Catacomb5442
Eddie won't work no more
After updating any attempt to creat a vpon tunnel fails. I reinstalled Eddie, and I am out of ideas.
Generated: Sat, 07 Feb 2026 19:41:09 +0000
Expiration: Mon, 09 Mar 2026 19:41:09 +0000
DELETE NOW
Eddie System/Environment Report - 07.02.2026 - 19:40 UTC
Eddie version: 2.24.6
Eddie OS build: linux_x64
Eddie architecture: x64
OS type: Linux
OS name: Fedora Linux
OS version: 43 (Workstation Edition)
OS architecture: x64
Framework: 6.8.0.96 (tarball Wed Jan 15 10:20:48 UTC 2020); Framework: v4.0.30319
OpenVPN: 2.6.17 - OpenSSL 3.5.4 30 Sep 2025, LZO 2.10 (/usr/sbin/openvpn)
Hummingbird: Not available
WireGuard: 1.0.0
SSH: OpenSSH_10.0p2, OpenSSL 3.5.4 30 Sep 2025 (/usr/bin/ssh)
SSL: 5.75 (/usr/bin/stunnel)
Profile path: /home/user/.config/eddie/default.profile
Data path: /home/user/.config/eddie
Application path: /usr/lib/eddie-ui
Executable path: /usr/lib/eddie-ui/eddie-ui
Command line arguments: (1 args) path.resources="/usr/share/eddie-ui"
Network Lock Active: No
Connected to VPN: No
OS support IPv4: Yes
OS support IPv6: Yes
Detected DNS: 127.0.0.53
Test DNS IPv4: Ok
Test DNS IPv6: Ok
Test Ping IPv4: 48 ms
Test Ping IPv6: Failed
Test HTTP IPv4: Error: Fetch url error:Could not connect to server
Test HTTP IPv6: Error: Fetch url error:Could not connect to server
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
key: (omissis)
servers.allowlist: 04c8003cc011ead147020baa01cb5301b409a49bddea1291127c67e1b156b6ce
proxy.mode: none
Logs:
. 2026.02.07 20:39:25 - Eddie version: 2.24.6 / linux_x64, System: Linux, Name: Fedora Linux, Version: 43 (Workstation Edition), Framework: 6.8.0.96 (tarball Wed Jan 15 10:20:48 UTC 2020); Framework: v4.0.30319
. 2026.02.07 20:39:25 - Command line arguments (1): path.resources="/usr/share/eddie-ui"
. 2026.02.07 20:39:26 - Raise system privileges
. 2026.02.07 20:39:31 - Collect network information
. 2026.02.07 20:39:32 - Reading options from /home/jens/.config/eddie/default.profile
. 2026.02.07 20:39:34 - OpenVPN - Version: 2.6.17 - OpenSSL 3.5.4 30 Sep 2025, LZO 2.10 (/usr/sbin/openvpn)
. 2026.02.07 20:39:34 - SSH - Version: OpenSSH_10.0p2, OpenSSL 3.5.4 30 Sep 2025 (/usr/bin/ssh)
. 2026.02.07 20:39:34 - SSL - Version: 5.75 (/usr/bin/stunnel)
. 2026.02.07 20:39:35 - Service systemd-resolved restarted
I 2026.02.07 20:39:40 - Ready
. 2026.02.07 20:39:42 - Collect information about AirVPN completed
I 2026.02.07 20:39:44 - Session starting.
. 2026.02.07 20:39:44 - Activation of Network Lock - Linux iptables-nft
I 2026.02.07 20:39:45 - Checking authorization ...
! 2026.02.07 20:39:45 - Connecting to Alderamin (Austria, Vienna)
. 2026.02.07 20:39:45 - Routes, add 185.9.19.109/32 for interface "wlp0s20f3".
. 2026.02.07 20:39:45 - WireGuard > Setup start
. 2026.02.07 20:39:45 - WireGuard > Setup complete
. 2026.02.07 20:39:45 - WireGuard > Setup interface
. 2026.02.07 20:39:46 - WireGuard > Received first handshake
. 2026.02.07 20:39:46 - DNS of the system switched to VPN DNS - via /etc/resolv.conf)
W 2026.02.07 20:39:47 - Routes, add 0.0.0.0/1 for interface "Eddie" failed: Exception: exit:2; err:Error: Device for nexthop is not up.; path:/usr/sbin/ip; arg:-4; arg:route; arg:add; arg:0.0.0.0/1; arg:dev; arg:Eddie; arg:metric; arg:0
! 2026.02.07 20:39:47 - Disconnecting
. 2026.02.07 20:39:47 - WireGuard > Stop request received
. 2026.02.07 20:39:47 - WireGuard > Stopping
. 2026.02.07 20:39:47 - WireGuard > Completed
. 2026.02.07 20:39:47 - Routes, delete 0.0.0.0/1 for interface "Eddie", not exists.
