SSL - Version: 5.72 (/usr/bin/stunnel4) . 2026.02.23 12:37:29 - Service systemd-resolved restarted I 2026.02.23 12:37:29 - Run the program with login & password of your AirVPN account. For example: I 2026.02.23 12:37:29 - eddie-cli -login=mynick -password=mypassword I 2026.02.23 12:37:29 - See https://eddie.website/ for more information, or run with -help for inline manual. . 2026.02.23 12:37:29 - Shutdown in progress . 2026.02.23 12:37:29 - Shutdown complete so i wanted to see what was in the default profile nano /home/hp-printer/.config/eddie/default.profile and got just a jumble of symbols, so i guess i cant edit it manually? Am i miss understanding the settings? Quote Share this post Link to post
Tech Jedi Alex 1531 Posted ... As per the manual: Default options are read from the profile. Options in command-line override them but are not saved in the profile at exit (exception note: if "remember" is set to "False" (see below), username and password will be deleted at exit, even if they were inside the profile file). You can run the UI, even with a custom profile, choose options in the UI, and then launch the command-line edition with the profile options, to avoid to specify all the options in the command-line. The behavior is expected. And no, the profile is encrypted with whatever is set in the Profile data protection option. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
