_Bob_
Hostinger blocks hstgr.io servers
The  hstgr.io  servers are used for admin related things, like downloading a backup from your site.  Hostinger claims this is because of a 100% abuse rate.  Tried about 12 different AirVPN servers in several counties but these are blocked.
They also seem to block about any existing Tor exit node.
Am I supposed to be able to resolve this domain? Because none of my DNS nor Cloudflare nor Quad9 seem to get any IP address out of it.
Ooh okay, I'm not supposed to resolve that domain, only together with the srvX part. Well, okay, then. Probably correct, then, and nothing AirVPN can do about it.
Yeah, nothing that can be done.  That's how they work at Hostinger.  Saying they are all about privacy but when there are issues they strongly advise you to not use VPN, Tor or proxies and to use a Gmail address if you want to communicate with them while promoting all other Google services at the same time.
You know, I'd do the same. A VPN adds a considerable layer of complication to troubleshooting :D it's not uncommon to block anonymizers on interfaces where administration of IT assets is possible; it's a security consideration, not an attack on privacy. The recommendation to use a Google address is probably also there to uncomplicate things.
To me it's like renting a house which you are only allowed to enter nude through one particular window but not before you put on a pair of purple shoes.
Your comparison is like using the internet completely in clear text, which is not how it works. You're forced to have some clothes on.
Using a VPN is akin to donning an overcoat with a hood. Would you let someone like that into a secure area, or would you rather that individual removes the overlay first to ascertain his/her identity? It's a completely understandable and reasonable policy; it's you who wants to waltz with a balaclava into a bank here.
