dukeforest
ANSWERED Checking Credentials issue on macOS Tahoe RC
I always find it so convenient to use, thank you.
After upgrading macOS, it gets stuck at “Checking Credentials” during connection and won't proceed.
It seems an error occurs when Eddie starts up.
Is there a solution?
I use Little Snitch, but the error persists even when I turn it off.
. 2025.09.14 07:02:46 - Eddie version: 2.24.6 / macos_arm64, System: MacOS, Name: macOS 26.0, Version: 26.0, Framework: v4.0.30319
. 2025.09.14 07:02:46 - Raise system privileges
. 2025.09.14 07:02:55 - Collect network information
. 2025.09.14 07:02:57 - Reading options from /Users/tadashi/.config/eddie/default.profile
. 2025.09.14 07:02:57 - OpenVPN - Version: 2.6.12 - OpenSSL 3.3.2 3 Sep 2024, LZO 2.10 (/private/var/folders/yp/fzpjpxrx1_31m6kpmks6th5r0000gn/T/AppTranslocation/8D40D933-6FFB-4B8D-B571-C870F01B598C/d/Eddie.app/Contents/MacOS/openvpn)
. 2025.09.14 07:02:57 - SSH - Version: OpenSSH_10.0p2, LibreSSL 3.3.6 (/usr/bin/ssh)
. 2025.09.14 07:02:57 - SSL - Version: 5.57 (/private/var/folders/yp/fzpjpxrx1_31m6kpmks6th5r0000gn/T/AppTranslocation/8D40D933-6FFB-4B8D-B571-C870F01B598C/d/Eddie.app/Contents/MacOS/stunnel)
. 2025.09.14 07:02:57 - Recovery. Unexpected crash?
! 2025.09.14 07:02:57 - Deactivation of Network Lock
E 2025.09.14 07:02:57 - Exception: Deactivation failure: exit:1; err:No ALTQ support in kernel
E 2025.09.14 07:02:57 -     ALTQ related functions disabled
E 2025.09.14 07:02:57 -     pfctl: pf not enabled; path:/sbin/pfctl; arg:-d
. 2025.09.14 07:02:57 - Activation of Network Lock - macOS - PF
I 2025.09.14 07:03:00 - Ready
. 2025.09.14 07:03:02 - Collect information about AirVPN completed
I 2025.09.14 07:03:18 - Session starting.
I 2025.09.14 07:03:18 - Checking authorization ...
After deleting the default.profile, I was able to connect.
The problem is solved.
Thank you.
Edited ... by dukeforest
