scgt1
No internet outside of Eddie with Network Lock off
Basically what the title says. Not sure if this is an Eddie problem (I just re-ran the install for good measure) No settings have been changed it was working as it should last night. Or if MS has jacked up Windows 11 more then normal.
I can get browsers to load if network lock is on and I'm connected. Once I disconnect from Eddie and turn off network lock nothing loads. It's as if the network lock isn't actually turning off. I've also restarted the pc to no avail.
Eddie 2.24.6
Win 11 Pro
24H2
Version    10.0.26100 Build 26100
OS Build 26100.4652
Windows Feature Experience Pack 1000.26100.128.0
**UPDATE**
sfc scan, DSIM commands nothing
Reset network settings and viola I have internet back outside of anEddie/AirVPN connection. Dunno wtf that was all about but highly annoying. Not sure if it was a windows update issue or Eddie issue but it seemed to not actually be disconnecting the network lock.
Pretty sure the DNS settings are simply not reset properly. Theck those on macOS and Windows after a disconnect, please.
It's happening on my system as well. Not sure why. It worked just fine last month (or was it two months ago—I don't remember as I don't disable Network Lock that often). Anyway, I don't think it's a Windows issue because I run Linux and it's still an occurrence.
CPU: Intel Core i7-10700K
GPU: Nvidia GeForce RTX 2060
OS: Linux Mint 22.2
DE: Cinnamon 6.4.8
Edited ... by That_One_Determined_Falcon
