Daniel Mildner
ANSWERED Another wrong not connectable IP on tracker
I have a strange problem.
I have Qbittorrent behind AirVPN with port forwarding setup.
Everything is working great on the most trackers.
All trackers show me the correct IP address of the airvpn server I'm connected to with the correct port which is forwarded. Also the torrent client itself  shows the expected airvpn adress.
Only one tracker shows besides the correct ip also another ip  a totally other IP Adress with the correct port. So, on this tracker all information is right but the additinal, wrong IP Adress. So, it's impossible to be connectable.
The tracker shows 185.39.65.10 as my IP adress, which isn't right.
So, two questions:
1. Is this an IP( 185.39.65.10) from any airvpn server ? How can I prevent the false unreachable IP from being created additionally after a couple of minutes.
2. If yes, how could it happen that this adress is shown in the tracker?
The adress does not belong to the connected airvpn server on my opinion, nor to my server itself.
My connected airvpn server is in switzerland.
I read that there might be a rerouting problem.
I have already set the "anti-geolocation system" (under "Settings") to "Not active / neutral". However, the problem with the additional, incorrect IP address still exists.
Definitely not AirVPN-related. It belogs to Telepark Passau. Is this your ISP by any chance?
Does something similar happen with IPleak's torrent addess detection?
Yes, Telepark Passau is my ISP. But i had the same Problem with my last ISP Telekom.
Imo, everything should be fine with IPleak's torrent addess detection I'm connected to a switzerland Airvpn-Server, except for one strange DNS Address Server 94.247.43.254, ( ISP: Lennart Seitz, Germany), which i don't know.
The wrong IP (185.39.65.10) doesn't appear.
Edited ... by Daniel Mildner
Hints at your BitTorrent client actually leaking the IP. Is the client bound to the VPN interface?
Hints at DNS leaks on your machine. What's the contents of /etc/resolv.conf on Linux or the output of ipconfig /all on Windows?
