alfavpn
No stars for servers
No stars for servers. Latency score
Eddie System/Environment Report - 7/28/2025 - 8:45 PM UTC
Eddie version: 2.24.6
Eddie OS build: macos_x64
Eddie architecture: x64
OS type: MacOS
OS name: macOS 11.7.10
OS version: 11.7.10
OS architecture: x64
Framework: v4.0.30319
OpenVPN: 2.6.12 - OpenSSL 3.3.2 3 Sep 2024, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
Hummingbird: 3.3.2 - Hummingbird - OpenVPN3 Client 1.3.0 - 1 June 2023 (/Applications/Eddie.app/Contents/MacOS/hummingbird)
WireGuard: 1.0.20200827
SSH: OpenSSH_8.1p1, LibreSSL 2.7.3 (/usr/bin/ssh)
SSL: 5.56 (/Applications/Eddie.app/Contents/MacOS/stunnel)
Profile path: /Users/ebf2/.config/eddie/default.profile
Data path: /Users/ebf2/.config/eddie
Application path: /Applications/Eddie.app/Contents/MacOS
Executable path: /Applications/Eddie.app/Contents/MacOS/Eddie-UI
Command line arguments: (0 args)
Network Lock Active: Yes, macOS - PF
Connected to VPN: Yes, Adhara
OS support IPv4: Yes
OS support IPv6: Yes
Detected DNS: 10.4.187.1,fde6:7a:7d20:bb::1
Test DNS IPv4: Ok
Test DNS IPv6: Ok
Test Ping IPv4: 187 ms
Test Ping IPv6: 159 ms
Test HTTP IPv4: Ok
Test HTTP IPv6: Ok
Test HTTPS: Ok
login: (omissis)
password: (omissis)
remember: True
servers.allowlist: 19b5c7333f2cce1a07c093e556c7fa68af4cea13237d528fd9100c6190250112,e5b1d9fcef1a237188d23f53003da77fe74ac91b9e85d86bd47c67b22d186e73
servers.denylist: 754018c7e9fcbff567b14fed7d61181b355ff87abd849f2c540d1b62a44b57fe,e06c58bddbc8133de26ab488f61863ab9424102e1c6933ec25f2f9ce8bb64787
servers.scoretype: Latency
mode.type: openvpn
mode.protocol: TCP
mode.alt: 2
wireguard.interface.mtu: 1320
gui.osx.visible: True
gui.osx.sysbar.show_info: True
gui.osx.sysbar.show_speed: True
gui.osx.sysbar.show_server: True
Logs:
. 2025.07.28 22:17:37 - Eddie version: 2.24.6 / macos_x64, System: MacOS, Name: macOS 11.7.10, Version: 11.7.10, Framework: v4.0.30319
. 2025.07.28 22:17:37 - Raise system privileges
. 2025.07.28 22:17:48 - Collect network information
. 2025.07.28 22:17:50 - Reading options from /Users/ebf2/.config/eddie/default.profile
. 2025.07.28 22:17:50 - OpenVPN - Version: 2.6.12 - OpenSSL 3.3.2 3 Sep 2024, LZO 2.10 (/Applications/Eddie.app/Contents/MacOS/openvpn)
. 2025.07.28 22:17:50 - SSH - Version: OpenSSH_8.1p1, LibreSSL 2.7.3 (/usr/bin/ssh)
. 2025.07.28 22:17:50 - SSL - Version: 5.56 (/Applications/Eddie.app/Contents/MacOS/stunnel)
I 2025.07.28 22:17:50 - Ready
. 2025.07.28 22:17:51 - Collect information about AirVPN completed
. 2025.07.28 22:18:04 - Collect information about AirVPN completed
I 2025.07.28 22:18:08 - Session starting.
. 2025.07.28 22:18:08 - Activation of Network Lock - macOS - PF
I 2025.07.28 22:18:09 - Checking authorization ...
! 2025.07.28 22:18:10 - Connecting to Adhara (Germany, Frankfurt)
. 2025.07.28 22:18:10 - Routes, add 185.104.184.45/32 for interface "en0".
