lasta3
ANSWERED Connection fails on Linux Mint 19 and 20
Up until a few days ago everything was working great in Linux Mint 19 and 20, but now we get ZERO data transfer, using the exact same config we have used for years.. It says "Initialization sequence Completed" as usual, but we get ZERO data (commandline openvpn 2.4.4).
If we try Eddie Client we get issues with something called WireGuard, and ends up in a disconnect/reconnect loop.
If we download a fresh config from your generator, we get errors in the command line with openvpn.
We have tried TCP and UDP, worked perfectly until a few days ago, now ZERO data transfer.
Eveyrthing is working again as of today, I suspect it was an ISP issue.
thanks