. 2026.02.07 20:39:47 - Routes, delete 128.0.0.0/1 for interface "Eddie", not exists.
. 2026.02.07 20:39:48 - Routes, delete ::/1 for interface "Eddie", not exists.
. 2026.02.07 20:39:48 - Routes, delete 8000::/1 for interface "Eddie", not exists.
. 2026.02.07 20:39:48 - Routes, delete 185.9.19.109/32 for interface "wlp0s20f3".
. 2026.02.07 20:39:48 - Routes, delete 185.9.19.107/32 for interface "Eddie", not exists.
. 2026.02.07 20:39:48 - Routes, delete 2001:ac8:29:5::3/128 for interface "Eddie", not exists.
. 2026.02.07 20:39:48 - DNS of the system restored - via /etc/resolv.conf)
. 2026.02.07 20:39:48 - Service systemd-resolved restarted
. 2026.02.07 20:39:48 - DNS of the interface 'wlp0s20f3' restored to '192.168.2.1' - via systemd-resolved
. 2026.02.07 20:39:48 - Default Route of the interface 'wlp0s20f3' restored to 'yes' - via systemd-resolved
. 2026.02.07 20:39:48 - Collect network information
. 2026.02.07 20:39:48 - Connection terminated.
I 2026.02.07 20:39:51 - Checking authorization ...
! 2026.02.07 20:39:52 - Connecting to Alderamin (Austria, Vienna)
. 2026.02.07 20:39:52 - Routes, add 185.9.19.109/32 for interface "wlp0s20f3".
. 2026.02.07 20:39:52 - WireGuard > Setup start
. 2026.02.07 20:39:52 - WireGuard > Setup complete
. 2026.02.07 20:39:52 - WireGuard > Setup interface
. 2026.02.07 20:39:53 - WireGuard > Received first handshake
. 2026.02.07 20:39:53 - DNS of the system switched to VPN DNS - via /etc/resolv.conf)
W 2026.02.07 20:39:53 - Routes, add 0.0.0.0/1 for interface "Eddie" failed: Exception: exit:2; err:Error: Device for nexthop is not up.; path:/usr/sbin/ip; arg:-4; arg:route; arg:add; arg:0.0.0.0/1; arg:dev; arg:Eddie; arg:metric; arg:0
! 2026.02.07 20:39:53 - Disconnecting
. 2026.02.07 20:39:54 - WireGuard > Stop request received
. 2026.02.07 20:39:54 - WireGuard > Stopping
. 2026.02.07 20:39:54 - WireGuard > Completed
. 2026.02.07 20:39:54 - Routes, delete 0.0.0.0/1 for interface "Eddie", not exists.
. 2026.02.07 20:39:54 - Routes, delete 128.0.0.0/1 for interface "Eddie", not exists.
. 2026.02.07 20:39:54 - Routes, delete ::/1 for interface "Eddie", not exists.
. 2026.02.07 20:39:54 - Routes, delete 8000::/1 for interface "Eddie", not exists.
. 2026.02.07 20:39:54 - Routes, delete 185.9.19.109/32 for interface "wlp0s20f3".
. 2026.02.07 20:39:54 - Routes, delete 185.9.19.107/32 for interface "Eddie", not exists.
. 2026.02.07 20:39:54 - Routes, delete 2001:ac8:29:5::3/128 for interface "Eddie", not exists.
. 2026.02.07 20:39:54 - DNS of the system restored - via /etc/resolv.conf)
. 2026.02.07 20:39:54 - Service systemd-resolved restarted
. 2026.02.07 20:39:54 - DNS of the interface 'wwan0' restored to '10.128.0.1 fd7d:76ee:e68f:a993::1' - via systemd-resolved
. 2026.02.07 20:39:54 - Default Route of the interface 'wwan0' restored to 'no' - via systemd-resolved
. 2026.02.07 20:39:54 - DNS of the interface 'enp0s31f6' restored to '10.128.0.1 fd7d:76ee:e68f:a993::1' - via systemd-resolved
. 2026.02.07 20:39:55 - Default Route of the interface 'enp0s31f6' restored to 'no' - via systemd-resolved
. 2026.02.07 20:39:55 - DNS of the interface 'wlp0s20f3' restored to '192.168.2.1' - via systemd-resolved
. 2026.02.07 20:39:55 - Default Route of the interface 'wlp0s20f3' restored to 'yes' - via systemd-resolved
. 2026.02.07 20:39:55 - DNS of the interface 'docker0' restored to '10.128.0.1 fd7d:76ee:e68f:a993::1' - via systemd-resolved
. 2026.02.07 20:39:55 - Default Route of the interface 'docker0' restored to 'no' - via systemd-resolved
. 2026.02.07 20:39:55 - Collect network information
. 2026.02.07 20:39:55 - Connection terminated.