. 2025.07.28 22:18:10 - OpenVPN > OpenVPN 2.6.12 x86_64-apple-darwin22.5.0 [SSL (OpenSSL)] [LZO] [LZ4] [PKCS11] [MH/RECVDA] [AEAD]
. 2025.07.28 22:18:10 - OpenVPN > library versions: OpenSSL 3.3.2 3 Sep 2024, LZO 2.10
. 2025.07.28 22:18:10 - OpenVPN > TCP/UDP: Preserving recently used remote address: [AF_INET]185.104.184.45:443
. 2025.07.28 22:18:10 - OpenVPN > Socket Buffers: R=[131072->262144] S=[131072->262144]
. 2025.07.28 22:18:10 - OpenVPN > Attempting to establish TCP connection with [AF_INET]185.104.184.45:443
. 2025.07.28 22:18:10 - OpenVPN > TCP connection established with [AF_INET]185.104.184.45:443
. 2025.07.28 22:18:10 - OpenVPN > TCPv4_CLIENT link local: (not bound)
. 2025.07.28 22:18:10 - OpenVPN > TCPv4_CLIENT link remote: [AF_INET]185.104.184.45:443
. 2025.07.28 22:18:11 - OpenVPN > TLS: Initial packet from [AF_INET]185.104.184.45:443, sid=f4068730 4e0531a5
. 2025.07.28 22:18:11 - OpenVPN > VERIFY OK: depth=1, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=airvpn.org CA, emailAddress=info@airvpn.org
. 2025.07.28 22:18:11 - OpenVPN > VERIFY KU OK
. 2025.07.28 22:18:11 - OpenVPN > Validating certificate extended key usage
. 2025.07.28 22:18:11 - OpenVPN > ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
. 2025.07.28 22:18:11 - OpenVPN > VERIFY EKU OK
. 2025.07.28 22:18:11 - OpenVPN > VERIFY OK: depth=0, C=IT, ST=IT, L=Perugia, O=airvpn.org, CN=Adhara, emailAddress=info@airvpn.org
. 2025.07.28 22:18:11 - OpenVPN > Control Channel: TLSv1.3, cipher TLSv1.3 TLS_CHACHA20_POLY1305_SHA256, peer certificate: 4096 bits RSA, signature: RSA-SHA512, peer temporary key: 253 bits X25519
. 2025.07.28 22:18:11 - OpenVPN > [Adhara] Peer Connection Initiated with [AF_INET]185.104.184.45:443
. 2025.07.28 22:18:11 - OpenVPN > TLS: move_session: dest=TM_ACTIVE src=TM_INITIAL reinit_src=1
. 2025.07.28 22:18:11 - OpenVPN > TLS: tls_multi_process: initial untrusted session promoted to trusted
. 2025.07.28 22:18:12 - OpenVPN > Error: ifconfig: ioctl (SIOCDIFADDR): Can't assign requested address
. 2025.07.28 22:18:12 - OpenVPN > Error: route: writing to routing socket: File exists
. 2025.07.28 22:18:12 - OpenVPN > SENT CONTROL [Adhara]: 'PUSH_REQUEST' (status=1)
. 2025.07.28 22:18:12 - OpenVPN > PUSH: Received control message: 'PUSH_REPLY,comp-lzo no,redirect-gateway ipv6 def1 bypass-dhcp,dhcp-option DNS 10.4.187.1,dhcp-option DNS6 fde6:7a:7d20:bb::1,tun-ipv6,route-gateway 10.4.187.1,topology subnet,ping 10,ping-restart 60,ifconfig-ipv6 fde6:7a:7d20:bb::1083/64 fde6:7a:7d20:bb::1,ifconfig 10.4.187.133 255.255.255.0,peer-id 0,cipher AES-256-GCM'
. 2025.07.28 22:18:12 - OpenVPN > Pushed option removed by filter: 'redirect-gateway ipv6 def1 bypass-dhcp'
. 2025.07.28 22:18:12 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS 10.4.187.1'
. 2025.07.28 22:18:12 - OpenVPN > Pushed option removed by filter: 'dhcp-option DNS6 fde6:7a:7d20:bb::1'
. 2025.07.28 22:18:12 - OpenVPN > OPTIONS IMPORT: --ifconfig/up options modified
. 2025.07.28 22:18:12 - OpenVPN > OPTIONS IMPORT: route-related options modified
. 2025.07.28 22:18:12 - OpenVPN > Opened utun device utun2
. 2025.07.28 22:18:12 - OpenVPN > /sbin/ifconfig utun2 delete
. 2025.07.28 22:18:12 - OpenVPN > NOTE: Tried to delete pre-existing tun/tap instance -- No Problem if failure
. 2025.07.28 22:18:12 - OpenVPN > /sbin/ifconfig utun2 10.4.187.133 10.4.187.133 netmask 255.255.255.0 mtu 1500 up
. 2025.07.28 22:18:12 - OpenVPN > /sbin/route add -net 10.4.187.0 10.4.187.133 255.255.255.0
. 2025.07.28 22:18:12 - OpenVPN > add net 10.4.187.0: gateway 10.4.187.133
. 2025.07.28 22:18:12 - OpenVPN > /sbin/ifconfig utun2 inet6 fde6:7a:7d20:bb::1083/64 mtu 1500 up
. 2025.07.28 22:18:12 - OpenVPN > add_route_ipv6(fde6:7a:7d20:bb::/64 -> fde6:7a:7d20:bb::1083 metric 0) dev utun2
. 2025.07.28 22:18:12 - OpenVPN > /sbin/route add -inet6 fde6:7a:7d20:bb:: -prefixlen 64 -iface utun2
. 2025.07.28 22:18:12 - OpenVPN > add net fde6:7a:7d20:bb::: gateway utun2: File exists
. 2025.07.28 22:18:12 - OpenVPN > Initialization Sequence Completed
. 2025.07.28 22:18:12 - OpenVPN > Data Channel: cipher 'AES-256-GCM', peer-id: 0, compression: 'stub'
. 2025.07.28 22:18:12 - Workaround to enable IPv6 DNS lookups activated
. 2025.07.28 22:18:12 - DNS of a network adapter forced (Ethernet 2, from 10.26.222.1, fde6:7a:7d20:16de::1 to 10.4.187.1, fde6:7a:7d20:bb::1)
. 2025.07.28 22:18:12 - DNS of a network adapter forced (Ethernet 1, from 1.1.1.1, 8.8.8.8, 8.8.4.4 to 10.4.187.1, fde6:7a:7d20:bb::1)
. 2025.07.28 22:18:12 - DNS of a network adapter forced (Wi-Fi, from 10.26.222.1, fde6:7a:7d20:16de::1 to 10.4.187.1, fde6:7a:7d20:bb::1)
. 2025.07.28 22:18:12 - DNS of a network adapter forced (Bluetooth PAN, from 10.26.222.1, fde6:7a:7d20:16de::1 to 10.4.187.1, fde6:7a:7d20:bb::1)
. 2025.07.28 22:18:12 - DNS of a network adapter forced (Thunderbolt Bridge, from 10.26.222.1, fde6:7a:7d20:16de::1 to 10.4.187.1, fde6:7a:7d20:bb::1)
. 2025.07.28 22:18:12 - Routes, add 0.0.0.0/1 for interface "utun2".
