Port forwarding is provided on a first-come-first-serve basis, so if a port is taken then, generally, you're out of luck.
Be advised, though, that you can forward a random open port and forward it to the local port 5911 if the listening software is so inflexible that it doesn't allow changing ports. So, for example, you could forward remote port 9000 to local port 5911. This way, people trying to reach your service must use port 9000 to connect.
