harold.lewis 23 Posted ... Hello, when I log in and activate networklock but not connecting to server, browsers are suppose to connect? Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... On 12/28/2025 at 9:19 AM, harold.lewis said: Hello, when I log in and activate networklock but not connecting to server, browsers are suppose to connect? Not sure what you're asking. If you enable NetLock and don't connect, no traffic flows out, ever, except to any AirVPN server. So browsers won't connect anywhere. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
harold.lewis 23 Posted ... well, i was having iptables-nft installed and selected in network lock page of settings, with applied netlock in Eddie without connecting to the servers, browsers where able to connect, if I selected Automatic browsers where blocked but Eddie tray tell me it connects with iptables legacy then I have installed again iptables (no nft) it blocks the connections in Atuomatic or iptable-legacy mode and in both iptables-nft (Automatic) or iptables-legacy (Automatic or iptables-legacy) Eddie tray tell me Limited Internet Connection but works fine... Quote Share this post Link to post
Tech Jedi Alex 1524 Posted ... 2 hours ago, harold.lewis said: well, i was having iptables-nft installed and selected in network lock page of settings, with applied netlock in Eddie without connecting to the servers, browsers where able to connect, if I selected Automatic browsers where blocked but Eddie tray tell me it connects with iptables legacy Sure there was no error about iptables-nft not being usable or something? What's the output of: iptables-nft --version Can you try installing nft and see whether nftables works? Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
harold.lewis 23 Posted ... ptables-nft --version iptables v1.8.11 (nf_tables) same as before, after network lock with iptables-nft selected in mode but no connection to the servers, browsers still connect, with mode Automatic browsers try to connect but no any page opening Quote Share this post Link to post
harold.lewis 23 Posted ... now seems fixed... probably some misconfiguration in my attempt to disable ipv6, or some file change after some update now I've enabled ip6 and seems to work correctly but in settings/Network Lock/Mode now I've only Automatic and iptables-legacy the Ethernet tray icons again trow 'This Interface seems not able to reach Internet, connection limited' in windows ipv6 is disable and Eddie works as expected blocking any connection with network lock enabled but not connected to any server Quote Share this post Link to post