. 2025.07.28 22:18:12 - Routes, add 128.0.0.0/1 for interface "utun2".
. 2025.07.28 22:18:12 - Routes, add ::/1 for interface "utun2".
. 2025.07.28 22:18:12 - Routes, add 8000::/1 for interface "utun2".
. 2025.07.28 22:18:12 - Routes, add 185.104.184.43/32 for interface "utun2".
. 2025.07.28 22:18:12 - Routes, add 2001:ac8:20:5:e56b:4c39:f245:7761/128 for interface "utun2".
. 2025.07.28 22:18:12 - Flushing DNS
I 2025.07.28 22:18:14 - Checking route IPv4
I 2025.07.28 22:18:15 - Checking route IPv6
I 2025.07.28 22:18:17 - Checking DNS
. 2025.07.28 22:18:18 - Collect network information
! 2025.07.28 22:18:19 - Connected.
. 2025.07.28 22:18:19 - OpenVPN > Timers: ping 10, ping-restart 60
. 2025.07.28 22:19:04 - Collect information about AirVPN completed
. 2025.07.28 22:19:10 - Collect information about AirVPN completed
. 2025.07.28 22:29:54 - Collect information about AirVPN completed
Network Info:
    "routes": [
            "destination": "0\/1",
            "expire": "",
            "flags": "UScg",
            "gateway": "utun2",
            "interface": "utun2",
            "mtu": "1500",
            "refs": "0",
            "rt_ifa": "10.4.187.133",
            "use": "0"
            "destination": "0.0.0.0\/0",
            "expire": "",
            "flags": "UGScg",
            "gateway": "192.168.1.1",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "rt_ifa": "192.168.1.102",
            "use": "3"
            "destination": "default",
            "expire": "",
            "flags": "UCSIg",
            "gateway": "link#19",
            "mtu": "1500",
            "refs": "438",
            "use": "0"
            "destination": "1.160.0.33\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "21"
            "destination": "2.85.59.208\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "8"
            "destination": "2.99.78.128\/32",
            "expire": "1364",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "14"
            "destination": "2.138.112.118\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "2.138.212.118\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "44"
            "destination": "2.222.95.153\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "6"
            "destination": "3.68.54.3\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "44"
            "destination": "3.69.85.174\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "3.79.111.41\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "20"
            "destination": "3.174.97.20\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "2882"
            "destination": "3.174.101.159\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "249"
            "destination": "5.18.242.199\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "22"
            "destination": "5.29.13.76\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "25"
            "destination": "5.53.16.250\/32",
            "expire": "1472",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "14"
            "destination": "5.135.209.104\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "37"
            "destination": "5.196.64.52\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "2707"
            "destination": "10.4.187\/24",
            "expire": "",
            "flags": "UGSc",
            "gateway": "10.4.187.133",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "destination": "10.4.187.133\/32",
            "expire": "",
            "flags": "UH",
            "mtu": "1500",
            "refs": "2",
            "use": "4"
            "destination": "12.27.149.210\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "2"
            "destination": "13.226.155.51\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "44"
            "destination": "17.57.146.23\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "2",
            "use": "18"
            "destination": "17.57.146.54\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "5"
            "destination": "17.145.48.1\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "30"
            "destination": "17.248.209.69\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "5"
            "destination": "17.253.14.123\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "2"
            "destination": "17.253.14.125\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "1"
            "destination": "17.253.14.253\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "1"
            "destination": "17.253.15.201\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "21"
            "destination": "17.253.52.125\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "1"
            "destination": "17.253.52.253\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "1"
            "destination": "18.197.166.63\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "27"
            "destination": "23.93.174.157\/32",
            "expire": "1516",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "7"
            "destination": "23.192.237.148\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "18"
            "destination": "23.234.100.176\/32",
            "expire": "1392",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "24.18.139.183\/32",
            "expire": "1251",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "24.38.244.95\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "24.40.162.4\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "24.141.59.59\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "31"
            "destination": "24.194.234.210\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "24.201.108.150\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "22"
            "destination": "24.227.14.249\/32",
            "expire": "1204",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "31.45.225.13\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "31.61.173.244\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "31.167.41.242\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "8"
            "destination": "31.188.226.161\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "31.217.161.7\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "32.221.77.42\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "48"
            "destination": "34.1.249.133\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "19"
            "destination": "34.8.249.45\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "2",
            "use": "153"
            "destination": "34.36.54.80\/32",
            "expire": "1184",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "21"
            "destination": "34.36.137.203\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "110"
            "destination": "34.49.51.44\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "23"
            "destination": "34.98.64.218\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "57"
            "destination": "34.107.221.82\/32",
            "expire": "1550",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "122"
            "destination": "34.107.243.93\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "65"
            "destination": "34.110.138.217\/32",
            "expire": "1444",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "34.110.253.53\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "64"
            "destination": "34.120.195.249\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "31"
            "destination": "34.120.208.123\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "217"
            "destination": "34.120.237.76\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "152"
            "destination": "34.160.144.191\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "10"
            "destination": "34.160.236.64\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "32"
            "destination": "34.247.205.196\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "22"
            "destination": "34.254.143.3\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "35.82.227.29\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "40"
            "destination": "35.145.209.218\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "35.186.196.148\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "47"
            "destination": "35.190.70.202\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "11"
            "destination": "35.190.72.216\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "31"
            "destination": "35.214.136.108\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "83"
            "destination": "35.214.252.141\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "37"
            "destination": "35.241.62.124\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "28"
            "destination": "35.244.181.201\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "22"
            "destination": "37.19.196.155\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "37.19.205.226\/32",