I 2026.02.07 20:39:58 - Checking authorization ...
! 2026.02.07 20:39:58 - Connecting to Alderamin (Austria, Vienna)
. 2026.02.07 20:39:58 - Routes, add 185.9.19.109/32 for interface "wlp0s20f3".
. 2026.02.07 20:39:58 - WireGuard > Setup start
. 2026.02.07 20:39:58 - WireGuard > Setup complete
. 2026.02.07 20:39:58 - WireGuard > Setup interface
. 2026.02.07 20:39:59 - WireGuard > Received first handshake
. 2026.02.07 20:39:59 - DNS of the system switched to VPN DNS - via /etc/resolv.conf)
W 2026.02.07 20:39:59 - Routes, add 0.0.0.0/1 for interface "Eddie" failed: Exception: exit:2; err:Error: Device for nexthop is not up.; path:/usr/sbin/ip; arg:-4; arg:route; arg:add; arg:0.0.0.0/1; arg:dev; arg:Eddie; arg:metric; arg:0
! 2026.02.07 20:39:59 - Disconnecting
. 2026.02.07 20:40:00 - WireGuard > Stop request received
. 2026.02.07 20:40:00 - WireGuard > Stopping
. 2026.02.07 20:40:00 - WireGuard > Completed
. 2026.02.07 20:40:00 - Routes, delete 0.0.0.0/1 for interface "Eddie", not exists.
. 2026.02.07 20:40:00 - Routes, delete 128.0.0.0/1 for interface "Eddie", not exists.
. 2026.02.07 20:40:01 - Routes, delete ::/1 for interface "Eddie", not exists.
. 2026.02.07 20:40:01 - Routes, delete 8000::/1 for interface "Eddie", not exists.
. 2026.02.07 20:40:01 - Routes, delete 185.9.19.109/32 for interface "wlp0s20f3".
. 2026.02.07 20:40:01 - Routes, delete 185.9.19.107/32 for interface "Eddie", not exists.
. 2026.02.07 20:40:01 - Routes, delete 2001:ac8:29:5::3/128 for interface "Eddie", not exists.
. 2026.02.07 20:40:01 - DNS of the system restored - via /etc/resolv.conf)
. 2026.02.07 20:40:01 - Service systemd-resolved restarted
. 2026.02.07 20:40:01 - DNS of the interface 'wwan0' restored to '10.128.0.1 fd7d:76ee:e68f:a993::1' - via systemd-resolved
. 2026.02.07 20:40:01 - Default Route of the interface 'wwan0' restored to 'no' - via systemd-resolved
. 2026.02.07 20:40:01 - DNS of the interface 'enp0s31f6' restored to '10.128.0.1 fd7d:76ee:e68f:a993::1' - via systemd-resolved
. 2026.02.07 20:40:01 - Default Route of the interface 'enp0s31f6' restored to 'no' - via systemd-resolved
. 2026.02.07 20:40:01 - DNS of the interface 'wlp0s20f3' restored to '192.168.2.1' - via systemd-resolved
. 2026.02.07 20:40:01 - Default Route of the interface 'wlp0s20f3' restored to 'yes' - via systemd-resolved
. 2026.02.07 20:40:01 - DNS of the interface 'docker0' restored to '10.128.0.1 fd7d:76ee:e68f:a993::1' - via systemd-resolved
. 2026.02.07 20:40:01 - Default Route of the interface 'docker0' restored to 'no' - via systemd-resolved
. 2026.02.07 20:40:01 - Collect network information
. 2026.02.07 20:40:01 - Connection terminated.
I 2026.02.07 20:40:04 - Checking authorization ...
! 2026.02.07 20:40:05 - Connecting to Alderamin (Austria, Vienna)
. 2026.02.07 20:40:05 - Routes, add 185.9.19.109/32 for interface "wlp0s20f3".
. 2026.02.07 20:40:05 - WireGuard > Setup start
. 2026.02.07 20:40:05 - WireGuard > Setup complete
. 2026.02.07 20:40:05 - WireGuard > Setup interface
! 2026.02.07 20:40:20 - Disconnecting
. 2026.02.07 20:40:21 - WireGuard > Stop request received
. 2026.02.07 20:40:21 - WireGuard > Stopping
. 2026.02.07 20:40:21 - WireGuard > Completed
. 2026.02.07 20:40:21 - Routes, delete 0.0.0.0/1 for interface "Eddie", not exists.
