I installed Siduction as a Linux distro, then Wireguard and Resolvconf... In the Linux terminal, after launching wg quick up, I get this response:
sudo wg-quick up /home/nicolas/airvpn/europewg.conf
Warning: `/home/nicolas/airvpn/europewg.conf' is world accessible
[#] ip link add dev europewg type wireguard
[#] wg setconf europewg /dev/fd/63
[#] ip -4 address add 10.163.170.96/32 dev europewg
[#] ip -6 address add fd7d:76ee:e68f:a993:5e09:e107:ad2:4168/128 dev europewg
[#] ip link set mtu 1320 up dev europewg
[#] resolvconf -a tun.europewg -m 0 -x
[#] wg set europewg fwmark 51820
[#] ip -6 rule add not fwmark 51820 table 51820
[#] ip -6 rule add table main suppress_prefixlength 0
[#] ip -6 route add ::/0 dev europewg table 51820
[#] nft -f /dev/fd/63
/dev/fd/63:5:110-123: Error: Could not process rule: No such file or directory
[#] resolvconf -d tun.europewg -f
[#] ip -6 rule delete table 51820
[#] ip -6 rule delete table main suppress_prefixlength 0
[#] ip link delete dev europewg
Does anyone have a solution? Thank you very much.
Edited ... by santec29