            "expire": "1354",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "37.46.113.173\/32",
            "expire": "1587",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "1"
            "destination": "37.67.125.74\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "44"
            "destination": "37.157.4.29\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "30"
            "destination": "37.166.47.14\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "2022"
            "destination": "37.223.95.91\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "37.228.201.102\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "14"
            "destination": "37.228.224.121\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "16"
            "destination": "37.252.171.85\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "41"
            "destination": "38.15.32.60\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "7"
            "destination": "38.25.52.84\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "38.80.243.46\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "2"
            "destination": "38.180.79.21\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "9"
            "destination": "38.250.159.172\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "41.66.123.12\/32",
            "expire": "1292",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "44.199.180.130\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "317"
            "destination": "44.215.133.88\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "178"
            "destination": "44.215.142.139\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "42"
            "destination": "45.71.126.12\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "45.91.23.72\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "45.130.83.18\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "50"
            "destination": "45.130.200.123\/32",
            "expire": "1188",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "45.133.138.42\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "19"
            "destination": "45.133.180.26\/32",
            "expire": "1316",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "41"
            "destination": "45.150.147.14\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "45.174.149.54\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "46.6.124.202\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "14"
            "destination": "46.27.32.142\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "46.65.83.145\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "7"
            "destination": "46.116.225.126\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "46.137.23.186\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "28"
            "destination": "46.177.74.163\/32",
            "expire": "1495",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "46.191.234.48\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "8"
            "destination": "47.18.189.128\/32",
            "expire": "1558",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "47.61.204.16\/32",
            "expire": "1315",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "3"
            "destination": "47.72.203.37\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "22"
            "destination": "47.153.204.10\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "5"
            "destination": "47.204.242.5\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "33"
            "destination": "47.205.130.252\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "50.72.91.72\/32",
            "expire": "1211",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "50.110.220.14\/32",
            "expire": "1589",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "17"
            "destination": "50.219.32.102\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "50.232.90.118\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "54"
            "destination": "51.19.35.20\/32",
            "expire": "1302",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "4"
            "destination": "52.7.81.39\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "126"
            "destination": "52.37.105.108\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "43"
            "destination": "52.222.178.85\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "26"
            "destination": "52.222.178.165\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "31"
            "destination": "54.36.150.181\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "27"
            "destination": "54.170.33.171\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "41"
            "destination": "58.107.103.251\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "5"
            "destination": "62.45.43.148\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "62.45.67.186\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "62.131.5.233\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "11"
            "destination": "62.205.215.196\/32",
            "expire": "1265",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "10"
            "destination": "63.33.78.166\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "260"
            "destination": "63.34.177.240\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "42"
            "destination": "63.131.202.59\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "29"
            "destination": "64.31.56.2\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "45"
            "destination": "68.55.148.152\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "7"
            "destination": "68.96.215.237\/32",
            "expire": "1233",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "72"
            "destination": "68.134.163.182\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "68.186.30.68\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "68.190.135.25\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "7"
            "destination": "68.196.14.44\/32",
            "expire": "1383",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "69.16.157.92\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "69.126.102.210\/32",
            "expire": "1247",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "69.173.144.139\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "27"
            "destination": "69.176.153.246\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "69.209.117.6\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "70.48.163.185\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "27"
            "destination": "70.95.42.244\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "50"
            "destination": "70.108.22.228\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "70.187.239.31\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "5"
            "destination": "71.190.47.198\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "71.195.40.168\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "26"
            "destination": "72.65.240.75\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "72.88.201.138\/32",
            "expire": "1498",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "47"
            "destination": "72.131.76.174\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "12"
            "destination": "72.131.94.0\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "72.168.144.32\/32",
            "expire": "1201",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "72.175.184.151\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "18"
            "destination": "73.16.9.239\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "13"
            "destination": "73.17.118.84\/32",
            "expire": "1189",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "73.38.58.249\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "73.47.11.91\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "26"
            "destination": "73.83.32.248\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "73.111.242.204\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "73.114.228.193\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "26"
            "destination": "73.176.72.162\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "8"
            "destination": "73.197.32.233\/32",
            "expire": "1545",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "90"
            "destination": "73.199.191.206\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "3"
            "destination": "73.213.125.250\/32",
            "expire": "1259",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "28"
            "destination": "73.237.253.224\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "10"
            "destination": "73.238.140.121\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "10"