. 2026.02.07 20:40:21 - Routes, delete 128.0.0.0/1 for interface "Eddie", not exists.
. 2026.02.07 20:40:21 - Routes, delete ::/1 for interface "Eddie", not exists.
. 2026.02.07 20:40:21 - Routes, delete 8000::/1 for interface "Eddie", not exists.
. 2026.02.07 20:40:21 - Routes, delete 185.9.19.109/32 for interface "wlp0s20f3".
. 2026.02.07 20:40:21 - Routes, delete 185.9.19.107/32 for interface "Eddie", not exists.
. 2026.02.07 20:40:21 - Routes, delete 2001:ac8:29:5::3/128 for interface "Eddie", not exists.
. 2026.02.07 20:40:21 - Service systemd-resolved restarted
. 2026.02.07 20:40:21 - Collect network information
. 2026.02.07 20:40:22 - Connection terminated.
I 2026.02.07 20:40:22 - Cancel requested.
. 2026.02.07 20:40:22 - Deactivation of Network Lock
! 2026.02.07 20:40:22 - Session terminated.
Network Info:
	"routes": [
			"destination": "0.0.0.0\/0",
			"gateway": "192.168.2.1",
			"interface": "wlp0s20f3",
			"metric": "600",
			"proto": "dhcp",
			"src": "192.168.2.45"
			"destination": "172.17.0.0\/16",
			"interface": "docker0",
			"proto": "kernel",
			"scope": "link",
			"src": "172.17.0.1"
			"destination": "192.168.2.0\/24",
			"metric": "600",
			"proto": "kernel",
			"scope": "link",
			"destination": "fe80::\/64",
			"metric": "1024",
			"pref": "medium",
			"proto": "kernel"
	"ipv4-default-gateway": "192.168.2.1",
	"ipv4-default-interface": "wlp0s20f3",
	"interfaces": [
			"friendly": "lo",
			"id": "lo",
			"name": "lo",
			"description": "lo",
			"type": "Loopback",
			"status": "Unknown",
			"bytes_received": "320867",
			"bytes_sent": "320867",
			"support_ipv4": true,
			"support_ipv6": true,
			"ips": [
				"127.0.0.1",
				"::1"
			"bind": true
			"friendly": "wwan0",
			"id": "wwan0",
			"name": "wwan0",
			"description": "wwan0",
			"type": "0",
			"status": "Down",
			"bytes_received": "0",
			"bytes_sent": "0",
			"ips": [],
			"bind": false
			"friendly": "enp0s31f6",
			"id": "enp0s31f6",
			"name": "enp0s31f6",
			"description": "enp0s31f6",
			"type": "Ethernet",
			"status": "Down",
			"bytes_sent": "0",
			"ips": [],
			"bind": false
			"friendly": "wlp0s20f3",
			"id": "wlp0s20f3",
			"name": "wlp0s20f3",
			"description": "wlp0s20f3",
			"type": "Wireless80211",
			"status": "Up",
			"bytes_received": "2278710",
			"bytes_sent": "512860",
			"ips": [
				"192.168.2.45",
				"fe80::91ee:1179:5e88:ccc4"
			"bind": true
			"friendly": "docker0",
			"id": "docker0",
			"name": "docker0",
			"description": "docker0",
			"type": "Ethernet",
			"status": "Down",
			"bytes_sent": "0",
			"ips": [
				"172.17.0.1"
			"bind": true
ip addr show:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: wwan0: <POINTOPOINT,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
    link/none
3: enp0s31f6: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN group default qlen 1000
    link/ether 8c:8c:aa:a6:81:3f brd ff:ff:ff:ff:ff:ff
    altname enx8c8caaa6813f
4: wlp0s20f3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 22:99:d5:df:3b:3e brd ff:ff:ff:ff:ff:ff permaddr e8:84:a5:b0:c4:17
    altname wlxe884a5b0c417
    inet 192.168.2.45/24 brd 192.168.2.255 scope global dynamic noprefixroute wlp0s20f3
       valid_lft 43092sec preferred_lft 43092sec
    inet6 fe80::91ee:1179:5e88:ccc4/64 scope link noprefixroute
5: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
    link/ether 66:7b:0a:fa:1d:aa brd ff:ff:ff:ff:ff:ff
    inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
ip link show:
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
2: wwan0: <POINTOPOINT,NOARP> mtu 1500 qdisc noop state DOWN mode DEFAULT group default qlen 1000
    link/none
3: enp0s31f6: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc fq_codel state DOWN mode DEFAULT group default qlen 1000
4: wlp0s20f3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP mode DORMANT group default qlen 1000
5: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN mode DEFAULT group default
