Fcknzs
Eddie keeps disconnecting/reconnecting
I am using MacOS 10.13.6 (High Sierra). I decided to change my VPN to AirVPN (Eddie, v. 2.24.6) a few hours ago, but I cannot seem to connect to any server.
I followed every step in this thread, yet that didn't help at all...
Logs attached.
Eddie_20251004_235732.txt
Edited ... by Fcknzs
Hi Fcknzs,
I am on the same boat as you are. I guess that you should stay with Eddie 2.21.8. The method mentioned in the link... I don't know if it works with High Sierra. Before that method came out, I was told by Staff that there is an incompatibility between Wireguard and OSX 10.13.6 (and Wireguard became the "de facto" protocol). But the other thing I found, was that Hummingbird was also not working with the new Eddie version, which would have been a good alternative. So went back to the previous stable version where the old version of Hummingbird works.
Haven't tried if the solution mentioned in the link at least helps with Hummingbird or not.
If someone can correct me I would be glad to be wrong.
Hope it helps.