            "destination": "73.243.190.247\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "75"
            "destination": "74.83.108.12\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "16"
            "destination": "74.138.69.212\/32",
            "expire": "1241",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "84"
            "destination": "75.26.16.228\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "75.130.208.156\/32",
            "expire": "1523",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "67"
            "destination": "76.24.250.9\/32",
            "expire": "1220",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "5"
            "destination": "76.27.227.66\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "76.32.210.110\/32",
            "expire": "1401",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "76.38.172.138\/32",
            "expire": "1511",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "76.69.116.85\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "25"
            "destination": "76.116.115.63\/32",
            "expire": "1327",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "48"
            "destination": "76.118.49.38\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "26"
            "destination": "76.150.160.243\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "23"
            "destination": "76.159.178.66\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "76.168.74.31\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "76.168.201.218\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "15"
            "destination": "76.223.111.18\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "25"
            "destination": "77.18.51.185\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "16"
            "destination": "77.189.73.113\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "77.205.21.207\/32",
            "expire": "1183",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "77.222.232.119\/32",
            "expire": "1210",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "77.243.51.121\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "78.60.148.1\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "4"
            "destination": "78.105.178.131\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "2",
            "use": "8"
            "destination": "78.111.201.136\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "7"
            "destination": "78.196.92.76\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "79.18.56.241\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "26"
            "destination": "79.31.220.75\/32",
            "expire": "1388",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "79.36.7.143\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "54"
            "destination": "79.80.30.240\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "16"
            "destination": "79.107.232.183\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "29"
            "destination": "79.112.44.87\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "79.115.63.46\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "79.116.6.13\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "10"
            "destination": "79.116.141.238\/32",
            "expire": "1302",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "54"
            "destination": "79.116.217.121\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "79.117.40.17\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "4"
            "destination": "79.117.113.253\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "11"
            "destination": "79.121.66.62\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "14"
            "destination": "79.127.136.75\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "383"
            "destination": "79.127.139.217\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "79.127.184.130\/32",
            "expire": "1381",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "79.135.124.222\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "79.177.144.42\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "251"
            "destination": "79.191.46.183\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "79.191.62.83\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "80.88.210.236\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "4"
            "destination": "80.107.187.93\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "6"
            "destination": "80.108.140.93\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "2",
            "use": "52202"
            "destination": "80.192.93.83\/32",
            "expire": "1574",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "28"
            "destination": "80.233.45.200\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "81.35.247.226\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "81.41.179.41\/32",
            "expire": "1529",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "54"
            "destination": "81.104.148.36\/32",
            "expire": "1183",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "13"
            "destination": "81.104.166.146\/32",
            "expire": "1265",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "81.108.200.4\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "81.136.91.170\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "81.153.3.110\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "81.154.58.212\/32",
            "expire": "1245",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "54"
            "destination": "81.179.217.47\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "81.206.80.98\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "18"
            "destination": "81.230.174.11\/32",
            "expire": "1227",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "82.5.40.40\/32",
            "expire": "1566",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "82.26.162.22\/32",
            "expire": "1284",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "82.28.230.129\/32",
            "expire": "1597",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "174"
            "destination": "82.37.69.39\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "82.45.51.80\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "14"
            "destination": "82.45.60.248\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "82.65.100.101\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "2"
            "destination": "82.67.74.146\/32",
            "expire": "1411",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "82.76.86.14\/32",
            "expire": "1292",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "82.85.17.100\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "6"
            "destination": "82.102.27.163\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "5"
            "destination": "82.132.213.135\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "82.169.176.179\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "83.27.172.213\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "83.135.160.167\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "83.192.240.66\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "84.26.136.76\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "2",
            "use": "14"
            "destination": "84.71.67.122\/32",
            "expire": "1590",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "84.78.248.176\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "84.203.66.205\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "85.52.64.68\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "22"
            "destination": "85.87.102.68\/32",
            "expire": "1281",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "13"
            "destination": "85.127.111.187\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "17"
            "destination": "86.18.247.241\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "28"
            "destination": "86.28.236.210\/32",
            "expire": "1458",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "21"
            "destination": "86.31.40.125\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "86.41.38.84\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "86.84.115.24\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "25"
            "destination": "86.89.238.16\/32",
            "expire": "1306",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "86.103.35.246\/32",
            "expire": "1195",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "86.121.182.165\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "86.138.128.175\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "8"
            "destination": "86.142.80.91\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "26"
