xm6g6 0 Posted ... Hi. I'm using Version 3.2.1 (VC35) on my S25+. Most of the time it works exactly as it should. On occasion, though, when I open Eddie the big 'power' button on the Quick Connect tab (which would log me into AirVPN) is grayed out. Restarting the phone does not always correct this. The app is otherwise fully functional, at least as much as it could be while not logged in. I can switch tabs, use the menu, and so on. The Eddie app has been uninstalled, CCleaner ran, and the phone rebooted, then Eddie reinstalled. No change. Quote Share this post Link to post
Tech Jedi Alex 1525 Posted ... It's greyed out because the network status check is not OK, most probably. Are you running any firewall or antivirus apps, or did you restrict background data for Eddie or system-wide? Have you tried both WiFi and GSM? Kill Eddie by opening the recent apps menu and swiping Eddie up, then reopen Eddie and provide the logs, if the status is still Not available and you are sure you're online and the network is not restricted in any way. Quote Hide Tech Jedi Alex's signature Hide all signatures NOT AN AIRVPN TEAM MEMBER. USE TICKETS FOR PROFESSIONAL SUPPORT. LZ1's New User Guide to AirVPN « Plenty of stuff for advanced users, too! Want to contact me directly? All relevant methods are on my About me page. Share this post Link to post
