nagonatel
lP Leaking from Unifi UDM Pro only in ipleak.net and nowhere else
I would like some assistance with setting up Network Wide routing through AirVPN using a WireGuard profile on Unifi UDM Pro. I did set it, and it seems to be working, but my real IP is showing on ipleak.net. This is what I've done:
1-Downloaded Wireguard template for Router;
2- Create a dedicated VLAN for AirVPN;
3- Created a VPN Client Entry for the Wireguard Profile, which by the way cannot be imported so I had to take the values and fill it all manually, but is connected;
4- I go to the new Settings > Policy Engine > Policy-Based Routers;
5- Selected my AirVPN VPN Client entry under Interface/VPN Tunnel;
6- Selected my new VLAN under Source;
7 Selected Any under destination.
These are the results:
1- Speedtest.net SUCCESSFULLY detects my VPN exit server and is putting very nice speeds;
2- Every sort of what's my IP website out there sees my VPN exit server;
3- Streaming platforms are all blocking my devices coming from that VLAN detecting that I'm exiting from a known VPN server;
4- When I access AirVPN.org I can correctly see that I'm arriving from the AirVPN exit server;
5- But when I go to ipleak.net while it sees all my AirVPN DNS servers, the IP listed on the top is my real one.
How is ipleak the only service capable of detecting my real IP? Any tips to plug the leakage?
Thank you!
For IPleak, it might be because your DNS IP address doesn't look like this: 10.4.0.1?
For streaming platforms, it mainly depends on the country-specific servers used with AirVPN.
I hope this helps.