            "destination": "86.182.40.63\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "86.216.176.34\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "86.218.88.205\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "56"
            "destination": "86.229.50.121\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "6"
            "destination": "87.8.253.212\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "6"
            "destination": "87.9.238.248\/32",
            "expire": "1224",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "87.66.170.101\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "87.116.180.126\/32",
            "expire": "1462",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "87.172.18.84\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "31"
            "destination": "87.223.224.93\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "17"
            "destination": "87.248.119.251\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "12"
            "destination": "87.248.119.252\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "67"
            "destination": "88.15.168.239\/32",
            "expire": "1270",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "88.22.94.240\/32",
            "expire": "1350",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "72"
            "destination": "88.97.164.204\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "88.147.53.163\/32",
            "expire": "1411",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "88.180.140.25\/32",
            "expire": "1344",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "89.37.63.227\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "89.64.0.237\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "15"
            "destination": "89.64.4.170\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "36"
            "destination": "89.85.80.245\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "89.88.87.232\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "7"
            "destination": "89.103.96.176\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "9"
            "destination": "89.134.9.52\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "16"
            "destination": "89.151.28.205\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "89.154.218.196\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "89.222.103.35\/32",
            "expire": "1514",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "89.226.68.26\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "10"
            "destination": "89.249.73.130\/32",
            "expire": "1539",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "4"
            "destination": "90.22.184.10\/32",
            "expire": "1366",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "28"
            "destination": "90.45.32.146\/32",
            "expire": "1301",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "6"
            "destination": "90.47.7.120\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "54"
            "destination": "90.89.219.208\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "90.127.209.75\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "90.166.247.58\/32",
            "expire": "1407",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "2"
            "destination": "90.198.207.62\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "90.242.253.25\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "44"
            "destination": "90.251.91.119\/32",
            "expire": "1406",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "91.16.21.156\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "91.141.151.15\/32",
            "expire": "1488",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "91.148.243.185\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "139"
            "destination": "91.166.79.183\/32",
            "expire": "1397",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "91.170.130.165\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "92.16.222.182\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "92.40.176.68\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "92.88.170.28\/32",
            "expire": "1528",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "92.108.119.36\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "23"
            "destination": "92.159.159.123\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "93.35.136.226\/32",
            "expire": "1299",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "93.40.186.78\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "93.40.208.216\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "93.41.35.132\/32",
            "expire": "1460",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "93.43.249.222\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "33"
            "destination": "93.49.82.46\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "93.50.248.188\/32",
            "expire": "1214",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "20"
            "destination": "93.56.156.63\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "93.104.146.73\/32",
            "expire": "1554",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "93.156.240.120\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "93.159.1.58\/32",
            "expire": "1466",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "94.31.118.98\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "58"
            "destination": "94.63.194.85\/32",
            "expire": "1504",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "94.71.118.77\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "94.101.114.26\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "94.110.38.80\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "8"
            "destination": "94.130.131.36\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "10"
            "destination": "94.174.192.94\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "13"
            "destination": "94.225.66.27\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "98"
            "destination": "95.32.16.60\/32",
            "expire": "1474",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "95.90.187.8\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "27"
            "destination": "95.90.236.65\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "4"
            "destination": "95.98.223.188\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "20"
            "destination": "95.173.217.182\/32",
            "expire": "1470",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "95.173.221.80\/32",
            "expire": "1590",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "50"
            "destination": "96.20.76.144\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "96.22.138.197\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "62"
            "destination": "96.245.17.136\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "5"
            "destination": "98.82.156.107\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "244"
            "destination": "98.98.21.196\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "98.113.65.21\/32",
            "expire": "1504",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "98.149.45.159\/32",
            "expire": "1226",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "98.159.234.137\/32",
            "expire": "1228",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "2"
            "destination": "98.209.184.158\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "10"
            "destination": "99.30.174.195\/32",
            "expire": "1301",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "160"
            "destination": "99.37.186.137\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "23"
            "destination": "99.57.234.7\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "99.183.196.21\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "99.239.60.45\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "2",
            "use": "16"
            "destination": "102.32.211.236\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "102.129.234.20\/32",
            "expire": "1260",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "103.102.247.106\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "31"
            "destination": "103.231.98.107\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "27"
            "destination": "104.7.54.246\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "104.18.21.114\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "37"
            "destination": "104.18.26.193\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "29"
            "destination": "104.18.27.193\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "25"
            "destination": "104.18.32.7\/32",
            "expire": "1187",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "32"
            "destination": "104.26.14.210\/32",
            "expire": "1187",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "19"
            "destination": "104.28.196.176\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "104.145.118.140\/32",
            "expire": "1545",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "104.158.115.164\/32",
            "expire": "1396",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "33"
            "destination": "105.112.231.60\/32",
            "expire": "1532",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "36"
            "destination": "107.179.180.157\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "12"
            "destination": "107.197.23.196\/32",
            "expire": "1228",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "108.4.205.214\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "50"
            "destination": "108.128.31.2\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "25"
            "destination": "108.157.4.121\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "28"
            "destination": "108.172.63.75\/32",
            "expire": "1227",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "108.195.180.169\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "2",
            "use": "70"
            "destination": "108.209.191.20\/32",
            "expire": "1276",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "108.216.138.238\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "24"
            "destination": "108.237.211.210\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "2",
            "use": "90"
            "destination": "109.40.178.132\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "28"
            "destination": "109.55.169.178\/32",
            "expire": "1370",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "109.76.85.216\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "24"
            "destination": "109.134.154.193\/32",
            "expire": "",
            "flags": "UHWIig",
            "mtu": "1500",
            "refs": "1",
            "use": "2364"
            "destination": "109.156.198.70\/32",
            "expire": "1414",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "109.161.175.38\/32",
            "expire": "1489",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "48"
            "destination": "109.220.195.89\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "109.221.145.240\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "109.255.104.164\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "5"
            "destination": "116.109.194.186\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "18"
            "destination": "125.237.93.58\/32",
            "expire": "1179",
            "flags": "UHW3Ig",
            "mtu": "1500",
            "refs": "0",
            "use": "10"
            "destination": "127",
            "expire": "",
            "flags": "UCS",
            "gateway": "127.0.0.1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "127.0.0.1",
            "use": "0"
            "destination": "127.0.0.1\/32",
            "expire": "",
            "flags": "UH",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "3",
            "use": "1708"
            "destination": "128.0\/1",
            "expire": "",
            "flags": "USc",
            "gateway": "utun2",
            "mtu": "1500",
            "refs": "241",
            "use": "8"
            "destination": "169.254\/32",
            "expire": "!",
            "flags": "UCS",
            "gateway": "link#4",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "185.104.184.43\/32",
            "expire": "",
            "flags": "USc",
            "gateway": "utun2",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "destination": "185.104.184.45\/32",
            "expire": "",
            "flags": "UGSc",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "destination": "192.168.1\/32",
            "expire": "!",
            "flags": "UCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "192.168.1.1\/32",
            "expire": "!",
            "flags": "UCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "expire": "1197",
            "flags": "UHLWIir",
            "gateway": "98:da:c4:32:51:ea",
            "interface": "en0",
            "mtu": "1500",
            "refs": "3",
            "use": "89"
            "destination": "192.168.1.102\/32",
            "expire": "!",
            "flags": "UCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "expire": "",
            "flags": "UHLWI",
            "gateway": "0:3e:e1:c2:3b:7d",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "83"
            "destination": "224.0.0\/4",
            "expire": "!",
            "flags": "UmCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "2",
            "use": "0"
            "expire": "",
            "flags": "UmCSI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "224.0.0.251\/32",
            "expire": "",
            "flags": "UHmLWI",
            "gateway": "1:0:5e:0:0:fb",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "239.255.255.250\/32",
            "expire": "",
            "flags": "UHmLWI",
            "gateway": "1:0:5e:7f:ff:fa",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "3"
            "destination": "255.255.255.255\/32",
            "expire": "!",
            "flags": "UCS",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UCSI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "::\/1",
            "expire": "",
            "flags": "UScg",
            "gateway": "utun2",
            "mtu": "1500",
            "refs": "206",
            "rt_ifa": "fe80::23e:e1ff:fec2:3b7d%utun2",
            "use": "0"
            "destination": "::\/0",
            "expire": "",
            "flags": "UGcIg",
            "gateway": "fe80::",
            "interface": "utun0",
            "mtu": "1380",
            "refs": "0",
            "rt_ifa": "fe80::20c4:ab06:4e7e:6815%utun0",
            "use": "0"
            "expire": "",
            "flags": "UGcIg",
            "interface": "utun1",
            "mtu": "2000",
            "refs": "0",
            "rt_ifa": "fe80::6017:35a3:73ad:36a1%utun1",
            "use": "0"
            "destination": "::1\/128",
            "expire": "",
            "flags": "UHL",
            "gateway": "::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "1",
            "rt_ifa": "::1",
            "use": "15"
            "destination": "2001:ac8:20:5:e56b:4c39:f245:7761\/128",
            "expire": "",
            "flags": "UHLS",
            "gateway": "utun2",
            "mtu": "1500",
            "refs": "0",
            "use": "16"
            "destination": "8000::\/1",
            "expire": "",
            "flags": "USc",
            "gateway": "utun2",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "fde6:7a:7d20:bb::\/64",
            "expire": "",
            "flags": "Uc",
            "gateway": "fe80::23e:e1ff:fec2:3b7d",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "destination": "fde6:7a:7d20:bb::1083\/128",
            "expire": "",
            "flags": "UHL",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "fde6:7a:7d20:bb::1083",
            "use": "0"
            "destination": "fe80::\/64",
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "1",
            "rt_ifa": "fe80::1%lo0",
            "use": "0"
            "destination": "fe80::1\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UCI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "2",
            "rt_ifa": "fe80::40e:f6f7:2a05:d8b%en0",
            "use": "0"
            "destination": "fe80::40e:f6f7:2a05:d8b\/128",
            "expire": "",
            "flags": "UHLI",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "destination": "fe80::9ada:c4ff:fe32:51ea\/128",
            "expire": "",
            "flags": "UHLWIi",
            "interface": "en0",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::20c4:ab06:4e7e:6815",
            "mtu": "1380",
            "refs": "2",
            "use": "0"
            "destination": "fe80::20c4:ab06:4e7e:6815\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#17",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "gateway": "fe80::6017:35a3:73ad:36a1",
            "mtu": "2000",
            "refs": "2",
            "use": "0"
            "destination": "fe80::6017:35a3:73ad:36a1\/128",
            "expire": "",
            "flags": "UHLI",
            "gateway": "link#18",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UcI",
            "mtu": "1500",
            "refs": "1",
            "use": "0"
            "destination": "fe80::23e:e1ff:fec2:3b7d\/128",
            "expire": "",
            "flags": "UHLI",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "use": "0"
            "destination": "ff00::\/8",
            "expire": "",
            "flags": "UmCI",
            "gateway": "::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "::1",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "gateway": "link#15",
            "interface": "awdl0",
            "mtu": "1484",
            "refs": "0",
            "rt_ifa": "fe80::a07c:5dff:fe74:f145%awdl0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "gateway": "link#16",
            "interface": "llw0",
            "mtu": "1500",
            "refs": "0",
            "rt_ifa": "fe80::a07c:5dff:fe74:f145%llw0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "2000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "ff01::\/32",
            "expire": "",
            "flags": "UmCI",
            "gateway": "::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "::1",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1484",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "2000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "destination": "ff02::\/32",
            "expire": "",
            "flags": "UmCI",
            "gateway": "::1",
            "interface": "lo0",
            "mtu": "16384",
            "refs": "0",
            "rt_ifa": "::1",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "interface": "en0",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1484",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1380",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "2000",
            "refs": "0",
            "use": "0"
            "expire": "",
            "flags": "UmCI",
            "mtu": "1500",
            "refs": "0",
            "use": "0"
    "ipv4-default-gateway": "192.168.1.1",
    "ipv4-default-interface": "en0",
    "ipv6-default-gateway": "fe80::",
    "ipv6-default-interface": "utun0",
    "interfaces": [
            "friendly": "lo0",
            "id": "lo0",
            "name": "lo0",
            "description": "lo0",
            "type": "Loopback",
            "status": "Up",
            "bytes_received": "0",
            "bytes_sent": "0",
            "support_ipv4": true,
            "support_ipv6": true,
            "ips": [
                "127.0.0.1",
                "::1",
                "fe80::1"
            "bind": true
            "friendly": "gif0",
            "id": "gif0",
            "name": "gif0",
            "description": "gif0",
            "type": "Unknown",
            "status": "Unknown",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "stf0",
            "id": "stf0",
            "name": "stf0",
            "description": "stf0",
            "type": "Unknown",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Ethernet 1",
            "id": "en0",
            "name": "en0",
            "description": "en0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "fe80::40e:f6f7:2a05:d8b",
                "192.168.1.102"
            "bind": true
            "friendly": "Ethernet 2",
            "id": "en1",
            "name": "en1",
            "description": "en1",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Wi-Fi",
            "id": "en2",
            "name": "en2",
            "description": "en2",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt 5",
            "id": "en7",
            "name": "en7",
            "description": "en7",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt 6",
            "id": "en8",
            "name": "en8",
            "description": "en8",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt 2",
            "id": "en4",
            "name": "en4",
            "description": "en4",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt 4",
            "id": "en6",
            "name": "en6",
            "description": "en6",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt 1",
            "id": "en3",
            "name": "en3",
            "description": "en3",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt 3",
            "id": "en5",
            "name": "en5",
            "description": "en5",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "Thunderbolt Bridge",
            "id": "bridge0",
            "name": "bridge0",
            "description": "bridge0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "p2p0",
            "id": "p2p0",
            "name": "p2p0",
            "description": "p2p0",
            "type": "Ethernet",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "awdl0",
            "id": "awdl0",
            "name": "awdl0",
            "description": "awdl0",
            "type": "Ethernet",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "llw0",
            "id": "llw0",
            "name": "llw0",
            "description": "llw0",
            "type": "Ethernet",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [],
            "bind": false
            "friendly": "utun0",
            "id": "utun0",
            "name": "utun0",
            "description": "utun0",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
            "friendly": "utun1",
            "id": "utun1",
            "name": "utun1",
            "description": "utun1",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
            "bind": true
            "friendly": "utun2",
            "id": "utun2",
            "name": "utun2",
            "description": "utun2",
            "type": "Unknown",
            "status": "Up",
            "bytes_sent": "0",
            "ips": [
                "10.4.187.133",
            "bind": true
ifconfig:
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
    options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
    inet 127.0.0.1 netmask 0xff000000
    inet6 ::1 prefixlen 128
    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
    nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=50b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV,CHANNEL_IO>
    ether 00:3e:e1:c2:3b:7d
    inet6 fe80::40e:f6f7:2a05:d8b%en0 prefixlen 64 secured scopeid 0x4
    inet 192.168.1.102 netmask 0xffffff00 broadcast 192.168.1.255
    media: autoselect (100baseTX <full-duplex>)
    status: active
en1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    ether 00:3e:e1:c2:3b:7c
    media: autoselect (none)
    status: inactive
en2: flags=8823<UP,BROADCAST,SMART,SIMPLEX,MULTICAST> mtu 1500
    options=400<CHANNEL_IO>
    ether 80:00:6e:f1:e7:d2
    media: autoselect (<unknown type>)
    status: inactive
en7: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    options=460<TSO4,TSO6,CHANNEL_IO>
    ether 82:0e:02:9d:e9:c1
    media: autoselect <full-duplex>
    status: inactive
en8: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    ether 82:0e:02:9d:e9:c0
    status: inactive
en4: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    ether 82:0e:02:9d:e9:c9
    status: inactive
en6: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    ether 82:0e:02:9d:e9:c8
    status: inactive
en3: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    ether 82:0e:02:9d:e9:c5
    status: inactive
en5: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
    ether 82:0e:02:9d:e9:c4
    status: inactive
bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    options=63<RXCSUM,TXCSUM,TSO4,TSO6>
    Configuration:
        id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
        maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
        root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
        ipfilter disabled flags 0x0
    member: en3 flags=3<LEARNING,DISCOVER>
            ifmaxaddr 0 port 11 priority 0 path cost 0
    member: en4 flags=3<LEARNING,DISCOVER>
            ifmaxaddr 0 port 9 priority 0 path cost 0
    member: en5 flags=3<LEARNING,DISCOVER>
            ifmaxaddr 0 port 12 priority 0 path cost 0
    member: en6 flags=3<LEARNING,DISCOVER>
            ifmaxaddr 0 port 10 priority 0 path cost 0
    member: en7 flags=3<LEARNING,DISCOVER>
            ifmaxaddr 0 port 7 priority 0 path cost 0
    member: en8 flags=3<LEARNING,DISCOVER>
            ifmaxaddr 0 port 8 priority 0 path cost 0
    media: <unknown type>
    status: inactive
p2p0: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 2304
    ether 02:00:6e:f1:e7:d2
    media: autoselect
    status: inactive
awdl0: flags=8902<BROADCAST,PROMISC,SIMPLEX,MULTICAST> mtu 1484
    ether a2:7c:5d:74:f1:45
    media: autoselect
    status: inactive
llw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
    inet6 fe80::20c4:ab06:4e7e:6815%utun0 prefixlen 64 scopeid 0x11
utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
    inet6 fe80::6017:35a3:73ad:36a1%utun1 prefixlen 64 scopeid 0x12
utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1500
    inet 10.4.187.133 --> 10.4.187.133 netmask 0xffffff00
    inet6 fe80::23e:e1ff:fec2:3b7d%utun2 prefixlen 64 scopeid 0x13
    inet6 fde6:7a:7d20:bb::1083 prefixlen 64
Edited ... by Tech Jedi Alex
Apply LOG format to system report
